TK. Posted January 20, 2011 Posted January 20, 2011 <very_strong_voice>sammichSwinSid</very_strong_voice> ? :flowers: Best Regards, Thorsten.
nILS Posted January 20, 2011 Posted January 20, 2011 Hehe, I am working on sth that'll fit sammich and mb6582 :thumbsup:
Schrabikus Posted May 9, 2012 Posted May 9, 2012 (edited) Tired of SID hunting and wondered by SwinSID samples I've decided to route dual MicroSwinSID board. Layout inspired by nILS 8515 module. I'm just take NanoSwinSID schematic and combined it with sammichSID. Am I moving the right way? I've replaced hard-to-find crystal oscillator with 74LS04+Resonator circuit which was successfully tested with OPL3 chipset. It cheaper and using available components. Also there's pin header compatible with pin-to-pin cable, like in nILS one. PCB is not yet tested - i need one more atmega chip + core board. But if there's volunteers i'll share it. Edited May 9, 2012 by Schrabikus
Schrabikus Posted May 15, 2012 Posted May 15, 2012 (edited) Couple of questions to Swinkles: 1. Can i substitute Mega88PA with 168? Which of AVR's in DIP package are good for such overclocking? 2. Will it work on lower frequencies? (just for testing purposes, i need to figure out where is proplem - MCU/Oscillator/Communication with core, and not shure that my ATmega168 supports 32 mhz. Will it run with 14.318 oscillator? And i have no scope) At this moment I have constant high-pitched tone during startup, which sometimes dissapears after CS is loaded and sometimes not. Without core and SR's it starts when i'm touching reset pin of Atmega. That's how it looks board prototype: Another question is addresed to Thorsten: You said about Possibility to control two MBHP_SID (stuffed with original SID chips) and one Stereo-SwinSID module in parallel from a single MBHP_CORE Is it possible with Stereo-MicroSwinSID? If so - please give me a hint ;) Edited May 15, 2012 by Schrabikus
TK. Posted May 15, 2012 Posted May 15, 2012 Nice layout work - only 7 bridges and a very pragmatic oscillator! :-) Is it possible with Stereo-MicroSwinSID? If so - please give me a hint ;) Easy: you can connect the address, data and control lines (provided by the outputs of the 74HC595 shift registers) 1:1 with the SwinSID and SID inputs. Also the two chip select lines (coming from PIC) can be shared - one CS for the left, the other CS for the right channel. Best Regards, Thorsten.
Schrabikus Posted May 17, 2012 Posted May 17, 2012 (edited) Thanks Torsten! As I undersdand this is not equal to dual CORE configuration and there's no way to control sids/swinsids independently? (about oscillator: why pay $8-10 per one and wait a month when there's an 30 cents solution from waste components =) But i've modified PCB for use with DIL14S oscillator. Edited May 17, 2012 by Schrabikus
TK. Posted May 17, 2012 Posted May 17, 2012 As I undersdand this is not equal to dual CORE configuration and there's no way to control sids/swinsids independently? No, this is definitely not possible. ;-) MBSID doesn't only stupidly forward MIDI events to the SIDs, it has a sound engine running in background which modulates SID parameters at high resolution and update rate for best results. This sound engine consumes CPU time and RAM, it's tailored around the resources of a single PIC to get the max out of it. Scalability is given by using a dedicated PIC for each pair of SIDs, and by connecting them via a CAN network (e.g. so that only a single control surface is required). Best Regards, Thorsten.
Schrabikus Posted June 5, 2012 Posted June 5, 2012 (edited) I've made atmega8515 based SwinSidX2 but it sounds very strange. Only few default patches working ok. Most of them produces noise. I've found that when filter is enabled it distorts sound. Also if patch has non zero attack/release value - they distorted too. Swinsid extensions enabled in config. Is it normal for swinsid or there's something wrong? (same results with another TDA1543, and on lower oscillator frequencies) Recorded some samples of it sound, they showing attack/release and filter distortions. TK, which firmware youre using with 8515? (i tried both midibox and latest version from Swinkels site)swinsid_bug.mp3 Edited June 6, 2012 by Schrabikus
swinkels Posted June 5, 2012 Posted June 5, 2012 It seems that you are using wrong DAC chip version. Please test firmware for TDA1543A. This should help.
Schrabikus Posted June 6, 2012 Posted June 6, 2012 (edited) It seems that you are using wrong DAC chip version. Please test firmware for TDA1543A. This should help. THANKS, Man!! This was the only thing i didn't try (DACS labeled "Philips TDA1543" without A). And it works like a charm! Slightly modified Crisp's PCB Edited June 6, 2012 by Schrabikus
Schrabikus Posted June 8, 2012 Posted June 8, 2012 (edited) igi wrote me about oscillator tuning bug, so i've checked and confirming: by default oscillators finepitch is 12 units lower (not cents, 12/127 semitone?) so you need to set finetune to +12 for every oscillator to be in tune. We need your help again, Swinkels! :logik: Is it clock/oscillator or firmware related? Crisp,(and other Swinsid users) do you have the same bug? Edited June 8, 2012 by Schrabikus
swinkels Posted June 8, 2012 Posted June 8, 2012 Yes it is related to clock source and firmware, so you need special MIDIbox firmware to get proper pitch. PAL C64 uses 0.985MHz clock, so the firmware can't work with both sources equally. Unfortunately there is no MB firmware for TDA1543A but i will try to compile it for you.
