I'm curious if anyone has converted the Schaeffer Front Panel template found here: http://www.ucapps.de/midibox_sid/mbsidv2_front.fpd to DXF format for use in autocad. For my front panel, I used that as a starting point and then found out that my friend's brother works in a metal shop so it will be way cheaper for me to have him create the front panel rather than ordering it from Schaeffer. The cost savings would be negated if I have to order the DFX export filter from Schaeffer, so I'm hoping that somebody else has already converted the template and could provide it to me so I can use it as a starting point.
yep - i have it - but no texts/engravings layer inside.
we removed all the texts so we cut only holes.
if this act not violates any midibox policy, i could share it with you.
That's actually exactly what I need. I'm gonna screen print the text and everything myself, so I just need the holes.
ok here it is.
6582 panels for lasercut/cnc/waterjet
take dxf,
and receive solid drawings as free bonus!  8)
Oops, I guess I didn't specify. I'm not building the mb6582, I'm building the modular 6581 version.
Oops, I guess I didn't specify. I'm not building the 6582, I'm building the modular 6581 version.
Just saying:
There's no midibox project called "6582". There's the mb6582, which is Wilba's impressive implementation of an mbSID v2. 6582 is just the SID chip. As is the 6581. </mini-rant>
Just saying:
...semantics
What I need is a .dxf file for the old style panel. I'm reusing the c64 keyboard case.
  • 5 months later...
...semantics
i need one of those files too..
before i waste time drawing it myself in Vectorworks..
sure someone has it? or does everyone use Front Panel Designer?
this is the design i'm going for, sort of: http://www.subatomicglue.com/sidl0g/
or like TK's original:
5175_tk_jpga8bbea821f1e7d1db70f604a25e32
