1,291 -
101
Everything posted by Antichambre
From the album: Antichambre "stuff and work"
Hi, It seems not new. YMF825 (SD-1) Year of release: 2011 FM: 16 channels (4-op, 29 waveforms) Used in: Home appliances (Chinese market) This appears to be a version of MA-3. It has no PCM or Analog Lite capabilities. Using 2-op instruments does not give extra channels, thus it's probably best to use 4-op instruments. https://gist.github.com/bryc/e85315f758ff3eced19d2d4fdeef01c5
Les cordonniers sont toujours les plus mal chaussés.
The HAARP, a Hardware Advanced Arpeggiator.
Antichambre replied to Antichambre's topic in MIDIbox User Projects
A quick video demo, made by a friend. I just gave it to him like that, without much explanation. The user manual is still not ready (blame me) but he managed to catch the thing even though he only used a few of the features. -
I sent you a message. -
So I don't know. Try to change the MIDI channel according to its MIDI manual.
- 69 replies
- jack
- `control port
(and 2 more)
Tagged with:
Here is a normal MIDI interface schematic. As you can see ground is only on pin 2 of the MIDI outputs. I think your problem is that the chase bliss has no optocoupler input and doesn't get the signal between the regular pin 4 and 5(between signal and 5V) but between 4 and 2(signal and ground). if no ground is provided on pin 2 of your controller then the pin4(signal) has no reference. Before open the controller check the continuity between midi out pin 2 and another ground, e.g. sleeve of the XPDL jack If there's nothing then open the enclosure and add it...
- 69 replies
- jack
- `control port
(and 2 more)
Tagged with:
What is ISO cable? Regular MIDI one? Which plug?
- 69 replies
- jack
- `control port
(and 2 more)
Tagged with:
Did you try to receive something from another machine(computer) to the chase bliss with this cable? Maybe pin 2 of your controller is not connected to the ground internally. Pin 2 is a shield and it's normally not used on the receiving side(MIDI In), some manufacturer don't follow the rules and don't connect it. Try with another MIDI Out device, if it works then open your MusicomLab controller and add a piece of wire from a ground position to the pin 2.
- 69 replies
- jack
- `control port
(and 2 more)
Tagged with:
Could you show us what you did, cabling pinout and the basic information you got in hand to do it?
- 69 replies
- jack
- `control port
(and 2 more)
Tagged with:
This thread talks about how to replace The Empress MIDIbox by a simple cabling. This product is from the Empress brand, and has just the same name as our forum. But! According to the chase bliss documentation, Tip and Ring mus be flipped to use it with the Empress interface. https://static1.squarespace.com/static/5dce1364138bbd66dabfb03c/t/5dd368e2b036cc38a02202ac/1574136034997/Tonal+Recall_MIDI+Manual_Pedal_Chase+Bliss+Audio.pdf I can't try this with my "simple cabling" solution, I've got no chase bliss product. It's maybe your issue. Also trying it is at your own risk ;) Best regards Bruno
- 69 replies
- jack
- `control port
(and 2 more)
Tagged with:
Hi, By default the UART are configured for regular MIDI DIN speed, 31250 baud. But you can change their configuration, in the mios32_config.h file of your project. The default value(if not previously defined in mios32_config.h) are found in include/mios32/mios32_uart.h // Baudrate of UART first interface #ifndef MIOS32_UART0_BAUDRATE #define MIOS32_UART0_BAUDRATE 31250 #endif Others settings are not easily accessible, they are dependant of the cpu. They are set in mios32_uart.c But they meet your requirement, example for stm32f4xx: USART_InitTypeDef USART_InitStructure; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; Best regards Bruno
This is normal, this is the first startup sequence to init/format the banksticks(eeprom). But it must stop after a short moment. Hummm. Check if it's working with the max-msp manager. or send a whole midi note range over channel 1... Try also to upload this firm: setup_tia_cartridge_keeze.hex If I remember well @Keeze got the same issue.
Eventually send a picture of the board(best reso as you can), I will maybe see something...
Tomorrow check for continuity and short-cut on the UART(MIDI) part of the circuit, mainly between optocoupler and pic, check resistors values, orientation of the diod, check also the orientation of the optocoupler(6N138), change it if possible... here is the diagram, optocoupler is on top-right.... if you have a waveform monitor check the signal on RX path.
Don't worry it can work without ground. but it's molded connector on that side, strange. I maybe didn't connect the right wire color when I did it. but don't touch it let it ike that, it can work without if you don't use 15 meters MIDI cable Can you explain what you did exactly, files used etc... Note: The jumper for MCLR is necessary for Core startup, put it back once you had burnt the pic.
Good pinout is this one: Check if IN pins are not inverted MIDI IN pin4 connected to MI+. DB25 pin14, wire should be green MIDI IN pin5 connected to MI-. DB25 pin1, wire should be white MIDI OUT pin2(center) connected to ground. DB25 pin15 MIDI OUT pin4 connected to MO+. DB25 pin2, wire should be green MIDI OUT pin5 connected to MI-. DB25 pin3, wire should be white There's no specific burner for surface mount, if you've got one you can connect it like this: No it's not destructive, le led are software driven, they their own pic pins. Do you try to do a "Query" in MIOS Studio even with this led behavor? (with MIDI In and Oout connected).
Yes sorry I was on an old dokuwiki revision ;)
@Keeze Could you share your illustration as I can add it to the other Thanks!
