d2k Posted August 4, 2003 Posted August 4, 2003 Hey....Today arrived my encoders from a ebay buy - and my oh my are they good :) Soz Ian, ur's are headin to encoder heaven :P...The feel/response of them is excellent - even with the detent removed (which is very easy with these) they work/feel better - no skipping values at all!!And I got a 100 of the beauties for only $24US (plus 15 shipping to Blighty)!! :DReeeeesult!PeeshdanBTW: the auction has been relisted: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=26211&item=2548904374
goyousalukis Posted August 5, 2003 Posted August 5, 2003 Hey.. those are the same ones I got!I haven't tried removing the detent, I'll try that today. I can vouch for the quick shipping and good deal with the seller though. d2k ... Let me know if you find a good source of knobs for these babies. I only see one (ugly) one in my mouser catalog, and they are pretty expensive. JustinEdit.. I just removed the detent, and they are very smooth! Also, they are easy to mount on a pcb. They fit on a regular board, just by enlarging two holes.
d2k Posted August 5, 2003 Author Posted August 5, 2003 Hey Justin...The knobs i used for my LC are from Sifam - however I found these on ebay:http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=2548702086200 knobs with a choise of 5 colour caps for uk £9!!They'll do for me :)BestDanPS: A group buy could be a possibility for these panasonic enocders if peeps are interested - they'd work out at well under a $1 a peice :P
goyousalukis Posted August 5, 2003 Posted August 5, 2003 That is a good deal, but I don't think they'd fit. The encoder shafts are 6mm - a bit smaller than .25". I wish they did fit. The same knob and caps at mouser cost 29 cents and 33 cents apiece - over $100 for 200!
d2k Posted August 5, 2003 Author Posted August 5, 2003 I think they're good fella :)1/4"/6mm - DType - one and the same...We shall see anyways...Dan
goyousalukis Posted August 5, 2003 Posted August 5, 2003 Ok, I have some .25" knobs here that fit my .25" pots fine. They aren't D's but they are loose on my encoders. I might try to rig em up and stick something in them to make them D's
Ian_Hurlock Posted August 5, 2003 Posted August 5, 2003 Well there's no pleasin some peopleIf anyone else is unhappy with the encoders you got from me then I will refund your moneyYou know where to contact me
d2k Posted August 5, 2003 Author Posted August 5, 2003 Well there's no pleasin some people  If anyone else is unhappy with the encoders you got from me then I will refund your money  You know where to contact meHmmm, hope ur joshin ere but I wern't saying the ones u got were shit or that I was even unhappy with them...i've thanked you enough for the effort into gettin them in the first place...This was just a good deal Ian - no need to be bitter :)PeeshDanPS: Urs will still be gettin used - don't u worry bout that :)
ilmenator Posted August 5, 2003 Posted August 5, 2003 I'd like to jump in here...1/4"/6mm - DType - one and the same... They are not the same - I once tried to use the 6mm caps with a 1/4" shaft. Not a chance... But you might be able to fix them using some kind of glue - though that might be a decision for life ;)Regards, ilmenator
Ian_Hurlock Posted August 6, 2003 Posted August 6, 2003 Hi DanActually I thought you were going to throw them in the bin ???i would'nt like to think they were no goodGlad to hear that you will still use them. :)
Steven_C Posted August 7, 2003 Posted August 7, 2003 I probably shouldn't have recommended that people pull apart and modify the encoders from Ian, as this is very difficult, and the button on one of mine dosen't work which is probably because of the modification???but apart from that I am happy with the encoders from Ian, considering the excellent value for money. Mine are working well on my LC. (apart from the one with the dodgy button, but I can live with that!)If anyone is concerned for the best quality encoders, then you can't go past the alps... very easy to remove the detent, they feel just like real pots!! (or buy non-detented version) only they are very expensive, unless you are friends with Nat!as for 1/4" knobs on 6mm shaft, I just wrapped a small piece of electrical tape around the curved part of the shaft, before tightening the grubscrew, works fine, and its concentric!
Ian_Hurlock Posted August 7, 2003 Posted August 7, 2003 SteveI can spare another enc for the one you mucked up.Give me the word and it's yoursIan
Steven_C Posted August 8, 2003 Posted August 8, 2003 very nice of you, Ian, I dunno if I can be bothered pulling it out of my LC and changing it!! (I connected it to a spare button ;))
Ian_Hurlock Posted August 8, 2003 Posted August 8, 2003 One will be on it's way to you next week free of charge. ;)Put it in ya lazy beggar :oRegardsIan
banneduser Posted August 8, 2003 Posted August 8, 2003 Steve and Ian...Just wanted to add, i modded both the button and non button encoders succsessfully and they're workin' fine so I feel it was worth doing, just requires attention to detail ;).
