4x16 (8x8) Button/Duo-LED programming example
blm_example is now available at http://www.ucapps.de/mios_download.html
I used this small application during the development of the Button/Duo-LED hardware for MIDIbox SEQ V3 in order to check different wiring options. The driver (blm.asm) is mainly based on sm_simple.asm of the sm_c_example1.
Today I added a debouncing option as requested by bugfight
I would like to highlight again, that the hardware as shown in http://www.ucapps.de/mbhp/button_duoled_matrix.pdf needs to be improved for high current LEDs. I don't see this as my task.
Newbies: there are no premade PCBs available, and manual wiring on vero boards requires advanced soldering experiences!
Pictures: http://www.midibox.org/midibox_seq_blm_ext/
From the README.txt
[tt]
Button/Duo-LED Example
Copyright 2008 Thorsten Klose (tk@midibox.org)
Licensed for personal non-commercial use only.
All other rights reserved.
A precompiled binary is already part of this package:
  o project.hex (can be loaded into MIOS Studio)
  o project.syx (can be loaded into any SysEx upload tool)
Following tools are required to recompile the code:
  o SDCC v2.5.0
  o gputils
  o perl
The details are described under http://www.ucapps.de/mios_c.html
Required hardware:
  o one MBHP_CORE module
  o one DINX2 module (or DINX4) and two DOUTX4 modules
    or dedicated board for BLM matrix as specified under:
This program demonstrates the so called "BLM" driver (-> blm.c)
This driver handles a 4x16 Button/Duo-LED scan matrix of up to 64 buttons and 64 Duo-LEDs
by using the circuit documented under:
The hardware was originally used for MIDIbox SEQ V3, but could also be useful for
other projects.
Note that the buttons/LEDs can be easily arranged to a 8x8 matrix w/o software modifications.
Please note also, that the shift register assignments in blm.c (DEFAULT_*) need to be adapted
to your hardware. The setup used in this example is prepared for connecting the
DIN/DOUT chain directly to the MBHP_CORE module (there are no additional DINX4 or DOUTX4
modules between the BLM and the core like on the MBSEQ V3 hardware).
The function "BLM_NotifyToggle()" in main.c is called when a button has been
pressed or released. LEDs are accessible from the blm_row_green[8] and
blm_row_red[8] array.
By default, this application sends Note Events from Number 0 (C -1) to 63 (E 4)
and it receives the same numbers to control the LEDs:
  Velocity 0x00 (or Note off): green and red LED off
  Velocity 0x01..0x3f:        green LED on, red LED off
  Velocity 0x40..0x5f:        green LED off, red LED on
  Velocity 0x60..0x7f:        both LEDs on
Optionally some code can be enabled in the BLM_NotifyToggle function
(located in main.c) to cycle the LED colour with the appr. buttons.
Buttons can be debounced with a definable delay (-> blm_button_debounce_delay)
The resulting delay is calculated as <value> * 4 mS
The Init() function in main.c sets the value to 20 (-> 20*4 mS = 80 mS)
If you want to experiment with different delays, you could (temporary)
control it with a CC event from MPROC_NotifyReceivedEvnt() function in
main.c with following code:
  if( evnt0 == 0xb0 && evnt1 == 16 ) { // control debounce delay with CC#16 over Channel #1
    blm_button_debounce_delay = evnt2;
Don't forget to remove this change, so that a common MIDI application
isn't able to modify the value unintentionally.