Hi do you use the provided DB25 adapter cable? Check it also please. Did you try to upload the application again? Best regards Bruno
Hello, SAM, Software Automatic Mouth, is an old "text-to-speech" program. It was released in 1982 and worked on most computers of the era. It was recently adapted to C by Sebastian Macke as a very tiny code. Source code Github. Here a web version of SAM, and a another one with parameters here. I've got two Texas Instrument speech device, one "Speak and Spell" and a "Math and Spell" but they are waiting since a long time now to be modified... Too much time :/ So when I read the @imaginarionthread I couldn't help but go and look at the code. And obviously I tried to do something with it First thing to understand is this program is not realtime, after converting the text to phoneme, each of this phoneme are converted to formants, then each sample is pushed in a buffer. When finished the samples buffer is written to a wave file or sent to an audio output using SDL. But it's 22KHz 8bit sound then depending on the duration this buffer can be too much big for our small Core. But ok let's try... For us(MIDIboxer/musician) the purpose is to play it from MIDI, the perfect thing should be to get a text, a sentence or a word associated to midi note, like a "speech kit" or one text pitched along the midi note range, but that will be for another time ;) First thing to try is to adapt the code to MIOS32, put something in and check what it can output. The best and easiest way for a test, is to implement SAM as a module, write some code to input text from MIOS Studio terminal then write the wave file to the SD card This is what I did: So I imported the github flies and put it in a new software module named "sam". Added a sam.mk file in it to include the necessary .c and .h files. # defines additional rules for integrating the random module # enhance include path C_INCLUDE += -I $(MIOS32_PATH)/modules/sam/src # add modules to thumb sources (TODO: provide makefile option to add code to ARM sources) THUMB_SOURCE += \ $(MIOS32_PATH)/modules/sam/src/sam.c \ $(MIOS32_PATH)/modules/sam/src/debug.c \ $(MIOS32_PATH)/modules/sam/src/render.c \ $(MIOS32_PATH)/modules/sam/src/processframes.c \ $(MIOS32_PATH)/modules/sam/src/createtransitions.c \ $(MIOS32_PATH)/modules/sam/src/reciter.c # directories and files that should be part of the distribution (release) package DIST += $(MIOS32_PATH)/modules/sam/src Then I took the inspiration from the non included main.c file to create a MIOS32 project and write a terminal.c file Some modification were done in the SAM's files. all printf function were replaced by MIOS32_MIDI_SendDebugMessage the buffer memory allocation malloc was removed and size was reduced until no more "FAULT" error ;) the 8 bits samples were reduced to 4bits to meet the original SID resolution, I put it back to 8. This can be done easily after if necessary depending on our future audio output device. After a couple of hours, it was working. Command and text are send to SAM thru the terminal, the result is written on the SD Card Here the menu and usage then the debug verbose: [28337.121] SD Card status 1 [28339.122] SD Card status 3 [28339.122] SD Card CONNECTED [28342.433] help [28342.435] Welcome to the HAARP Terminal! [28342.435] Following commands are available: [28342.435] sam_usage: SAM Usage [28342.435] sam: SAM [28342.435] reset: resets the MIDIbox (!) [28342.435] help: this page [28345.225] sam_usage [28345.227] usage: sam [options] Word1 Word2 .... [28345.227] options [28345.227] -phonetic enters phonetic mode. (see below) [28345.227] -pitch number set pitch value (default=64) [28345.227] -speed number set speed value (default=72) [28345.227] -throat number set throat value (default=128) [28345.227] -mouth number set mouth value (default=128) [28345.227] -wav filename output to wav instead of libsdl [28345.228] -sing special treatment of pitch [28345.228] -debug print additional debug messages [28345.228] [28345.228] VOWELS VOICED CONSONANTS [28345.228] IY f(ee)t R red [28345.228] IH p(i)n L allow [28345.228] EH beg W away [28345.228] AE Sam W whale [28345.228] AA pot Y