zephyrin Posted November 20, 2012 Posted November 20, 2012 MB808 seq for MB808 voice Hello i m trying to make th MB808 with the microlarge PCB. I have finish the 3 boards , i have also building power supply, and output from yoda design. Now i will building the sequencer part, for that i have 1 x MBHP_CORE, stuffed with PIC18F4620, 2 x MBHP_DINX4 amd 2 x MBHP_DOUTX4. I will also building the banksitck I know that TK and Kogz23 works on a new "combined" PCB I wanted to know this standalone MB808 seq have the same design as MB808 with the digitast switch and what is the difference between this MB808 seq and the MB9090 seq from jozef ? I need also some help for connecting switch and led to DIN and DOUT :) On the original MB808 there is a pot swing (10KB) and accent (10K) where there are connecting ?
Shuriken Posted November 20, 2012 Posted November 20, 2012 (edited) MB808 seq for MB808 voice Hello i m trying to make th MB808 with the microlarge PCB. I have finish the 3 boards , i have also building power supply, and output from yoda design. Now i will building the sequencer part, for that i have 1 x MBHP_CORE, stuffed with PIC18F4620, 2 x MBHP_DINX4 amd 2 x MBHP_DOUTX4. I will also building the banksitck I know that TK and Kogz23 works on a new "combined" PCB I wanted to know this standalone MB808 seq have the same design as MB808 with the digitast switch and what is the difference between this MB808 seq and the MB9090 seq from jozef ? I need also some help for connecting switch and led to DIN and DOUT :) On the original MB808 there is a pot swing (10KB) and accent (10K) where there are connecting ? I assume with the MB9090 seq, you mean this one: That one is based on LPC17 Core and is with custom app. TK is adjusting his (PIC) Core8 code to make this possible. The upside on that is that you will have supported code :wink: ATM I don't think there is more info available on the combined pcb TK and Kogz32 are working on. Connecting Switches to DIN4 Connecting leds to DOUT4 Edited November 20, 2012 by Shuriken
Hawkeye Posted November 20, 2012 Posted November 20, 2012 (edited) As Shuriken said, wouldn´t it be possible to use pcbatterj/Jef/Synthage.com ´s 9090 MBSEQ V4 based sequencer board for the 808 voice boards, too? The design looks very nifty and it "only" needs to trigger the analog voices? Edit: ok, there´s things like note accents, too - I think they are triggered via additional trigger channels... You´ve gotta love the euclidean rhythm generator in the V4 SEQs, a great addon for any drum sequencer... Many greets! Peter Edited November 20, 2012 by Hawkeye
zephyrin Posted November 20, 2012 Author Posted November 20, 2012 I assume with the MB9090 seq, you mean this one: Yes is that, i m testing now the MB9090 of Jozef and i think that we can control other drum box with this. The MB9090 app is based on MBSeq V4 and used midi port. I will try to see if the MB9090 works with my new yamaha RX5. For the the switch and the led i have found some information in the setup_808_default.asm file For exemple for the button and i m not shure that is the same i see also 27 button and not 33 :ermm: SEQ_IO_TABLE_DIN ;; Function name SR# Pin# ;; NOTE: the pins of the 16 general purpose buttons are assigned above, search for DEFAULT_GP_DIN_SR_L (and _R) DIN_ENTRY SEQ_BUTTON_Scrub, 0, 0 DIN_ENTRY SEQ_BUTTON_Metronome, 0, 0 DIN_ENTRY SEQ_BUTTON_Stop, 5, 5 DIN_ENTRY SEQ_BUTTON_Pause, 0, 0 DIN_ENTRY SEQ_BUTTON_Play, 5, 3 DIN_ENTRY SEQ_BUTTON_Rew, 5, 6 DIN_ENTRY SEQ_BUTTON_Fwd, 5, 2 DIN_ENTRY SEQ_BUTTON_Live, 5, 1 DIN_ENTRY SEQ_BUTTON_F1, 0, 0 DIN_ENTRY SEQ_BUTTON_F2, 0, 0 DIN_ENTRY SEQ_BUTTON_F3, 0, 0 DIN_ENTRY SEQ_BUTTON_F4, 0, 0 DIN_ENTRY SEQ_BUTTON_Shift, 2, 5 DIN_ENTRY SEQ_BUTTON_Alt, 2, 4 DIN_ENTRY SEQ_BUTTON_SectionA, 1, 0 DIN_ENTRY SEQ_BUTTON_SectionB, 1, 5 DIN_ENTRY SEQ_BUTTON_SectionC, 1, 3 DIN_ENTRY SEQ_BUTTON_SectionD, 1, 4 DIN_ENTRY SEQ_BUTTON_LayerGate, 2, 0 DIN_ENTRY SEQ_BUTTON_LayerAux, 2, 1 DIN_ENTRY SEQ_BUTTON_Edit, 6, 4 DIN_ENTRY SEQ_BUTTON_Mute, 5, 0 DIN_ENTRY SEQ_BUTTON_Pattern, 6, 7 DIN_ENTRY SEQ_BUTTON_Song, 6, 5 DIN_ENTRY SEQ_BUTTON_Solo, 0, 0 DIN_ENTRY SEQ_BUTTON_Fast, 0, 0 DIN_ENTRY SEQ_BUTTON_All, 0, 0 ;; OPTIONAL! see CHANGELOG.txt DIN_ENTRY SEQ_BUTTON_Group1, 0, 0 DIN_ENTRY SEQ_BUTTON_Group2, 0, 0 DIN_ENTRY SEQ_BUTTON_Group3, 0, 0 DIN_ENTRY SEQ_BUTTON_Group4, 0, 0 DIN_ENTRY_EOT
Antix Posted November 20, 2012 Posted November 20, 2012 http://www.ucapps.de/tmp/mbdr_proto1.jpg Or this?
