15,248 -
The MIDIbox SID will get an AOUT interface with a 4-channel 12-bit DAC and 8 trigger outputs in the future. Of course, the firmware can also run without the SID itself, on this way you have nice CV interface with additional virtual LFOs, EGs, slide, arpeggiator, and so on... :) Best Regards, Thorsten.
No, I didn't forget the drum pad option, I just decided not to implement it, since Admir already did it in his edrum project. Why should I reinvent the wheel? ;-) Best Regards, Thorsten.
Since I also need this possibility sometimes, when I want to duplicate the stored pot setups, it's on the ToDo List now. Best Regards, Thorsten.
Some menu options (e.g MIDI Learn and Encoder Mode assignments) can be already controlled by the encoders, for other function it isn't really necessary. Btw.: In the next weeks I will release a new MB16E firmware which allows to select one of 128 parameters for every encoder seperately on the fly - intependend from the current bank by pressing a button and just turning the encoder to which the parameter should be assigned to. During the selection, the parameter name will be displayed on the LCD. In a later version, it will also be possible to group encoder assigments. I think that this will result into a very efficient usemodel for (software) synthesizers. :) Best Regards, Thorsten.
I'm on vacation for some days, please link together on problems and questions regarding the MIDI projects. :) Best Regards, Thorsten.
Ideen sind angekommen :) Sobald ich den Sequencer erstmal von der MIDIbox64 firmware separiert habe, kann ich solche Features beruecksichtigen. Momentan werden noch die MIDI-Events fuer alle 64 pots gleichzeitig im RAM gehalten, das verbraucht 128 Bytes RAM. Ich moechte das Handling aber so abaendern, dass die Informationen nur bei Bedarf (kurz bevor sie benoetigt werden) aus dem internen Flash, bzw. aus dem externen BankStick geladen werden. Auf diese Weise lassen sich a) wesentlich laengere Sequenzen, b) mehr Variationen, c) mehr Tracks gleichzeitig, d) einen Super-Combined Mode mit Wahlschalter fuer Notenhoehe/Velocity/Gatelength pro Pot-Reihe, und noch vieles mehr realisieren. Mutes sind uebrigens schon sowohl fuer die einzelnen Tracks, als auch fuer die einzelnen Pot-Reihen moeglich - aber auch das wird dann noch erweitert... :) Gruss, Thorsten.
Hoert sich so an, als wuerde die Spannung einbrechen, die sollte immer konstant auf ca. 5 V (+/- 0.2V) liegen, auch dann, wenn man an den Pots herumdreht. Wieviel Strom liefert Dein Netzteil maximal? Und funktioniert es vielleicht besser, wenn Du das Backlight erstmal abklemmst? Gruss, Thorsten.
For the records: Legato problem has been fixed - if anybody has a synth with the same feature (mostly used for glides), just download the update here: http://www.ucapps.de/midibox/mb64_v0035pre1.hex.zip Best Regards, Thorsten.
Hi Sascha, normaly the pins are the same like descriped on the MBHP-LCD page. Merely the pins for the backlight are sometimes twisted (+ -> -) . But take care for the SIL connectors if you don't have experience with SMD pitch soldering. Here: my first try - on this way I soldered Tor Arne's LCD (I removed the SIL cable, since SIL headers are hard to find) Best Regards, Thorsten.
Hi Soma, some people really want detented dials (which normaly only send 24 ticks/revolution), others not - thats a problem ;-) For MIDIbox16E non-detented types (without the click) are a must, otherwise the double-resolution feature will not work. I used ALPS STEC16B36 encoders (see http://www.ucapps.de/midibox16e.html, the feeling is similar to normal pots. Best Regards, Thorsten.
Hi Alex, yes, I think this is the best "temporary" solution, before you start with the case for all the pots and buttons. MIDIbox16E: sure, it works - you can assign the different controllers (see http://www.ucapps.de/midibox_sid/sid_cc_implementation_chart.txt) to the 8 internal banks. The "encoder positions" will be automatically saved on every bank change, so that you can switch back and forth through the banks without information loss. :) Best Regards, Thorsten.
Hi TraiZor, the old schematics are archived in this zip archive: midibox64_pcb_greg6.zip However, the connections for the BankStick are still the same like for the MBHP version. Best Regards, Thorsten.
Yes, 250mW is in the allowed range. With 5V every pots spends U2/R = (5V*5V)/10000 = 2.5mW Best Regards, Thorsten.
