stryd_one Posted February 29, 2008 Report Posted February 29, 2008 I'll take 4. Wait, this isn't one of those threads is it...
syamajala Posted March 2, 2008 Author Report Posted March 2, 2008 I ordered the rest of the parts for the cs, power supply, and second opl3 board. All I need now is a case.
syamajala Posted March 6, 2008 Author Report Posted March 6, 2008 I got the rest of the parts today, so hopefully by the end of the weekend I will have a working fm. I don't know about the cs though.
syamajala Posted March 30, 2008 Author Report Posted March 30, 2008 ok, so worked on my fm stalled for a while, because my grandfather passed away. However, I had a bit of time to work on it this weekend and i finished the power supply. So, if i connect the opl3 module to the core i should be able to test it out.
Smithy Posted March 30, 2008 Report Posted March 30, 2008 ok, so worked on my fm stalled for a while, because my grandfather passed away. However, I had a bit of time to work on it this weekend and i finished the power supply. So, if i connect the opl3 module to the core i should be able to test it out. Sorry to hear about your loss. Good to see you making lots of progress man,your work will be really helpful when newbs like me try to start one.
stryd_one Posted April 4, 2008 Report Posted April 4, 2008 Condolences mate. I hope the midibox helps cheer you up.
syamajala Posted April 20, 2008 Author Report Posted April 20, 2008 Hey guys! Its been a while since I have posted an update, anyway I just pulled out my mb stuff, and I hooked up the power supply and checked all the voltages. Everything seems to be good!!!! The opl3 board is getting the +5v, -12v, and +12v. I checked the voltages at the sockets for tl074s everything is good. Also checked the voltages for the core at pins listed on ucapps, and everything is fine there. So, I guess I need to put the pic in, the tl074s, and the optocoupler. Then figure out where to go from there.
syamajala Posted April 21, 2008 Author Report Posted April 21, 2008 ok, so there is something wrong with my core. I installed mios studio and midi-ox. I'm using an m-audio midisport 1x1. I don't seem to get a sysex upload request. Maybe I should check all the voltages again. Everything seemed fine before I put the pic in though.
nILS Posted April 21, 2008 Report Posted April 21, 2008 * Where did you get the PIC?* Are you sure it's got the bootloader/MIOS on it?
syamajala Posted April 21, 2008 Author Report Posted April 21, 2008 I got it from Smashtv. The sticker on the pic says bsl v1.2b mios v1.9f.
stryd_one Posted April 22, 2008 Report Posted April 22, 2008 Done the midi troubleshooting guide yet? Can you paste the results?(I think there should be a big flashing banner at the top of this page that links to that page heheheh)
syamajala Posted April 22, 2008 Author Report Posted April 22, 2008 I think I know what I did wrong. I connected the pic to the wrong 5v on the power supply. core voltages at pic:1 - 3.18v11 - 3.18v20 - 3.17v25 - .85v26 - 3.1v32 - 3.13vmidi out - .92v8 - 3.16v
syamajala Posted April 22, 2008 Author Report Posted April 22, 2008 ok, now i get sysex messages in mios studio. I uploaded the test tone, but don't seem to hear anything. I didn't connect a bank stick yet. Maybe I should do that.
syamajala Posted April 22, 2008 Author Report Posted April 22, 2008 never mind. It was the volume on the amp I'm using. ;-D So, now its time to figure out how to use jsynthlib.
syamajala Posted April 23, 2008 Author Report Posted April 23, 2008 I don't think all the channels are working. It appears as though only 2 of them are. But that is just with the test tone app. I still can't figure out how to use jsynthlib. I downloaded the preset patches from ucapps and sent one to the fm, but when I try to play it nothing seems to happen. Is there a guide on how to use jsynthlib?
nILS Posted April 24, 2008 Report Posted April 24, 2008 I found Serge's Sysex Loader (linked on ucapps) to be easier to use if you only want to upload/download patches. Try that one :-)
syamajala Posted April 24, 2008 Author Report Posted April 24, 2008 i just wanna make sure, but is this what the test tone is supposed to sound like? http://genesis.blogdns.net/testtone.mp3
Sasha Posted April 24, 2008 Report Posted April 24, 2008 I never built one but that don`t sounds healthy to me. :-\
syamajala Posted April 24, 2008 Author Report Posted April 24, 2008 maybe its my opl3. i know all the voltages are correct.
syamajala Posted April 25, 2008 Author Report Posted April 25, 2008 I'm having a weird problem. I hooked up a lcd to my core and its working, but the 7812 in my power supply is getting really hot. I have a heatsink on it. I also noticed that the output of the opl3 module is really loud when I hook up the lcd. After I hooked it up I loaded the test app again and couldn't hear anything, but on the lcd it said test tone generator. I also loaded the fm app and could see it changing patches when I was playing with jsynthlib, but I still couldn't hear anything. Is the lcd drawing too much current and causing the 7812 to heat up and cause the other problems? Also does anyone know if that recording is what the test tone app is supposed to sound like?
offe Posted April 25, 2008 Report Posted April 25, 2008 Something is definately wrong here. The test tone should be 1khz and played on all four channels. My MBFM is in my workshop and I'm going away for vacation for a week so I can't record the test tune, but tyr google for 1khz test tune and you will know what it'll sound like. Have you checked, double checked and tripple checked every connection between the core->opl3 module->psu against the wiring diagrams? Have you checked for any soldering problems on the opl3 board? /offe
stryd_one Posted April 26, 2008 Report Posted April 26, 2008 the 7812 should only be powering the audio circuits which should draw...next to nothing. There's definitely a short there. Maybe inside a busted OPL, but that's not right. i know all the voltages are correct.How?
syamajala Posted April 26, 2008 Author Report Posted April 26, 2008 the 7812 is only getting hot when the lcd is connected. If I disconnect it, its fine. I checked all the voltages with my multimeter after I connected the core to the right +5v. I'm using the bipolar power supply found here http://www.midibox.org/dokuwiki/northernlightx I had originally connected my core to jp6, but then I realized i'm supposed to connect it to jp5. I'll worry about the lcd problem later I guess I should first try another opl3. I think one of the yac512s might also be burnt out, because only 2 channels are working.
stryd_one Posted April 26, 2008 Report Posted April 26, 2008 I'll worry about the lcd problem later I guess I should first try another opl3. I think one of the yac512s might also be burnt out, because only 2 channels are working.Although I think you may be right, that might not be the best way to find out. At this point, you should really disconnect all the peripheral boards (like the OPL3 module) and just work on the core.The 7812 should have nothing to do with the core at all, it's only for the audio circuitry on the OPL3 board, so I don't understand why the LCD would effect it. I suspect you have a short circuit somewhere.Trying another set of FM chips might help, it might also blow them up as well. Fix the core first. (see my signature - one at a time)
syamajala Posted April 26, 2008 Author Report Posted April 26, 2008 after disconnecting the opl3 module from the core, and connecting only the lcd to the 7812, its still heating up a lot. I'm still getting stuff on the lcd though.
