TK. Posted December 20, 2008 Posted December 20, 2008 ...is now available for download: http://www.ucapps.de/mios_download.htmlMost of the requested features of the last months (but also my private wishes) have been implemented (hope that the guys are still reading this forum )-> http://www.ucapps.de/midibox_seq_changelog.htmlThe remaining feature requests can be found at the bottom of CHANGELOG.txtBest Regards, Thorsten./Edit: uploaded v3_4 again due to another improvement for the MENU button function
stuartm Posted December 20, 2008 Posted December 20, 2008 the official version Ahh, at last !Thanks TK, great to see my sync idea made it's way into the new version!I'll try it out as soon as I can, I'm also planning to make a new video with that sync function.the true versionTK, your timing could be improved! I've just packed my stuff and unplugged my gear to leave for the holidays and had a last web check,saw your announcement and went "noooo" so I'll have to wait till the next year to test the new version. ;)But nevermind, just strange coincidence, raises the excitement :DGreat work!
stryd_one Posted December 21, 2008 Posted December 21, 2008 [quote name=stuartm link=topic=12668.msg106633#msg106633 the true versionTK, your timing could be improved! ...so I'll have to wait till the next year to test the new version. ;)
TK. Posted December 21, 2008 Author Posted December 21, 2008 so I'll have to wait till the next year to test the new version. ;)But nevermind, just strange coincidence, raises the excitement :DSongs created after a break are mostly the best - have a nice vacation! :)Best Regards, Thorsten.
TK. Posted December 22, 2008 Author Posted December 22, 2008 During a play session I noticed, that F1 button behaviour is currently inconsistent to the overworked F3/F4.Questions to users: would it be ok for you if F1 button behaves like the new F3/F4 button function in future: Utility page only visible so long F1 button pressed, and jump back to previous page when F1 button is released?Or is it important for you, that only one finger (instead of two) is required to select a utility function?Best Regards, Thorsten.
bosone Posted December 22, 2008 Posted December 22, 2008 according to me is better how it behaves now. when you press the utility button you got a lot of different function for almost all of the 16 GP buttons, and pressing 2 of them simultaneusly could not be so confortable, because for some function you would need both hands.this is one of the most useful buttons because gives access to the most used functions, and maybe you just press the button, then think... hmmm should i move the step, or the whole track? wait a minute, i just save the pattern before making variations... what about some realtime recording instead? so: seeing all the commands at once without keeping the finger on the seq could be better... (IMHO)
swindus Posted January 5, 2009 Posted January 5, 2009 There is still a problem with the bank/pattern selection in song/phrase mode. The value for group 4 jumps always back to bank 1 for me when switching the bank/pattern value or selecting another group.While searching in the source code for the according lines in cs_m_menu.inc I found this: ;; toggle pat/bnk sel CS_M_SONG_GP_Callback_Sel ;; btg CS_STAT, CS_STAT_SONG_EDIT_BNK ;; disable - somehow makes no sense here (UI not consistent - time to ask the community, which approach they would prefer) ;; rgoto CS_M_SONG_GP_Callback_Cont I don't think that this is related to the problem though.Any hint on which line I can try to fix it? I'm a long time pascal and c++ programmer but the assembler stuff is killing me. ;)
TK. Posted January 5, 2009 Author Posted January 5, 2009 No, it isn't - can you confirm that this only happens for G4? Then it's a strange bugAny hint on which line I can try to fix it?Any hint on which line I can try to fix it? ;)Best Regards, Thorsten.
swindus Posted January 6, 2009 Posted January 6, 2009 It happens only for G4. No way to select a bank or pattern regardless of using an encoder or the gp buttuns to select a bank or pattern. Sorry, no hint for you. :P ;)
stuartm Posted January 11, 2009 Posted January 11, 2009 Finally back home and running v3.4.Thanks for implementing the sync function, work fine and just as I thought it would be!I also like the "one-finger" mode of F1, no need for a change there.I can also confirm the G4 Bank Selection bug in Song/ Phrase mode.It jumps back to the previous value, so if i have a Pattern from Bank 2 on the G4, it'll always jump to 2, no matter which new bank I select.The jump happens when I press any other button/ turn encoder,
TK. Posted January 12, 2009 Author Posted January 12, 2009 Ok, found the bug :)The bugfix is already available in the repository.At the end (after adding some more comments), it turned out that the issue was caused by a single line of code:Wrong: ;; don't save if cursor pos >= 7 movlw 0x06[/code] Correct: [code] ;; don't save if cursor pos >= 7 movlw 0x07Note that the comment already gave me a hint about the intended boundary ;)Any other issues before I'm doing a new release?Best Regards, Thorsten.
