MIDIbox of the Week (MB64E based Traktor Controller made by PayC)
I didnt know for shure that encoders could be implemented for use in TRAKTOR for fast forwarding and reversing....
Good thing you left that big blank space on both sides of your panel then :D
Thnx a lot for that!  :)
But I really think that the BIG difference in those two boxes only lies in some frontplate design. Just use the same stuff as I do (some sort of self-adhesive inkjet-printable overhead foil) and voila -> wonderful frontplate designs! :)
Its too obvious, ill have to fill up that space.... but i dunno where to find big round spin caps..
And i wasted so much time on that plate, its brushed aluminum 6 mm thick and now i want to change layout (too late).. and the worst part is that  its giving me hard time implementing the buttons... i have 40  9x9 mm click buttons and I dont know ow to put them... Tryed glueing with epoxy but they refuse to hold after few clicks.. :(
You know what? I didn´t have the slightest clue where to get those spin caps, too. So I did them myself! I misused some "normal" knob as a base (especially the screw holding the stuff to the pot/enc shaft is important). The outer stuff is just a plexiglass plate (satiniced) which was roughly brought into shape and then attached to the drilling machine for grinding it exactly round (so I misused the driller as a turning machine). Tadaaa! Spin caps! :)
Are your buttons PCB-compatible? Then you could solder the buttons just as normal to the PCB and attach *THE PCB* to the frontplate with some screws. I do that always and it works out pretty perfect (especially because you save a LOT of screw holes).
Hepls?
Greetz! :D
how do you satinice your plaxiglass
am besten mit 1000er Nasschleifpapier ;) *geheimtipp
sorry for deutsch :P
Regards
MTE
I ordered the Plexiglass already satiniced (cause there´s nearly no difference in pricing). If you want to satinice it afterwards, like MTE said: Just some grinding paper (rough at the beginning going in big steps to finer papers) and circular motions will do.
Greetz & good luck!
  • 7 months later...
  • 2 years later...
can someone share the circuit diagram pls
Stacky, you seem to be asking for circuit diagrams in lots of threads - how about you make a new thread and tell us what you wanna do and we'll see what you need to get there?
  • 2 years later...