you [28345.228] AH b(u)dget M Sam [28345.228] AO t(al)k N man [28345.229] OH cone NX so(ng) [28345.229] UH book B bad [28345.229] UX l(oo)t D dog [28345.229] ER bird G again [28345.229] AX gall(o)n J judge [28345.229] IX dig(i)t Z zoo [28345.229] ZH plea(s)ure [28345.229] DIPHTHONGS V seven [28345.229] EY m(a)de DH (th)en [28345.230] AY h(igh) [28345.230] OY boy [28345.230] AW h(ow) UNVOICED CONSONANTS [28345.230] OW slow S Sam [28345.230] UW crew Sh fish [28345.230] F fish [28345.230] TH thin [28345.230] SPECIAL PHONEMES P poke [28345.230] UL sett(le) (=AXL) T talk [28345.230] UM astron(omy) (=AXM) K cake [28345.231] UN functi(on) (=AXN) CH speech [28345.232] Q kitt-en (glottal stop) /H a(h)ead [28359.145] sam -debug -pitch 64 -speed 128 -mouth 128 -wav TEST_OK midibox sam is great! [28359.147] text input: MIDIBOX SAM IS GREAT! [28359.147] Applying rule: [28359.147] ( [28359.147] M [28359.147] ) [28359.147] -> [28359.147] M [28359.147] [28359.147] Applying rule: [28359.147] ( [28359.147] I [28359.147] ) [28359.147] ^ [28359.148] + [28359.148] : [28359.148] # [28359.148] -> [28359.148] I [28359.148] H [28359.148] [28359.148] Applying rule: [28359.148] ( [28359.148] D [28359.148] ) [28359.148] -> [28359.148] D [28359.148] [28359.148] Applying rule: [28359.148] I [28359.148] ^ [28359.148] ( [28359.148] I [28359.148] ) [28359.148] ^ [28359.148] # [28359.148] -> [28359.148] I [28359.148] H [28359.148] [28359.148] Applying rule: [28359.148] ( [28359.148] B [28359.148] ) [28359.148] -> [28359.148] B [28359.148] [28359.148] Applying rule: [28359.148] ( [28359.148] O [28359.148] ) [28359.148] -> [28359.148] A [28359.148] A [28359.148] [28359.149] Applying rule: [28359.149] ( [28359.149] X [28359.149] ) [28359.149] -> [28359.149] K [28359.149] S [28359.149] [28359.149] Applying rule: [28359.149] ( [28359.149] S [28359.149] ) [28359.149] -> [28359.149] S [28359.149] [28359.149] Applying rule: [28359.149] ( [28359.149] A [28359.149] ) [28359.149] -> [28359.149] A [28359.149] E [28359.149] [28359.149] Applying rule: [28359.149] ( [28359.149] M [28359.149] ) [28359.149] -> [28359.149] M [28359.149] [28359.149] Applying rule: [28359.149] ( [28359.149] I [28359.149] ) [28359.149] -> [28359.149] I [28359.149] H [28359.149] [28359.149] Applying rule: [28359.149] [28359.149] : [28359.149] # [28359.149] ( [28359.149] S [28359.150] ) [28359.150] [28359.150] -> [28359.150] Z [28359.150] [28359.150] Applying rule: [28359.150] ( [28359.150] G [28359.150] R [28359.150] E [28359.150] A [28359.150] T [28359.150] ) [28359.150] -> [28359.150] G [28359.150] R [28359.150] E [28359.150] Y [28359.150] 4 [28359.150] T [28359.150] [28359.150] Applying rule: [28359.150] ( [28359.150] ! [28359.150] ) [28359.150] -> [28359.150] . [28359.150] [28359.150] phonetic input: MIHDIHBAAKS SAEM IHZ GREY4T. � [28359.150] =========================================== [28359.150] Internal Phoneme presentation: [28359.150] idx phoneme length stress [28359.150] ------------------------------ [28359.151] 0 * 0 0 [28359.151] 27 M* 0 0 [28359.151] 6 IH 0 0 [28359.151] 57 D* 0 0 [28359.151] 6 IH 0 0 [28359.151] 54 B* 0 0 [28359.151] 9 AA 0 0 [28359.151] 72 K* 0 0 [28359.151] 32 S* 0 0 [28359.151] 0 * 0 0 [28359.151] 32 S* 0 0 [28359.151] 8 AE 0 0 [28359.151] 27 M* 0 0 [28359.151] 0 * 0 0 [28359.151] 6 IH 0 0 [28359.152] 38 Z* 0 0 [28359.152] 0 * 0 0 [28359.152] 60 G* 0 0 [28359.152] 23 R* 0 0 [28359.152] 48 EY 0 4 [28359.152] 69 T* 0 0 [28359.152] 1 .* 0 0 [28359.152] 0 * 0 0 [28359.154] =========================================== [28359.154] [28359.154] Parser2 [28359.154] 0: * [28359.154] 1: M* [28359.154] 2: IH [28359.154] 3: D* [28359.154] RULE: Soften T or D following vowel or ER and preceding a pause -> DX [28359.154] 4: IH [28359.154] 5: B* [28359.154] 6: AA [28359.154] 7: K* [28359.154] RULE: K <VOWEL OR DIPTHONG NOT ENDING WITH IY> -> KX <VOWEL OR DIPTHONG NOT ENDING WITH IY> [28359.154] 8: S* [28359.154] 9: * [28359.154] 10: S* [28359.154] 11: AE [28359.154] 12: M* [28359.154] 13: * [28359.154] 14: IH [28359.154] 15: Z* [28359.154] 16: * [28359.154] 17: G* [28359.154] RULE: G <VOWEL OR DIPTHONG NOT ENDING WITH IY> -> GX <VOWEL OR DIPTHONG NOT ENDING WITH IY> [28359.154] 18: R* [28359.154] 19: EY [28359.154] RULE: insert YX following dipthong ending in IY sound [28359.154] 20: YX [28359.154] 21: T* [28359.154] 22: .