swindus Posted January 14, 2009 Posted January 14, 2009 Changed the source, compiled and uploaded v3.4 to my sequencer. All things in song/phrase mode are now working as expected. Thanks!
stuartm Posted January 20, 2009 Posted January 20, 2009 Changed the source, compiled and uploaded v3.4 to my sequencer. All things in song/phrase mode are now working as expected. Thanks!Did the same over here, got the same pleasing result.Thanks TK!
TK. Posted January 22, 2009 Author Posted January 22, 2009 Thanks for testing!MIDIbox SEQ V3.4a is available nowBest Regards, Thorsten.
monokinetic Posted January 23, 2009 Posted January 23, 2009 Compiled, uploaded and tested.Works nicely....(Thanks * 1million)23;)Dave mK
swindus Posted January 23, 2009 Posted January 23, 2009 It will be a nice weekend! Thanks a lot!!! :)
stuartm Posted January 23, 2009 Posted January 23, 2009 Tested and approved. :)/edit: Although the initial cursor pos change in Song page doesn't fit my workflow.I don't use Song Pos that much, so I expect it to be on "Song" when I press the Song Button.Can I change that back in the source code (cs_m_song.inc) ?Maybe for SeqV4 it could be selected via the .asm file, if possible.
TK. Posted January 23, 2009 Author Posted January 23, 2009 Although the initial cursor pos change in Song page doesn't fit my workflow.And it doesn't fit my programming style! ;-)Can I change that back in the source code (cs_m_song.inc) ?Open cs_menu.inc, search for the keyword "DIRTY DIRTY DIRTY", and remove everything between BEGIN and END markerBest Regards, Thorsten.
stuartm Posted January 23, 2009 Posted January 23, 2009 .. search for the keyword "DIRTY DIRTY DIRTY", and remove everything between BEGIN and END marker...Mmmmh, I've got a "clean" Midibox again. ;)Thanks for the quick reply.I'm planning on doing another video tomorrow, lets hope German weather stays rainy.
stuartm Posted January 24, 2009 Posted January 24, 2009 The weather was good, anyway:http://www.midibox.org/forum/index.php/topic,12881.0.html
TK. Posted May 13, 2009 Author Posted May 13, 2009 There is an update (v3_4d):o In Slave Mode the sequencer won't switch to Master mode when the Play button is pushed.This automatic switching is only available in Auto Mode anymore[/code]Best Regards, Thorsten.
Futureman Posted May 16, 2009 Posted May 16, 2009 Hey there,sorry to resurect this old thread, but I only recently uploaded the most recent version of the SEQ3 OS (3.4d) with a few changes for me (J5 gates enabled etc).It seems the 'sync to measure' throws the pattern out less than a step.. I also noticed that if i put a note at the start, the note gets stuttered, if you know what i mean?I do dig the sync to measure, because you can throw in any odd timing and know that in say 64 steps it'll get thrown back in sync.TK, I can imagine you are mainly concentrating on V4 (Which i'm can't wait to take for a spin) , but if you have the time, please re-visit this and see if you can fix up the 'sync to measure'(That is unless it's something to do with me being an idiot and missing something)Kind regardsMike
TK. Posted May 16, 2009 Author Posted May 16, 2009 Hi Mike,interesting! You and me seem to be the only guys who are using this feature (it's one of my most favourite ones).According to the svn log, it wasn't working since 298 days, 21 hours, 10 minutes (it was working in v4 of course ;))Fixed in v3.4eBest Regards, Thorsten.
Futureman Posted May 17, 2009 Posted May 17, 2009 You and me seem to be the only guys who are using this feature haha.. your a champion as always TK!Best regardsMike
