Phatline Posted May 28, 2018 Posted May 28, 2018 (edited) its time for a Midi - control - Change Looper it records the incoming ccs (from a connected Synth) and sends it looped out again... it needs also note in and midiclock in order to merge it with the cc-automation and send it back to the synth. this device makes sense for synths like the clavia nord rack III where we have ledrings as UI. Features: 4 Midi Channels 128 CCs per Midichannel 4 Pitchbend tracks 256 or 512 Steps at 32th Resoultuion, depends on Ram Sequencer Tact System standart is 4/4 other systems like 3/4 are set with a CC on the system channel (like programchange) 4 Ledbars to indidacte loop position, and loop length 4x Combined Rec/MUTE Buttons (+shift = Rec) Copy, Paste, Clear Select, Clear all Store Load Button Programchange via Midi, progams saved on SD-Card 2xMidi in, 2xMidi out SMD LEDs, and good Tactial Buttons. Easy Case Design a Plexi-Glas Plate with exact one hole (for loop length encoder) + Rest Wood. a fabricated UI-PCB with J8/j9 connection to plug in a minicore sandwitch. Small PCB with 10x10cm max to reduce costs to minimum -a bulk order some prototypes if interest... have to order anyway about 5 pcbs at minimum... pretty much of the code i have already done by other applications(MSQ-CC-BCR, MSQ-CC-LRE, Filterbox...), i just have to adapt the code and strip down a bit, to get ram free for the 512 steps. Edited July 31, 2018 by Phatline 1
Phatline Posted June 8, 2018 Author Posted June 8, 2018 (edited) PCB-Design: with STM32 Discovery Board... + 4x Midi Sockets/Cables which are not on PCB --- they have to be mounted on Housing. OBSOLATE: (the design is finally done with dipCoreF4 as brain CC_Looper.zip Edited October 10, 2018 by Phatline 1
Phatline Posted July 20, 2018 Author Posted July 20, 2018 (edited) i overworked the whole thing... now the usb ports are free, and all connectors are on back-location OBSOLATE: (the design is finally done with dipCoreF4 as brain Edited October 10, 2018 by Phatline
pat_00 Posted July 31, 2018 Posted July 31, 2018 This looks great! I'm interested to see it in operation... 1
Phatline Posted September 14, 2018 Author Posted September 14, 2018 (edited) i overworked the whole thing - now it operates with the "dipCoreF4" Edited October 10, 2018 by Phatline
Antichambre Posted September 14, 2018 Posted September 14, 2018 I understand now, you did not explain me that you wanted to use the mini-USB directly to the back of your machine. The connector will not flush the backside, you will need a cut-out of the size of the plastic body connector part. Visually this is not beautiful but mechanically it's better and stronger. Your schematics seems fine for me. Your project could be a good companion for the LoopA. Do you plan to implement Sysex commands? Best Bruno
Phatline Posted September 14, 2018 Author Posted September 14, 2018 loopa xmas.... triggematrix. a keyboard ... loopa ... a cc looper looped nordrack 3... dupdiduu ;) its a remote device built to be a midiclock slave. it takes clock.start stop as usual. cc looper get remoted via cc (from the master 4 examle loopa in my case triggermatrix by songparts selecting like ableton) select bank and pc (pc as standard pc message + bank via cc..). store and load. set the tactsystem 3/4 4/4 5/4..... havenot need sysex so far just a few ccs . all the other functions (play record looplength copy clear paste whole sets or single selected cc automations are set on cc looper itself and will be saved on sd card as pc loadable file - which itself has non-standard :)
Phatline Posted September 14, 2018 Author Posted September 14, 2018 hot glue on the usb socket. and a big hole as usual no problem. planned is remote record for the 4 parts. as already implemented in the cliplauncher of triggermatriX (cc command) also on device is footswitchjack which act as record/play button for currently selected part. ... i will screw the jack directly on the housing. a footswitch turnt out to be "handy" :) to tweedle and record multiple ccs...
Antichambre Posted September 14, 2018 Posted September 14, 2018 Just now, Phatline said: hot glue on the usb socket You don't need, it's a THT ;)
Phatline Posted September 14, 2018 Author Posted September 14, 2018 nice ! @_sysex: the callback if needet could be a problem because of only one Midi out din socket... the second out is only available as 3pin header. the houseing will be very flat so no place to mount. maybe with a 3.5 jack or something...