* [28359.154] 23: * [28359.154] RULE: Lengthen <FRICATIVE> or <VOICED> between <VOWEL> and <PUNCTUATION> by 1.5 [28359.154] PRE [28359.154] phoneme 20 (YX) length 8 [28359.154] POST [28359.154] phoneme 20 (YX) length 13 [28359.154] RULE: Lengthen <FRICATIVE> or <VOICED> between <VOWEL> and <PUNCTUATION> by 1.5 [28359.154] PRE [28359.154] phoneme 21 (T*) length 4 [28359.154] POST [28359.154] phoneme 21 (T*) length 7 [28359.154] RULE: <VOWEL> <VOICED CONSONANT> - increase vowel by 1/2 + 1 [28359.154] PRE [28359.154] phoneme 3 (DX) length 2 [28359.154] POST [28359.154] phoneme 4 (IH) length 11 [28359.154] RULE: <VOWEL> <UNVOICED PLOSIVE> - decrease vowel by 1/8th [28359.155] PRE [28359.155] phoneme 6 (AA) length 11 [28359.155] POST [28359.155] phoneme 6 (AA) length 10 [28359.155] RULE: <VOWEL> <VOICED CONSONANT> - increase vowel by 1/2 + 1 [28359.155] PRE [28359.155] phoneme 10 (S*) length 2 [28359.155] POST [28359.155] phoneme 11 (AE) length 11 [28359.155] RULE: <VOWEL> <VOICED CONSONANT> - increase vowel by 1/2 + 1 [28359.155] PRE [28359.155] phoneme 13 ( *) length 0 [28359.155] POST [28359.155] phoneme 14 (IH) length 11 [28359.155] RULE: <LIQUID CONSONANT> <DIPTHONG> - decrease by 2 [28359.155] PRE [28359.155] phoneme 18 (R*) length 10 [28359.155] POST [28359.155] phoneme 18 (R*) length 8 [28359.156] RULE: <VOWEL> <UNVOICED PLOSIVE> - decrease vowel by 1/8th [28359.156] PRE [28359.156] phoneme 20 (YX) length 13 [28359.156] POST [28359.156] phoneme 20 (YX) length 12 [28359.156] =========================================== [28359.156] Internal Phoneme presentation: [28359.156] idx phoneme length stress [28359.156] ------------------------------ [28359.156] 0 * 0 0 [28359.156] 27 M* 7 0 [28359.156] 6 IH 8 0 [28359.156] 30 DX 2 0 [28359.156] 6 IH 11 0 [28359.156] 54 B* 6 0 [28359.157] 55 ** 1 0 [28359.157] 56 ** 2 0 [28359.157] 9 AA 10 0 [28359.157] 75 KX 6 0 [28359.157] 76 ** 1 0 [28359.157] 77 ** 4 0 [28359.157] 32 S* 2 0 [28359.157] 0 * 0 0 [28359.157] 32 S* 2 0 [28359.157] 8 AE 11 0 [28359.157] 27 M* 7 0 [28359.157] 0 * 0 0 [28359.157] 6 IH 11 0 [28359.157] 38 Z* 6 0 [28359.157] 0 * 0 0 [28359.158] 63 GX 6 0 [28359.158] 64 ** 1 0 [28359.158] 65 ** 2 0 [28359.158] 23 R* 8 5 [28359.158] 48 EY 14 4 [28359.158] 21 YX 12 4 [28359.158] 69 T* 7 0 [28359.158] 70 ** 2 0 [28359.158] 71 ** 2 0 [28359.158] 1 .* 18 0 [28359.158] 254 ?? 0 [28359.158] 0 * 0 0 [28359.158] =========================================== [28359.158] [28359.159] =========================================== [28359.159] Final data for speech output: [28359.159] flags ampl1 freq1 ampl2 freq2 ampl3 freq3 pitch [28359.159] ------------------------------------------------ [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.160] 0 9 6 2 46 0 81 61 [28359.160] 0 9 10 4 59 2 87 59 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 23 96 23 151 29 102 16 [28359.160] 0 44 179 6 230 6 111 231 [28359.161] 0 0 6 0 54 0 121 61 [28359.161] 0 2 8 2 60 2 197 60 [28359.161] 0 4 11 4 66 2 17 59 [28359.161] 0 11 14 8 72 4 93 57 [28359.161] 0 11 14 8 72 4 93 57 [28359.161] 0 11 14 8 72 4 93 57 [28359.161] 0 11 14 8 72 4 93 57 [28359.162] 0 11 14 8 72 4 93 57 [28359.162] 0 11 14 8 72 4 93 57 [28359.162] 0 11 14 8 72 4 93 57 [28359.162] 0 11 14 8 72 4 93 57 [28359.162] 0 26 76 29 124 2 154 26 [28359.162] 0 9 138 14 177 6 215 251 [28359.162] 0 36 200 30 229 36 20 220 [28359.162] 0 2 6 0 26 0 81 61 [28359.162] 0 2 6 0 26 0 81 61 [28359.162] 0 2 6 0 26 0 81 61 [28359.162] 0 2 6 0 26 0 81 61 [28359.162] 0 2 6 1 26 0 81 61 [28359.162] 0 0 6 0 26 0 81 61 [28359.162] 0 0 6 0 26 0 81 61 [28359.163] 0 3 12 2 30 0 83 58 [28359.163] 0 6 19 4 35 0 86 55 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 20 65 30 47 8 89 32 [28359.164] 0 23 104 23 54 23 90 12 [28359.164] 0 9 144 16 62 17 91 248 [28359.164] 0 44 183 44 69 10 92 229 [28359.164] 0 51 222 51 76 73 93 209 [28359.164] 0 0 6 0 84 0 94 61 [28359.164] 0 0 6 0 84 0 94 61 [28359.164] 0 0 6 0 84 0 94 61 [28359.164] 0 0 6 6 84 3 94 61 [28359.164] 0 0 6 0 84 0 94 61 [28359.165] 0 0 6 0 84 0 94 61 [28359.165] 0 0 6 0 84 0 94 61 [28359.165] 0 0 6 0 133 0 95 61 [28359.165] 241 0 6 0 182 0 96 61 [28359.165] 241 0 6 0 231 0 97 61 [28359.165] 241 0 6 0 24 0 98 61 [28359.165] 241 0 6 0 73 0 99 61 [28359.166] 0 2 10 2 134 2 160 59 [28359.166] 0 4 15 4 195 2 221 57 [28359.166] 0 8 19 6 0 3 26 55 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.167] 0 15 24 13 62 4 88 52 [28359.167] 0 6 143 10 182 6 212 249 [28359.167] 0 9 6 2 46 0 81 61 [28359.167] 0 9 6 2 46 0 81 61 [28359.167] 0 9 6 2 46 0 81 61 [28359.167] 0 9 6 2 46 0 81 61 [28359.167] 0 9 6 2 46 0 81 61 [28359.168] 0 9 6 2 46 0 81 61 [28359.168] 0 9 10 4 59 2 87 59 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 29 64 23 119 20 93 32 [28359.169] 0 18 114 20 166 26 93 7 [28359.169] 1 6 164 6 213 6 93 238 [28359.169] 1 66 214 73 4 86 93 213 [28359.169] 1 8 9 2 51 0 93 60 [28359.169] 1 8 9 2 51 0 93 60 [28359.169] 1 8 9 2 51 0 93 60 [28359.169] 1 29 72 2 59 0 93 28 [28359.169] 0 16 135 6 67 0 93 253 [28359.169] 0 50 198 48 75 0 93 221 [28359.169] 0 1 6 0 84 0 94 61 [28359.170] 0 1 6 0 84 0 94 61 [28359.170] 0 1 6 0 84 0 94 61 [28359.170] 0 1 6 0 84 0 94 61 [28359.170] 0 2 6 1 84 0 94 61 [28359.170] 0 0 6 0 84 0 94 61 [28359.170] 0 0 6 0 84 0 94 61 [28359.170] 0 2 9 2 139 1 149 109 [28359.170] 0 3 12 3 195 2 205 157 [28359.170] 0 5 15 4 250 2 4 206 [28359.170] 0 9 18 6 50 3 60 254 [28359.171] 0 9 18 6 50 3 60 48 [28359.171] 0 9 18 6 50 3 60 48 [28359.171] 0 9 18 6 50 3 60 48 [28359.171] 0 9 18 6 54 3 66 70 [28359.171] 0 9 18 8 58 3 72 93 [28359.171] 0 11 18 9 63 4 78 116 [28359.171] 0 11 18 11 67 4 84 139 [28359.171] 0 13 18 13 72 5 90 162 [28359.171] 0 13 18 13 72 5 90 184 [28359.171] 0 13 18 13 72 5 90 207 [28359.172] 0 13 18 13 72 5 90 230 [28359.172] 0 13 18 13 72 5 90 253 [28359.172] 0 13 18 13 72 5 90 20 [28359.172] 0 13 18 13 72 5 90 45 [28359.172] 0 13 18 13 72 5 90 46 [28359.172] 0 13 49 8 103 10 90 35 [28359.172] 0 13 81 26 135 29 90 24 [28359.172] 0 13 112 16 166 18 91 12 [28359.172] 0 13 144 6 198 10 91 1 [28359.172] 0 13 175 6 229 6 91 246 [28359.173] 0 13 207 46 5 24 92 235 [28359.173] 0 13 238 66 36 26 92 223 [28359.173] 0 13 14 9 68 4 93 84 [28359.173] 0 13 14 9 68 4 93 88 [28359.173] 0 13 14 9 68 4 93 93 [28359.173] 0 13 14 9 68 4 93 97 [28359.173] 0 13 14 9 68 4 93 102 [28359.173] 0 13 14 9 68 4 93 61 [28359.173] 0 13 14 9 68 4 93 62 [28359.173] 0 26 76 27 131 2 100 56 [28359.173] 0 9 138 16 195 6 107 51 [28359.174] 0 50 200 50 2 36 114 45 [28359.174] 0 0 6 0 66 0 121 168 [28359.174] 0 0 6 0 66 0 121 193 [28359.174] 0 0 6 0 66 0 121 219 [28359.174] 0 0 6 0 66 0 121 244 [28359.175] 0 0 6 0 66 0 121 14 [28359.175] 25 0 6 0 66 0 121 75 [28359.175] 25 0 6 0 66 0 121 76 [28359.175] 0 0 6 0 66 0 121 77 [28359.175] 0 0 9 0 66 0 177 99 [28359.176] 0 0 12 0 66 0 234 121 [28359.176] 0 0 15 0 66 0 34 144 [28359.176] 0 0 19 0 67 0 91 166 [28359.176] 0 0 19 0 67 0 91 190 [28359.176] 0 0 19 0 67 0 91 214 [28359.176] 0 0 19 0 67 0 91 238 [28359.176] 0 0 19 0 67 0 91 6 [28359.176] 0 0 19 0 67 0 91 30 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 0 0 0 0 0 0 [28359.176] 0 0 0 0 0 0 0 0 [28359.176] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] =========================================== [28359.526] TEST_OK.WAV saved The outputted wave file: Here is the SAM software module to add in the MIOS32 module and the project to play with. sam.zip sam_tester.zip Next step is to make it real time. One way is to render the text first to the SD card then add a sample reader from SD card. But pitch/speed/throat and mouth parameters will not be realtime, so SAM code must be deeply changed to achive a realtime process... TODO! ;) But we can imagine a small CS to input different speeches and map them to midi events. CC for parameters etc... the dipcoreF4 has a second USB host port which supports HID keyboard, useful for fast text input. Then it can be outputted with a DAC, a SID or a TIA... But that is another story... ;)
- 1 reply
- 1
Open a new thread in user's project please, named MIDIbox SAM, a MIDI speeching box... something like that. I will share what I did in it...
