rbv2
    105
    5
Everything posted by rbv2
  1. Hello all Selling my midibox sequencer including breakout box. The sequencer is fully functional, from a non-smoking household. Has never been used for live performances, only studio use. The breakout box is a bit obvious DIY but fully functional. You need a free slot in the modular system for the +-12V power supply. Selling price 1350,-€. best regards rbv2 https://www.ebay-kleinanzeigen.de/s-anzeige/midiphy-sequencer-v4-midibox-stepsequencer/2241157248-74-4257
      • 1
      • Like
  2. Hi all, would it be possible to implement saving mutes of the individual drum instruments (drum Tracks) when using s&top function in phrase mode? Have a nice weekend rbv2
  3. thanks for your reply. the m16 looks promising but I'm afraid i not fully understand the capabilities or how to set it up. would it be possible to make a standalone midi-router from it? probably have to wait until it's more prepared for soldering by numbers :) thanks
  4. hello, is it possible to get boards for this project or is it planned to offer it in midiphy-shop? I am very interested... would like to be able to route 32inputs to 16outputs (ports). thanks rbv2
  5. have found something.. https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=477
  6. i pulled them by hand. is there a special tool? the picture does not match the actual impression. one can clearly distinguish which steps are selected.
  7. pulling off the caps from the matias switches is quite tough. a lot of force is needed. The new caps looking great and help with the light diffusion. thanks
  8. just ordered
  9. now i'm curious :)
  10. :D yesss, can't wait. after a while of usage i find it a little bright too.
  11. i like the keycaps a lot :D
  12. when sending out triggers from AOUT Ch16 and then select in the parameter layer "lenght" i can change the lenght of the trigger/gate from 1% to Glide at 1% - no trigger at 2% - sporadic trigger from - 3-20% steady trigger from - 21-100 % double trigger with increasing distance (21% narrow / 100% wide) glide - only the first trigger before we fixed the grounding issue i got double triggers starting at 5% and other problems but now i'm pretty shure those are gates and not triggers making some modules being triggered at the beginning and the end of that rectangular pulse.
  13. thanks a lot, it's working much better now also the random triggers when inserting cables are gone now :) only get double triggers on very long "lenght" settings wich i assume is normal behavior. are those real triggers or very short gates? thanks @Hawkeye and @latigid on for your support and patience you deserve a beer btw. where is the "buy hawkeye a beer" button?
  14. no, its 5V didn't know how write it correctly. yes, isn't so well drawn but that's what I meant. thanks. i try it and report
  15. @latigid on thanks! to be on the safe side, I made a drawing. it shows my current wiring. the black line with the question mark shows how I understand it. would that be okay? thank you! rbv2
  16. hi latigid on, thanks a lot for your answer. - since i have made no changes in the HW Config beside setting the 1ms-option and SRs for clocks, gates & Trigger i would assume no - all tracks muted except for the one sending triggers to CH16 - checked all cables visually again - the resistance between 0V Eurorack and pin 2 of a Midi Socket oscillates between 1,8-2,5 Ohm - no jumper in J3 - the double trigger only occours on some modules and depends on the setting of the length in the parameter layer, when length is 4% it's almost gone, it's acting like a gate.. - I'll try to do the tests in mios when I understand how it works so the connection underneath the DAC is not sufficient then? yes, i am using an external power plug. i get 4,96V on J2 of AOUT NG and 4,96V on J19 of the Receiver unfortunately I still have to wait for the scope.. thanks rbv2
  17. hi peter, at the shematic i can see the point you refering to but there is no jumper or place for a pinheader. yes i use the DOUT module for 8x Gate, 16x Trigger an 8x Clock the AOUT NG is for CV only. a friend of mine will lend me his scope. but i don't have one right now. thank you!
  18. hi peter, thanks a lot for you answer. at the moment i have wired 12V+/- and GND directly from a doepfer bus board to J3 of the AOUT NG the external psu is in the middle of the cable from JAOUT of the receiver to J1 of the AOUT NG. (Vs & Vd) . by common ground do you mean i should connect the Vs line of 5V PSU to the GND of J3 at the AOUT NG? all the jacks (gate, trigger, cv) are connected to ground and since the panel is made of aluminium the gnd of both psu's is connected. unfortunately i saw the information about the new modules too late. i would rather use them but i had already bought all the parts and ordered a panel at schaeffer.. i have also learned that the 5v on the doepfer boards are not there at all although it is written on it thanks!
  19. hi all, after testing i found an minor issue with my breakout-box. everything is working as intended but i get annoying double triggers on some modules. when i connect the same modules to my robokop sequencer or other trigger source everything is fine. could it be a grounding issue? the +/-12V for the AOUT NG is coming from my eurorack and the +5V for AOUT NG and the LineDriver Receiver from an additional psu. the external psu (5v) is in the middle of the ribbon cable between AOUT NG and the receiver as suggested by latigid on. i also enabled the 1ms trigger but it makes no difference. when using the same trigger on another module it works so i guess i can rule out the double trigger is coming from the sequencer itself. please help rbv2
  20. hi all, after testing i found an minor issue with my breakout-box. everything is working as intended but i get annoying double triggers on some modules. when i connect the same modules to my robokop sequencer or other trigger source everything is fine. could it be a grounding issue? the +/-12V for the AOUT NG is coming from my eurorack and the +5V for AOUT NG and the LineDriver Receiver from an additional psu. the external psu (5v) is in the middle of the ribbon cable between AOUT NG and the receiver as suggested by latigid on. i also enabled the 1ms trigger but it makes no difference. please help rbv2
  21. rbv2
    looks great
  22. thanks for the update. looks great
  23. you were right. SR10 (gates) , SR11 (trigger 1-8), SR 12 (trigger 9-16). thanks again, it's working now
  24. I'll try that tomorrow. thank you for the quick reply