Shuriken Posted November 20, 2012 Posted November 20, 2012 (edited) As Shuriken said, wouldn´t it be possible to use pcbatterj/Jef/Synthage.com ´s 9090 MBSEQ V4 based sequencer board for the 808 voice boards, too? The design looks very nifty and it "only" needs to trigger the analog voices? Edit: ok, there´s things like note accents, too - I think they are triggered via additional trigger channels... You´ve gotta love the euclidean rhythm generator in the V4 SEQs, a great addon for any drum sequencer... Many greets! Peter I think the 9090 can only be controlled via midi. http://www.ucapps.de/tmp/mbdr_proto1.jpg Or this? Like Antix, i will be waiting for this one. Edited November 20, 2012 by Shuriken
Hawkeye Posted November 20, 2012 Posted November 20, 2012 I think the 9090 can only be controlled via midi. I should have done some research first :-) Thanks! Just out of pure interest, would it not be possible to connect MBSEQV4 "Trig outs" to the individual "Trigger inputs" of the 9090 voice modules? E.g. like the trigger in of the bassdrum: http://blogimages.bloggen.be/mb9090/attach/82304.pdf But of course, you´re right, if it is already MIDI-equipped, this way uses less cables and allows to use it with other MIDI gear :) Many greets, Peter
Antix Posted November 20, 2012 Posted November 20, 2012 Probably you can trigger 9090 voices with Seq4 trigger out but: build voiceboards from 909 schematics is a hard work I think that it is more comfortable use the Trevor' s boards that are MIDI controlled Antonio
Elektruck Posted November 20, 2012 Posted November 20, 2012 I need also some help for connecting switch and led to DIN and DOUT :) Hey, I builded the MB808 sequencer as a standalone midi drumsequencer. I didn't know how to connect the din/dout pins but came across a file from a forum member who did modify the code to use less shift registers. I used this file to find out the original pinout and made a pinout overview myself. I'll attach both files to this message. Maybe you can use them. I'm also looking forward to the new 9090 drum sequencer, I hope there's a bulkorder for the PCB soon! Cheers, Roel808 hardware config.pdfMB808 drumseq pinout.pdf
jojjelito Posted November 20, 2012 Posted November 20, 2012 There are headers for "raw" triggers and velocity/accent data on Trevor's 9090 boards as well. I don't know if Jozef's PCB uses MIDI, or if he talks directly to those headers. If he does you're in luck as the adaptation to 808 boards would be less work.
TK. Posted November 20, 2012 Posted November 20, 2012 Just to clarify: together with Al (aka. kogz23) I'm working in this one which will be PIC based: http://www.ucapps.de/tmp/mbdr_proto1.jpg Actually a slightly enhanced MB808 firmware with support for velocity. Al will run a batch order for PCB and frontpanel soon. Jef (aka. pcbatterij) works on this one: http://midibox.org/forums/uploads/gallery_8996_152_12242.jpg It's a modified MBSEQV4, he works independent from me on the firmware changes. Best Regards, Thorsten.
Antix Posted November 20, 2012 Posted November 20, 2012 (edited) There are headers for "raw" triggers and velocity/accent data on Trevor's 9090 boards as well. I don't know if Jozef's PCB uses MIDI, or if he talks directly to those headers. If he does you're in luck as the adaptation to 808 boards would be less work. You are right what I am trying to say is : if you have the Trevor boards why dont use MIDI control ( as is implemented already ) and save a lot of work in wiring triggers with an external drumsequencer? Edited November 20, 2012 by Antix
jojjelito Posted November 20, 2012 Posted November 20, 2012 (edited) Well, there's the 1ms note on delay for a MIDI note on event if you're really picky about your timing :fear: But no, it's not that important in most use cases. Unless you stack 8 or so drums on the same measure. You could hear some flam effect then. Edit: The TK/Kogz23 begs for an OLED display if custom characters are defined as the normal HD44670 LCDs. It will be crisp looking :whistle: Edited November 20, 2012 by jojjelito
zephyrin Posted November 21, 2012 Author Posted November 21, 2012 (edited) if you have the Trevor boards why dont use MIDI control ( as is implemented already ) and save a lot of work in wiring triggers with an external drumsequencer? There are a circuit triggers on the 9090 over J30 DATA and J31 CTRL (just only 10 wire) , i don't know how it's work but someone are using J30 DATA and J31 CTRL here for building the sequencer of his 9090 without used midi MR9090 There are headers for "raw" triggers and velocity/accent data on Trevor's 9090 boards as well. I don't know if Jozef's PCB uses MIDI, or if he talks directly to those headers I think it's J30 and J31? Jozef only use midi. The MB9090 use only 8 74HC595, i m supposed that we can add some other 74HC595 via (DOUT) for triggering the 9090 boards via J30 and J31 Edited November 21, 2012 by zephyrin
