95 -
3
Everything posted by Highcooley
Sorry, my fault. I figured out during stripping down the .NGC that I had one AINSER event routed to the same CV Out as the pitch CV. Why the note-on DOUT got triggered because of that, I don't know. However, consider it as solved. The Synth is really getting shape now. I am looking forward to post some audio samples or videos as soon as it sounds about right. But there are still a couple of little programming things to do first :-) Best Regards & have a nice weekend, Andy
Aaaah, 2500ms did the trick. I already tried 500ms before, but this was obviously to short. "show id DOUT:1" only responds with "Invalid element name 'DOUT'!". But using "show id CV:4", i get the following values: After reset (Note on DOUT pin is low): [782449.918] id=CV:4 (hw_id=CV:4) [782449.918] - bank=0 [782449.918] - condition: none [782449.918] - fwd_id=DISABLED:0 [782449.918] - fwd_value=off [782449.918] - fwd_to_lcd=1 [782449.918] - type=NoteOn [782449.919] - chn=1 [782449.919] - key=128 [782449.919] - use_key_number=1 [782449.919] - ports=10001000000010000000 [782449.919] - value=424 [782449.919] - secondary_value=3 [782449.919] - map=0 [782449.919] - map_ix=0 [782449.919] - min=0 [782449.919] - max=127 [782449.919] - offset=0 [782449.919] - dimmed=0 [782449.920] - rgb=0:0:0 [782449.920] - syxdump_pos=0:0 [782449.920] - radio_group=0 [782449.920] - fwd_gate_to_dout_pin=3.D0 [782449.920] - cv_inverted=0 [782449.920] - cv_gate_inverted=0 [782449.921] - cv_hz_v=0 [782449.921] - led_matrix_pattern=Undefined [782449.921] - colour=0 [782449.921] - lcd_pos=1:1:6 [782449.921] - label="^std_key" After first key press and release (Note on DOUT pin is high, the audible frequency defers from the key just pressed): [782449.918] id=CV:4 (hw_id=CV:4) [782449.918] - bank=0 [782449.918] - condition: none [782449.918] - fwd_id=DISABLED:0 [782449.918] - fwd_value=off [782449.918] - fwd_to_lcd=1 [782449.918] - type=NoteOn [782449.919] - chn=1 [782449.919] - key=128 [782449.919] - use_key_number=1 [782449.919] - ports=10001000000010000000 [782449.919] - value=424 [782449.919] - secondary_value=3 [782449.919] - map=0 [782449.919] - map_ix=0 [782449.919] - min=0 [782449.919] - max=127 [782449.919] - offset=0 [782449.919] - dimmed=0 [782449.920] - rgb=0:0:0 [782449.920] - syxdump_pos=0:0 [782449.920] - radio_group=0 [782449.920] - fwd_gate_to_dout_pin=3.D0 [782449.920] - cv_inverted=0 [782449.920] - cv_gate_inverted=0 [782449.921] - cv_hz_v=0 [782449.921] - led_matrix_pattern=Undefined [782449.921] - colour=0 [782449.921] - lcd_pos=1:1:6 [782449.921] - label="^std_key" After pressing the correct key with the same as the audible frequency (it turns out, that it is not always key 0 but this time was key 40) --> (Note on DOUT pin is low): [782449.918] id=CV:4 (hw_id=CV:4) [782449.918] - bank=0 [782449.918] - condition: none [782449.918] - fwd_id=DISABLED:0 [782449.918] - fwd_value=off [782449.918] - fwd_to_lcd=1 [782449.918] - type=NoteOn [782449.919] - chn=1 [782449.919] - key=128 [782449.919] - use_key_number=1 [782449.919] - ports=10001000000010000000 [782449.919] - value=424 [782449.919] - secondary_value=3 [782449.919] - map=0 [782449.919] - map_ix=0 [782449.919] - min=0 [782449.919] - max=127 [782449.919] - offset=0 [782449.919] - dimmed=0 [782449.920] - rgb=0:0:0 [782449.920] - syxdump_pos=0:0 [782449.920] - radio_group=0 [782449.920] - fwd_gate_to_dout_pin=3.D0 [782449.920] - cv_inverted=0 [782449.920] - cv_gate_inverted=0 [782449.921] - cv_hz_v=0 [782449.921] - led_matrix_pattern=Undefined [782449.921] - colour=0 [782449.921] - lcd_pos=1:1:6 [782449.921] - label="^std_key"As described, everything works as it should afterwards. Best Regards, Andy
Jup, I am very happy too, since I really was at my wit's end. To a) The Midi Keyboard is attached, running and the midibox also connected to MIOS studio. After the .NGC script is loaded, the assigned note on DOUT pin is low. But as soon as I hit the first key, using either the midi keyboard or the soft keyboard of the MIOS studio, the DOUT pin goes high and stays when I release the key. The only way to get it low again is to press the C-2 key (lowest in the scale) once. After that, the note on event acts as it should and only goes high as long as the key is pressed. To b) Except for the delay, this is what I wrote into the .NGR file. But for good measure, I copied your code and replaced mine to err out typers. The ^section == 0 gets executed (I checked with a "Hello World" to the LCD) but the show pool command in MIOS studio shows only zeros for all inputs. As soon as I move a pot, the actual value of this pot is shown if I do show pool again. I tried to switch the pot mode to direct instead of parallax but this does not change anything. Best Regards, Andy
Hey TK You're the man! All fine, the AINSER doesn't affect the DIO Matrix anymore. Thank you very much for your super fast support. Now I only have to figure out why I ... a) always have a "note on" event staying on, when I hit a key on the midi keyboard attached for the first time after restart. It stays on until I hit the lowest note of the keyboard once. I already tried to set another dout pin to rule out an overflow of the DIO matrix scan pattern, but get the same effect. and ... b) why my .NGR script always only writes 0s into the .NGS file during startup. I do have to slightly turn every single knob once to get the AINSER values and output them to the AOUTS. So I was not able to test the parallax mode yet. However, I haven't implemented a menue with a manual dump and load snapshot command. Anyways, you brought me a huge step further with my project. I owe you one. Cheers, Andy
Hey Thorsten Unfortunately, the pre12 didn't have the expected effect and I still get the same scanning sequence. But you are definitely close. I changed all the ain_modes to "direct" and repeatedly get the following sequence as soon as the error occurs: [607193.357] Page 0: 7f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.357] Page 1: 3f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.359] Page 2: 5f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.360] Page 3: 6f 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.361] Page 4: 77 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.361] Page 5: 7b 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.363] Page 6: 7d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.363] Page 7: 7e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.365] Page 8: 7f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.365] Page 9: 3f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.367] Page 10: 5f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.367] Page 11: 6f 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.369] Page 12: 77 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.369] Page 13: 7b 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.371] Page 14: 7d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.371] Page 15: 7e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.373] Page 16: 7f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.373] Page 17: 3f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.375] Page 18: 5f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.375] Page 19: 6f 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.377] Page 20: 77 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.377] Page 21: 7b 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.377] Page 22: 7d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.379] Page 23: 7e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.379] Page 24: 7f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.381] Page 25: 3f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.381] Page 26: 5f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.383] Page 27: 6f 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.383] Page 28: 77 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.385] Page 29: 7b 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.385] Page 30: 7d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [607193.386] Page 31: 7e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Changing back to parallax results in the old wrong sequence again. I hope, these info helps for further debugging. Best Regards, Andy
I can't follow you at the moment, but did the tests anyway :-) removing fwd_id=CV:x gets rid of the problem removing fwd_id=LED:x doesn't both removed solves the problem as well of course ;-) Best Regards, Andy
As soon as the error occurs, I get: [523254.412] Page 0: 6f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.412] Page 1: af 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.414] Page 2: cf 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.414] Page 3: ef 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.416] Page 4: e7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.416] Page 5: eb 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.418] Page 6: ed 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.418] Page 7: ee 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.419] Page 8: 6f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.419] Page 9: af 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.421] Page 10: cf 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.421] Page 11: ef 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.423] Page 12: e7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.423] Page 13: eb 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.424] Page 14: ed 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.426] Page 15: ee 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.426] Page 16: 6f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.428] Page 17: af 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.428] Page 18: cf 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.428] Page 19: ef 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.430] Page 20: e7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.430] Page 21: eb 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.432] Page 22: ed 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.432] Page 23: ee 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.434] Page 24: 6f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.434] Page 25: af 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.436] Page 26: cf 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.436] Page 27: ef 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.436] Page 28: e7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.438] Page 29: eb 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.438] Page 30: ed 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [523254.439] Page 31: ee 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00before that, all is well. I used this command several times when I had the error with the same sequence. I'm wondering how this zero gets to the fifth position of the string. But of course, all is off afterwards. Also, if I disable AINSER, the error never occurs. Also with AINSER and AOUT. But with AOUT off and AINSER on, I have the problem regularly. So it's the AINSER command which seems to have something to do with the problem. I didn't have a .NGR but now do have one with the following in it: if ^section == 0 exec_meta RetrieveAinserValues exec_meta DumpSnapshot endif...since I accidentally had it in the .NGC which didn't work of course. Unfortunately this also doesn't initialize the Ainsers somehow. So I have to turn each knob once to initialize it until I can test the synth. Cheers Andy
Hey Thorsten Good point. Yes, it does get stable again when I reset via the terminal. One new finding is, that if I disconnect the AINSER64 from J19 of the Processor board and the AOUTs subsequently, I cannot provoke the error on the DIO-Matrix anymore regardless of whether or not I have the DIO-Matrix supplied separately from the PSU or not. The scope shows the same noise of +/-60mV at the 5V rail. I checked, if the problem also occurs if the AINSER is connected without the AOUTs and the answer is yes. So the question arises if this is a software bug which only happens if AINSER64 is connected or if it has something to do with interference from the AINSER64 scan cables. But even if I turn a pot which is on a strand 20cm away from the DIO-Matrix cables, the problem still occurs. If I disconnect the scan cables of the AINSER64 which cross my DIO-Matrix cable, and the processor goes into unlimited value change scanning at these lines, the error of the DIO-Matrix occurs instantly. One last thing I can test is if the error can be provoked if I disconnect the crossing lines but also ground these inputs in order to not having value changes at these inputs all the time. Find the whole config file. Maybe there is a clue about the problem in there: default.ngc Thanks guys for bearing with me and best regards, Andy
Yes, it's an LPC17. I run two 20cm long flat flex cables from a DIO-Matrix module to a veroboard at the front pannel (distribution board). From there, I wired the different matrix strands. The buttons are TC011s which I described here a while ago: http://midibox.org/forums/topic/19468-led-button-switch-tc011/ Meanwhile I can say that the quality is quite decent. Cheers, Andy
You're right...here is what we are talking about: Marked red is the DIO Matrix board close to the processor right below (8cm ribbon). Then green is the distribution board which is connected with two 20cm flat flex cables and orange is another 20cm flat flex with three LED push button boards (two mounted on the front panel and the one with visible buttons floating). In the back you can see the rotary switches also connected to the distribution board and the smaller parts are pots connected directly to the AINSER_64. Ignore the other ribbon cables in the lower part of the image. These are temporary CV connections of the analog section. I don't think they can be causing interference, since the CVs are all static voltages from the AOUT_NGs so far (no modulation yet). The audio path is running through shielded cables. I know, the front panel cabling is a terrible mess, but so far I don't see a better solution for parts mounted such far away from each other. Everything will be tidied up with cable ties in the end, but that won't help if the cables of the DIO and the AINSER scanning matrices are even closer together. Since the front panel is over 60cm wide, PCBs won't be a good solution to connect the parts either. Cheers, Andy
Alright, a little step closer: J6 is set correctly, the pull-up resistors are the right value and solidly solderd and I also checked J27 which is fine as well (also the signal itself, not just the jumper). But what I figured out is, that if I feed both 5V and GND directly from the PSU to the board, the fault happens much less (which means it does happen but much later). Also the noise level on the 5V rail lowers from +/-400mW to +/-60mV. But still, it does happen far too often. Also, if I connect my scope to the rail at the board, it happens more often. I soldered some 100uF cap and a 1000p cap to the board which unfortunately did not help at all. But it even gets more mysterious. If I turn AINSER64 pots, I can provoke the fault as well, which never happened before. Of course, the wires of these pots cross the button wires at some point, which won't be possible to avoid. Well, I am a bit lost here with this mystery.
Wow, 160 bucks on a veroboard Thanks for the fix, it should work a treat. Giving you feedback asap. Shall I do any testing with different number of DACs or have you already done that? Best regards, andy Update: Yep, all working fine now with every reset and power-up I tried with 4 DACs. The synth starts to sound cool Thanks a lot (and secretly hoping that my other issue with the DIO matrix turns out to be a software problem as well)
Gonna test it tonight if I find the time. When you say "where CS is strobed after each 16bit transfer" you mean only during init phase? Afterwards, the whole 4*16bits need to be sent between CS (named FS in the datasheet), otherwise the first DACs will repeat the output as you described. Just to be sure we are talking about the same thing. You do init the following way for 4 modules with midibox_ng_1_033_pre9_aout_ng_multics: 1000 0000 0000 1000 (CTRL0 setting DOUT=on) FS 1001 0000 0000 0000 (CTRL1 setting everything to default) FS 1011 0000 0000 1000 (blank) or setting any AOUT to 0 FS 1011 0000 0000 1000 (blank) or setting any AOUT to 0 FS 1011 0000 0000 1000 (blank) or setting any AOUT to 0 FS This way, all DACs receive CTRL0 and CTRL1. After that, you normally send 64bits followed by a CS continuosly to update the AOUTs? of course, you could also do someting like this to keep the 64bits and one clock rhythm: 1000 0000 0000 1000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FS 1001 0000 0000 0000 1000 0000 0000 1000 0000 0000 0000 0000 0000 0000 0000 0000 FS 0000 0000 0000 0000 1001 0000 0000 0000 1000 0000 0000 1000 0000 0000 0000 0000 FS 0000 0000 0000 0000 0000 0000 0000 0000 1001 0000 0000 0000 1000 0000 0000 1000 FS 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 1001 0000 0000 0000 FS Or am I completely mistaken? Best Regards, Andy
I consulted the datasheet as well. Do we need any changes in CTRL1 at all? Otherwise, CTRL1 could be skipped. As soon as CTRL0 is set to DOUT enabled for the first chip (D3=1 --> 1000 0000 0000 1000), one could conclude that any further telegram will be put to DOUT with a 16 bit delay. What is unclear to me is, if these first 16 bits get discarded or pushed on (to be used for the next chip). If they are lost, the process would have to be repeated two more times for 4 chips, extending the string length by 16 bits after each cycle. A pity there are no further details concerning this in the datasheet. Google also didn't help. Regards, Andy
Hey guys Thanks for your suggestions. @Thorsten: - The serial cable length is below 10cm. If I take a 20cm long one, nothing changes in the behavior. - I tried to reduce the config to only 15 toggle buttons, but that won't change anything. A couple of button presses and suddenly they influence each other again, where before they work individually. - On the hardware side it gets a bit trickier, since all buttons are soldered to the distribution board. The only thing I know is, that the same problem occurred ever since I assembled my front panel, when I only had the rotary switches connected before the toggle switches. - Jup, 1n4148s are all good. @latigid on: I measure 5V with +/-400mV noise from the CPU. Should I be worried about the noise? I tried attaching an additional larger cap, but that didn't help with noise of course. Supplying extra 5V won't help unless I would cut the connection to the processor board. @FantomXR: It's a print screen out of the Moog Voyager Synth PDF manual. Horrible resolution, but a start to get the front panel together :-) I am currently redesigning the layout in inkscape which is a freakin pain in the butt since lines get misaligned frequently and I didn't manage to get nice concentric scales around the buttons (the nice plugin for exactly that which I found online doesn't work with my installation). I'm still not happy about the fact, that the config always works fine after a reboot for a couple of button presses. Any other idea how to nail this? Cheers Andy
Hey Thorsten Thanks for the update. Unfortunately, the init seems not to be working properly every time. Where as module 2 is working every time with v1.032, now I either have 4 or only 1 module working. Rebooting always only enables 1 module no matter how many times I try. Only if I reflash the software several times, suddenly all modules work after about 5 to 8 tries. Update: Soft resetting via MIOS terminal sometimes also helps after a couple of tries. Best Regards, Andy
Hey fellow midiboxers I start feeling bad, always coming with more problems instead of solutions. But another unsolved mystery in my Midibox_NG project (next to operating more than 2 AOUT_NGs) is an odd behavior of my DIO Matrix. Basically, it is configured like in the example for 8x16 buttons and 8x8 LEDs. In my configuration, I have a couple of rotary switches configured as OnOnly for the different states as wells as some toggle buttons with included LEDs: the matrix is wired as follows: and this is how the configuration looks like: # DIN_MATRIX hardware DIN_MATRIX n=1 rows=8 sr_dout_sel1=1 sr_din1=1 sr_din2=2 button_emu_id_offset=1001 # DOUT_MATRIX hardware DOUT_MATRIX n=1 rows=8 sr_dout_sel1=1 sr_dout_r1=2 led_emu_id_offset=2001 # EVENTs #MOD BUS EVENT_BUTTON id= 1001 type=CC button_mode=OnOnly chn= 1 CC= 68 range= 0:0 lcd_pos=1:1:4 label="MW Source Tri " EVENT_BUTTON id= 1002 type=CC button_mode=OnOnly chn= 1 CC= 68 range= 25:25 lcd_pos=1:1:4 label="MW Source Square " EVENT_BUTTON id= 1003 type=CC button_mode=OnOnly chn= 1 CC= 68 range= 51:51 lcd_pos=1:1:4 label="MW Source OSC 3 " EVENT_BUTTON id= 1004 type=CC button_mode=OnOnly chn= 1 CC= 68 range= 76:76 lcd_pos=1:1:4 label="MW Source S&H " EVENT_BUTTON id= 1005 type=CC button_mode=OnOnly chn= 1 CC= 68 range= 102:102 lcd_pos=1:1:4 label="MW Source ON/MOD2 " EVENT_BUTTON id= 1006 type=CC button_mode=OnOnly chn= 1 CC= 68 range= 127:127 lcd_pos=1:1:4 label="MW Source Noise/PGM " EVENT_BUTTON id= 1017 type=CC button_mode=OnOnly chn= 1 CC= 69 range= 0:0 lcd_pos=1:1:4 label="MW Dest Pitch " EVENT_BUTTON id= 1018 type=CC button_mode=OnOnly chn= 1 CC= 69 range= 25:25 lcd_pos=1:1:4 label="MW Dest OSC 2 " EVENT_BUTTON id= 1019 type=CC button_mode=OnOnly chn= 1 CC= 69 range= 51:51 lcd_pos=1:1:4 label="MW Dest OSC 3 " EVENT_BUTTON id= 1020 type=CC button_mode=OnOnly chn= 1 CC= 69 range= 76:76 lcd_pos=1:1:4 label="MW Dest Filt " EVENT_BUTTON id= 1021 type=CC button_mode=OnOnly chn= 1 CC= 69 range= 102:102 lcd_pos=1:1:4 label="MW Dest Wave " EVENT_BUTTON id= 1022 type=CC button_mode=OnOnly chn= 1 CC= 69 range= 127:127 lcd_pos=1:1:4 label="MW Dest LFO Rate/PGM" EVENT_BUTTON id= 1033 type=CC button_mode=OnOnly chn= 1 CC= 70 range= 0:0 lcd_pos=1:1:4 label="MW Shaping Filt " EVENT_BUTTON id= 1034 type=CC button_mode=OnOnly chn= 1 CC= 70 range= 48:48 lcd_pos=1:1:4 label="MW Shaping Velocity " EVENT_BUTTON id= 1035 type=CC button_mode=OnOnly chn= 1 CC= 70 range= 80:80 lcd_pos=1:1:4 label="MW Shaping Pressure " EVENT_BUTTON id= 1036 type=CC button_mode=OnOnly chn= 1 CC= 70 range= 127:127 lcd_pos=1:1:4 label="MW Shaping ON/PGM " EVENT_BUTTON id= 1037 type=CC button_mode=OnOnly chn= 1 CC= 73 range= 0:0 lcd_pos=1:1:4 label="Ped Shaping Filt " EVENT_BUTTON id= 1038 type=CC button_mode=OnOnly chn= 1 CC= 73 range= 48:48 lcd_pos=1:1:4 label="Ped Shaping Velocity" EVENT_BUTTON id= 1039 type=CC button_mode=OnOnly chn= 1 CC= 73 range= 80:80 lcd_pos=1:1:4 label="Ped Shaping Pressure" EVENT_BUTTON id= 1040 type=CC button_mode=OnOnly chn= 1 CC= 73 range= 127:127 lcd_pos=1:1:4 label="Ped Shaping ON/PGM " EVENT_BUTTON id= 1049 type=CC button_mode=OnOnly chn= 1 CC= 71 range= 0:0 lcd_pos=1:1:4 label="Ped Source Tri " EVENT_BUTTON id= 1050 type=CC button_mode=OnOnly chn= 1 CC= 71 range= 25:25 lcd_pos=1:1:4 label="Ped Source Square " EVENT_BUTTON id= 1051 type=CC button_mode=OnOnly chn= 1 CC= 71 range= 51:51 lcd_pos=1:1:4 label="Ped Source OSC 3 " EVENT_BUTTON id= 1052 type=CC button_mode=OnOnly chn= 1 CC= 71 range= 76:76 lcd_pos=1:1:4 label="Ped Source S&H " EVENT_BUTTON id= 1053 type=CC button_mode=OnOnly chn= 1 CC= 71 range= 102:102 lcd_pos=1:1:4 label="Ped Source ON/MOD2 " EVENT_BUTTON id= 1054 type=CC button_mode=OnOnly chn= 1 CC= 71 range= 127:127 lcd_pos=1:1:4 label="Ped Source Noise/PGM" EVENT_BUTTON id= 1065 type=CC button_mode=OnOnly chn= 1 CC= 72 range= 0:0 lcd_pos=1:1:4 label="Ped Dest Pitch " EVENT_BUTTON id= 1066 type=CC button_mode=OnOnly chn= 1 CC= 72 range= 25:25 lcd_pos=1:1:4 label="Ped Dest OSC 2 " EVENT_BUTTON id= 1067 type=CC button_mode=OnOnly chn= 1 CC= 72 range= 51:51 lcd_pos=1:1:4 label="Ped Dest OSC 3 " EVENT_BUTTON id= 1068 type=CC button_mode=OnOnly chn= 1 CC= 72 range= 76:76 lcd_pos=1:1:4 label="Ped Dest Filt " EVENT_BUTTON id= 1069 type=CC button_mode=OnOnly chn= 1 CC= 72 range= 102:102 lcd_pos=1:1:4 label="Ped Dest Wave " EVENT_BUTTON id= 1070 type=CC button_mode=OnOnly chn= 1 CC= 72 range= 127:127 lcd_pos=1:1:4 label="Ped Dest LFO Rate/PGM" #OSC EVENT_BUTTON id= 1009 type=CC button_mode=OnOnly chn= 1 CC= 74 range= 64:64 fwd_id=SENDER:3001 lcd_pos=1:1:4 label="OSC 1 Octave 32 " EVENT_BUTTON id= 1010 type=CC button_mode=OnOnly chn= 1 CC= 74 range= 65:65 fwd_id=SENDER:3001 lcd_pos=1:1:4 label="OSC 1 Octave 16 " EVENT_BUTTON id= 1011 type=CC button_mode=OnOnly chn= 1 CC= 74 range= 66:66 fwd_id=SENDER:3001 lcd_pos=1:1:4 label="OSC 1 Octave 8 " EVENT_BUTTON id= 1012 type=CC button_mode=OnOnly chn= 1 CC= 74 range= 67:67 fwd_id=SENDER:3001 lcd_pos=1:1:4 label="OSC 1 Octave 4 " EVENT_BUTTON id= 1013 type=CC button_mode=OnOnly chn= 1 CC= 74 range= 68:68 fwd_id=SENDER:3001 lcd_pos=1:1:4 label="OSC 1 Octave 2 " EVENT_BUTTON id= 1014 type=CC button_mode=OnOnly chn= 1 CC= 74 range= 69:69 fwd_id=SENDER:3001 lcd_pos=1:1:4 label="OSC 1 Octave 1 " EVENT_BUTTON id= 1025 type=CC button_mode=OnOnly chn= 1 CC= 75 range= 64:64 fwd_id=SENDER:3002 lcd_pos=1:1:4 label="OSC 2 Octave 32 " EVENT_BUTTON id= 1026 type=CC button_mode=OnOnly chn= 1 CC= 75 range= 65:65 fwd_id=SENDER:3002 lcd_pos=1:1:4 label="OSC 2 Octave 16 " EVENT_BUTTON id= 1027 type=CC button_mode=OnOnly chn= 1 CC= 75 range= 66:66 fwd_id=SENDER:3002 lcd_pos=1:1:4 label="OSC 2 Octave 8 " EVENT_BUTTON id= 1028 type=CC button_mode=OnOnly chn= 1 CC= 75 range= 67:67 fwd_id=SENDER:3002 lcd_pos=1:1:4 label="OSC 2 Octave 4 " EVENT_BUTTON id= 1029 type=CC button_mode=OnOnly chn= 1 CC= 75 range= 68:68 fwd_id=SENDER:3002 lcd_pos=1:1:4 label="OSC 2 Octave 2 " EVENT_BUTTON id= 1030 type=CC button_mode=OnOnly chn= 1 CC= 75 range= 69:69 fwd_id=SENDER:3002 lcd_pos=1:1:4 label="OSC 2 Octave 1 " EVENT_BUTTON id= 1041 type=CC button_mode=OnOnly chn= 1 CC= 76 range= 64:64 fwd_id=SENDER:3003 lcd_pos=1:1:4 label="OSC 3 Octave 32 " EVENT_BUTTON id= 1042 type=CC button_mode=OnOnly chn= 1 CC= 76 range= 65:65 fwd_id=SENDER:3003 lcd_pos=1:1:4 label="OSC 3 Octave 16 " EVENT_BUTTON id= 1043 type=CC button_mode=OnOnly chn= 1 CC= 76 range= 66:66 fwd_id=SENDER:3003 lcd_pos=1:1:4 label="OSC 3 Octave 8 " EVENT_BUTTON id= 1044 type=CC button_mode=OnOnly chn= 1 CC= 76 range= 67:67 fwd_id=SENDER:3003 lcd_pos=1:1:4 label="OSC 3 Octave 4 " EVENT_BUTTON id= 1045 type=CC button_mode=OnOnly chn= 1 CC= 76 range= 68:68 fwd_id=SENDER:3003 lcd_pos=1:1:4 label="OSC 3 Octave 2 " EVENT_BUTTON id= 1046 type=CC button_mode=OnOnly chn= 1 CC= 76 range= 69:69 fwd_id=SENDER:3003 lcd_pos=1:1:4 label="OSC 3 Octave 1 " #LFO EVENT_BUTTON id= 1007 type=CC button_mode=OnOnly chn= 1 CC= 67 range= 0:0 lcd_pos=1:1:4 label="LFO Sync OFF " EVENT_BUTTON id= 1008 type=CC button_mode=OnOnly chn= 1 CC= 67 range= 48:48 lcd_pos=1:1:4 label="LFO Sync MIDI " EVENT_BUTTON id= 1015 type=CC button_mode=OnOnly chn= 1 CC= 67 range= 80:80 lcd_pos=1:1:4 label="LFO Sync KB " EVENT_BUTTON id= 1016 type=CC button_mode=OnOnly chn= 1 CC= 67 range= 127:127 lcd_pos=1:1:4 label="LFO Sync Env Gate " EVENT_BUTTON id= 1057 type=CC fwd_id=LED:2025 button_mode=Toggle chn= 1 cc= 65 range= 0:127 lcd_pos=1:1:4 label="Glide ^onoff " EVENT_BUTTON id= 1058 type=CC fwd_id=LED:2026 button_mode=Toggle chn= 1 cc= 77 range= 0:127 lcd_pos=1:1:4 label="1-2 Sync ^onoff " EVENT_BUTTON id= 1059 type=CC fwd_id=LED:2027 button_mode=Toggle chn= 1 cc= 78 range= 0:127 lcd_pos=1:1:4 label="3-1 FM ^onoff " EVENT_BUTTON id= 1060 type=CC fwd_id=LED:2028 button_mode=Toggle chn= 1 cc= 90 range= 0:127 lcd_pos=1:1:4 label="5Pulser ^onoff " EVENT_BUTTON id= 1061 type=CC fwd_id=LED:2029 button_mode=Toggle chn= 1 cc= 95 range= 0:127 lcd_pos=1:1:4 label="2-3 Ring ^onoff " EVENT_BUTTON id= 1062 type=CC fwd_id=LED:2030 button_mode=Toggle chn= 1 cc= 79 range= 0:127 lcd_pos=1:1:4 label="3 KB Cont ^onoff " EVENT_BUTTON id= 1063 type=CC fwd_id=LED:2031 button_mode=Toggle chn= 1 cc= 80 range= 0:127 lcd_pos=1:1:4 label="3 Freq ^highlow " EVENT_BUTTON id= 1073 type=CC fwd_id=LED:2033 button_mode=Toggle chn= 1 cc= 91 range= 0:127 lcd_pos=1:1:4 label="Pulse 3 ^onoff " EVENT_BUTTON id= 1074 type=CC fwd_id=LED:2034 button_mode=Toggle chn= 1 cc= 92 range= 0:127 lcd_pos=1:1:4 label="Pulse 5 ^onoff " EVENT_BUTTON id= 1075 