Nigel Posted December 5, 2010 Posted December 5, 2010 Hi guy at first a was a little bit sceptic about building my own midibox SID because a don't have any skills envolving circuitry but now that I've seen you are such a good online community I'm willing to give it a go. So I ask if there are amongst you whom have got any pdf material they can send me so I can get started on my first project. :tongue: cheers Nigel
levon Posted December 6, 2010 Posted December 6, 2010 You can find most of the information available on the midibox SID on the wiki at http://www.midibox.org/dokuwiki/doku.php?id=midibox_sid Once you have read that, if you have any specific questions we would be more than happy to answer them for you. If you already have 1 SID chip, and can get 1 more, you might be interested in the sammichSID, a kit made by Wilba to make a 2 SID chip synth. http://www.midibox.org/dokuwiki/doku.php?id=sammichSID
Flemming Posted December 6, 2010 Posted December 6, 2010 You can also find tons of info at http://www.ucapps.de/ All midiboxes are listed and explained there, but also each and every midibox module is described with building guides and everything you would want to know to get your own build going :) On that site you also can find links to other important resources, like our wiki (also mentioned by Levon in the post above), shops where you can order parts for midiboxing, and a pretty sexy gallery that holds pictures of a lot of beautiful builds which members has built in the past (pictures of even newer builds can be found in the gallery section of this forum). Ofocurse you can also find a lot of help if you search this forum. If you have a question, chances are very high that it has been asked before, and that way you can find answers much quicker instead of having to wait till someone answers your post. It is a kind of 'unwritten rule' we practice inhere; to avoid forummembers ansering the same questions over and over again, we urge newcomers to read, read and then read a little more - and don't worry :) to start out with you will probably find all of the information to be confusing, but quickly you will get the hang of it. I'm really happy that you decided to give it a shot :thumbsup: Welcome to the coolest community on the internet!
Hawkeye Posted December 6, 2010 Posted December 6, 2010 Also, consider building a MB6582 - it is a great package with the awesome power of up to 8xSID, it is not difficult to build and can be done in two weeks, if you have time in the evenings... there are also building tutorials with parts lists floating around ;-)
nILS Posted December 6, 2010 Posted December 6, 2010 Also, consider building a MB6582 Maybe not a really good first project, eh?
Wilba Posted December 6, 2010 Posted December 6, 2010 Maybe not a really good first project, eh? It was for me! :thumbsup:
Wilba Posted December 6, 2010 Posted December 6, 2010 Now, but not then... It took years of being crazy and being called an epic superdouche before I claimed MIDIbox Hero status.
Flemming Posted December 6, 2010 Posted December 6, 2010 Now, but not then... It took years of being crazy and being called an epic superdouche before I claimed MIDIbox Hero status. Oh, there might still be hope for me too then :tongue: Still i'm only semidouche.. going for super, ofcourse
Nigel Posted December 6, 2010 Author Posted December 6, 2010 thanks for the great welkom...wich model do you recommend building for someone with no building experience and only on C64 to dismantel (I have a second one but I want to keep it unharmed) I'm on a tight budget to but if I buy part in small order I will manage cheers :ahappy:
Hawkeye Posted December 6, 2010 Posted December 6, 2010 (edited) nILS is right, the MB6582 has quite some solder connections... the SammichSID comes to mind if you want an easy, well documented project suitable for two SIDs, which is available as a completely packaged kit. And... it is sold by a hero ;-) Edited December 6, 2010 by Hawkeye
flip Posted December 7, 2010 Posted December 7, 2010 MB-6582 was my first project too, didn't find it too hard. The sammichSID seems even easier though. MB-6582: pro: Hands-on controls 8 SIDs Well documented con: You have to source the parts yourself Expensive sammichSID: pro: Easy step by step documentation Complete kit available Not too expensive con: No knobs for live tweaking Just 2 SIDs
Nigel Posted December 9, 2010 Author Posted December 9, 2010 I've checked out the sammichSID project and I think it is way to complex :frantics: to be my first project are there any other DIY synth projects jou recommend. My standards are it needs to be really cheap, easy and well documented so it's more kind of a learning project before I start a bigger project cheers Nigel :ahappy:
Flemming Posted December 10, 2010 Posted December 10, 2010 I've checked out the sammichsid project and I think it is way to complex :frantics: to be my first project are there any other DIY synth projects jou recommend. My standards are it needs to be really cheap, easy and well documented so it's more kind of a learning project before I start a bigger project cheers Nigel :ahappy: It doesn't really get much easier than SammichSID - Full kit - Easy build, very well documented - Cheap Keep in mind that many people built a SammichSID, even beginners :thumbsup: The only alternative that would be any easier, would be to buy a MSSIAH for your C64.
rosch Posted December 10, 2010 Posted December 10, 2010 (edited) probably the same level as the SammichSID (haven't built one) would be the Shruthi-1 at http://mutable-instruments.net they are similar projects w/r/t very beginner friendly documentation (both noob proof), come with case and parts and low cost. if you like to go smaller at the beginning you could search at www.electro-music.com for APC or cacophonator schematics. that's probably the cheapest way to start with some nice noise sounds and really low parts count. note that the SammichSID is probably already the easiest way to put together a standalone SID synth if you compare the steps you'd have to go otherwise with the modular approach (which isn't that complicated either). Edited December 10, 2010 by rosch
flip Posted December 10, 2010 Posted December 10, 2010 Yo rosch! Thanks for the hint with the Shruti-1 synth! Just bought two ;)
