15,251 -
> How were the holidays? too short like every time. But my next holidays are in June ;-) Best Regards, Thorsten.
Use of buttons for sending midi on off note events
TK. replied to banneduser's topic in Design Concepts
Step by step 'HowTo's and Walkthroughs written by people who don't see the projects from the technical side are very welcome! Best Regards, Thorsten. -
Btw.: the main reason why such features are not provided by the old firmwares are limitations of the PIC16F architecture. The "caller stack" has only a depth of 8, therefore it's very difficult (or dangerous -> buffer overrun) to call "button functions" from a "MIDI function", etc. However, with PIC18F these limitations are much more relaxed. Best Regards, Thorsten.
thanks thanks thanks - but please wait with your praises until I've finished the module ;-) I will get two AN2131SCs in the next days, thereafter I will create the layout for a prototype board, Mike will make the PCBs, afterwards I can begin with the firmware development. This procedure can take some weeks. However, I don't expect problems, since I got an example application running on a (borrowed) evaluation kit from Cypress Sephult: it's not clear to me what you exactly mean. Bank and firmware exchange via MIDI (resp. USB-MIDI) is already possible; Drag and Drop is something which has to be supported at the "other" side (e.g. by a windows application) and this is not my job ;-) The basics are already available - you are able to access the flash, EEPROM and BankStick memory via MIDI Best Regards, Thorsten.
An interesting solution - yes, should work :) Best Regards, Thorsten.
classical sequencer as mios application
TK. replied to banneduser's topic in MIOS programming (Assembler)
Hi, check also this posting for the planned PIC18F port of MB64seq: http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=news;action=display;num=1051052087 I don't think that it is possible to realize a RM1x like sequencer with one PIC, the implementation of such an project would be easier with an old homecomputer (e.g Atari ST), but an analogue style sequencer with the possibility to chain patterns is exactly the MB64seq concept :) How to setup a new MIOS application: learn the PIC assembly language by reading the PIC18F452 datasheet from the Microchip homepage, learn the programming style by studying the existing MIOS examples and applications (there are a lot of comments in the source code which will help to understand the principles). Best Regards, Thorsten. -
Yes, 6n8 for the 8580 The descriped method (15 V -> 7809 -> 7805) is a good solution for converting the voltage without much heat Best Regards, Thorsten.
Hi Etko, the firmware will send a lot of random MIDI events when some inputs are open. See also the FAQ under "What is the minimal configuration for MIDIbox64". Under these circumstances the box won't work correctly. Rule-of-thumb: Every open analog input has to be connected to ground, every open digital input has to be connected via a 10k resistor to +5V Best Regards, Thorsten.
pots sends only one value (like button)
TK. replied to banneduser's topic in Testing/Troubleshooting
Hi Dendy, it seems that your pots are not connected correctly. Maybe the power lines at the outer pins... check also this schematic: http://www.ucapps.de/mbhp/mbhp_ainx4_64pots.pdf Best Regards, Thorsten. -
Hi Pay.c I will check this. Best Regards, Thorsten.
Don't buy these encoders, 5-bit coding is good for developers who want to drive discrete logic with the encoders, but useless for microcontrollers, therefore it is not supported by MIOS. MIOS only supports the common 2-bit coding. Best Regards, Thorsten.
Hi Lo, the LCD solution which is descriped under Concepts->MIDIbox Link->Introduction requires MIOS and the support for remote menu control by the application. Currently this is not natively supported by any application, but it's already possible (by enhancing the source codes) and official support is planned for the future. Best Regards, Thorsten.
Hi Lowrider, for vectorboard a layout is normaly not required, it confuses much more than the original schematic which can be found here: http://www.ucapps.de/midibox/midibox_plus_16.pdf Just mount the components step by step and connect the pins with wires. Additional informations for this method can be found in electronic beginners books, magazines and possibly somewhere in the web. Best Regards, Thorsten.
Hi Sephult, the application will be written in assembly language for the best performance. A C frontend could be possible, but it's not planned yet. However, small modifications in the control surface should be possible without much PIC knowledge, for advanced solutions you need to learn the assembly language (but a MIDI project is a really good starting point for this :)) Best Regards, Thorsten.
To finish the endless USB discussions, I finally decided to realize a MBHP USB module based on the Cypress AN2131SC. This chip has some advantages compared to ready-made serial USB solutions: 8051 compatible (I already programmed some applications with 8051 derivatives some years ago) 2 UARTS (-> 2 MIDI INs, 2 MIDI OUTs) 8k internal SRAM - only a few number of external pins have to be connected; this reduces the probability for failures 2-stage bootstrap loader allows to transfer the firmware via USB to SRAM without the need for a EPROM or FLASH programmer no propritary USB solution, allows the implementation based on official USB-MIDI specs from http://www.usb.org therefore this module will run under Windows, Mac, Linux without a dedicated driver free development environment & good documentation Since this quarter the chip is available @ Reichelt for 10.50 EUR, therefore it's really a long-term solution In the US it is available @ Digi-Key for US $10.53 the whole module (components, plugs + PCB) will cost about 20 EUR can also be used as MIDI merger and processor, but further enhancements (mini MIDI controller or similar) are not planned from my side (the chip is too slow for such tasks, and MIOS is the better solution for this purpose) implementation in assembler and/or C, code will be published under GNU public license Disadvantage: it's a SMD chip. But this will not be my problem ;-) It has only 44 pins and the pitch is large enough for a common soldering iron with a small tip (="loetspitze") Mike wrote me that he is able to handle with the SMD size, so a PCB will be available once I've finished the firmware development. Best Regards, Thorsten.