I had a look on the code, it's more complicated than just add some SAM files. You will need to understand an maybe adapt/modify the necessary parts(files) and create Input/Output interfacing, check ram memory needed etc... For us it must be realtime process... But as a start: For input the easiest first way is to use MIOS-Studio Terminal for SAM commands, and output wave file to the SD card. It's not real-time but just an example. Something like that: [28337.121] SD Card status 1 [28339.122] SD Card status 3 [28339.122] SD Card CONNECTED [28342.433] help [28342.435] Welcome to the HAARP Terminal! [28342.435] Following commands are available: [28342.435] sam_usage: SAM Usage [28342.435] sam: SAM [28342.435] reset: resets the MIDIbox (!) [28342.435] help: this page [28345.225] sam_usage [28345.227] usage: sam [options] Word1 Word2 .... [28345.227] options [28345.227] -phonetic enters phonetic mode. (see below) [28345.227] -pitch number set pitch value (default=64) [28345.227] -speed number set speed value (default=72) [28345.227] -throat number set throat value (default=128) [28345.227] -mouth number set mouth value (default=128) [28345.227] -wav filename output to wav instead of libsdl [28345.228] -sing special treatment of pitch [28345.228] -debug print additional debug messages [28345.228] [28345.228] VOWELS VOICED CONSONANTS [28345.228] IY f(ee)t R red [28345.228] IH p(i)n L allow [28345.228] EH beg W away [28345.228] AE Sam W whale [28345.228] AA pot Y you [28345.228] AH b(u)dget M Sam [28345.228] AO t(al)k N man [28345.229] OH cone NX so(ng) [28345.229] UH book B bad [28345.229] UX l(oo)t D dog [28345.229] ER bird G again [28345.229] AX gall(o)n J judge [28345.229] IX dig(i)t Z zoo [28345.229] ZH plea(s)ure [28345.229] DIPHTHONGS V seven [28345.229] EY m(a)de DH (th)en [28345.230] AY h(igh) [28345.230] OY boy [28345.230] AW h(ow) UNVOICED CONSONANTS [28345.230] OW slow S Sam [28345.230] UW crew Sh fish [28345.230] F fish [28345.230] TH thin [28345.230] SPECIAL PHONEMES P poke [28345.230] UL sett(le) (=AXL) T talk [28345.230] UM astron(omy) (=AXM) K cake [28345.231] UN functi(on) (=AXN) CH speech [28345.232] Q kitt-en (glottal stop) /H a(h)ead [28359.145] sam -debug -pitch 64 -speed 128 -mouth 128 -wav TEST_OK midibox sam is great! [28359.147] text input: MIDIBOX SAM IS GREAT! [28359.147] Applying rule: [28359.147] ( [28359.147] M [28359.147] ) [28359.147] -> [28359.147] M [28359.147] [28359.147] Applying rule: [28359.147] ( [28359.147] I [28359.147] ) [28359.147] ^ [28359.148] + [28359.148] : [28359.148] # [28359.148] -> [28359.148] I [28359.148] H [28359.148] [28359.148] Applying rule: [28359.148] ( [28359.148] D [28359.148] ) [28359.148] -> [28359.148] D [28359.148] [28359.148] Applying rule: [28359.148] I [28359.148] ^ [28359.148] ( [28359.148] I [28359.148] ) [28359.148] ^ [28359.148] # [28359.148] -> [28359.148] I [28359.148] H [28359.148] [28359.148] Applying rule: [28359.148] ( [28359.148] B [28359.148] ) [28359.148] -> [28359.148] B [28359.148] [28359.148] Applying rule: [28359.148] ( [28359.148] O [28359.148] ) [28359.148] -> [28359.148] A [28359.148] A [28359.148] [28359.149] Applying rule: [28359.149] ( [28359.149] X [28359.149] ) [28359.149] -> [28359.149] K [28359.149] S [28359.149] [28359.149] Applying rule: [28359.149] ( [28359.149] S [28359.149] ) [28359.149] -> [28359.149] S [28359.149] [28359.149] Applying rule: [28359.149] ( [28359.149] A [28359.149] ) [28359.149] -> [28359.149] A [28359.149] E [28359.149] [28359.149] Applying rule: [28359.149] ( [28359.149] M [28359.149] ) [28359.149] -> [28359.149] M [28359.149] [28359.149] Applying rule: [28359.149] ( [28359.149] I [28359.149] ) [28359.149] -> [28359.149] I [28359.149] H [28359.149] [28359.149] Applying rule: [28359.149] [28359.149] : [28359.149] # [28359.149] ( [28359.149] S [28359.150] ) [28359.150] [28359.150] -> [28359.150] Z [28359.150] [28359.150] Applying rule: [28359.150] ( [28359.150] G [28359.150] R [28359.150] E [28359.150] A [28359.150] T [28359.150] ) [28359.150] -> [28359.150] G [28359.150] R [28359.150] E [28359.150] Y [28359.150] 4 [28359.150] T [28359.150] [28359.150] Applying rule: [28359.150] ( [28359.150] ! [28359.150] ) [28359.150] -> [28359.150] . [28359.150] [28359.150] phonetic input: MIHDIHBAAKS SAEM IHZ GREY4T. � [28359.150] =========================================== [28359.150] Internal Phoneme presentation: [28359.150] idx phoneme length stress [28359.150] ------------------------------ [28359.151] 0 * 0 0 [28359.151] 27 M* 0 0 [28359.151] 6 IH 0 0 [28359.151] 57 D* 0 0 [28359.151] 6 IH 0 0 [28359.151] 54 B* 0 0 [28359.151] 9 AA 0 0 [28359.151] 72 K* 0 0 [28359.151] 32 S* 0 0 [28359.151] 0 * 0 0 [28359.151] 32 S* 0 0 [28359.151] 8 AE 0 0 [28359.151] 27 M* 0 0 [28359.151] 0 * 0 0 [28359.151] 6 IH 0 0 [28359.152] 38 Z* 0 0 [28359.152] 0 * 0 0 [28359.152] 60 G* 0 0 [28359.152] 23 R* 0 0 [28359.152] 48 EY 0 4 [28359.152] 69 T* 0 0 [28359.152] 1 .