napierzaza Posted March 6, 2007 Report Posted March 6, 2007 I have a question about the USB module. It says you need a 24LC64 eeprom for the project, but I wonder, is it okay to use a Microchip 24LC512-I/PG in place of the 24LC64? I realize that the 512 is hugely larger, but I have a number of those around because I bought 3 and got a couple samples too. I assume I can change it to a LC64 later, but wonder if I can get it functioning with a 512 first?
lylehaze Posted March 6, 2007 Report Posted March 6, 2007 I thought the Cypress AN2131 was pretty hard to get.Have you found a source for that chip?LyleHaze
napierzaza Posted March 6, 2007 Author Report Posted March 6, 2007 I was given the USB module with the SMD already on the board. It doesn't have a eeprom though, so I have to figure that
napierzaza Posted March 7, 2007 Author Report Posted March 7, 2007 Also, is there any information for installing the firmware onto the eeprom in Windows XP? It appears as if it doesn't work (it just doesn't identify the driver files as valid when I browse and find them).I've even dragged them into the System32 folder and no such luck in identifying the module. I even unplugged the eeprom.Starting the ez-usb control panel says there's nothing plugged in.
dj3nk Posted March 7, 2007 Report Posted March 7, 2007 24c512 should work ... but its likely you have an 64 installed.
Lall Posted March 7, 2007 Report Posted March 7, 2007 Hi Napierzaza,I think I remember about such problems as well like it was working on Windows 98 but not on Windows 2000. Unfortunately, I can't absolutely not remember how I did solve the problem. Another option (far less elegant I agree) is to burn directly the eeprom with the code. You simply need to convert the executable using a small program (I don't have it at hand and don't remember the name by heart) and burn it into the eeprom and you're done.Best regards,Lall
napierzaza Posted March 7, 2007 Author Report Posted March 7, 2007 Like I said, or should have said, there was no eeprom on the board, so I was thinking of using a (very definitely) 512k eeprom.Lall... :( I don't know anough about this sort of stuff to use that information, though it seems very close to helping me. If I could burn the eeprom though, however that might be possible... would it work on Windows and other OS'es afterwards or is the USB module completely defunct? It seems like it wasn't very popular and not one has really posted about it since 2003.
kris Posted March 7, 2007 Report Posted March 7, 2007 i was definately communicting to them thru windows 2000 once programmed they should work with newer os's nothing has happened to them to make me beleive that the smd chips are no good if i thought they where complete junk i wouldn't have passed them on good luck kris
TK. Posted March 7, 2007 Report Posted March 7, 2007 Programming works fine under WinXP. Once the module is connected w/o EEPROM, Windows should ask for the drivers.If this message doesn't pop up, than it's very likely an issue with the USB connection, or with the module itself (bad solderings?)A 24LC512 EEPROM cannot be used, as it has a 16bit address register, but only EEPROMs with 8bit address register are supportedHowever, once your module is detected by Windows, and once the Cypress driver is installed, you can temporary upload the mbhp_usb_midi*.hex file through the EzMr Control Panel - you have to do this after each restart manually. With the EEPROM, the firmware will be available permanently.Best Regards, Thorsten.
napierzaza Posted March 7, 2007 Author Report Posted March 7, 2007 Hey, thanks for the responses...Kris, I wasn't implying that the units in particular were bad, far from it, what I was wondering was whether it was a deprecated chip because of OS upgrades etc or something else that might have happened since then. The unit looks in good working condition and the SMD looks to be well done and undamaged! One problem though was that .1uf ceramic caps were used instead of 1uf electrolytic caps, but I replaced those. Thorsten, it indeed asks for drivers when I plug it into my XP machine, I located the folder with the drivers but it responds saying there was nothing in that folder that could be used. Also I had moved the .inf and the two driver files into my System32 folder and it appears to have no effect.Is there something else I should be doing apart from trying to browse,find and select the firmware files? I'm a little spotty on driver installation.I will locate the proper eeprom chip so that I might upload it forever.
