latigid on Posted February 11, 2019 Posted February 11, 2019 (edited) Prototype of an 8x "DOUT" module. It is a simple build of two stacked PCBs called "binaire" and "octal". I reckon it can be done in an hour or less. In the SEQ v4+ context it can be configured as 8 gates, in combination with 8 CVs (in the works) 8 configurable clocks, or 7 clocks plus one start signal 8 triggers. Up to 64 triggers can be generated with the SEQ! Each output has an LED that illuminates with a positive gate. The modules are designed to be easily chainable, so decide how many are needed in your system. 4HP width. It would also work with other SEQ versions. More info to come! Edited February 11, 2019 by latigid on 1
southpole Posted February 13, 2019 Posted February 13, 2019 awesome! i was just about to mount an AOUT_NG to a eurorack panel... but if this is based on the same schematic as the AOUT_NG, i might save the components and wait with building for this more compact solution :-)
latigid on Posted February 16, 2019 Author Posted February 16, 2019 (edited) Thanks for the feedback! Re: AOUT_NG: in the MIDIbox paradigm, CV/gate is split into AnalogueOUT and DigitalOUT modules. The assembly above is the DOUT side, which was previously available as a PCB build using a DOUTX4 module, but you needed to provide your own 3.5mm jacks. There have been various solutions over the years, like using Ken Stone breakout PCBs, also Altitude did a combination that had eight each of CVs/gates/clocks/triggers. The AOUT side will be a different design to AOUT_NG. I had a previous incarnation in through hole, but this version is more compact and simplified. (The other one had CV range switches and fine-tune control, but was only four channels in I think 10HP.) Here's a teaser of transmute8 fresh from OSHPark (thanks for the image Peter!), not tested and won't be for a little while. Hope you like 1206 resistors (or 0805 if you wish!)! Best, Andy Edited February 16, 2019 by latigid on
southpole Posted February 16, 2019 Posted February 16, 2019 yes i like 1206, just received a set from the land in the middle. unfortunately some of the boxes had opened in transfer so at some point i have to put the crumb puzzle back together (unless i got lucky and the required values are in the properly closed boxes)...
goyousalukis Posted February 19, 2019 Posted February 19, 2019 (edited) That looks great! I took another route, and built a breakout panel in-between two rows of 3U in my case. I do have a quick question: In your circuit, do the lights blink even if nothing is plugged into the jack? (looking at the picture, it looks like it does). On mine, I have an LED installed, and I've gotten it to blink when it is driving something, but it doesn't blink with nothing connected. I tried a simple BC547 circuit, but no luck. If yours does, I would love to see the schematic! Edited February 19, 2019 by goyousalukis
latigid on Posted February 19, 2019 Author Posted February 19, 2019 Feel free to post/link your circuit and I can see. Mine is quite different though and uses buffers etc.
goyousalukis Posted February 19, 2019 Posted February 19, 2019 I was using the top right corner of this schematic from the YuSynth gate delay, except connecting the base of the transistor to the DOUT module.
Antichambre Posted February 19, 2019 Posted February 19, 2019 (edited) 53 minutes ago, goyousalukis said: I was using the top right corner of this schematic from the YuSynth gate delay, except connecting the base of the transistor to the DOUT module. Interesting, based on this diagram the LED should work without something connected, except if the load is a lot less than 10K, is your jack has a kind of bypass inside? Maybe the jack put the output to the ground internally when there's nothing plugged? Edited February 19, 2019 by Antichambre
latigid on Posted February 20, 2019 Author Posted February 20, 2019 It would be better to see the actual connections or even a photo of the circuit... Presumably the transistor base is connected to the 220R resistor of a DOUT pin? Normally I use 1k resistors for setting the NPN base current, but it probably doesn't matter. Plugging something into the jack might create a voltage divider? Also, this circuit is trying to source current out of the NPN. The LED/resistor should rather be connected to the collector.
Antichambre Posted February 20, 2019 Posted February 20, 2019 (edited) 1 hour ago, latigid on said: Plugging something into the jack might create a voltage divider? Yep, here the voltage depends on the Impedance connected to the GATE OUT for sure! The Voltage applied to the 547 base is between something like 3,6V with Z=0 and approximatively 11V with Hi-Z, strange. Led current depends on it too, between 1,5mA and 9mA. This will work better: But it's 15V gate. A bit less because of the diode. Edited February 20, 2019 by Antichambre
goyousalukis Posted February 20, 2019 Posted February 20, 2019 Thanks guys, I'll give that a shot. I unhooked the transistor a while back, trying different solutions, so I don't have a photo. It is for a Eurorack, so it is actually 12V, not 15. I was just using the schematic as a starting point. I was using the 220 ohm resistor. Sorry for hijacking the thread!
TheMentat Posted September 20, 2019 Posted September 20, 2019 How does one get the SEQ to fire off the triggers in D3? I can get the clocks and AOUT working. Should I have a DOUT option in the Port? Is that a change I need to make in the configuration file or something?
latigid on Posted September 20, 2019 Author Posted September 20, 2019 You need to assign the shift register to the triggers in the HWCFG. Then the triggers should work on AOUT channel 16. Quote DOUT drum gates/triggers Notes to AOUT Channel #16 (C-1, C#1, D-1, ... upwards) will be redirected to up to 64 digital outputs of the DOUT chain. Each key number triggers an individual gate for 1 mS, accordingly this mode is predestinated for drum triggers. The used shift registers have to be defined in the MBSEQ_HW.V4 file (DOUT_GATE_SR1..8) With the new firmware version you can adjust the pulse time of the triggers.
lukas412 Posted October 17, 2019 Posted October 17, 2019 (edited) How do you configure the clocks? Never mind I found it! In the cv page. Edited October 17, 2019 by lukas412
kaiserzop Posted May 18, 2022 Posted May 18, 2022 (edited) How does one get the SEQ to fire off the triggers in D3? techzpod stream free movies Edited May 20, 2022 by kaiserzop
latigid on Posted May 18, 2022 Author Posted May 18, 2022 For this, set up a note track on AOUT port channel 16 Note 16 DOUT drum gates/triggers Notes to CV Channel #16 (C-1, C#1, D-1, ... upwards) will be redirected to up to 64 digital outputs of the DOUT chain. Each key number triggers an individual gate for 1 mS, accordingly this mode is predestinated for drum triggers. The used shift registers have to be defined in the MBSEQ_HW.V4 file (DOUT_GATE_SR1..8)