Schrabikus Posted June 8, 2012 Posted June 8, 2012 I will be very appreciated! :flowers: And other SwinSIDx2 users too.
Schrabikus Posted June 14, 2012 Posted June 14, 2012 Confirm that MB_StereoMicroSwinSID PCB is working! Here is final version (added DIL-8 oscillator)stereoswinsid_mbfm_v2.pdfstereoswinsid_mbfm_v2.zip
trilader Posted June 16, 2012 Posted June 16, 2012 Confirm that MB_StereoMicroSwinSID PCB is working! Here is final version (added DIL-8 oscillator) Very nice. I tried to make my own version of this a while ago and failed horribly. Can you post a part list for this?
Schrabikus Posted June 17, 2012 Posted June 17, 2012 (edited) Part Value Device Package Library Sheet AUDIO_OUT PINHD-1X3 1X03 adafruit 1 C1 100n C-EU025-024X044 C025-024X044 rcl 1 C2 100n C-EU025-024X044 C025-024X044 rcl 1 C3 100n C-EU025-024X044 C025-024X044 rcl 1 C4 100n C-EU025-024X044 C025-024X044 rcl 1 C5 100uf CPOL-EUE3.5-8 E3,5-8 rcl 1 IC1 74LS04N 74LS04N DIL14 74xx-eu 1 IC2 MEGA88-PA MEGA88-PA DIL28-3 atmel 1 IC3 MEGA88-PA MEGA88-PA DIL28-3 atmel 1 IC4 74HC595N 74HC595N DIL16 74xx-eu 1 IC5 74HC595N 74HC595N DIL16 74xx-eu 1 J14 PINHD-1X1 1X01 adafruit 1 JP1 PINHD-2X4 2X04 pinhead 1 JP2 PINHD-1X2 1X02 pinhead 1 JP3 PINHD-1X2 1X02 pinhead 1 Q1 32mhz CRYSTALHC49S HC49/S crystal 1 QG1 32mhz QG5860 DIL14S crystal 1 QG2 32mhz XO-8 DIL08S crystal 1 R1 1K R-EU_0204/7 0204/7 rcl 1 R2 240K R-EU_0204/7 0204/7 rcl 1 R3 1K R-EU_0204/7 0204/7 rcl 1 R4 2K2 R-EU_0204/7 0204/7 rcl 1 R5 4K7 R-EU_0204/7 0204/7 rcl 1 R6 470 R-EU_0204/2V 0204V rcl 1 R7 470 R-EU_0204/2V 0204V rcl 1 R8 1K R-EU_0204/7 0204/7 rcl 1 R9 240K R-EU_0204/7 0204/7 rcl 1 R10 2K2 R-EU_0204/7 0204/7 rcl 1 R11 1K R-EU_0204/7 0204/7 rcl 1 R12 4K7 R-EU_0204/7 0204/7 rcl 1 omit IC1,Q1,R6,R7 and one of OG, if you have oscillator. And there will be one more revision with decoupling/filtering added. Edited August 18, 2012 by Schrabikus
Schrabikus Posted June 20, 2012 Posted June 20, 2012 (edited) Here is fixed with a help from Swinkels version with filtering/decoupling caps added.stereoswinsid_mbfm_v3.zip Edited June 20, 2012 by Schrabikus
trilader Posted August 12, 2012 Posted August 12, 2012 Could you please post an updated list for the new version and could you also clarify which version of the ATMEGA88 I have to get.
gerald.wert Posted June 9, 2017 Posted June 9, 2017 (edited) I recently built one of these with some 8515. Works great. Was curious why the output filter is a 1K resistor with a 1uF cap. That seems like a high pole for the high pass filter at about 160Hz. Would a 100k resistor be a better selection to set the pole at 16 Hz or is there something I am missing as a reason to set it higher? I am currently running with a TDA1543 if I wanted to use one of the PCM17xx does anyone know where to source the second clock from for SCKI? Also would it sound better if the opamp filter was added as on the data sheet vs the passive? It would seem the design decision was for simplicity and not having to source a differential supply. Also saw this fun tube output idea for the TDA as the output. Not sure I want the 330v in my audio gear though but I may at least bread board it out to hear it. http://www.lampizator.eu/lampizator/REFERENCES/AH%20DAC/AHDAC.html Also is there any opinion of the 88pa version without the DAC versus the 8515 with the dac? It can run a bit higher clock and I have read that it sounds a bit better as it is running a higher sample rate. I saw that some equipment was having issues with the output but no real details on the issue. It can be sized down a bit more so that may be nice as my midi box is in a c64 case and space is at a premium in there. Edited June 9, 2017 by gerald.wert
