Smithy Posted January 25, 2016 Report Posted January 25, 2016 (edited) Hi TK, I'm having a lot of fun with wavetables recently, and ripping them from SID Tunes. Do you have upcoming plans to add the Wavetable Editor to Ctrl? I'm particularly interested in using the Multi Engine for wavetables. I know you have a hectic schedule but it would be nice to see the Ctrl panel finalized. It would be nice to have a full editor you can use fully offline (without connecting to the MIDIbox SID) A lot of the time Rutger's Editor Crashes and dumps a log file when I close the patch editor window and click Yes to Save. Kind Regards. Edited January 26, 2016 by Smithy
ChinMuzik Posted November 24, 2016 Report Posted November 24, 2016 ^^^ so this doesn't edit wavetables? So the only way to program wavetable sequences is through the MIOS menu? Is there any non-Hex windows based application that can edit sequences? I hate to say it..but Mode Machines had a really nice way to do it.
Smithy Posted December 20, 2016 Report Posted December 20, 2016 On 24/11/2016 at 3:54 PM, ChinMuzik said: ^^^ so this doesn't edit wavetables? So the only way to program wavetable sequences is through the MIOS menu? Is there any non-Hex windows based application that can edit sequences? I hate to say it..but Mode Machines had a really nice way to do it. Have a look at Rutger's Java based editor for MIDIbox SID. The wavetable implementation is complete:http://www.ucapps.de/midibox_sid/v2_editor/MBSIDV2_Editor_v0_5.zip
ChinMuzik Posted December 21, 2016 Report Posted December 21, 2016 Alternatively, could I use a standard c64 tracker and then punch the values in the wavetable sequencer in MIOS?
Smithy Posted December 21, 2016 Report Posted December 21, 2016 15 hours ago, ChinMuzik said: Alternatively, could I use a standard c64 tracker and then punch the values in the wavetable sequencer in MIOS? in MIOS Studio? MIOS Studio is for uploading the firmware to MIDIbox SID, asfaik it never had a wavetable sequencer built in to it! :) Someone correct me if I'm wrong! Your best bet is using Rutgers editor.
skunks Posted September 16, 2017 Report Posted September 16, 2017 I'm running recommended Ctrlr_ac6a3185.exe on Windows (it is now available from archive.org only). Selection SID1 - SID4 does not work correctly. Only SID1 selection produces expected results. E.g., I activate ENS tab. I can receive and modify patch # etc. for first core. When I switch cores (SID2-SID4), information seams to be received correctly, but when I modify any knob (e.g. patch#), it does not get stored to ENS buffer. The only condition under which it get stored, as I noticed, is when that particular SID core I've selected in CTRLR is selected on control surface also. From time to time I notice messages like "SIDx not available (No MBNet Response)" on LCD. Sometimes they last for a second, sometimes they stay. MIOS studio reports a continuous flow of messages F0 00 00 7E 40 00 0F 00 F7 from MIDI IN, when CTRLR is active.
ChinMuzik Posted September 20, 2017 Report Posted September 20, 2017 On 12/20/2016 at 2:18 PM, Smithy said: Your best bet is using Rutgers editor. How do I even use this?? I've downloaded it.....does it need to be compiled? Never ran a Java script this way.
Smithy Posted September 20, 2017 Report Posted September 20, 2017 (edited) 4 hours ago, ChinMuzik said: How do I even use this?? I've downloaded it.....does it need to be compiled? Never ran a Java script this way. It's not Java Script, it's a Java executable. Just download and install Java on your machine and run the .jar file. Make sure the midi in and midi out of the MIDIbox SID is connected properly otherwise you won't be able to open the patch editor interface. Edited September 20, 2017 by Smithy
ChinMuzik Posted September 24, 2017 Report Posted September 24, 2017 On 9/20/2017 at 4:23 AM, Smithy said: It's not Java Script, it's a Java executable. Just download and install Java on your machine and run the .jar file. Make sure the midi in and midi out of the MIDIbox SID is connected properly otherwise you won't be able to open the patch editor interface. Right, but in the link you posted there's no .jar files just CLASS files.
Smithy Posted September 25, 2017 Report Posted September 25, 2017 19 hours ago, ChinMuzik said: Right, but in the link you posted there's no .jar files just CLASS files. I posted a link to a zip file with the .jar file inside. I have no idea how you're seeing class files unless you clicked a different link to mine?
