15,247 -
Hi Thomas, Yes - to be more exact: MBSEQ MIDI IN3 -> BLM MIDI OUT MBSEQ MIDI OUT3 -> BLM MIDI IN MBSEQ 5V Power -> BLM J2 SR counting starts at 1 (0 disables a button/LED function) The first shift register (SR) is number 1, the second SR is number 2, etc Please ignore this part - for historical reasons MBSEQ supports two different BLM extensions as well, but they are not so powerful as the BLM16x16+X All parameters which are starting with BLM_* are intended for a 4x16 matrix - it's expired and only used by people who used this feature for their MBSEQ V3 All parameters which are starting with BLM8x8_* are only used by Wilba's Frontpanel to reduce the number of shift registers The configuration of BLM16x16+X is very very simple! :) Just select OUT3 for BLM_SCALAR in the MIDI->Misc menu - thereafter an auto detection will be started at this port and the BLM16x16+X will be configured remotely from MBSEQ V4 This picture shows how the menu page looks like: Best Regards, Thorsten.
Btw.: the schematics are interesting - I haven't expected that Mackie controls motorfaders with an analog circuit. Thats the way how Rasmus started the MIDIbox MF story some years ago, but we decided to go for total digital control due to the reduced complexity. Best Regards, Thorsten.
As long as you don't connect a SD Card or MBHP_ETH interface to J16: - up to 4 DINX4 - up to 4 DOUTX4 - up to 4 AINX4 Number of buttons/encoders/LED rings only limited by the application you will program by yourself. E.g. if you would multiplex 2x2 DOUT SRs to a 16x16 matrix, you could easily control 256 LEDs If you duplicate this multiplexing to 8x2x2 DOUT SRs to 8 16x16 matrices, you could control 2048 LEDs If it makes sense or not would be your own decision - thats one of the reasons why you will never get a straightforward answer. It would be easier for us to give you a helpful answer if you would introduce your plans (and maybe also a bit of your programming knowledge) first and ask for a feasible partitioning of available resources. Best Regards, Thorsten.
No - I expected that this "imperfection" can't be recognized, and you proved it - thank you! :) I will release the new version anyhow. Best Regards, Thorsten.
Btw.: could you do me a favor? Some days ago I noticed that the timer used for the LED meter handler was called much more frequently than required; this resulted into an unnecessary CPU load of ca. 10% only for meters (instead of ca. 1%). I'm unsure if this really caused any noticable effect (e.g. worse LCD performance), but I feel more comfortable when it's configured as intended. I fixed this but have no chance to test the change on my own MBLC, since it's stuffed with a Core32 module meanwhile. Could you please try this firmware version and tell me, if meters are still working as expected? -> http://www.ucapps.de/mios/midibox_lc_v1_6e.zip Best Regards, Thorsten.
Both issues seem to be related to Sonar. MBLC itself is a "brainless" device - it only sends commands on button/encoder/fader movements, and it receives commands for LCD output, LEDs and Meters. It's always up to the host to control them properly. Thats a special feature of MBLC - in the past there were people who build a MBLC with a reduced number of LEDs and Buttons. The layer feature allows to assign a second set of control/display functions to these buttons/leds. The appr. button/LED assignments are done in LC_IO_TABLE_LAYER1 (the second table in lc_io_table.inc) There are some more special functions, e.g. to switch between different LCD modes, etc... see comments in lc_io_table.inc They are assigned to the second layer so that no dedicated button has to be added. Best Regards, Thorsten.
You could build two MIDIbox64 and link the cores as shown in this picture: http://www.ucapps.de/midibox_link/tunnel1.gif This gives you up to 128 pot, 128 button and 128 LED functions (no need to add a LCD) For USB just buy a cheap 10 EUR interface from EBay (or build a GM5 module) But before you are starting this project it makes sense to ensure that all functions of 3xOSC can be controlled via MIDI. Are you sure that "total control" is supported by the software? Best Regards, Thorsten.
The control surface of your MB-6582 will only run properly with the configuration of setup_6582.hex, please upload this file again. There is no need to select another file just only for changing filter calibration values, as they can be configured in the ENS->FIL menu page (thereafter store the ensemble to make this change permanent) And as a sidenote: the calibration values defined in the .asm files are only taken into account when a "virgin" BankStick will be formatted. Thereafter the values can only be changed in the ENS->FIL page anymore (or from external via SysEx, resp. Rutger's MBSID V2 Editor). Best Regards, Thorsten.
After you've entered the OSC menu page, select all three oscillators so that the pitch range is changed for all of them. Thats the leftmost item of this page (OSC) -> has to be set to "123" instead of "1--", thereafter scroll to the PRn parameter and set it to 12 Best Regards, Thorsten. P.S.: I agree with Phil, your appearance isn't really fair - most people don't know the manual, you haven't mentioned it in your first posting. Nils gave an initial hint which is mostly sufficient. No need to call him "dickhead", is this the usual tone in other forums meanwhile? He is really a nice guy!
In the last days I worked on a major MBHP_MF update, mainly triggered by Screaming Rabbit who gave me a big package of different Alps faders for free! :) Design Targets: find a solution to handle high-quality faders like Alps K faders with "coreless" motors find a solution for MBHP_CORE_LPC17 which doesn't deliver stable enough ADC conversion results due to the reduced 3.3V voltage range find a solution for MBHP_CORE_LPC17 which cannot handle touch sensors properly without heavy CPU load (resp. without an additional external device or microcontroller) find a solution which is compatible with PIC based projects for best usability find a solution which is DIY friendly and doesn't require additional gear (e.g. chip programmer) for something which isn't part of the MBHP yet find a solution which can be easily tested and troubleshooted (no need to learn new processes) Following circuit is the result: http://www.ucapps.de/mbhp/mbhp_mf_ng.pdf a dedicated PIC controller controls the motorfaders directly it can be accessed via MIDI (only) - this allows standalone usage, cascading (to chain multiple modules), and the re-use of existing infrastructure such as MIOS, MIOS Studio and MIOS Bootloader the module can either be connected to a PC directly, or controlled from a second PIC or STM32 or LPC17 (note that MBHP_CORE_LPC17 has a third and even a fourth MIDI IO port at TTL level so that the available two MIDI IO pairs are still free) native support of various protocols (e.g. PitchBender, CCs, even Logic Control and Mackie Control Emulation) support for 8 touch sensors instead of TC4427 I'm using L293D now - not at least because of the integrated diodes. due to the direct motor control connections, the PIC is now able to generate PWM with 50 uS steps for improved motor speed control while a motor is moved since the firmware is dedicated for this task, there was enough memory free to integrate advanced features, such as runtime-calibration and motor position tracing Two snapshots of the prototype - currently I've only tested the circuit with high-quality K Faders, which were not properly controllable with MBHP_MF_V1 Meanwhile PCBs are available (layout created by SmashTV - thank you!!! :) ) MIOS Studio got a new configuration tool: Especially the calibration is much easier now, not at least because of the new motor position tracing feature: Currently following modes are planned: [*] PitchBender Chn#1..#8 [*] PitchBender Chn#9..#16 [*] CC#07 Chn#1..#8 [*] CC#07 Chn#9..#16 [*] CC#16..#23 Chn#1 [*] CC#24..#31 Chn#1 [*] Faked Logic Control [*] Faked Logic Control Extension [*] Faked Mackie Control [*] Faked Mackie Control Extension There is no real need to add more modes, considered that MIDI events can be mapped on the host PC and/or from another microcontroller (like Core32) which uses MBHP_MF_V3 as a companion. By using Pitchbender events, the highest resolution (10bit) is available. More about this topic (e.g. test of different motorfaders) after holidays. :) Best Regards, Thorsten.
0xb1 0x4a will be sent by the pot at the third row, second column. What happens if you turn this pot to full-left or full-right? If nothing happens: the pot isn't properly connected, check the connections! If full-left outputs 0xb1 0x4a 0x00, and full-right outputs 0xb1 0x4a 0x7f, and if jitter stops: replace the pot! Best Regards, Thorsten.
From the album: TK: Guess the Project
Looks like...? -
If somebody would ever do this, please use Juce to ensure platform independency! This would also allow to port the editor to an iPad w/o much effort :) Best Regards, Thorsten.
Since I wasn't sure I tried to switch button functions of my BLM with different resistor values. It works with 1k, 2.2k, 4.7k - it doesn't work with 10k anymore (I guess because the current through the diode isn't high enough) So, it should be ok for these buttons. Best Regards, Thorsten.
Congratulations for this awesome work! I'm really impressed about the short time it took you to create such a robust and great looking case! :) blogged :) Best Regards, Thorsten.
Since you haven't mentioned the keywords "unusued inputs clamped to ground", here a hint: http://www.ucapps.de/mbhp/auaimbctg.pdf Best Regards, Thorsten.
How about a L293D? The propagation delays are in the nS range. Best Regards, Thorsten.
4 years after the last "inofficial" JSynthLib release it made sense to provide a new .jar file with the latest changes. It can be downloaded from: http://www.ucapps.de/jsynthlib.html MacOS users: the Java MIDI driver provided by Apple doesn't support SysEx - you have to install MMJ http://www.humatic.de/htools/mmj.htm Best Regards, Thorsten.
the application has to be adapted to the new interface layer, this hasn't been done yet. i will try to get a camera connection kit before christmas holidays and do the required changes thereafter. best regards, thorsten.
A link would be added to this page once we clarified where to host the precompiled toolchain. But of course, you are allowed to improve the Wiki! Some MIOS32 related informations have been added on a quick&dirty way, and nobody tried to improve the structure thereafter, therefore just step forward! :) Best Regards, Thorsten.
An interesting idea! I don't expect problems, but maybe you should add 100 Ohm resistors to the DIN sync outputs to protect them against shorts. And it could make sense to add these outputs to the MIDI Out socket as well, just for the case that somebody uses the MIDI IN for MIDI clock synchronization. Best Regards, Thorsten.
Never saw this website before; enjoyed the audio samples! :) Best Regards, Thorsten.
Halo Jan, ja, das ist fuer alle "Realtime SysEx" Events (>= 0xf8) erlaubt. Sie duerfen auf der Empfaengerseite auch den Running Status nicht veraendern, so dass man sie wirklich voellig ruecksichtslos jederzeit "einstreuen" kann. Vorrausgesetzt natuerlich, dass sich die Empfaengerseite auch an die MIDI-Spec haelt. Und hier liegt das Problem: MIOS und MIOS32 Applikationen kommen damit bspw. zurecht, doch mir schrieb mal jemand, dass die Elektron-Kisten durcheinander kommen. Auch bei manchen Billig-MIDI Interfaces fuer Mac/PC waere ich mir nicht so sicher (GM5 und MIDIsport 2x2 parsen jedoch korrekt). Gruss, Thorsten.