Hi, I neither know the MC-505, nor the RPS function, but I can tell you that the step triggers are working on a very efficient way: you can trigger a single step with one of 16 buttons, the note(s) and controller(s) will be played exactly with the original parameters and length, and you can modify the values in this mode by using the pots. The main purpose of the PIC18F version will be to replace the PIC16F firmware. All PIC16 projects will be "phased out" on this way. However, the implementation will be easier to understand, the source code will be available under GNU public license and everybody will be free to reuse the sequencer engine for other control surfaces (303, 909 or whatever...) Best Regards, Thorsten. P.S.: lemonhorse: nice pictures! :)
I'm on leave until end of next week, so don't wait for my answers, help each other and don't let too much open questions here ;-) Best Regards, Thorsten.
Hi Lo, thats an imperfection in the PIC18F implementation which will be fixed with MIOS V1.2 --- problem: it takes a little bit longer to save values in a BankStick, as MIOS also verifies (read back & compare) the content. This enlarges the upload of new patches and can corrupt the data transfer. There are two possible workarounds: upload the whole bank twice (yes, this works! ;-)) or change the delay between the patch transfers directly in JSynth: synthdrivers/MIDIboxSID/MIDIboxSIDBankDriver.java, search for SlowSender.sendSysEx and increase the delay value from 500 to 750, go back into the root menu and compile the source with "javac synthdrivers/MIDIboxSID/MIDIboxSIDBankDriver.java" MIOS V1.2 will provide a "fast write" function without verify which will solve this problem Best Regards, Thorsten.
After exactly two years and a lot of beta versions, v1.00 of MIDIbox64seq is available now. This is the final version for the PIC16F chip --- the features are frozen, only bugfixes will be provided in the future. More features can be expected with the upcoming MIOS based implementation. :) References: Firmware: http://www.ucapps.de/midibox64seq/midibox64seq_v1_00.zip Introduction of the major menu functions http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=news;action=display;num=1035749682 Module connections: http://www.ucapps.de/mbhp/mbhp_midibox64seq.gif Button assignments: http://www.ucapps.de/mbhp/mbhp_dinx4_mb64seq.pdf Tutorial: will be provided after my holidays ;-) Compared to the last beta version, following functions are new: 32 buttons: since most people built a DINX4 module, 8 additional functional buttons are provided now: 4 "Mute Track" buttons, one "Menu Shortcut" button and Sequencer Start/Stop/Continue buttons. However, the box can still be used with 24 buttons only Menu Shortcut button: allows a quick access to all 16 menu pages - you don't want to miss it :) The available menu pages are listed here: http://www.ucapps.de/mbhp/mbhp_dinx4_mb64seq.pdf 128 Patterns: ...are available now with every BankStick. They are named from A1, A2, A3... A8... B1... to h8 Copy function: allows you to duplicate patterns Variable offset: allows you to set a global start point for all patterns BPM: internal clock or slave synced is now a global setting for all patterns Manual Trigger: stops the sequencer and allows you to trigger single steps manually with the general purpose buttons. It's usefull if you want to check or edit every single note Next Pattern: is a mighty function which allows you to create sequences of patterns. Also a repeat function is available (see below) Event config: the MIDI learn function has been replaced by a simple config menu for Note and Controller Events. Other events are not supported anymore (by the PIC16F version!) Some words to the pattern sequencer: the use of this feature could be a little bit unfamiliar at the first time, but in fact this is the easiest solution for live playing - and thats the main purpose of the MB64seq - it's no groovebox, but an analog style sequencer :). Here a usecase: select bank A1 and load preset 4 (N1/C1/C1/C1). Change the notes on the first track so that it sounds cool. Use track 2/3/4 to send controller events for different sound parameters of your synth (e.g CutOff, filter envelope decay, slide/portamento). Go into the copy menu and copy this pattern to A2, A3, A4, ... A8. Go into the "next pattern" menu, set the repeat value to 1, select Bank A1, set A1->A2, select Bank A2, set A2->A3, ... select Bank A8, set A8->A1 press the start button Now you will hear the sequence and you will be able to change the controllers in realtime. Changes will be recorded automatically. If the sequencer is running too fast for you, just slow down the BPM and make your changes without ruffle. Or go into the "manual trigger" mode and edit the steps there. Have fun! :) Best Regards, Thorsten.
Hi Cyril, which PCB are you using? If it is Greg's layout, take care for the DIN chain (must be terminated) and check the connections to the DOUT chain (other people reported problems as well, but after some time they got it running - just soldering errors or missed bridges). Just compare the PCB layout with the DINXx and DOUTXx schematics, this should help. Best Regards, Thorsten.
Hi Steve, yes, thats correct, you need Logic 5 or higher Best Regards, Thorsten.
Yes, really weird. Must be a problem with the bridge between pin 2 of the 74HC00 and the resistor... if not: exchange the IC by another 74HC00 to check if it still works Best Regards, Thorsten.
I'm not sure if this rotary encoder is really applicable for MIOS. The additional pins are not documented, maybe they are used for a push-button function (this would be great) or they are used in conjunction with another movement coding (thumb down) This is the webpage of the manufacturer http://www.nobleusa.com/ Unfortunately the datasheet of the SDE161PUB encoder is not freely available... Best Regards, Thorsten.
Hi Sephult, see also this thread http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=concepts;action=display;num=1046190688 once I've ported the MB64SEQ to MIOS, it will be easy to reuse the sequencer engine also for other control surfaces. Best Regards, Thorsten.
Hi Dan, the "snap" mode allows a similar use like with motorfaders. However, the pots will not be moved automatically, but they won't send new values until the received target position has been reached. See also the MB64 tutorial for additional infos Best Regards, Thorsten.