Hi Thomas, you can control note, velocity and gate at the same time with the 3 upper pot tracks in all modes beside of "independent mode" - best results in "transpose hold" and "arpeggiator hold" mode. :) Best Regards, Thorsten.
This was also my thought while i've heard the song. ;-) However, the tune is really nice - much better than the current top10 stuff from www.mp3.de Best Regards, Thorsten.
Hi Alex, See the MIDIbox SID page: Not before next year, when the features are clear and I know which knobs, sliders and buttons have to be available for direct control. I don't want to provide any further informations before all synth features have been implemented. The MIDIbox64 solution I explained in the last posting is an immediate solution --- it will be replaced by something really different - a perfect control surface which is handled by the MIDIbox SID firmware itself. sure Don't mix the BankStick for MIDIbox64 with the BankStick for MIDIbox SID! To reduce the confusion, I will not answer any MIDIbox64 relevant questions now --- the BankStick for MIDIbox SID will be able to store 128 patches. You can plug it on any MIDIbox SID module, of course, it will also be possible to transfer the settings to one of the SID modules. No further informations until next year. I want to finish a lot of features for the other projects (which will partly be used by the SID firmware) before I continue with the MIDIbox SID. And I don't want to promise non-evaluated features. This is already possible. Once more: the MIDIbox SID is already a perfect synth module - main focus for the next time is to finish the sound features, thereafter I will begin with the pot stuff. Note that all MIDIbox projects are sparetime projects ;-) I take your inspirations into account, but I implement it on a way where it works perfectly for my own needs :) Best Regards, Thorsten.
It's a DINX4 (fixed). The digital inputs are for the menu keys, the special-function-buttons, MIDI triggers and later for the touch sensors. Best Regards, Thorsten.
Leider nicht, das wuerde nur mit einer sogenannten Calibration-Table funktionieren. Koennte man vielleicht mit einem Meta-Event realisieren; Beispiel folgt. Gruss, Thorsten.
Ueberpruefe nochmal die Polung des MIDI-Out-Ports. Meistens sind die beiden Adern vertauscht. Falls das nicht hilft, schliesse eine LED an den Port, so siehst Du, ob sich etwas tut. Gruss, Thorsten.
The error must be between the programming port J3 and the PIC power lines. You could follow the tracks based on the schematic, this will be easier: http://www.ucapps.de/mbhp/mbhp_core.pdf Best Regards, Thorsten.
Hi DiGiMac, the Doepfer support forum can be found here: http://server3.ezboard.com/bdoepfermusicelektronic Best Regards, Thorsten.
Hi Alex, since the SID firmware is very busy with all the 16 and 32 bit additions, multiplications and divisions, which are necessary to emulate the LFOs/Pitch/Envelope generators, only one SID can be controlled by one core module. Every CORE/SID module combination can be assigned to another MIDI channel, so up to 16 SIDs can be controlled over one MIDI cable ;-) If you want to control them with a MIDIbox64, you can get use of a BankStick which allows you to store 16 setups (e.g. for 16 channels) seperately. However, with the upcoming control surface the SID can be controlled much easier and of course I will provide a function which allows to access other SID modules from one console (I will try it with the MIDIbox-Link...) Best Regards, Thorsten.
...can be found here: http://www.ucapps.de/mbhp_mf.html Worst part is the documentation yet, but I will try to improve it in the next days. :) Here an impression: I switched back and fourth through 8 banks and recorded the sound of the faders. "Unfortunately" the faders are very quiet, so I had to amplify the mic so much, that a disturbing 50 Hz buzz was hearable :-/ Result: the bankswitching takes about 0.2 ms :D http://www.ucapps.de/midibox_mf/mbmf_sound_of_faders.mp3 Best Regards, Thorsten.
Dem muss ich widersprechen - Lochraster eignet sich zumindest fuer Potis hervorragend. Siehe auch: http://monopole.ph.qmw.ac.uk/~thomas/synthdiy/TBbox1.htm und: http://www.midibox.org/midibox16e_photos/10.html Noch ein Tip zu den Kabeln: am besten lassen sich die von mir empfohlenen Flachbandkabel verloeten, Litze ist meist zu dick, und Klingeldraht wird sehr schnell bruechig. Gruss, Thorsten.
Great! :D Best Regards, Thorsten.