Description about the most important files:
  - mios_wrapper\mios_wrapper.asm and mios_wrapper\mios_tables.inc:
    The MIOS wrapper code and MIOS specific configuration tables
  - pic18f452.c: exports PIC18F452 specific SFRs
  - main.c: the main program with all MIOS hooks
  - blm.asm: the assembly optimized scan matrix code
There are additional .h files for all .c files which contain
general definitions and the declaration of global functions/variables
These .h files must be included into the program parts which
get use of these globals
[/tt]
blm_example is now available...
woohoo! thanks, i'll check this out this weekend...
did you not like my attempt at this?
http://www.midibox.org/forum/index.php/topic,10004.msg74201.html#msg74201
is something more necessary?
seems to work well...
just had first glance at new project example.
here is how i did the led toggle function:
		unsigned char mask = MIOS_HLP_GetBitORMask( pin ); //ex 0b00000001, 0b00000010
		unsigned char idx = (pin >> 3) & 0x07;
		if (BLM_LED_states1[idx] & mask)
			BLM_LED_states2[idx] ^= mask; //states2 bit is toggled if states1 bit is 1
		BLM_LED_states1[idx] ^= mask; //states1 is always toggled
i think it's more efficient, no?
not that it matters much in a test program...
i think inserting this directive will work to implement the switch for
current sinking transistors on the led rows:
#define BLM_INVERT_LED_CATHODES  1 ; 1 if sinking transistors are used on the led cathodes, 0 if not
BLM_PrepareCol
;; select next DOUT/DIN column
movf blm_selected_column, W, BANKED ; (* see note below)
call MIOS_HLP_GetBitANDMask ; (inverted 1 of 8 code)
andlw 0x0f
#if BLM_INVERT_LED_CATHODES
xorlw 0x0F
#endif
movwf MIOS_PARAMETER1
ok, i've tested the app.  the debounce function works great. thanks again.
it turns out i may have my led cathodes wired to the opposite 4 pins as you,
because i had to move the code to invert the pins as follows.  i'm holding out
a slim hope that the comment is just backwards, since this would require a
re-rout of the pcb:
andlw 0x0f
;; duplicate the 4 selection lines for button matrix ;should this line read dupe for the leds??
xorlw  0x0f
#endif
swapf WREG, W
iorwf MIOS_PARAMETER1, F
here's the (now tested) simplified toggling func in place
void BLM_NotifyToggle(unsigned char pin, unsigned char value) __wparam
  unsigned char mask;
  // send pin number and value as Note On Event
  MIOS_MIDI_TxBufferPut(0x90);
  MIOS_MIDI_TxBufferPut(pin);
  MIOS_MIDI_TxBufferPut(value ? 0x00 : 0x7f);
  // enable this code (turn #if 0 into #if 1) if buttons should change the LED colour directly
  // disable it when LEDs should only be controlled via MIDI
#if 1
  if (!value)
      mask = MIOS_HLP_GetBitORMask(pin);
      if ( blm_row_green[blm_button_column] & mask )
         blm_row_red[blm_button_column] ^= mask;
      blm_row_green[blm_button_column] ^= mask;
#endif
  // request display update
  app_flags.DISPLAY_UPDATE_REQ = 1;
Thank you!
I added the inversion parameter the following way to blm.asm:
; set an inversion mask for the DOUT shift registers if sink drivers (transistors)
; have been added to the cathode lines
; Settings: 0x00 - no sink drivers
;           0xf0 - sink drivers connected to D0..D3
;           0x0f - sink drivers connected to D4..D7
#define DEFAULT_SRM_CATHODES_INV_MASK   0x00
[/code]
The cathodes of your LEDs are connected correctly - DOUT registers are mirrored, this might be confusing...
I will consider to add sink drivers to my own hardware as well. They are not really required (as I'm using low-power LEDs), but it makes sense to be "source code compatible" with other solutions.
I also added your optimied LED toggling code.
-> blm_example_v1_1 in the MIOS download section.