* 0 0 [28359.152] 0 * 0 0 [28359.154] =========================================== [28359.154] [28359.154] Parser2 [28359.154] 0: * [28359.154] 1: M* [28359.154] 2: IH [28359.154] 3: D* [28359.154] RULE: Soften T or D following vowel or ER and preceding a pause -> DX [28359.154] 4: IH [28359.154] 5: B* [28359.154] 6: AA [28359.154] 7: K* [28359.154] RULE: K <VOWEL OR DIPTHONG NOT ENDING WITH IY> -> KX <VOWEL OR DIPTHONG NOT ENDING WITH IY> [28359.154] 8: S* [28359.154] 9: * [28359.154] 10: S* [28359.154] 11: AE [28359.154] 12: M* [28359.154] 13: * [28359.154] 14: IH [28359.154] 15: Z* [28359.154] 16: * [28359.154] 17: G* [28359.154] RULE: G <VOWEL OR DIPTHONG NOT ENDING WITH IY> -> GX <VOWEL OR DIPTHONG NOT ENDING WITH IY> [28359.154] 18: R* [28359.154] 19: EY [28359.154] RULE: insert YX following dipthong ending in IY sound [28359.154] 20: YX [28359.154] 21: T* [28359.154] 22: .* [28359.154] 23: * [28359.154] RULE: Lengthen <FRICATIVE> or <VOICED> between <VOWEL> and <PUNCTUATION> by 1.5 [28359.154] PRE [28359.154] phoneme 20 (YX) length 8 [28359.154] POST [28359.154] phoneme 20 (YX) length 13 [28359.154] RULE: Lengthen <FRICATIVE> or <VOICED> between <VOWEL> and <PUNCTUATION> by 1.5 [28359.154] PRE [28359.154] phoneme 21 (T*) length 4 [28359.154] POST [28359.154] phoneme 21 (T*) length 7 [28359.154] RULE: <VOWEL> <VOICED CONSONANT> - increase vowel by 1/2 + 1 [28359.154] PRE [28359.154] phoneme 3 (DX) length 2 [28359.154] POST [28359.154] phoneme 4 (IH) length 11 [28359.154] RULE: <VOWEL> <UNVOICED PLOSIVE> - decrease vowel by 1/8th [28359.155] PRE [28359.155] phoneme 6 (AA) length 11 [28359.155] POST [28359.155] phoneme 6 (AA) length 10 [28359.155] RULE: <VOWEL> <VOICED CONSONANT> - increase vowel by 1/2 + 1 [28359.155] PRE [28359.155] phoneme 10 (S*) length 2 [28359.155] POST [28359.155] phoneme 11 (AE) length 11 [28359.155] RULE: <VOWEL> <VOICED CONSONANT> - increase vowel by 1/2 + 1 [28359.155] PRE [28359.155] phoneme 13 ( *) length 0 [28359.155] POST [28359.155] phoneme 14 (IH) length 11 [28359.155] RULE: <LIQUID CONSONANT> <DIPTHONG> - decrease by 2 [28359.155] PRE [28359.155] phoneme 18 (R*) length 10 [28359.155] POST [28359.155] phoneme 18 (R*) length 8 [28359.156] RULE: <VOWEL> <UNVOICED PLOSIVE> - decrease vowel by 1/8th [28359.156] PRE [28359.156] phoneme 20 (YX) length 13 [28359.156] POST [28359.156] phoneme 20 (YX) length 12 [28359.156] =========================================== [28359.156] Internal Phoneme presentation: [28359.156] idx phoneme length stress [28359.156] ------------------------------ [28359.156] 0 * 0 0 [28359.156] 27 M* 7 0 [28359.156] 6 IH 8 0 [28359.156] 30 DX 2 0 [28359.156] 6 IH 11 0 [28359.156] 54 B* 6 0 [28359.157] 55 ** 1 0 [28359.157] 56 ** 2 0 [28359.157] 9 AA 10 0 [28359.157] 75 KX 6 0 [28359.157] 76 ** 1 0 [28359.157] 77 ** 4 0 [28359.157] 32 S* 2 0 [28359.157] 0 * 0 0 [28359.157] 32 S* 2 0 [28359.157] 8 AE 11 0 [28359.157] 27 M* 7 0 [28359.157] 0 * 0 0 [28359.157] 6 IH 11 0 [28359.157] 38 Z* 6 0 [28359.157] 0 * 0 0 [28359.158] 63 GX 6 0 [28359.158] 64 ** 1 0 [28359.158] 65 ** 2 0 [28359.158] 23 R* 8 5 [28359.158] 48 EY 14 4 [28359.158] 21 YX 12 4 [28359.158] 69 T* 7 0 [28359.158] 70 ** 2 0 [28359.158] 71 ** 2 0 [28359.158] 1 .* 18 0 [28359.158] 254 ?? 0 [28359.158] 0 * 0 0 [28359.158] =========================================== [28359.158] [28359.159] =========================================== [28359.159] Final data for speech output: [28359.159] flags ampl1 freq1 ampl2 freq2 ampl3 freq3 pitch [28359.159] ------------------------------------------------ [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.160] 0 9 6 2 46 0 81 61 [28359.160] 0 9 10 4 59 2 87 59 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 23 96 23 151 29 102 16 [28359.160] 0 44 179 6 230 6 111 231 [28359.161] 0 0 6 0 54 0 121 61 [28359.161] 0 2 8 2 60 2 197 60 [28359.161] 0 4 11 4 66 2 17 59 [28359.161] 0 11 14 8 72 4 93 57 [28359.161] 0 11 14 8 72 4 93 57 [28359.161] 0 11 14 8 