15,250 -
Here is the MIDIbox SEQ V4 firmware: http://www.ucapps.de/mios32/midibox_seq_v4_087_pre1.zip Here a (temporary) BLM build for Linux: /edit: removed, now available at http://www.ucapps.de/midibox_seq_manual_blm.html After you've started the BLM emulation, select the MIDI IN/OUT port which connects to your MBSEQ. Don't take the 1st USB port (normally used for other purposes), I usually take the 3rd In the MBSEQ MIDI->Misc page, select USB3 (for the 3rd USB MIDI port) Back to the BLM emulation: select the "16x8+X" layout and click on the "Ext. Controllers" button and configure the MIDI ports to which your Launchpads are connected, and the "rotation" (this is freely configurable, but I only tested 270° for the first, and 0° for the second Launchpad as you can see on the photo above). It's currently too late in Europe to give you more details (or test the BLM emulation under Linux)... More informations tomorrow - just try out whatever is possible today. It also makes sense to start a separate thread for this topic, because I think that you will have a lot of questions and proposals ;) Best Regards, Thorsten.
Hallo, nein, das sollte nicht sein. Vielleicht ein Kurzschluss? Nimm mal alle L293D ICs aus den Sockeln, ist Vm dann wieder normal? Gruss, Thorsten.
I've enhanced the BLM Emulation so that it supports Novation Launchpads, and I updated the MBSEQ V4 firmware so that it properly supports 16x8 matrices. Up to 4 Novation Launchpads can be connected to emulate a complete BLM16x16+X, here only two for a BLM16x8+X The BLM Emulator is currently only tested under MacOS, but it should also run under Windows and Linux. @borfo: which OS do you prefer? I could build & test the binary for you. Best Regards, Thorsten.
Yes, it may be less intuitive (but that's also a question of good documentation... you could help me to improve this :smile:) Maybe it's implemented this way because I thought a step further: it makes sense to control transpose and root note centrally (from loopback tracks or from an external keyboard). Mostly you want to transpose the root note as well, but there are also cases where it makes sense to keep the root note as demonstrated in the tutorial. yes: with root="keyb", the root note will be set according to the notes which are received from Bus1 (and only from this one). Which means: if you would like to get an independent control over root note and track transpose, then send the notes which should target the transposer from another loopback track to different bus. Best Regards, Thorsten.
Hi, Yes, but this is exactly what the text above the configuration option wants to say: ;; select the BankStick type you are using here: ;; 0: "normal" 24LC256 EEPROM (32k), up to 8 EEPROMs can be connected for 8 banks ;; 1: 24LC512 EEPROM (64k), up to 4 EEPROMs can be connected for 8 banks ;; (it is not possible to mix 32k with 64k EEPROMs, more than 4 64k devices not supported) 24LC256: 8 EEPROMS, 8 banks 24LC512: 4 EEPROMS, 8 banks Means: one 24LC512, 2 banks, two times a rising sound during startup, alright? :) See http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fsynthesizers%2Fmidibox_sid_v1%2Fdoc%2Fsid_cc_implementation_chart.txt CC # | Hex | Description | Range | Reset =====+=====+==============================================+=============+====== 0 | 00h | Bank change | 0-7: bank | 0 Best Regards, Thorsten.
In MBSEQ you would transpose the notes played by a track centrally from a loopback track or external keyboard. Advantage: all tracks follow the transpose note (or chord if arpeggiator is used) at once. For those who prefer separate control, they could use different transpose/arpeggiator busses. 4 Busses are available, which should be sufficient (I never used more than 2 busses by myself) @Daniel: I will reply to other ideas sooner or later (piecewise) Best Regards, Thorsten.
Some words how something similar could be achieved with the current firmware: The force-to-scale function allows you to set the root note to the one which is received from the transposer. Means: if you transpose from C to D (Track mode set to Transpose in the MODE menu page), the scale root will be automatically shifted by +2 and the played chords would still be proper major, playing the i, ii, iii, iv, v, vi, and vii and some other combinations depending on the selected chord number. The transpose function has to be enabled for the track similar to this tutorial: http://www.ucapps.de/midibox_seq_manual_tut3.html Only difference is, that you would set Root=Keyb in the MENU->Fx-Scale page. Note also, that it's possible to control the root note from a loopback track as well (there is a CC for this) Are you already aware of this possibility, or is this new to you? Well, easy: just use a drum track and configure the notes for the different trigger layers according to the chord members you want to play. Enable force to scale, and take either a static root note, or set the root note to Keyb Would this already solve your request? Best Regards, Thorsten.
-> http://www.ucapps.de/midibox_seq_manual_in.html Best Regards, Thorsten.
Yes, it will be integrated into the Juce based emulator. Of course, it can be compiled for Linux, and with a newer Juce version it should even be possible to compile it for a Raspberry Pi which then will be the cheapest solution to connect the controllers. ;) Best Regardsm, Thorsten.
No, I've haven't implemented the required code yet... Best Regards, Thorsten.