Thank you!
no, thank you!
new version loaded and tested.
this is clearly better, more easily configured and keeps timing the same.
note that i used 0xF0 for the mask.
originally i used  BC847AMTF because the specs matched up with bc547,
but i had an issue with the leds dimming as more were added
(this only really showed up on the last 5 or so of 16)
so i changed to a darlington transistor.
i used MMBTA14, which is smd version of MPSA14
coolness.
i wasn't paying attention to the column and row numbers.
now that i did, i noticed a few things:
  - column and row are reversed (i think there was a provision for swapping them in the old code)
  - column alternates between sides while row is always 0-7 so if set up for seq (4x16)
    going left to right and top to bottom sequentially you get (col,row)
    (0,0)...(0,7) (1,0)...(1,7)
    (2,0)...(2,7) (3,0)...(3,7)
    (4,0)...(4,7) (5,0)...(5,7)
    (6,0)...(6,7) (7,0)...(7,7)
    for 8x8 monome style you get
    (0,0)...(0,7)
    (2,0)...(2,7)
    (4,0)...(4,7)
    (6,0)...(6,7)
    (1,0)...(1,7)
    (3,0)...(3,7)
    (5,0)...(5,7)
    (7,0)...(7,7)
Me too, it is matching with the schematic (D0 is bit 7, D1 is bit 6, etc...)
Ooops, you are right!
I fixed this in version blm_example_v1_2 (-> see MIOS download section)
Column alternates between sides while row is always 0-7 so if set up for seq (4x16)
For the 4x16 matrix (which I own) this scrambling is better.
Therefore I guess it's only a documentation issue - I added your input to the README.txt file
The processing routines in main.c (or in the host software) can easily map the column/row numbers to the "physical layout" if desired.
with the column and row no longer swapped, the "scrambling" should now read
  4x16:
  (0,0)(1,0)(2,0)(3,0)(4,0)(5,0)(6,0)(7,0)(0,1)(1,1)(2,1)(3,1)(4,1)(5,1)(6,1)(7,1)
  (0,2)(1,2)(2,2)(3,2)(4,2)(5,2)(6,2)(7,2)(0,3)(1,3)(2,3)(3,3)(4,3)(5,3)(6,3)(7,3)
  (0,4)(1,4)(2,4)(3,4)(4,4)(5,4)(6,4)(7,4)(0,5)(1,5)(2,5)(3,5)(4,5)(5,5)(6,5)(7,5)
  (0,6)(1,6)(2,6)(3,6)(4,6)(5,6)(6,6)(7,6)(0,7)(1,7)(2,7)(3,7)(4,7)(5,7)(6,7)(7,7)
  8x8:
here's a quick way to move the midi note range up, which helps
when testing with mios studio, and may be useful for others...
add to main.h:
// Global definitions
#define BLM_MIDI_STARTNOTE 24 ;; NOTE: this should be kept under 64 or the notes will wrap back down to 0
change in main.c:
void MPROC_NotifyReceivedEvnt(unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam
  unsigned char led_column;
  unsigned char led_row;
  unsigned char evnt1Adj;
  evnt1Adj = (evnt1 - BLM_MIDI_STARTNOTE) & 0x7f;
  if( (evnt0 == 0x80 || evnt0 == 0x90) && (evnt1Adj < 0x40 ) ) {
    // derive LED column and row from note number
    led_column = evnt1Adj >> 3;
    led_row = evnt1Adj & 0x07;
  unsigned char mask;
  MIOS_MIDI_TxBufferPut((pin + BLM_MIDI_STARTNOTE) & 0x7f);
edit* changed as tk suggested...
Note, that this code will send invalid MIDI events when BLM_MIDI_STARTNOTE >= 65
It's better to write:
[/code]
and something similar in MPROC_NotifyReceivedEvnt(); so that the "wrapped" note number is still maching between LEDs and Buttons
right you are.
hehe, i didn't even consider someone would try that...
fixed now in previous post.
ouch !
exactly what i am trying to do since 4 weeks ... TK is Lucky Luke, he triggers faster than his shadow.
BIG THANK
now that MIOS is available via USB, Monome becomes obsolete
  • 8 months later...
  • 4 weeks later...
Got the hardware working.
What is the most efficient way to do this so that my rows go 0,1,2,3,4,5,6,7 instead of 0,2,4,6,1,3,5,7?
Thanks,
Luke
