Shiftone
    39
Everything posted by Shiftone
  1. DM'd for PCBs. Any news on sammichFM? Would you sell these as kits? I like building.
  2. Thinking about selling my beloved sammichSID to fun a new midibox build. It's an original Wilba kit built by me. Come with a PSU that should be good world wide - you'll just need a figure 8 power cable. The unit is in perfect working order and has been used by me faultlessly for several years now. Image gallery - (Detail photos - insulating tape on back of CS is to stop the heatsink below shorting. Right side panel arrived cracked and was subsequently glued. Had to reflow the stack connectors and the board overheated a little.) https://imgur.com/gallery/vWK5SQM Video of it running https://www.youtube.com/watch?v=H9Bd33Bptyc £280 plus shipping (add 3.5% if paying by PayPal goods and services - no charge for paypal gift or bank transfer) Ask me for a shipping quote.
  3. Doesn't matter what velocity I get out of the hardware keyboard, I've had over 100 out of it in the MIDI monitor by playing the keys harder. Testing on the init patch. More info. I fired up Ableton Live and mapped MIDI channel 1 as an external instrument. The hardware keyboard is now triggering the Sammich. In the MIDI monitor window the note message is the same as when Ableton isn't running... Still can't understand why the hardware keyboard won't just trigger the synth on its own.
  4. ..and installed a software MIDI keyboard - set it to MIDI Out on the Photon X25 and it triggers the Sammich... It's crazy, I can watch the Soft keyboard send a C3 note message on MIDI Ch1 and the Sammich triggers. I press C3 on the physical keyboard and nothing - but I see the note on Ch1 in my monitor wtf. 22:58:46.101 From PhotonX25 Note On 1 C3 48 22:58:46.194 From PhotonX25 Note Off 1 C3 0 22:58:57.528 From VMPK Output Note On 1 C3 100 22:58:57.614 From VMPK Output Note Off 1 C3 100
  5. The plot thickens... Installed MIOS Studio to make sure the MIDI interface could connect to the core and it works fine. I can also trigger notes using the MIOS Studio virtual keyboard... still no notes being triggered by the hardware keyboard.
  6. Can anyone help me work out why my MIDI Keyboard isn't playing nicely with my sammichSID? I'm using an Alesis Photon X25 USB MIDI Keyboard - and I've had it work with my Sammich in the past just fine. It's been a looooong time since I last tinkered with the Sammich and now I can't get it working. I can get the Sammich into SIDPlayer mode using the Photon X25 interface just fine - so I know the MIDI interface is working and can talk to the Sammich. As soon as I drop out of SIDPlayer mode I get nothing. Playing the keys does not trigger the Sammich. I've checked that I'm sending on Ch1 and that my Sammich is defaulting to Ch1 - I can see the note on/off commands flowing in MIDI Monitor. Not really sure what to check next to try and troubleshoot...?
  7. Thread necromancy I know but I just built this and it's working fine. Just thought I'd mention that the SIDPLAY won't start if my MIDI interface is connected to my MBP. I have to start SIDPLAY and then connect the interface (MIDISport 2x2 but same behaviour with my generic China 1x1 interface).
  8. How are the pre-orders going? I just signed up for one more - loved building my last one.
  9. Yeah, my name's on the list but keen to pick one up as soon as possible.
  10. After a sammichFM kit if anyone has one they don't think they will get round to building. Prefer un-touched kit but if you have a part built or even built - I'd consider it.
  11. Would you sell the 2 boards only? If so, I'm interested.
  12. Drop Jason (Wilba) an email - I was in a similar situation and he said he might be able to dig a spare out for me. Happy that I could get a spare if I needed it, I went ahead and hit mine with the hot air station. Turns out I've managed to fix my CS so I won't need a spare from Wilba now. ....or DIY it
