niles Posted April 20, 2025 Posted April 20, 2025 (edited) Hey everyone, just wanted to share my latest build since I'm sure there are some 3D printing enthusiasts here like myself. I bought the parts for an MB6582 about 5 years ago, if you remember Meeblip was selling those 8580 SID chips and I picked up 8 of them, and then put everything into a box in a closet . 3D printing has come a very long way since the original MB6582 was created by Wilba. I read that the JB Weld solution may or may not be holding up great after all this time. Also, I wanted to use a Newhaven OLED which is much thinner than the original LCD. I thought there must be a solution to lower the gap distance so why not create some type of spacer for between the front panel and the PCB? I designed all parts in Fusion360. The PCB screws directly into the spacer using M2.5 nuts/screws and plastic screws. The top of it has a flange that rests in the panel groove for the PT-10. Total spacer height is 5.7mm which is the height of the base of the encoders. The front panel is another 1.25mm. Everything is printed out of ASA, which is very strong and heat resistant. I designed the panel graphics in Inkscape and printed on translucent vinyl. I used Davies knobs with small printed skirts to cover up the threads of the encoders since they were exposed. I do not have a vinyl autocutter but I do have an exacto and lots of patience Overall tried going with a 80s beige computer look. A build plate for my printer created the carbon fiber effect on the panel. I'm happy to share the 3D files if anyone could use them. Edited April 20, 2025 by niles 3
latigid on Posted April 23, 2025 Posted April 23, 2025 Cool solution, looks great! The skirts for the knobs are a nice touch. One thing I wonder about is if heat would build up here, as the free air space in the case is less and the panel is also an insulator. The SIDs are on another PCB of course. 1
niles Posted April 24, 2025 Author Posted April 24, 2025 Thank you :) Yes heat could be something that may be an issue so I will follow that closely. I took Peter's advice from another thread and used heatsinks on the SID chips, at least.
jrp Posted April 25, 2025 Posted April 25, 2025 (edited) This looks amazing! With some of the older chips like vintage vca, filter or delay chips you really have to be careful regarding heat and also (or even more so) static discharge. Nowadays with most ics these issues have long been solved by modern manufacturing processes and built in safety measures. I had to lear the hard way that this is not the case with chips from the 80s... So the heatsink is probably a good idea, as would be any way to allow for some airflow. On the other hand, i have removed the fans from some of my gear with no issues at all, as commercial units have to consider every worst case scenario (crowded rack in hot environment). So if you know how you use your gear you can get away with things that could not be allowed for every scenario. Edited April 25, 2025 by jrp 1
Rio Posted May 12, 2025 Posted May 12, 2025 (edited) you can of course fit it with heatsinks, but it's not necessary. It is normal for the 6581 to get warm/hot, but it is also in their nature to run at such temperatures. if i read it correctly, then there are only 8580 in use and there also a fan installed. I've never had to worry about anything like that (fan/cooler), nor have I ever had any problems during operation. they break when handled incorrectly (ESD). Note the fact that a heatsink, fan or whatever you use is fine, but that is never installed inside an original c64. ... and yes, your device does look cool. Edited May 12, 2025 by Rio
dwestbury Posted May 17, 2025 Posted May 17, 2025 On 4/20/2025 at 6:14 PM, niles said: Hey everyone, just wanted to share my latest build since I'm sure there are some 3D printing enthusiasts here like myself. .... I'm happy to share the 3D files if anyone could use them. I'd love to experiment with the STL file(s) if you're willing to share. A lovely build, with some nice innovations. Cheers!
Smithy Posted July 13, 2025 Posted July 13, 2025 (edited) Absolutely beautiful build and much more affordable front panel design also. If you could upload the STLs to the MB-6582 wiki page under the "Panel Designs" section it would be the best place for them: http://www.midibox.org/dokuwiki/doku.php?id=wilba_mb_6582 Otherwise they will not be preserved for future builders. Edited July 13, 2025 by Smithy
px27 Posted November 10, 2025 Posted November 10, 2025 Quote I'm happy to share the 3D files if anyone could use them. Hi! Wow, well done! Could you please share printing files here?
niles Posted November 10, 2025 Author Posted November 10, 2025 Apologies everyone I just saw these messages. I will make a note of gathering the files tonight and uploading them to the appropriate section here (Thanks Smithy). Thanks everyone for the kind words :) 1
niles Posted November 15, 2025 Author Posted November 15, 2025 Here are the files. If someone could post them to the appropriate location that would be great as I do not see an upload function on the page that Smithy linked to. The front panel was created in inkscape and needs this font: https://www.1001fonts.com/bitwise-font.html The knob_base.stl works with Davies 1900H (and clones) style knobs. This is the only part I printed with a very high resolution of 0.08mm layer height. The rest can be either 0.16mm or 0.20mm layer height, or personal preference. The LED_spacer_standoff.stl's purpose is to hold a series of LEDs in place while soldering so they are the exact height for the PCB_spacer.stl and top_panel.stl. You can slice it in half for fewer LEDs or just print more for the bigger runs like on the mod matrix. I printed out quite a few since they are so tiny. For the top panel: 3D printed face down on a "carbon-fiber style" steel plate to get an interesting design on the top to shine through the vinyl sticker, so that was just personal preference. I printed the SVG 100% (no scale) on a color inkjet printer onto a vinyl adhesive/sticker (https://www.amazon.com/dp/B0BVMZMWCY), applied carefully to top_panel.stl and then just used an exacto to cut the holes out and trim the extra off the sides. Then placed it onto the unit, a small drop of super glue in each corner or thin double stick tape would work also to hold it in place. Then I used superglue to add the knob bases, then the knobs themselves. Hope this helps :) MB6582_STLs.zip
