cimo
Programmer
    1,774
Everything posted by cimo
  1. cimo
    Bulk Order Rules
    mm ok ok good to know this was completely unknown to me what other method we have to gather money? possibly something that you guys have tried already, i think we all agree we don t want to support paypal afterall. simone
  2. the dirty solution: midiox or midipipe, they can give you full flexibility over midi mapping while you write new code for your box ;) sorry Res i havent read properly your first post before, now i got it. simone
  3. cimo
    Bulk Order Rules
    eBay owns paypal so no surprise they won t bother ebayers anyway, it is clear to me (to anybody else?) that paypal policy or "violacy" can be a source for problems, let s take this into account
  4. cimo
    Hot 6582s
    hi i ve already considered this method but with a little variant: bear with me now (and with my english) you need a "tightening strip" which in my personal language means that kind of plastic strip (usually black or white) used, for example to tight a bunch of cables together, it has dents and a squared hole where you push in the tip of the strip.Are we there? good. Under the IC sockets there is usually space enough to slip the "tightening strip" underneath and loop it on the top so you can press the heat sink against the IC. uh? simone
  5. cimo
    thanks TwinX
    ok! now, about the chat, if i am not wrong this is a different beast, java based, is that right? FF on Ubuntu asks for new plugin (java runtime) which i already have, the java runtime enviroment.. .. in other words, is the chat up and running and i can t connect or is it still down?
  6. cimo
    Hot 6582s
    just like that JB (not the scotch whysky)
  7. cimo
    Hot 6582s
    i was rather surprised to see how hot the 6582s can become, what is to be considered normal? heatsink would be an option? simone
  8. cimo
    thanks TwinX
    how wouldn t you trust a web master whose surname is LAAN ? ;) don t tell me you have somebody in the family called NAT! i would happily change from my actual provider (one.com) to a new one so i ll keep in mind the offer but let s talk aboput this in 6 7 months simone
  9. cimo
    Bulk Order Rules
    hi wouldn t this mean another xtra 4%
  10. cimo
    Bulk Order Rules
    .. after phineus experience : x) Paypal may close your account if all this summing money smells bad to them.. contact Paypal first? /use another way to gather the money? ..phineus wanna add something?
  11. hi sorry to hijack this thread but i am looking for 30mm sliders (2MR linear) to fix and old yamaha from '78.If you where to source them in europe... simone
  12. hej! sorry but my swedish isn t that good as to go into technical details.. anyway.. yes you are right i also use to solder those bridges after all the other components.Use a long piece of wire so you can easily hold it when soldering , then you can cut it afterwards.For the bypass caps i use a little blob of hot glue to keep them in place and then you can easily solder them.Jatte bra kompis! Simone
  13. hi groups will define encoders/pots and not buttons, although there is a way (the hard way!) to change this behaviour, i think that the easiest way is to use meta events to change MIDI channel instead of groups.Midi channel will affect buttons and encoders/pots.Hope this help Simone
  14. thanks TwinX (and all the people involved) it s been busy time uh? Simone
  15. hi SM i was trying the SID-Control buti can t have it working.I tried with ableton 6, set the midi out but nothing goes out, and i cant upload anything to the 6582 any idea? would it be better to keep this post in your forum? thanks simone
  16. cimo
    *whack*
    may anybody explain to this dumb ass how to connect to a IRC server ? i am using XIRC but i can use anything for example i also have pidgin, whatever, please! i can t live without the bug !
  17. of course i have the preamp after the turntables!! http://www.ableton.com/forum/viewtopic.php?t=81281
  18. it looks like that:
  19. i had to log as root to get the device status:
  20. .. oh a blackout! that s what i needed !
  21. ok here it goes
  22. cimo
    Controllerism
    i think it is as lame as the music
  23. i think that Mr tippach has done quite a good job, well let s say that he s given the possibility to asio-less soundcard owners (most of pc users) to use their pcs for audio purposes, windows and steinberg didn t go so far, because they thought obviously it was not a good business. err am i going off topic? Asio4all is not an out of the box app, it often needs some tweaking, playboss, have you read the manual? how small was your buffer? simone
  24. hi after i got a midimate, i bought a cheaper interface of the same kind from ebay, when i asked the vendor for the driver for XP he pointed me out to... the audiotrack (now esi) website.!! when i opened the little box with the chips all the chips were "sanded" on the top so that you couldn t read the chips names. no need for explanation eh? ;) the chip on the midimate is a TAS1020B usb_device.product_id 4096 (0x1000) usb.vendor_id 2706 (0xa92)
  25. hi asio4all has always fixed any latency problem i had on slower windows machines, if you want to gain some extra ms (and stability) i recommend, especially if you have an older machine (i guess because of the usb1.1) to have an extra "audio only" partition and install to keep clean and away from non-audio software. It s also usefull to have the audio partition as first partition cause it will spin on the external side of the HD and it will be faster. Simone