  13. Hi guys, please add me to the sammichFM list please.
  14. I'm going to say Sammich lives! Turns out to have been a few issues compounding into one wonky Sammich. Bank sticks issue - I'm fairly sure this was PSU related. I've moved to a 2A 12v switching supply that I used for a Tripath amp previously. I'll look for a better quality linear (or build my own). CS and LED issues - putting this down to poor solder work. When I built this box 3 years ago, it was about my 3rd ever proper project and I was using lead free process with a 300 degree C tip and cheapo Chinese fake flux. I ended up using a heat gun to pull the resistor network below the first CS register, cleaned up the pads and resoldered. After this work the bottom left switch was acting up causing all kinds of CS weirdness (gently tapping it made the issue occur). Heat gun removed and resoldered the switch. Reflowed most of the board with the heat gun and my soldering iron (mine is now a toasted Sammich ;) ) After that - Sammich played nice for the rest of the evening - both in Sidplayer mode and synthesis. Thanks for all your help and moral support. I can now haz Sammich.
  15. LCD is fine if removed from the CS - so yeah - CS issue. If I pull both CS ICs - problem disappears - but obviously CS is now not working. If I put the left hand IC back in the error returns - so where ever the issue is - it is connected to that first logic chip.
  16. Another quick question; Are J6 and J7 on the base PCB and J2 on the CS PCB the same as J8 and J9 and J1? Can I solder some header on there and use some flex cable to connect the 2 while I troubleshoot?
  17. Ok, some progress. I have managed to update to MIOS 1.9h and midibox_sid_v2_044 using my old Alesis Photon X25 on my Macbook Pro. I have also successfully uploaded the default patches using the SysEx tool in MIOS Studio. So the bank chips are working and the PIC is doing what it should. Haven't seen the formatting bank sticks error for a few hours now. I do however have some weird intermittent issues with the CS. LEDs sometime just plain don't work - sometimes the innermost 3 LEDs on each side are on from power on, sometimes they work fine. The LCD usually flicks over to a page that says - ENV Dep Del At1 ALv If i tap the MENU button repeatedly I can make it go back to the patch selection screen momentarily (usually long enough to scroll through a couple of patches) Patches load and the Sammich is making the right noises - just the CS issue to resolve I think.
  18. I've got various other 12v PSU to hand - I've tried a 2 amp switchmode and big 12.5a switching that I bought for a 6 channel Tripath amp project. More weirdness - the bank sticks have stopped looping round. But the CS goes straight to the ENV Dep Del At1 ALv screen and the LEDs aren't flashing like they used to...? My MIDI interface in MIOS Studio is spitting out f0 00 00 7e 40 01 f7 in the MIDI IN windows when I power cycle.
  19. Epic thread resurrection.... Anyone care to have a look back over this thread and try to help again? This Sammich got thrown into its box and chucked in a dusty corner for the last 3 years. Never managed to progress. Well today I dug it out after feeling like the Gods of semiconductiors were smiling on me after restoring my Quad 303 amplifiers. I have to say this thing has got me totally baffled. For the first 20 minutes or so of playing around with it - the constantly formatting bank sticks were nowhere to be seen. The Sammich even responded to MIDI IN signals coming from my PC via a cheapo generic eBay special USB-MIDI cable and played notes using the default patch. So I'm fiddling around trying to get the default patches uploaded but I can't seem to get MBSIDV2_Editor_v0_5 to transmit anything successfully. The unit has an old version of the software installed (midibox_sid_v2_041 & MIOS 1.9g) so I thought I'd try and get midibox_sid_v2_044 to install. Try as I might, I couldn't get MIOS Studio to catch an upload request. Round about now (20 minutes or so in to my fiddling) the bank sticks started formatting. And now we are back to turn on, bank sticks format - sometimes one bank after another, sometimes one repeatedly, sometimes returning back to the default Pinit Lead patch screen for a few seconds before starting all over again. Sometime it says formatting 64k sometime 32k. https://www.youtube.com/embed/ou_HhTcUBUI Things I've tried; Pulling the CS altogether - I can still hear the bank sticks formatting and the LEDs flashing. Pulling the opto - same Pulling the 8 bit registers and the sides - same Leave just one bank stick - same Pulling all the banks - obviously no more formatting the bank sticks now Other things I've noticed; If I play a few notes quickly one after another I end up with no more sound. Power cycle brings it back. Sometime while formatting the bank sticks I get the odd higher tone that the standard beeps. Sometimes the LEDs