SLP
1,149 -
Everything posted by SLP
np. but don't forget to order the paper-catalog,too. so the next time you can search the parts more easily without understanding german. ;)
There was something similar that happened to me. I asked my uncle to cut the faderslots in my frontpanel. I drilled the holes for the pots,buttons and the display before and I did it very carefully cause I didn't want to scratch my anodized aluminium panel. But when I got the frontpanel back, I noticed that my uncle made some really bad scratches in the frontpanel. I was really angry, but on the otherside my uncle did it for free so I couldn't go to him and complain. At the end I bought some blue self-adhesive foil and glued it over the panel. I doesn't look too bad in my eyes. I know that Sasha the perfectionist would probably throw up when he'd see that ;D ;D
why don't you just cut some wood away at every side except the shortest one (upper one in picture 3)? Then you'll have an uniform look again.
http://www.reichelt.de/?SID=26LdMvQ6wQARoAAGZl5aw2187e6e04a9a66480cad2b1fb21dec9e;ACTION=4;LA=4;SEARCH=VERBINDER;WHOLE=0;TYPE=AND;TEXTSEARCH=1;SEARCHGROUPID=3224;GROUPID=3224;SEARCHALL=1 DIL crimp connectors: perhaps this: http://www.reichelt.de/?SID=26LdMvQ6wQARoAAGZl5aw2187e6e04a9a66480cad2b1fb21dec9e;ACTION=2;LA=3;GROUP=C1441;GROUPID=3223;START=0;OFFSET=1000;SHOW=1 but this works quite well too for SIL and DIL: http://www.reichelt.de/?SID=26LdMvQ6wQARoAAGZl5aw2187e6e04a9a66480cad2b1fb21dec9e;ACTION=2;LA=2;GROUP=C142;GROUPID=3221;START=0;OFFSET=1000;SHOW=1
Drehimpulsgeber http://www.reichelt.de/?SID=26LdMvQ6wQARoAAGZl5aw2187e6e04a9a66480cad2b1fb21dec9e;ACTION=4 (or "Drehencoder", but those are optical ones and therefore quite expensive) Kühlkörper TO-220 http://www.reichelt.de/?SID=26LdMvQ6wQARoAAGZl5aw2187e6e04a9a66480cad2b1fb21dec9e;ACTION=4 Stripboard -> Streifenrasterplatine http://www.reichelt.de/?SID=26LdMvQ6wQARoAAGZl5aw2187e6e04a9a66480cad2b1fb21dec9e;ACTION=4 Protoboard -> Lochrasterplatine http://www.reichelt.de/?SID=26LdMvQ6wQARoAAGZl5aw2187e6e04a9a66480cad2b1fb21dec9e;ACTION=4 GElb -> yellow GrüN-> green RoT -> red http://www.reichelt.de/?SID=26LdMvQ6wQARoAAGZl5aw2187e6e04a9a66480cad2b1fb21dec9e;ACTION=2;LA=2;GROUP=A5331;GROUPID=3018;START=0;OFFSET=16;SHOW=0 I haven't found any Ceramic Caps with 300nF
I know that :P
Meine Rede. Aber warum einfach, wenns auch unständlich geht ;)
Arkade : joysticks + other goodies based controller
SLP replied to goule's topic in MIDIbox User Projects
That is f*ckin AWESOME!!! :o :o :o -
1st suggestion: Midibox Plus! cheap,reliable and easy to build. 2nd suggestion: a single core module would do the job. just connect your breath controller to one of the analog inputs that are directly on the Core-PCB. This will probably need a bit of programming. matthias
1,8V für rote, 2,1 für gelbe und 2,4 für grüne LEDs sind so Standartspannungen. Bist Du dir sicher dass du den Hochziehwiederstand am letzten DIN-Modul angelötet hast? http://ucapps.de/mbhp/mbhp_dinx1.jpg Falls Du den nicht vergessen hast, würde ich auch auf den Kondensator als Fehlerquelle tippen. Der dient eigentlich nur der Spannungsstabilisierung, du kannst also auch einen nehmen dessen Wert ein bisschen von 100µF abweicht fakls Du so einen gerade zur Hand hast. matthias
Ich würd bei einem Stückpreis von 11,60€ 2 Stück nehmen, ansonsten nur einen.
[depressed mood] ok... I've completely disconnected the SID-module from the Core and removed every IC from the SID-PCB. If I power it on, I hear the strange noise. If I take the connector which is used to connect the Cables for the SID-Core-connection and move it closer to the PIC, the noise gets louder. It seems that the PIC sends some electromagnetic waves which are recieved by the SID-PCB and forwarded to the amp. Now I take the input-wire of my amp (TDA 7052,btw.) and connect it to every pin of the PIC, I can hear the loudest noise at pin#: 6,19,28 (noise#1) and 22,21 (noise#2) edit: Testtone application works well, btw.
Back again. :) http://www.malzahn-innovations.de/media/xycontrol.swf (diagramm, german text) http://www.seo4top.com/nrz.dinslaken.volltext.php.htm (newspaper article, german) http://www.malzahn-innovations.com (main page, german) I'll try to get some samples
Don't you think the stabilizing caps on the Core and SID-Module are enough? I've downloaded my noise-record again and must say that the record-level was too low. it's much louder. There seems so be an other problem... ::) (This thread is never going to end :P ) When I power only the Core, something seems to oscillate. There are some sounds that are generated and then led through the ground-wire to the SID and then to the audio out and to the amp. When I power the SID on now, there is a 1KHz triangle-wave (?-quite the same as the testtone-app, though the SID-app is on the PIC) and the additional noise from the Core. When I power just the SID, there's a quite loud noise. ...I'll make a video and put it on youtube ::) edit: I won't put a video on youtube..... modem.... :P
LOL but quite scary though... ::)
I tried something different (see attachment). result: No noise :D now there are 2 possibilities: - The noise was just because of the bad PSU or - I've just killed something (I'll try the testone-app tomorrow) ...something inside of me sais that Murphy was right... ::)
achso,... stimmt, hab ich übersehen. Aktuelle Liste: Hendrik: 32 sebastian: 18 dj3nk: 10 audiocommander: 8 MTE: 18 ptitjes: 32 Playboy: 14 Bibster: 8 SLP: 2 ----------------------- 142 von 200
ich habs nochmal zusammengefasst: Aktuelle Liste: Hendrik: 32 sebastian: 18 dj3nk: 18 audiocommander: 8 MTE: 18 ptitjes: 32 Playboy: 14 Bibster: 8 SLP: 2 ----------------------- 150 von 200
I'd love to try Fedora and EnergyXT, but could someone please tell me where to download a Linux driver for my E-MU 0404 soundcard? I've searched for hours, but not even the E-MU-Hotline is able to tell me if such a driver exists. :'( HELP!!
ist das hier eigentlich noch aktuell??
jep. I don't know If you've ever build something youself. The feeling when it's finished is amazing. You love your MB. I think it won't take that long until you've finished a MB-SEQ. Especially when you don't make the frontpanel yourself but buy it. And you don't have to spend hours of troubleshooting because of some noise like with the MB-SID or the MB-FM.
Unfortunately that's not the reason :(
Angekommen! :)
Download the FrontPanelDesigner http://www.schaeffer-apparatebau.de/English/FPD_index.htm and open TKs Frontpanel-file http://ucapps.de/midibox_sid_cs/mbsid_panel.fpd Now you can see exactly where everything is situated and c+p it directly in your preferred graphics-program (CorelDraw12 in my case). this will work perfectly.