goyousalukis Posted January 26, 2018 Report Posted January 26, 2018 Hi, any way someone can upload Ctrlr_ac6a3185.exe here? I can't find it anywhere. Thanks
Hawkeye Posted January 26, 2018 Report Posted January 26, 2018 I don't know if we should upload software made by others on here (even if it is free), but you can always try the wayback machine: web.archive.org Then enter ctrlr.org as URL Then click on the circa date the files should have been present in their download area Then click on the download area - i just did this experimentally for 2013 and it works - but you have to search for your exact release by properly travelling in time, which is half of the fun :) http://web.archive.org/web/20131125171837/http://ctrlr.org:80/nightly/ Many greets and good luck! Peter
goyousalukis Posted January 26, 2018 Report Posted January 26, 2018 Thanks Peter - I found it: http://web.archive.org/web/20140518080526/http://ctrlr.org:80/nightly/ Maybe add this link to TK's first post so new users can find this version. Thanks again! Justin
Hawkeye Posted January 26, 2018 Report Posted January 26, 2018 Well done - link to the original/first post added. Thanks for searching! :) Many greets, Peter
cuca Posted March 20, 2019 Report Posted March 20, 2019 Hi all. I have sammichSID and today i opened this editor pannel for ctrlr after some years but it gets stucked and freezes when i try move some parameter in the editor or when i try to edit in the arpegiator page or when i click play buttomm and much more parameters. The editor Gets stucked and i dont know where is the problem? Maybe windows 10? My soundcard? sammichSID? Something wrong with The midi config in ctrlr ? Thanks a lot. Someone can help me?
lunnar Posted October 19, 2019 Report Posted October 19, 2019 (edited) today i download versions of Ctrlr_1655 & Ctrlr_262f2710 and they both work fine in standalone mode(not vst) on my Mac 10.13.16, i downloaded them from this archive http://web.archive.org/web/20140518080526/http://ctrlr.org:80/nightly/ maybe it will be useful for new users... Thanks, this editor is excellent, i'm so tired of making an editor from my small screen :) MDBX + CTRLR video: https://www.youtube.com/watch?v=dOix9ltw6vM&feature=emb_logo Best W, Lunnar. Edited November 16, 2019 by lunnar 2
nathmaheshmp Posted October 12, 2020 Report Posted October 12, 2020 (edited) I can't use it as I've a Powermac G5 and ctrlr app seems made for Intel with 10.6. If someone has a trick, it is welcome :thumbsup: 9apps cartoonhd Like this Edited January 6, 2021 by nathmaheshmp
pricklyrobot Posted March 21, 2022 Report Posted March 21, 2022 Anyone managed to get Ctrlr to run on an Apple-silicon based Mac? Got a new MacBook Pro 14" recently. Would like to be able to edit my sammichSID from it. Not much luck so far. Seemed like it imported the current patch from the Sammich once or twice randomly out of several tries, but it won't do it consistently. And I can't get it to send an edited patch back to the Sammich at all.
Giovanni Posted August 26, 2023 Report Posted August 26, 2023 I'm trying to control a midibox sid v2 that i built years ago with ctrlr. My machine is a literal black box, it has no controls nor display, just a power switch and input/output connections. I would really like to be able to load ctrlr as a vst inside of my daw (reaper) and control the synth as any other virtual instrument, but, so far, no luck. Here's a list of what i've tried: -Latest version of ctrlr, running standalone, load the panel, set midi input, control, output -> everything seems to work. Specifically, activating the midi monitor in ctrlr i can see that for any knob or parameter that i tweak in the panel, a correspondig amount of midi data is sent to the machine, and obviously changing parameters affect the sound. -Latest version of ctrl loaded in reaper as either vst 86, vst 64 or vst 3, either allowing ctrlr to directly control midi in/out or routing them through the host -> no luck. Checking with the midi monitor, only the buttons on the left side of the panel, (init, receive, SID1-4, link osc, link stereo, play) generate a midi output, while all the knobs and buttons of the various engines generate nothing. I can play notes just fine, but no matter what i click or turn the sound doesn't change. run the same thest with the Ctrlr_ac6a3185 version, got pretty much the same result. So I'm curious, has anyone managed to run the panel in ctrlr as a vst and got it to work?
TK. Posted October 24, 2023 Author Report Posted October 24, 2023 Hi, in the last days I troubleshooted the MIDIbox SID panel with the latest CTRLR sources which are available on Github. This resulted into: a solution for newer Macs with Apple Silicon: https://github.com/RomanKubiak/ctrlr/issues/560#issuecomment-1771700555 a small source code change to get the "ui" flag working again because my panel relies on this feature, which vanished some years ago for whatever reason:https://github.com/RomanKubiak/ctrlr/pull/573 some LUA script changes to get the panel compatible I will do some testing in the next days to ensure that all parameters are working, and I have to find a way to build AUs However, I will only be able to provide a MacOS version. PC users might be interested on the "fixed version" as well. Therefore the question: has anybody the knowledge to build CTRLR with my source code changes on a PC? Best Regards, Thorsten.
TK. Posted October 26, 2023 Author Report Posted October 26, 2023 Finally Ctrlr is perfectly working with MBSID under MacOS (Intel and Apple Silicon) again! :) The application and migrated MIDIbox_SID_V2.bpanelz file can be found in this package: -> http://www.ucapps.de/midibox_sid/ctrlr/Ctrlr__tk_changes_for_midibox__20231026.zip Best Regards, Thorsten.
Hawkeye Posted October 27, 2023 Report Posted October 27, 2023 @TK. - awesome, great work! Many greets, Peter
TK. Posted November 4, 2023 Author Report Posted November 4, 2023 Discussions about Wavetables now here:
