68 -
2
Everything posted by cit
Korg Poly-61 MIDIbox Upgrade, Poly-61MB.
cit replied to Antichambre's topic in MIDIbox User Projects
wow ..what a great project. -
danke :) but the page is not there anymore
yes. i know how to edit length. thanks. i mean as a quick entry on the rigth side on the length menue. there is one fre slot so if you can set here a custom length it would be aswome for faster jamming :). sorry hard to explain in english. im a stupid german :) thnaks and take care.
i know this treat /post is a bit old. i have the midiphy v4+ . is it posible to have roland din sync on it? i want to use some tb 303‘s and others on it. ok i have sync boxes etc. but i just want to know if i can use it direct on it? thanks
hello, is it posible to implement in the length menu a custom length ? i know to use the dial to set it to the length you ned but i often work with lengths like 3,6,7,9 and i saw that at the length option there is a slot free. would be great to have a custom one there ... any how i had a great day with the midibox, very great tool. thanks all and TK for this great tool.
40 is great will add the serial to my unit :)
and the next one is ready. thanks for your work on it. now i have a v4l and a v4+
Hello, after long time im back here. with a builded V4+ . Now i own a v4 lite and a v4+.
sorry, back for a long long time. i lost the link to the actual or latest v4l firmware, where can i find it please ? i have an old one on mine. thanks
hi, im not good in making files in eps. i drilled them myself. it was a bit tricky, but i got it. you had 4 screws for mounting the case, take 6 , 2 in the middle so the case will close properly. i have to drill them manuly too. any how thanks a lot for your work. i have now a nice case for round about 25€. thanks.
me to , mine has arrived jesterday. i took the cheaper material, but its not so strong, so for my second i take the harder material. some holes must be on the file. for mounting the smal pcb and in the middel of the rrontplate there must be 2 more holes. any how, nice case. picture is here: https://www.facebook.com/photo.php?fbid=168628226624561&set=a.147360718751312.35191.100004321531447&type=1&relevant_count=1&ref=nf
Hi Martijn, nice work. thanks for it. Can i ask you something. Can you provide this file with holes for each LED Please. Ok it is a lot of work i know. Im to stupid to do that. it will we nice if you can do that. Have you tested this file , does it fit ? Thanks a lot, cit
hi, it will be nice if you can share your file.thanks cit
Hi , i need a builded midimerger. does any one have on to sell. in germany ? thx
hi christian, i think you have an old firmware. or you have to switch the in-out funktion off!
hallo, versuch einen casio cz zu sichern und bekomme keine dumps hin. weiß jemand ob und wie ich zb via mios studio einen dump request zum cz senden kann ? und wie muss ich das machen ? gibt einen befehl etc? danke
that sounds nice :thumbsup:
Also mit der neusten Firmware ist das mit dem Doepfer richtig schön. danke noch mal an Thorsten. werde dann in kürze das Video machen.
Habe den MAQ grade bekommen und muss sagen hammer erweiterung mit dem sv4l als controller leider habe ich da selbst jetzt 2 fehler gemacht. hoffe der thorsten ist noch so nett das anzupassen. ich werde jedenfalls asap ein video und ein tutorial zu machen und hoffen das ander maq user genauso einen spaß damit haben wie ich. danke noch mal an thorsten !!!!!!!!
so am montag kann ich endlich meinen maq abholen dann gibts ein feedback :-)# danke noch mal
nice sounds for me like underworld meets yellow ...verry sexy have you some mp3 to share ?
super danke...teste ich asap wenn der maq hier ist, gebe dann auch feedback.... dauert aber noch 2-3 tage.....
ah ok ...jetzt verstehe ich... einfach mute und Midi ch gleichzeitig. danke sehr
so habe mal eine xls tabelle und das deutsche handbuch als zip erstellt. ich habe in der xls alle mir wichtigen funktionen incl allen wichtigen daten hinterlegt. zur sicherheit habe ich auch das manual von doepfer beigelegt . danke schon mal. bin sehr gespannt ob das geht . hier der link zip file solltest du vorschläge haben wie man die belegung besser machen sollte bin ich da offen. das manual von doepfer läßt noch mehr funktionen zu , aber diese scheinen mir im moment am sinnvolsten. auch sollte das umschalten in den editor mode alle anderen v4L funktionen am besten deaktivieren (ausser merge) damit da kein midisalat entsteht . danke
