TK. Posted June 1, 2004 Posted June 1, 2004 Hi,the new version allows to edit the additional parameters of MIDIbox SID V1.6 (curve, assigns, phase synchronization, keyboard zones):http://www.midibox.org/midibox_sid/jsynth_018_with_mbsid_rel6.zipAlso the layout has been improved - now we have some nice knobs instead of faders :)Best Regards, Thorsten.
bosone Posted June 1, 2004 Posted June 1, 2004 thanks thorsten!!just one question: when do you go to sleelp?? ;D
TK. Posted June 2, 2004 Author Posted June 2, 2004 It was my MIOS robot who posted this article ;-)Best Regards, Thorsten.
adamjking Posted June 3, 2004 Posted June 3, 2004 Hi Thorsten,I'm not sure if this is covered anywhere on the midibox/ucapps site - but is there a section with links to tutorials/tips/how-to's/etc for writing applications?I know this is mainly a hardware site, but for those of us with programming skills who (inspired by this great work) wish to create programs for interacting with their hardware, a list of resources for using MIDI/sound with Java (for its cross-platform abilities) might be a good idea. What do you think?Cheers.
TK. Posted June 3, 2004 Author Posted June 3, 2004 Hi Meeshka,What do you think?I've no oversight about the current software projects for MIDI, so this is something which has to be driven by the community.Best Regards, Thorsten.
goyousalukis Posted June 5, 2004 Posted June 5, 2004 Hey Meeshka, I have been working with Java a bit. I have been writing a jsynthlib editor for my korg MicroKorg, and I wrote a ROUGH midi step sequencer. If you want, you can email me to compare notes. Justin@Ahrens.NetJustin
RadicalAns Posted August 3, 2004 Posted August 3, 2004 Hey Meeshka, I have been working with Java a bit. I have been writing a jsynthlib editor for my korg MicroKorg, and I wrote a ROUGH midi step sequencer. If you want, you can email me to compare notes. Justin@Ahrens.NetJustinoooo a microKorg interface. :) Sounds awesome! Any chance I could have a look?David
goyousalukis Posted August 18, 2004 Posted August 18, 2004 David, I'd be happy to send you a copy. I am on vacation right now. When I get back, I'll let you know. It is still a little rough. I have been figuring out the sysex format via trial and error.Justin
RadicalAns Posted August 18, 2004 Posted August 18, 2004 Sweet!! PM me when you get back. Have fun vacationing!
Jurbo Posted September 23, 2004 Posted September 23, 2004 A stupid question: how do I start the program? I have Java Runtime installed, but can't start the program. Is the .class file the "executable"? ???
illogik Posted September 23, 2004 Posted September 23, 2004 i think you have to start the program via a command shell, but i'm not sure; there is an installation "tutorial" on the jsynthlib website.if you follow that info, you should be able to figure it out.good luck, marcel
Phattline Posted September 29, 2004 Posted September 29, 2004 another question: or better a problem:With my old jsynth I had no problems but with this baby-When I click to edit a bank, ->the normal bank comes and under 1 second later a message comes: ERROR! no patch is selectet! OK I click ok (in the hope to mark some patch) under 1 second later the same message I cant do anything-yea ofcourse strg alt entf ;DWhats the problem: I have Installed: win98-2 and Java 2 runtime environment standart editon v1.3.1_11
TK. Posted September 29, 2004 Author Posted September 29, 2004 I don't know why this should happen, anyhow - it makes sense to update java to >= 1.4.2 due to the better MIDI supportBest Regards, Thorsten.
goyousalukis Posted September 30, 2004 Posted September 30, 2004 I have seen this error a bunch of times while working on my own editor. I believe it is a problem with jsynth. My usual solution has been to restart the computer. Sorry I can't help more.Justin
Phattline Posted September 30, 2004 Posted September 30, 2004 After I downloadet the new java - its running great
Tanstaafl Posted October 1, 2004 Posted October 1, 2004 Nobody really answered Jurbo's question about running JSynth....I have the same problem. According to the docs, there is a JsynthLib.jar file. Where do you get that? I have downloaded all of the stuff from the JSynthLib site but do not find a file by that name. and (if i am reading the docs correctly) that is what gets called in the batch file.is that jar file a part of JSynthLib, or is it located somewhere else on the web... sun... tucows....? i've googled for it and it only appears on the JSynthLib faq .have not built the mb-sid yet but do have about 5 c64,128,amiga's in the attic.c yagb
Phattline Posted October 1, 2004 Posted October 1, 2004 Hi Yurbo and gbethI can only say what to do under wiiindoooows98-2Do you have a actually version of Jaaava like: 1.4.2.05No: www.java.com download it! and install it!Do you have downloadet Jsynt, of course yes!- take a look in the folder: and start (- click at) the run icon (a dos icon) This programm print config loadet-and after this a window is opend (you must wait a while when you have a "slower PC)Yea here is Jsynth lib. Go to config -> prefences -> midi -> take windows wire providerGo to config - synth - click add device - seek midibox sid in the list -click it- Then select the midiportsHave you downloadet the example patch?No - download at www.ucapps.de->mbhp projects--Midibox Sid-> under Sound patches: example patchesYes- Then open it- (libery - open) Now there is a new patch - click rigth mouse switch- -> editNow you have the screen with the controllers and dont forget to press cc on your sid - Thats all I can say up to now.Hope that helps
Tanstaafl Posted October 1, 2004 Posted October 1, 2004 i get this error when i run the batch file....Exception in thread "main" java.lang.NoClassDefFoundError: JSynthLiband get spat out.i don't have a JSynthLib.jar file... i do have a .class and a .java file.
Phattline Posted October 2, 2004 Posted October 2, 2004 " don't have a JSynthLib.jar file... i do have a .class and a .java file."I also dont have a JSyntLib.jar file - Yes I have it in the old version-but not in thisTAKE RUN--RUN is the icon you need-
Tanstaafl Posted October 2, 2004 Posted October 2, 2004 found the old version... seems to work.. kindai will play with it this weekendhave a better one!gb
goyousalukis Posted October 2, 2004 Posted October 2, 2004 If you download the JSynthLib from Thorsten's site (uCapps.de) , and double click on run.bat, you shouldn't have problems. There is no jar file. The batch file just does "java JSynthLib". The NoClassDefFoundError means that it isn't finding JSynthLib.class. It is in the same directory as the Run.bat right? You could also add "PATH=c:\whatever directory JSynthLib is in" to the top of the run.bat file.Justin