TK. Posted March 7, 2007 Report Posted March 7, 2007 No, Windows should just find the drivers in the ez-usb/driver directory.There are alternative drivers available, maybe it's worth a try. Just google for "ezusb driver"Best Regards, Thorsten.
napierzaza Posted March 7, 2007 Author Report Posted March 7, 2007 Really? That's really weird. I'll try and look for alternatives. Does this possibly mean that the eeprom (.bin) file wouldn't work if I happened to upload it? Side note: I was wondering just now whether you had any stats to how many midiboxes were out there, and of which kind. It seems like an interesting idea, I guess Smash/Mike could shed some light but it'd be interesting to know how many were out there.
kris Posted March 7, 2007 Report Posted March 7, 2007 hey napierzaza no offence was taken i was trying to make it clear that i think it could be something simple as you seemed to be getting down with them it was loading the cypress drivers where i had problems good luck kris
napierzaza Posted March 8, 2007 Author Report Posted March 8, 2007 Okay, in terms of eeprom how about a X24C00P? http://www.chipdocs.com/datasheets/datasheet-pdf/XICOR/X24C00.htmlIt says it's a "128bit (16 x 8bit) serial E2PROM"
Lall Posted March 8, 2007 Report Posted March 8, 2007 Hi,Okay, in terms of eeprom how about a X24C00P? That one is unfortunately way too small...Reading the thread I think I remember now having used an alternative driver for the EZ-USB that a friend of mine was using in his company. I can't remember though when the problems started to happen with the official driver. I don't remember if I fucked up something at the install, played with something I shouldn't or simply had bad luck...The fact that Windows triggers you that a new hardware has been found and tries to let you install the corresponding driver would mean to me that the USB is working OK and that the chip is doing the basic stuff it needs to do so that the PC can see it. It looks in a way like the match between the driver and the device found cannot be made. Best regards,Lall
napierzaza Posted March 8, 2007 Author Report Posted March 8, 2007 Okay, just to make sure: If I do find a alternate Windows driver, I can use it to get the thing working, then after that I can upload the .bin provided by Thorston? Or are there other bin files and hex files too?
Lall Posted March 8, 2007 Report Posted March 8, 2007 You're correct, nothing more needed.Note that if you get the alternate (or not) drivers working, you can already play with the chip without an eeprom as these should allow you to load code in the RAM of the chip. That's actually an easier way to make debugging than burning a new image each time in eeprom.Best regards,Lall
napierzaza Posted March 9, 2007 Author Report Posted March 9, 2007 Not sure what you mean by debugging. Do you mean the process of having it identified and then loading the program onto the eeprom? That's all I want to do. If you mean to imply that I'll be writing any code for the USB module... I'm not. I certainly hope the alternate or original firmwares are sufficient.
Lall Posted March 9, 2007 Report Posted March 9, 2007 I indeed meant in case one wants to write/modify code for the EZ-USB.But you don't need to of course :)Best regards,Lall
TheAncientOne Posted March 9, 2007 Report Posted March 9, 2007 Rapid in the UK have 24LC64 for £0.62 plus VAT and Carriagehttp://www.rapidonline.com/productinfo.aspx?kw=24lc64&tier1=Electronic+Components&tier2=Micros+%26+Crystals&tier3=Memory&tier4=Serial+EEPROMs&moduleno=35151They have a lot of other useful stock too. Otherwise I could put some on my next order and do you a swap for something.Hope this helpsMike
napierzaza Posted March 9, 2007 Author Report Posted March 9, 2007 Thanks for the offer, but there's another option that allows me to get the chips without having to bother with VAT and shipping, but I dare not mention what that is.
napierzaza Posted March 14, 2007 Author Report Posted March 14, 2007 Okay, so now I have my eeproms and I'm trying to get it working again. I got some other firmware and stuff but there seems to be and issue. Windows identifies it as a usb device, but that its ID is 0000. WOuld this be the case before you loaded the driver or does this mean theres some physical problem with the module?Also the light in the top left of the module (one of the activity lights) appears to flash now and then, this is strange as there is nothing connected. In the second module no less than 3 of the activity lights are lit, but there are lit statically and don't flash.
TK. Posted March 14, 2007 Report Posted March 14, 2007 You should see the ID 0547 - this is the official vendor ID of EZ-USBWould it be possible for you to test module on another PC?Best Regards, Thorsten.
napierzaza Posted March 14, 2007 Author Report Posted March 14, 2007 Yeah, I can try it at work.Will Mac OS X at least see the id or give information?
napierzaza Posted March 14, 2007 Author Report Posted March 14, 2007 Okay Mac gives this info: Version: 0.04 Bus Power (mA): 500 Speed: Up to 12 Mb/sec Product ID: 0x2131 Vendor ID: 0x0547