freakout while format looping - usually they flash in a cross pattern but sometimes I'll end up with a line of four just on. So what to do now? Replace the Optocoupler? Replace the bank sticks? Replace the PIC? Has the PIC been bad flashed at some point - I remember having a bit of a nightmare getting it to flash 3 years ago and only succeeded in Linux in the end. I've double and triple checked the components are in their right places - all the solder joints have been reflowed with a good solder station (Metcal sp-200) Is something overheating as their are odd intermittent occurrences. Can you help? I'm UK based in Cornwall - if you think you could send me a programmed PIC to swap test please let me know or if you are not a million miles away and have a known good MIDI interface we can try let me know or if you have any other good ideas as to how I can get this Sammich singing nicely - let me know
  20. I'm using the interface that is built into my Alesis Photon X25 Controller Keyboard and have tried both under Windows 7 x64 and Linux (Ubuntu 12.10)
  21. This has really go me baffled... so I pick up the sammich after leaving it alone for the night - plug it in with audio out connected to my amp but no MIDI cables connected. The box boots fine and plays the start up sound (still only one channel though So I power cycle a few times - and each time boots fine and sound out of one channel. Things start to go down hill when I plug the MIDI cables in - first problem, the start up sound turns back into puffs of white noise... I connect to mios studio and re-upload the software. The upload appears to complete successfully. Over then next handful of power cycles I experience the following problems; puffs of white noise oddness in the CS LCD menus - Like page changes without me pressing any buttons... mios spontaneously rebooting and then finally problems getting the midi interface to behave and be recognised in mios studio... I'm fairly sure if I leave it alone for a couple of hours I'll be able to rinse repeat this whole affair... I wonder if my MIDI interface is the flaky thing and the software is not being uploaded properly? Or if I have a flaky octocoupler?
  22. Incoming massive pictures I know that solder in the middle of the PIC looks aweful (I'm embarrassed of it) but it is making good contact and not shorting the pin next to it. I really should have used some leaded solder for this build - hate lead free I just managed to get it to start up all the way to the default patch and the CS was responding as expected (with SIDs installed). I hooked up the audio and power cycled - again started fine and I got the test tones out of the left SID but nothing out of the right (these SIDs are verified in a working C64) After a little more testing (left right swapping) I still didn't get anything out of the right hand SID and the test tones have now turned into some puffs of white noise... In an effort to see how much more I could break it - I powered off and inserted the MIDI cables (but did not connect the other ends to anything). Next start up things are getting decidedly worse - we're back to hanging at the bootloader or blank screen after the dancing LEDs.
  23. Nope - no lift off. So after the SIDs went in (8580R5x2) the Sammich would power up and report the MIOS version - flash the lights then the screen clears and nothing - Launching CS does not appear. So I removed the SIDs and back up a step - but I am back to encountering strange corruption on the LCD (not as bad as before). The odd thing is, if I lift the PIC and go make a cup of tea - come back drop it back in I can generally get the CS to launch. It invariably gets worse with each successive power cycle and I have not yet managed to get it to work with SIDs in. Is it possible I have a flaky PIC? I've been back over the boards with a meter and voltages are spot on - not visible problems with shorts or bad joints.
  24. Update - got frustrated with it after reflowing the entire base board and still having the same issue and creating an entirely new issue - screen corruption! Decided the best course of action was to box it and let both myself and my Metcal cool off for a few days. In the interim my proper 12v regulated 500ma power supply has arrived. So I put my Sammich back together and added the banksticks - plugged in the new PSU and everything just worked - banks all formatted no issues at all. Moral of the story - stop using naff switching psus to test after initial voltage checks. I'll pop in some SIDs now and see if we truly have liftoff.
  25. It will go from Bank A to B to C back to A to D sometimes to ensemble - occasionally it gets back to the initial CS screen and then in a matter of seconds starts again... In other news... I just reflashed the sammich hex and now its stopped endless formatting... but doesn't see any bank sticks at all... no other changes were made, just re-flashing.