72 4 93 57 [28359.161] 0 11 14 8 72 4 93 57 [28359.162] 0 11 14 8 72 4 93 57 [28359.162] 0 11 14 8 72 4 93 57 [28359.162] 0 11 14 8 72 4 93 57 [28359.162] 0 11 14 8 72 4 93 57 [28359.162] 0 26 76 29 124 2 154 26 [28359.162] 0 9 138 14 177 6 215 251 [28359.162] 0 36 200 30 229 36 20 220 [28359.162] 0 2 6 0 26 0 81 61 [28359.162] 0 2 6 0 26 0 81 61 [28359.162] 0 2 6 0 26 0 81 61 [28359.162] 0 2 6 0 26 0 81 61 [28359.162] 0 2 6 1 26 0 81 61 [28359.162] 0 0 6 0 26 0 81 61 [28359.162] 0 0 6 0 26 0 81 61 [28359.163] 0 3 12 2 30 0 83 58 [28359.163] 0 6 19 4 35 0 86 55 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 20 65 30 47 8 89 32 [28359.164] 0 23 104 23 54 23 90 12 [28359.164] 0 9 144 16 62 17 91 248 [28359.164] 0 44 183 44 69 10 92 229 [28359.164] 0 51 222 51 76 73 93 209 [28359.164] 0 0 6 0 84 0 94 61 [28359.164] 0 0 6 0 84 0 94 61 [28359.164] 0 0 6 0 84 0 94 61 [28359.164] 0 0 6 6 84 3 94 61 [28359.164] 0 0 6 0 84 0 94 61 [28359.165] 0 0 6 0 84 0 94 61 [28359.165] 0 0 6 0 84 0 94 61 [28359.165] 0 0 6 0 133 0 95 61 [28359.165] 241 0 6 0 182 0 96 61 [28359.165] 241 0 6 0 231 0 97 61 [28359.165] 241 0 6 0 24 0 98 61 [28359.165] 241 0 6 0 73 0 99 61 [28359.166] 0 2 10 2 134 2 160 59 [28359.166] 0 4 15 4 195 2 221 57 [28359.166] 0 8 19 6 0 3 26 55 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.167] 0 15 24 13 62 4 88 52 [28359.167] 0 6 143 10 182 6 212 249 [28359.167] 0 9 6 2 46 0 81 61 [28359.167] 0 9 6 2 46 0 81 61 [28359.167] 0 9 6 2 46 0 81 61 [28359.167] 0 9 6 2 46 0 81 61 [28359.167] 0 9 6 2 46 0 81 61 [28359.168] 0 9 6 2 46 0 81 61 [28359.168] 0 9 10 4 59 2 87 59 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 29 64 23 119 20 93 32 [28359.169] 0 18 114 20 166 26 93 7 [28359.169] 1 6 164 6 213 6 93 238 [28359.169] 1 66 214 73 4 86 93 213 [28359.169] 1 8 9 2 51 0 93 60 [28359.169] 1 8 9 2 51 0 93 60 [28359.169] 1 8 9 2 51 0 93 60 [28359.169] 1 29 72 2 59 0 93 28 [28359.169] 0 16 135 6 67 0 93 253 [28359.169] 0 50 198 48 75 0 93 221 [28359.169] 0 1 6 0 84 0 94 61 [28359.170] 0 1 6 0 84 0 94 61 [28359.170] 0 1 6 0 84 0 94 61 [28359.170] 0 1 6 0 84 0 94 61 [28359.170] 0 2 6 1 84 0 94 61 [28359.170] 0 0 6 0 84 0 94 61 [28359.170] 0 0 6 0 84 0 94 61 [28359.170] 0 2 9 2 139 1 149 109 [28359.170] 0 3 12 3 195 2 205 157 [28359.170] 0 5 15 4 250 2 4 206 [28359.170] 0 9 18 6 50 3 60 254 [28359.171] 0 9 18 6 50 3 60 48 [28359.171] 0 9 18 6 50 3 60 48 [28359.171] 0 9 18 6 50 3 60 48 [28359.171] 0 9 18 6 54 3 66 70 [28359.171] 0 9 18 8 58 3 72 93 [28359.171] 0 11 18 9 63 4 78 116 [28359.171] 0 11 18 11 67 4 84 139 [28359.171] 0 13 18 13 72 5 90 162 [28359.171] 0 13 18 13 72 5 90 184 [28359.171] 0 13 18 13 72 5 90 207 [28359.172] 0 13 18 13 72 5 90 230 [28359.172] 0 13 18 13 72 5 90 253 [28359.172] 0 13 18 13 72 5 90 20 [28359.172] 0 13 18 13 72 5 90 45 [28359.172] 0 13 18 13 72 5 90 46 [28359.172] 0 13 49 8 103 10 90 35 [28359.172] 0 13 81 26 135 29 90 24 [28359.172] 0 13 112 16 166 18 91 12 [28359.172] 0 13 144 6 198 10 91 1 [28359.172] 0 13 175 6 229 6 91 246 [28359.173] 0 13 207 46 5 24 92 235 [28359.173] 0 13 238 66 36 26 92 223 [28359.173] 0 13 14 9 68 4 93 84 [28359.173] 0 13 14 9 68 4 93 88 [28359.173] 0 13 14 9 68 4 93 93 [28359.173] 0 13 14 9 68 4 93 97 [28359.173] 0 13 14 9 68 4 93 102 [28359.173] 0 13 14 9 68 4 93 61 [28359.173] 0 13 14 9 68 4 93 62 [28359.173] 0 26 76 27 131 2 100 56 [28359.173] 0 9 138 16 195 6 107 51 [28359.174] 0 50 200 50 2 36 114 45 [28359.174] 0 0 6 0 66 0 121 168 [28359.174] 0 0 6 0 66 0 121 193 [28359.174] 0 0 6 0 66 0 121 219 [28359.174] 0 0 6 0 66 0 121 244 [28359.175] 0 0 6 0 66 0 121 14 [28359.175] 25 0 6 0 66 0 121 75 [28359.175] 25 0 6 0 66 0 121 76 [28359.175] 0 0 6 0 66 0 121 77 [28359.175] 0 0 9 0 66 0 177 99 [28359.176] 0 0 12 0 66 0 234 121 [28359.176] 0 0 15 0 66 0 34 144 [28359.176] 0 0 19 0 67 0 91 166 [28359.176] 0 0 19 0 67 0 91 190 [28359.176] 0 0 19 0 67 0 91 214 [28359.176] 0 0 19 0 67 0 91 238 [28359.176] 0 0 19 0 67 0 91 6 [28359.176] 0 0 19 0 67 0 91 30 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 0 0 0 0 0 0 [28359.176] 0 0 0 0 0 0 0 0 [28359.176] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] =========================================== [28359.526] TEST_OK.WAV saved
SAM is an independant program, no need of a SID, the SID was used on C64 as DAC. But it was working on Apple, Atari etc... But good news it's a C source code you can embed onto a MIDIbox Core, you just need a DAC, an audio output.