FREON Posted August 10, 2003 Posted August 10, 2003 Hi,I'm one of the lucky guys that got these nice panasonic encoders ! 50pc for 12$ !!! Yooooouuuppppeeee !!!I've received them yesterday and modded one of them without any big issues and the feel is excellent as pointed by d2k, even when not modded. However, as I'm not 100% sure about what I did (I removed a little plate), would it be possible that someone (dan?) posts pictures of its modification ???Also, I don't know for you, but mine have an integrated switch, that allows to use the encoder as a push-button, still acting as en encoder. So I was wondering if it's possible to use this feature to assign to the encoder 2 variables, one when used in normal mode, another one while pushed...what do you think ????Tks and if you can get those, go for it...Relisted at http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=2550409211Richard
d2k Posted August 10, 2003 Author Posted August 10, 2003 Hey Richard...Can't post any pics atm as my web space is down. However, you just open the encoder up, remove the main bit and the copper ring detent is on the top part (where the shaft is) under the encoder wheel...job done.Ye, the inbuilt switch is a very nice bonus and of course can be used like any other switch - just connect as described in the din pdfs...Nice...Dan
goyousalukis Posted August 11, 2003 Posted August 11, 2003 Yeah, that's the same thing I did, just removed the little plate. I had the same idea as you about using the push button to choose a different value to change with the encoder. I don't think it would take too much code to check the button state when the encoder value changes. I don't know if I up to doing it though. At the price we got these encoders for, I'll just use one for each parameter and use the button by itself.Justin
banneduser Posted August 12, 2003 Posted August 12, 2003 Hey goyousalukis !I was considering that also....the only pb is I don't know which actions really make sense while pushing the encoder....???I did it already for the navigation dial and the menu button...but appart this, no more idea....If you have any suggestions ?Also I was wondering if anybody managed to find decent knobs for these guys but without pointer ? I'm looking for some soft touch one but they all come with pointer..(at least the one I found). :-/Tks Richard
goyousalukis Posted August 12, 2003 Posted August 12, 2003 Yeah Richard, I haven't thought of any. I just finished the basic SID step A, I want to make the Control surface like TK's, but I think that I will use the push buttons on the encoders to change the various items. I think that the most usefull implementation of the push encoder, would be on a mixer type platform. You could have the encoder change Aux Send One normally and then Aux Send Two when Depressed. I guess it would make more room and save one hole. I haven't found any cheap knobs yet. I have a bunch of .25" non D style knobs. I may try to modify them to fit, but they aren't very attractive. Coincedently, the jog knob from my Yamaha MU128 synth mod fits perfectly. I wish I could buy a bunch of these!Justin
TK. Posted August 12, 2003 Posted August 12, 2003 The push buttons are also very usefull if you want to visualize the value which is assigned to the knob without changing the value. Maybe I will build such a function into the MBSID application (although I'm using encoders without integrated knobs) because it improves the handling. Currently you have to change the layer to achieve this.Another usecase is already support by this application: you can add 5 rotary encoders to StepA if you want to change the values which are currently visible in the menu (StepC users: change to the Assign layer in the ENV section). Integrated knobs would save 5 menu buttonsBest Regards, Thorsten.
banneduser Posted August 13, 2003 Posted August 13, 2003 Hi Thortsen,That's a very good idea !!! I'll play with it.Actually as I received too many of these encoders (50!!), I can afford to send some to you (let's say 10pcs): I've been lucky and you deserve some support. If you want some more, I've seen that the auction is still hanging around on ebay.com.Tks,Richard
Dr_Nick Posted August 14, 2003 Posted August 14, 2003 Hi everybody!Sadly the person who sells the encoders on ebay.com won't ship to Germany. Does Anybody know where I could get those for a decent price in Germany?Thanks! Dr. Nick
banneduser Posted August 14, 2003 Posted August 14, 2003 Hi, maybe it´s possible to arrange an bulk order to gemany through another ucapps-user, living in the same country as the seller?If anybody needs something from germany, just send me a pmSascha
goyousalukis Posted August 15, 2003 Posted August 15, 2003 I'd be happy to buy some and ship them out to anyone. I have already purchased from the seller here in the US.I can accept paypal.Justin Ahrens
