Phatline
Hello,
So I persisted in this direction, here is what results.
I took your notes into account, it may be able to meet your requirements too.
I designed a DIP40 PCB with the necessary MIOS32 features on board. The dipCoreF4.
It matches the main functions and pins of a MIOS8 PIC, I think I will try to put it in my SammichSID change the LCD for an ssd1322 and see what happens ;)
It also fully matches the MIOS32 ports and features with some slightly changes. It's a very small Core you can put everywhere easily.
fetch.php?media=antichambre:1808_dipcore
I designed the mbhp which comes with it. The dipBoardF4.
Size is 65x46mm.
It is compatible with Andy's wCore USB and RES-SD modules.
fetch.php?w=500&tok=0481d1&media=anticha
Check the dokuwiki pages and tell me if you want to try it.
For the name, I'm still hesitating with dipCoreF4 ?!
Best
Bruno
Edited by Antichambre
  • Like 2
1 hour ago, latigid on said:
Cool development!
I just sent you a message ;)
If you like, I still have some of the USB PCBs around (maybe res-SD too). All wCores come with the USB attached; there's no current plan to sell them separately.
Ahhh! Totally forgot this. I will draw new modules too... different but still compatible...
  • Like 1