type=CC fwd_id=LED:2035 button_mode=Toggle chn= 1 cc= 93 range= 0:127 lcd_pos=1:1:4 label="Pulse 7 ^onoff " EVENT_BUTTON id= 1076 type=CC fwd_id=LED:2036 button_mode=Toggle chn= 1 cc= 94 range= 0:127 lcd_pos=1:1:4 label="Pulse 9 ^onoff " EVENT_BUTTON id= 1081 type=CC fwd_id=LED:2041 button_mode=Toggle chn= 1 cc= 81 range= 0:127 lcd_pos=1:1:4 label="External Audio ^onoff " EVENT_BUTTON id= 1082 type=CC fwd_id=LED:2042 button_mode=Toggle chn= 1 cc= 82 range= 0:127 lcd_pos=1:1:4 label="OSC 1 ^onoff " EVENT_BUTTON id= 1083 type=CC fwd_id=LED:2043 button_mode=Toggle chn= 1 cc= 83 range= 0:127 lcd_pos=1:1:4 label="OSC 2 ^onoff " EVENT_BUTTON id= 1084 type=CC fwd_id=LED:2044 button_mode=Toggle chn= 1 cc= 84 range= 0:127 lcd_pos=1:1:4 label="OSC 3 ^onoff " EVENT_BUTTON id= 1085 type=CC fwd_id=LED:2045 button_mode=Toggle chn= 1 cc= 85 range= 0:127 lcd_pos=1:1:4 label="Noise ^onoff " EVENT_BUTTON id= 1086 type=CC fwd_id=LED:2046 button_mode=Toggle chn= 1 cc= 86 range= 0:127 lcd_pos=1:1:4 label="Filter Mode ^filmode " EVENT_BUTTON id= 1087 type=CC fwd_id=LED:2047 button_mode=Toggle chn= 1 cc= 87 range= 0:127 lcd_pos=1:1:4 label="Env Gate ^envgate " If I reboot the midibox, all buttons and LEDs work as intended. But after a couple of button presses, suddenly two strange things happen: - Rotary switches start to lock each other out. If one switch is in position green on the matrix table, the same position in terms of DIN row of other switches is not registered any longer. - Switches trigger all button events in the same row (e.g. the ones marked yellow in the matrix table). One small detail is that if this happens, the LEDs of the corresponding buttons are getting brighter, the more switches of this row are in the actual ON position. For example, if ID 1009 suddenly starts to trigger ID1025. 1041, 1057 and 1073, LED 2025 and 2033 switch on. If the second rotary switch is set to the position wit the ID1025, the LEDs 2025 and 2033 get brighter. If I toggle on button 1057 (pressing and releasing it), both LEDs 2025 and 2033 even get brighter. In reverse, if I toggle buttons off, the LEDs get dimmer again. You can actually see differently bright lit LEDs in the picture I took of the front panel mockup. Now what could the actual problem behind this behavior be? What is strange is, that everything always works after rebooting and suddenly starts, after I pressed a couple of buttons or did a couple of switches. Can it be some capacitive behavior of the ribbon cables I used to connect the switches (some are up to 40cm long) which builds up over time? Or could it have something to do with the fact that the rotary switches trigger one of the 4 to 8 switches in every scan (some kind of stack overflow)? What do you think I could try to get closer to a solution? I appreciate your thoughts and hints regarding this behavior. Best regards and a happy weekend Andy
Do you have enough AOUT_NGs laying around for the tests or can I help you with anything by performing tests? I did a couple of tests myself: - exchanged all cables and modules with each other. Still the third module does nothing and the other two work. - fed 5V directly to the third module to rule out voltage drop - reduced cable length by eliminating the AINSER_64 which is daysichained ahead of the AOUT_NG modules. - configured 16 channels in the hope that module 3 would replicate module 1. No change with or without the AINSER_64 (however,I don't fully understand the transfer protocol, so maybe if the software only feeds 2 modules, the third won't do anything no matter what) - measured DOUT of the third module and didn't measure any signal coming out One thing I noticed though is, that if I fully sweep the output CV of a channel of the third module, the voltage changes from 0.09 to 0.11 V. This does not make any sense to me, but maybe it could be a clue what's going on here. Thanks for your effort! Regards, Andy
Hmmm, has anybody been successful with more than 2 AOUT_NG Modules? I am struggling with the 3rd module which does not respond yet (checked cabling and also if this additional module is actually working, which it is). So, no luck with more than 16 channels yet. I set AOUT type=AOUT_NG cs=1 num_channels=24 (cs=0 still used for AINSER) and addressed the new channels with fwd_id=CV:17 upwards But nope, no response yet. Thanks for your reply! Cheers, Andy