Antichambre Posted September 14, 2018 Posted September 14, 2018 (edited) Not very regulatory but you can use the two other pins of your DIN5 Out and make a short Y cable Male to dual Female. This will not be a problem to connect a single and regular MIDI cable too. Edited September 14, 2018 by Antichambre 1
Phatline Posted September 14, 2018 Author Posted September 14, 2018 Just now, Antichambre said: Not very regulatory but you can use the two other pins of your DIN5 Out and make a short Y cable Male to dual Female. This will not be a problem to connect a single and regular MIDI cable too. good input, will integrate that! 1
Antichambre Posted September 15, 2018 Posted September 15, 2018 10 hours ago, Phatline said: cc looper get remoted via cc (from the master 4 examle loopa in my case triggermatrix by songparts selecting like ableton) select bank and pc (pc as standard pc message + bank via cc..). store and load. set the tactsystem 3/4 4/4 5/4..... havenot need sysex so far just a few ccs . I figured you'd need sysex for the commands to leave the CCs totally free for record/play.
latigid on Posted September 15, 2018 Posted September 15, 2018 9 hours ago, Phatline said: good input, will integrate that! If you use a non-standard protocol, consider using a different connector e.g. a DIN5 240/270 degree pin pattern.
Antichambre Posted September 15, 2018 Posted September 15, 2018 (edited) 1 hour ago, latigid on said: If you use a non-standard protocol, consider using a different connector e.g. a DIN5 240/270 degree pin pattern. He wants 2 regular MIDI Out on the same connector, If he chooses a DIN5-240/270° he will not ba able to connect a regular DIN5-180°(when only one MIDI out needed). but he can choose a DIN7-270° to avoid any problem with a SYNC24 pinout. Edited September 15, 2018 by Antichambre
Antichambre Posted September 15, 2018 Posted September 15, 2018 Digikey has 4 references in stock:https://www.digikey.com/products/en/connectors-interconnects/circular-connectors/436?k=&pkeyword=&pv69=367&sf=0&FV=160000f%2C35c00b1%2Cffe001b4&quantity=&ColumnSort=0&page=1&stock=1&pageSize=25 Mouser:https://www.mouser.fr/ProductDetail/Switchcraft/62PC7FS?qs=sGAEpiMZZMtAYTMy7wxAr13KGyWtEeUKoNdfSl%2fLnxo%3d You can also use DIN8-270° Like this one https://www.mouser.fr/ProductDetail/CUI/SDF-80J?qs=%2fha2pyFadugMOpW%2fmtqhOULV0YI0Vc4gflcNSjtzoJM%3d which is cheaper.
Phatline Posted September 21, 2018 Author Posted September 21, 2018 i addet the suggested DIN7 - thx. i ordert the prototype pcbs - should get it in 8-25days ...next thing is mouser boom... at least 8days time for that. these is the final proto-design:
Hawkeye Posted October 9, 2018 Posted October 9, 2018 Looking good! :) Just out of curiosity, how many CC samples can you store on a track (resolution)? Will you support more inputs than one CC per track? I've recently found some unused memory on the LoopA and was thinking of limited CV support, too. But it will be a single CC per track only at limited resolution. So yours will be the dedicated machine for it, for clean filtersweeps and such, no competition there, no worries! :) Many greets, Peter
Phatline Posted October 9, 2018 Author Posted October 9, 2018 4Midichannels @ each 512Steps X 32th X 128 CCs of course only a few of the 128CC should be used @ once - 4x128xCCs @ 32th is Midi Data MESS and µC Death maybe only 256Steps, will depend on RAM.... RealWorld will tell each TRACK has a shared Track length for all its 128 CCs, The Whole Track can be copied, or a single CC. There is no EDIT, you can erase a CC or Track and make it new/override CC-Looper need a Synth with LEDRINGs -otherwise you have no Feedback and Overview. --- for Synths without LEDRINGS i take MSQ-CC-LRE http://wiki.midibox.org/doku.php?id=msq-cc-lre - it has 8x32CCs and can automate them, and Save and Dump/Recall-them - CC-Maping is Hardcode.
Antichambre Posted October 9, 2018 Posted October 9, 2018 4 minutes ago, Phatline said: RealWorld will tell I should receive the dipCoreF4 boards on Monday, you will be able to test it quickly ;) Best Bruno 1
Phatline Posted April 5, 2020 Author Posted April 5, 2020 First Prototype, First Working Firmware ( a lot of bugs, and not all features implemented) --- but enough for a teaser ;) 1
Hawkeye Posted April 5, 2020 Posted April 5, 2020 Good job and cool visualization with the mini LEDs! Many greets, Peter
Antichambre Posted April 5, 2020 Posted April 5, 2020 (edited) Hi Mike, I will ask for an UPS or DHL shipping on Monday, I know they continue to work... Cause you really need it, it will be better for next demo ;) Do you intend to create a dedicated case or will you leave it like that? I improved the VELOCITY part of the HAARP into an "ANIMATION" part which now applies to Velocity and CC but only 1 CC. So, as I suspected, the CC-Looper could be a very good partner for the HAARP. I really have to make a video like this for the HAARP, but my English spoken will be a disaster lol. Best regards Bruno Edited April 5, 2020 by Antichambre 1
