SLP
1,149 -
Everything posted by SLP
sure. :-[ I've been tired... it was a stupid mistake
I'd take 2 pieces. also ich würd noch 2 nehmen. So'n faderfox-teil wär schon ne tolle sache :) Ausserdem habt Ihr dann gerade Zahlen ;)
Interesting stuff... But i doubt whether it it really able to produce the real analog SID-sound. (nice guestbook, btw. ;D)
No ideas? ??? Is it likely that this problem is caused by the PSU?
hab ich mir schon gedacht.... irgendwie warn die URLs schon verdächtig lang... Du musst aber bei Conrad nicht lang suchen bis di sie findest.
guckstu conrad. http://www1.conrad.de/scripts/wgate/zcop_b2c/~flN0YXRlPTI3NzAwMDE0NzU=?direkt_aufriss_area=SHOP_AREA_14735&~template=PCAT_AREA_S_browse&p_page_to_display=&catalogs_sub_id=sub13&aktiv=13&navi=oben_2 AFAIK die einzigen mit 100mm. da kommst aber mit 100mm motorfadern günstiger weg. http://www1.conrad.de/scripts/wgate/zcop_b2c/~flN0YXRlPTI3NzAwMDE0NzU=?direkt_aufriss_area=SHOP_AREA_14735&~template=PCAT_AREA_S_browse&p_page_to_display=&catalogs_sub_id=sub13&aktiv=13&navi=oben_2
well... now that makes me feel a bit doubtful whether it's right what i've said... ::) Can you tell me where you've read that? But I'm 100% sure that it's possible to use the MF-module with non-motorised-faders. yep. But it could be possible to connect more than 1 MF-module to the core. you should look that up. But as long as you just use 1 MF-module you're able to connect 8 (or less) faders. A DINx1 supports 8 analog inputs. If you need 9 AINs you can build your own DINx2 board (16 inputs) or you can order an common DINx4 from smash or mike and just leave the 2 multiplexers away as you don't need them. BUT (!) after your post I'm not 100% sure that you can use AINs with the LC-application. AND (!) I don't know anything about the LC-protocol. I don't know whether a 9th fader will work. matthias
just leave the MF-module out and connect the middle pin of the slider to one AIN. the outer pins should be connected to +5V and GND.
background? everything you can hear shouldn't be there. the 50Hz buzz and the "usual"-SID-and-PSU-noise isn't the problem. I turn it on and the noise starts. If I send any note-on messages nothing happens.
I do always hear that noise, not only after powering on.. noise2.zip noise2.zip
ok. problem solved hmm.. there aren't very many mistakes left that I haven't done ;D I just didn't push one multiplexer entirely into the socket. New problem - same headline: If I upload the SID-application and start the MB, I hear some really weird sound. I'll record it later. I tried every single Core-SID combination, and tried with both the PIC18F452 and PIC18F4685. It's always the same. After booting up, i shouldn't hear any sound, right? There's no BankStick connected. thx, matthias
but I prefer attaching them to the posts.
nice design, but I don't think this is the right place to post it :/
I think this one is better. btw. i'll delete the pictures in my last posts... you all know what happened yesterday... I already have a bad conscience ::)
Es gibt doch überall diese CMOS-kameras. Die bekommst du schon ab 10€ bei C*nrad oder R*ichelt. AFAIK haben die nur 3 pins (+,-,analog out). Ich denke das wäre das beste für deine Zwecke. Das erinnert mich übrigens an eine Idee für ein MB-projekt, die schon länger in meinem Kopf herumschwirrt, welche ich aber nie wirklich realisieren werde, weil ich kein DJ bin und weil ein ordentlicher DJ sowas eigentlich auch garnicht braucht. Stell dir mal ne MB vor, mit Infrarotkameras, die Temperatur und Bewegung des Puplikums registrieren, einen alkohol und einen C02 sensor,die den Alkoholgehalt und körperliche verausgabung des Puplikums reigstrieren. und diese sachen kontrollieren dann in traktor die Musikrichtung, sowie Geschwindigkeit und Lautstärke. ...also,.. nur für den Fall dass es jemanden interessiert ;)
I don't like the picture myself. the colors are so cold. In reality it's much more warmer. Oh yeah! ;D
damn! I'm so stupid. I actually wanted to upload the picture of my carpet. ;D EDIT: picture of carpet deleted.
wow... i never thought that the aluminium rings around the LEDs would look so nice! hehe ;D I'm personally not a fan of those oriental rugs. I prefer those "modern art"-like carpets. EDIT: picture of open MB-SID removed. It's still here: http://www.midibox.org/forum/index.php?topic=9268.msg66093#new
while searching for some laser-overclocking-instructions, i found several veery interesting pages: DIY-waterjet: http://www.cnczone.com/forums/archive/index.php/t-16526.html Amateur Laser Construction: http://www.repairfaq.org/sam/lasercon.htm Transmit Audio with a Laser Pen: http://www.makezine.com/blog/archive/2005/05/transmit_audio.html http://www.i-hacked.com/index.php?option=com_content&task=view&id=162&Itemid=44 and this site is absolutely awesome: http://www.hackaday.com/2007/03/18/make-your-own-fusion-reactor/ check out the other hacks on that page, too.
Stryd, didn't you want me NOT to open a poll concerning illegal software? ;D well, you may do that. you're an admin :P You should send your songs to michael moore. he's famous. If the cops really try to get you, he could make a nice documentary movie. ;)
what about overclocking his laser ? ;D ;D
Why didn't you just go to the guy with the laser-cutter? Isn't it possible to laser-cut aluminum?
ich denk die tuts vorerst auch. hat halt den vorteil dass du weder Spannungsregler noch Gleichrichter brauchst. evtl. ist der S/N-abstand etwas klein...
yeah... that sucks.... my internal hdd broke some months ago (hitachi)... and I had -all- my stuff on it. there were just very few backup CDs. that was shocking...