Hey everybody. After some hot summerholidays it is time to work on my synth again. Meanwhile, all the PCBs (except for the modbus/ DOUT board which still has to be designed) have arrived and are ready to be populated. [photos comming soon] The 5Pulser and Ringmod board worked on the first try after the soldering was complete. It was still a lot of work cabling and tuning everything, but it all worked straight away which is seldom the case in my electronics experience. I also just finished assembling, tuning and debugging the filter stage. This was a lot more work as the circuits are a lot more complex and have to work unisono. It is now possible to switch between using the two LP filters in parallel to generate a Stereo effect by phase shifting one filter or using one LP filter sequentially with the HP filter generating a bandpass and also phase shifting the HP filter to widen the band. By using, switching and shifting I mean doing it manually, since these modules are not yet connected to the midibox controller. The analog part should be easy, as I configured everything already when I did the VCO stages. However, I haven't tackled DOUT to switch relays as well as toggle LED buttons on the DIO MATRIX side yet. And since I haven't done a lot of midibox programming/ configuration work lately, it will be a challenge again to get everythong hoocked up properly. Next will be the ADSR and VCA circuits. The boards are populated and ready for testing.
- 22 replies
- midification
- ainser64
(and 3 more)
Tagged with:
Ok, thanks a lot for your quick reply. Let me know if you consider such an option. It Would be great to be able to midi sync my Synth. Cheers, Andy
Hey everybody I searched in the forum as well as the NG documentation but couldn't find anything about this topic. Is there a possibility to forward the midi clock pulse or a division of it to a DOUT pin (comming either from the internal generator or an external clock through midi in)? I would like to sync an LFO to the clock. Cheers Andy
Too bad. Although, I would not care if I needed to design another scan circuit. But as long as the midibox_NG cannot scan "Charlieplexed" (good to know what the "official" name is) matrices, it wouldn't work anyway. If you are interested in the RBG price, I can pm you the contact of the salesperson.
Has anybody built a BLM with bidirectional two lead duocolor LEDs, where the two colors can be adressed by reversing the polarity? How would the scan circuit have to be designed in order to work with the standard midibox solutions? Of course, compared with the scalar board, the resistor-transistor arrangement of IC2 could be placed next to IC3 and another 74HC595 next to IC2. But then the scan algorythm would also have to scan each color sequentially. Why am I looking for such a solution? I evaluated the the switch of choice for my Synth project: For my needs, I only have single color buttons (yellow). But this button could also be interesting for BLM applications where duocolor would be needed (RGB is available as well). I am working on a versatile matrix PCB solution for my synth project, where single rows of a matrix can be cut to the desired length and the LEDs can be adressed individually via solder jumpers. These smaller boards can be bought much cheaper in small quantities than the propriatary matrix boards and in my case serve different needs.
Hey guys I evaluated an LED backlit push button switch for my Synth project. Well Buying's TC011-A S4 T turned out to be the perfect switch for my needs: Although called tact switch, it feels more like a push button switch with a smooth pressure point and doesn't have the distinct click of a membrane switch. It's more like a Marquart but with a stronger spring resistance and a more defined switching point. The cap is 11x11 mm, translucent with a white diffusor cap inside (other versions with only square white caps are also available), as well as an ergonomic indent. There are different color options as well as duocolor and RGB available. Unfortunately, the duocolor version (colors can be chosen freely, as far as I know) is a bidirectional setup, where the LED has to be adressed by switching the polarity of the two leads. The switches can be obtained relatively cheap directly from the manufacturer Wellbuying from China. For a lot of 100 pcs, I paid only USD 0.78 a piece for a single color version. If anybody is interested, I can post pictures of the yellow as well as the orange version in action. I also have a contact, if somebody needs switches. Meanwhile, they are also available through Mouser, but for a much higher price. Find an individually addressable four button PCB eagle schematic for single LED type TC011s including the part library: LEDSwitch_Matrix_0.7_4.brd LEDSwitch_Matrix_0.7_4.lbr LEDSwitch_Matrix_0.7_4.sch Important: In case you want to use these PCBs in conjunction with a Schaeffer frontpanel with standoffs (no through hole), the mounting holes on the PCB need to be further apart as the glued on standoffs have quite a large base which otherwise interfer with the routed holes for the buttons.
