cimo Posted October 3, 2008 Posted October 3, 2008 hii have a Yamaha RM1X with some bad buttons, i thought i could try to clean them up with some special spray or likesuchas but they look rather "sealed", it would probably be better to change all of them, can anybody point me to right direction to get some replacement?They hace a "gummy" top and a black body and a silent/soft feeling or maybe a "soft/silent/clicky" feeling as they click but with a padded feedbackthe picture is quite bad but i only have a web camera at the moment..thankssimone
stryd_one Posted October 4, 2008 Posted October 4, 2008 Don't suppose you asked yamaha and your local repair shop? They should be able to get these for you.
Artesia Posted October 4, 2008 Posted October 4, 2008 couldnt see too well form that photo; so took a rm1x appart which i have here.they are absolutely standard microswitches (with the exception of the rubber tactile motion) used in everything; cheap as chips.. look up your local big supplier and theyll carry something suitable.try these maybe:http://uk.farnell.com/1555982/switches-relays/product.us0?sku=tyco-electronics-fsm4jhManufacturer: TYCO ELECTRONICSOrder Code: 1555982Manufacturer Part No: FSM4JH
cimo Posted October 4, 2008 Author Posted October 4, 2008 hola@Artesia: these buttons are 8mm and not 6mm so they wouldn t fit the fooprint, also they have a soft feeling which i would like to keep, if possible and the pins pitch is 4mm (or something like that)@Stryd: i ve sent a mail to a repair shop in Barcelona, waiting for response..FInding the service manual would be great
Doug Wellington Posted October 4, 2008 Posted October 4, 2008 Yamaha is very good about service manuals - I have manuals for almost every piece of gear I own. Let me know if you can't get one locally and I'll order one for you...
cimo Posted October 4, 2008 Author Posted October 4, 2008 ;D ;D ;D ;D ;D ;D ;D ;D ;Dhttp://parts.digikey.com/1/parts/979045-switch-tact-soft-touch-120gf-tl9000f120qg.htmlEDIT: Farnel stocks them but with an additional fee to ship to Europe, i can try to ask for samples directly from E-switchEDIT2: E-switches ships samples only to USA and JapanDigiKey ships to Europe for a reasonable price of 90 $ (my bad they also ship for 18$, maybe)
stryd_one Posted October 5, 2008 Posted October 5, 2008 Interesting part :) Makes me wonder if there are some nice actuators for them!Did you try your local distributor for samples?
cimo Posted October 5, 2008 Author Posted October 5, 2008 Interesting part :) Makes me wonder if there are some nice actuators for them!yep, the feeling is the same as you ve described for the soft MEC
Artesia Posted October 5, 2008 Posted October 5, 2008 good work, a little more thorough than i could be asked with sometimes :)unfortunately the actuators are almost always a custom part designed by the company to fit the design & ordered in a silly quantity from a plastic fab.let us know if you find some tho :)
Smithy Posted October 6, 2008 Posted October 6, 2008 OOoooooooooooo! :oA soft touch tactile switch! Whatever will they think of next!
reboot Posted October 6, 2008 Posted October 6, 2008 that's it and cheap ...partspipe again ...10$ for 50http://cgi.ebay.fr/PKG50-Tactile-Push-Momentary-SPST-Off-On-Switch-TMS_W0QQitemZ300256417000QQihZ020QQcategoryZ47076QQcmdZViewItemQQ_trksidZp1742.m153.l1262f6a2_1.JPGf6a2_1.JPG
Smithy Posted October 6, 2008 Posted October 6, 2008 that's it and cheap ...partspipe again ...10$ for 50http://cgi.ebay.fr/PKG50-Tactile-Push-Momentary-SPST-Off-On-Switch-TMS_W0QQitemZ300256417000QQihZ020QQcategoryZ47076QQcmdZViewItemQQ_trksidZp1742.m153.l1262Speaking of partspipe, did a search for Dual Gang 100K pots today on ebay, and they were the only seller that came up for them.Handy to know for MB-Sid feedback.
cimo Posted October 6, 2008 Author Posted October 6, 2008 that's it and cheap ...partspipe again ...10$ for 50http://cgi.ebay.fr/PKG50-Tactile-Push-Momentary-SPST-Off-On-Switch-TMS_W0QQitemZ300256417000QQihZ020QQcategoryZ47076QQcmdZViewItemQQ_trksidZp1742.m153.l1262these are 13mmx13mm, the ones i need are 8mmx8mmthanks anyway,,
sneakthief Posted October 8, 2008 Posted October 8, 2008 Two options:1. Cleaning the buttons:- open the rm1x (but be careful with the flat ribbon cable that goes to the LCD - don't touch this!!!!)- very gently snap off the white and black molded plastic keys- take a blunt pointy object and VERY VERY VERY gently push the rubber membrane of each of the main pattern/note buttons to one side. the point is to be able to get inside the button assembly and scrub it with contact cleaner on the tip of a q-tip or something like that. you may even want to gently scrape the oxidization off the metal contact on the bottom of the button.- carefully, patiently, slowly tuck the rubber membrame of each button back under the bezel of the housing. this takes time and practice. if you rip the rubber membrane, you're screwed.2. Replacing the buttons:- if you're handy with a soldering iron, then just order new buttons:The digikey part # is:KSI0M011-NDthe manufacturer part #is:KSI0M011from ITT/Cannon
cimo Posted October 8, 2008 Author Posted October 8, 2008 - carefully, patiently, slowlyme? :)anyway i have here in front of me a desoldered button and although it is possible to pull off the gray rubber, it is impossible to put it back again, you probably need a spacial tool.The digikey part # is:KSI0M011-NDthe manufacturer part #is:KSI0M011from ITT/CannonNO, this is not the proper replacement part, the right Digikey part is:EG4346-NDthe E-switch part number is:TL9000F120QGand in the service manula yo ucan find the part number from Yamaha:SKEYAG
sneakthief Posted October 8, 2008 Posted October 8, 2008 cimo - ok, i was told that by somebody who replaced their switches with those ITT. btw, it's not impossible to put the rubber back in. i've done this procedure to my rm1x and my rs7000's.
cimo Posted October 8, 2008 Author Posted October 8, 2008 I ve ordered some new buttons but i d like to know the tool you ve used to put the rubber back, maybe i can save some of them for the future..
Goblinz Posted October 8, 2008 Posted October 8, 2008 I ve ordered some new buttons but i d like to know the tool you ve used to put the rubber back, maybe i can save some of them for the future..Perhaps a needle and lots of patience!
