post-4611-0-86485600-1314383331_thumb.jp
thanks to TK and the community
handmade aluminium frontpanel with standard cheap drill!!!! not perfect but works
DIN and DOUT with a lot of wiring , duo GP leds ... lot of work !!! the Wilba CS is a better solution!
seq V4 is amazing.... whaouh!!!!!
next step is installation of the aout and the four midi IIC options......
looks like a very decent job to me!
it looks flat, is there room inside for more boards (or are you going to add a breakout box)?
did you use on board transformer? quite obviously
Edited by rosch
thanks!!! :rolleyes:
there's just enough place for all the boards!!!!! there two transformer : 2x9v(2x2A) and 2x15v(2x100mA).
DOUT , standard LEDs and DIN are powered by another 7805 because the 7805 from the core was too hot!!!!
the second 5V power could drive a BLM with low current leds!!!!
rear panel is metal from the back of an old cd player.... the rest of the box is plywood!!!!
it's time learning use it!!!!! :thumbsup:
Merci Julien!
after use the seq ... it's a very good machine lot of possibilities
lot of good fonctions.... great
the only thing that i don't understand is the mixer section
in event you can choose the port and the channel but not program change
i don't understand how to assign program change per track. is it possible?
Great build!!! :)
yes, by using song phrases.
See also this posting:
I added a third example where a mixer map, mutes and tempo is set
Great build!!! :)
thanks Thorsten!! :sorcerer: (nice to have a comment from the genius god of uccaps! :thumbsup: )
I've understand now the song mode it's exactly what i was searching!
how to assign mixer map! yeah!!!
thanks peter!!!!! i can not wait you to see your frontpanel!!!!! :tongue:
i love your double square leds design... :thumbsup:
looking to the BLM connector schematic:
MI2 MO2 are spare?
they are direct connection but with all option (ethernet ,CV&gates , din syncro and din start) there no spares available?
sorry there are on J11 :whistle:
Edited by tashikoma
