John E. Finster Posted April 25, 2014 Posted April 25, 2014 (edited) Hi, I finally came around and compiled a brief tutorial on how to create glcd fonts for Midibox NG. It can be found on my wikipage here. I hope it´s comprehensable. If any questions arise, don´t hesitate to ask. I will try to help as well as I can. Also, if you find any mistakes I might have put in, just tell me. Have fun! my regards EDIT: Update 01.05.2014: Small changes, mostly fixing linguistic errors and adding additional hints. EDIT: Update 11.05.2014: - Tutorial now on seperate wiki page - including "little helpers" section with usefull designing apps Edited May 11, 2014 by John E. Finster
FantomXR Posted May 2, 2014 Posted May 2, 2014 (edited) Hey, thanks for the tutorial. But I'm stucked at the perl-point. The perl-script says: ERROR: Wrong Pixel Size - expecting x = 192! I double checked everything. I converted the file first to bmp, than to xpm like described in the tutorial. I also tried to export it directly to xpm. Any tipps you can give on that? The file has a size of 192x128, exactly like your example... //edit: Ok... solution: It has to be black and white... no grayscale... I overread this point... let's go on ;) Edited May 2, 2014 by FantomXR
John E. Finster Posted May 3, 2014 Author Posted May 3, 2014 @FantomXR Glad you got it to work :happy: . Maybe you could post a picture of your work once you´re done, I´m pretty curious. @TK Thanks. I hope it will be of some help to others.
FantomXR Posted May 3, 2014 Posted May 3, 2014 In the meanwhile I deleted the font I was using. I realized that it's hard to find a good-looking font. Because all fonts are using not only black/white pixels but also gray and gray is not supported, it looks very different after the conversion. So maybe I will stick to the standard fonts that come with NG for the first time. I'm more interested in getting the HD-bars running ;)
John E. Finster Posted May 3, 2014 Author Posted May 3, 2014 Yeah, it is tough to create good looking fonts if they have to be a) this small and b) only black and white. If you´re looking on the internet, then try to find some dedicated lcd fonts or particular small or squared fonts as a template. I think the true potential here lies in creating nice icons or bars, especially since the original glcd fonts from TK are nice to look at and functional.
FantomXR Posted May 4, 2014 Posted May 4, 2014 Here is a recommondation for an application: http://www.lmnopc.com/bitmapfontbuilder This program converts fonts to bmps. You can set the resolution you want. After that you have to do a bit of size editing in GIMP, but its A LOT easier, than putting the puzzle in GIMP together. Check it out! I just put Arial into MBNG quite easy... (well... The resolution I choosed was a bit high so one letter fills the whole display... but... it works).
FantomXR Posted May 4, 2014 Posted May 4, 2014 Also you should check "knobman". It's a nice tool to create pots. I will give it a try these days.
John E. Finster Posted May 11, 2014 Author Posted May 11, 2014 Thanks for these tipps. Both are very usefull apps. I included them in my tutorial und updated it. For other changes see initial topic.
Marxon Posted August 24, 2014 Posted August 24, 2014 Hi John Great usefull tutorial! I immediately started to create some bigger knobs. Unfortunately GIMP shows this error when exporting the .bmp as a .xpm file I also tried "XPMEdit" and "AutoImager" to convert the bitmap. But converting these .xmp files leads to useless .inc files. Do you know what could be the reason? Or would you convert my .bmp files for me, please? https://drive.google.com/file/d/0B-plp4B8LLvaUnlTaXJiTXhuWnM/edit?usp=sharing Best regards Marxon
mono Posted August 24, 2014 Posted August 24, 2014 (edited) ...heres one more tip from me: instead of using hundreds of programs for thousands of uses, stick with one program that is more versatile! eg. for creating icons/fonts use a spreadsheet. attached is an example of how i create fonts in excel. no converting issues, no looking for converters, etc...its really great for all sorts of code-related stuff, in fact any spreadsheet will do the job...;-) Edited August 24, 2014 by mono
John E. Finster Posted August 24, 2014 Author Posted August 24, 2014 (edited) Hi Marxon, I just converted your *.bmp to *.xpm with Gimp Portable 2.8.10 (see attachement). No problems here... Unfortunately I can´t tell what the problem might be on your end. I´ve not seen this error before. If I had to take a guess I would say maybe there is an issue with the file path (dots, exponents). I´ve encountered errors with paths like this before. Not necessarily with Gimp, but with other Apps. Other than that I´m afraid I can´t be of much help. Your *.bmp looks fine, the *.xpm I created seems to be in order and ready for further processing. Till you get around this problem I´m happy to convert your *.bmps. Just pm me. @mono: Nice work with the spreadsheet. I´m not that deep into excel, so I can´t entirely follow your process. Maybe you could upload a sample sheet, so I can have a deeper look. Greets knob48x48.zip Edited August 24, 2014 by John E. Finster
mono Posted August 24, 2014 Posted August 24, 2014 @john: thanks! like your wiki regarding fonts as well! the only thing that i dont get are all these seperate programs for drawing and converting. this is why i have made my own in excel. its nothing complicated either! the first column is the ascii-code (hex), the 2nd is the character in a normal font, the 3rd is the character taken from a truetype-font, then the pixel-drawing (done with conditional formatting) plus the bits for the code. they are then just added binary into decimal and the last column tells you the hex-value. no need for seperate programs... i cant upload that spreadsheet now, because it contains much more "private" stuff, but i will upload an example tomorrow. i have done characters for dot-matrix-displays with excel as well! the point is, that normal lcd-characters are small and i believe using a "paint"-like program for that is a bit over the top. i have done similar stuff on my amiga about 20 years ago. the converting bit is just not worth the hassle, especially because theres only one bitplane on lcds :-) . with excel you get exactly, what you want. you simply copy the last column into a text-editor of your choice :-) and make up your include-file for the compiler. eg. im using sublime-text, which comes with macro-functions to do this type work. kind regards, mOnO
