hi
i have a Yamaha RM1X with some bad buttons, i thought i could try to clean them up with some special spray or likesuchas but they look rather "sealed", it would probably be better to change all of them, can anybody point me to right direction to get some replacement?
They hace a "gummy" top and a black body and a silent/soft feeling or maybe a "soft/silent/clicky" feeling as they click but with a padded feedback
the picture is quite bad but i only have a web camera at the moment..
thanks
simone
couldnt see too well form that photo; so took a rm1x appart which i have here.
they are absolutely standard microswitches (with the exception of the rubber tactile motion) used in everything; cheap as chips.. look up your local big supplier and theyll carry something suitable.
try these maybe:
http://uk.farnell.com/1555982/switches-relays/product.us0?sku=tyco-electronics-fsm4jh
Manufacturer: TYCO ELECTRONICS
Order Code: 1555982
Manufacturer Part No: FSM4JH
hola
@Artesia: these buttons are 8mm and not 6mm so they wouldn t fit the fooprint, also they have a soft feeling which i would like to keep, if possible and the pins pitch is 4mm (or  something like that)
@Stryd: i ve sent a mail to a repair shop in Barcelona, waiting for response..
FInding the service manual would be great
Interesting part :) Makes me wonder if there are some nice actuators for them!
Did you try your local distributor for samples?
yep, the feeling is the same as you ve described for the soft MEC
good work, a little more thorough than i could be asked with sometimes :)
unfortunately the actuators are almost always a custom part designed by the company to fit the design & ordered in a silly quantity from a plastic fab.
let us know if you find some tho :)
Two options:
1. Cleaning the buttons:
- open the rm1x (but be careful with the flat ribbon cable that goes to the LCD - don't touch this!!!!)
- very gently snap off the white and black molded plastic keys
- take a blunt pointy object and VERY VERY VERY gently push the rubber membrane of each of the main pattern/note buttons to one side. the point is to be able to get inside the button assembly and scrub it with contact cleaner on the tip of a q-tip or something like that. you may even want to gently scrape the oxidization off the metal contact on the bottom of the button.
- carefully, patiently, slowly tuck the rubber membrame of each button back under the bezel of the housing. this takes time and practice. if you rip the rubber membrane, you're screwed.
2. Replacing the buttons:
- if you're handy with a soldering iron, then just order new buttons:
The digikey part # is:
KSI0M011-ND
the manufacturer part #is:
KSI0M011
from ITT/Cannon
me?  :)
anyway i have here in front of me a desoldered button and although it is possible to pull off the gray rubber, it is impossible to put it back again, you probably need a spacial tool.
KSI0M011-ND
KSI0M011
from ITT/Cannon
NO, this is not the proper replacement part, the right Digikey part is:
EG4346-ND
the E-switch part number is:
TL9000F120QG
and in the service manula yo ucan find the part number from Yamaha:
SKEYAG
cimo - ok, i was told that by somebody who replaced their switches with those ITT.
btw, it's not impossible to put the rubber back in. i've done this procedure to my rm1x and my rs7000's.
I ve ordered some new buttons but i d like to know the tool you ve used to put the rubber back, maybe i can save some of them for the future..
Perhaps a needle and lots of patience!