An update on the Novation Launchpad Mini experiment: I got the devices today. The adaption shouldn't be so difficult, although we will miss the second half of the original BLM16x16+X, and MBSEQ will also be loaded much more due to the poor LED control protocol (even the "optimized" solution is multiple times slower than my own protocol, especially when LED rows should be updated vertically). However, since it's a USB MIDI connection, we would probably never noticed this... But I've also bad news: the controllers won't work with a direct USB connection to a STM32F4 core due to three reasons: 1) MIOS32 doesn't support USB hubs, which means that only a single device can be connected directly. Adding support for USB hubs will be a challenge, because there isn't so much information available in the internet which would directly help. Developing it from scratch would result into too much effort, and the only open sources I found so far are in the Linux driver, but even this one needs some days & try & error to get it working. 2) even more annoying: a USB MIDI connection can't be established while connecting a single Novation Launchpad Mini to a STM32F4. The communication already stalls while STM32F4 tries to get the device descriptor. 3) But not only that: this device is the first one that I've seen so far which uses isochronous transfers instead of bulk transfers for USB MIDI; transfers will only take place each mS instead of "as soon as possible". Again a poor choice - I've no clue why this should make sense, e.g. data integrity is not guaranteed with this type of transfers (-> MIDI events can get lost) However, considering these flaws I think that Novation devices shouldn't be accessed directly by a MIOS32 core, but only from a computer (Mac or (Micro-)PC). And if a computer is involved anyhow, MBSEQ doesn't need to provide the remote device protocol directly, but it could still use it's own "optimized BLM protocol", and the translation to the remote device can be done externally. Thinking a bit further I come to the conclusion, that I could simply implement the "translation" into the BLM16x16+X emulation app! This might also add some more flexibility - let's see. More updates on this topic this weekend. Best Regards, Thorsten.
pitch, external switches and cvs sometimes not working as expected
TK. replied to jrp's topic in MIDIbox SID
It still puzzles me how this can happen. Best Regards, Thorsten. -
Yes, a software solution should be easy. Providing a switch which allows to change the behaviour during runtime is a bit more difficult, because this hasn't been considered yet. But if it's acceptable to provide a runtime control only for MBNG, and only via a .NGR command, then it wouldn't be a big deal. Best Regards, Thorsten.
I'm glad that you are happy with the current solution :) Today I did some finetuning & minor improvements (e.g. display clearly shows if you are in the "EDIT RECORDING" mode), record page can now also be entered by pressing EDIT+GP12 button, etc... If somebody still notices imperfections, please check again with the final v4.086 release. @Gridracer: sounds like Live recording was enabled, and some notes were incoming from an external device. If this happens again check with the integrated MIDI Monitor if events are received over the MIDI port and channel which is selected in the Record page. Complete ChangeLog for V4.086: MIDIboxSEQ V4.086 ~~~~~~~~~~~~~~~~~ o MIDI Learn for Drum notes in Track Event configuration page: on a drum track, press & hold button GP12 to set the drum note depending on the configured recording port & channel (which has to be configured in the RECORD page) o Edit page: press&hold a GP button to record directly into the selected step o Edit page: config page which was previously visible by pressing the SELECT button now displayed by pressing&holding EDIT button. SELECT button now toggles step recording mode o Edit page: added shortcut to Recording Config (EDIT+GP11/GP12) o Record page now allows to toggle the FTS and FX flag for MIDI Forwarding (same flags can be configured in LIVE page) o Step Recording: note length measurements now also working correctly when the sequencer is clocked in slave mode. o Track Event configuration page: VelN/VelA not displayed if they are not relevant for the selected configuration. o Clear function will clear all selected tracks o LFO page: Extra CC can now be disabled/enable with a separate switch o Echo page: echo can now be enabled/disabled without touching the repeat value Best Regards, Thorsten.
Topic 13 and 15 are now implemented in v4.086 Best Regards, Thorsten.
V4L.086 is now available for download From the ChangeLog of V4L.085 (didn't got a public release) and V4L.086: MIDIboxSEQ V4L.086 ~~~~~~~~~~~~~~~~~~ o Step Recording: note length measurements now also working correctly when the sequencer is clocked in slave mode. MIDIboxSEQ V4L.085 ~~~~~~~~~~~~~~~~~~ o new parameter LiveKeepChannel in MBSEQ_C.V4 file to change the MIDI forwarding function so that the MIDI channel won't be changed according to the selected sequence, but will be kept. o clock divider (configured while pressing the Tempo button) handled correctly for PitchBend and CC tracks Best Regards, Thorsten.
Ok, habs verlinkt Gruss, Thorsten.
Is this normal for a sammichSID? (three mono voices)
TK. replied to Dronepiper's topic in MIDIbox SID
Which firmware version are you using? And did you upload the firmware by yourself, or could it be that somebody else modified the default configuration? If not it makes sense to upload the latest version just to ensure that you are using the sammichSID under the same conditions like the other users who haven't reported such a problem yet. Best Regards, Thorsten. -
Hallo, es wundert mich nicht, dass der Fader die Position nicht mehr anfahren kann - wie soll er die momentane Position wissen, wenn der Wiper nicht an J2 angeschlossen wurde. Es gibt leider kein Tutorial; in der letzten Zeit wurden weiterfuehrende Infos meistens in diesem Thread bekanntgegeben: Gruss, Thorsten.
Well, I'm not blind... I developed the BLM16x16+X at a time where nothing comparable was available on the market aside from the super-expensive Monome (which only supported mono-colour LEDs). Multiple people tried to help me to make this project more DIY friendly (e.g. by creating PCBs), but without much success. We had problems to find an inexpensive Button/LED combo which will be available over long-term, and to make the PCB(s) "shipping friendly" for a small community. Meanwhile it doesn't make much sense to continue with this approach anymore: although a BLM16x16+X has still more button/LEDs with a perfectly suitable layout, the Launchpad Minis are cheaper, have a higher quality, could be used together with other SW and even have RGB LEDs instead of Duo-Colour LEDs -> more bang for the money. So, if such devices become some kind of inexpensive standard, it really makes sense to support this - not only for MIDIbox SEQ, but maybe also for MIDIbox NG! I'm always interested to find a solution which is interesting for as many users as possible. I'm not a DIY fanatic, instead I like the challenge to make unusual things happen. So: thank you for triggering this initiative at the right time, I feel that it will become a MIDIbox standard device for the next years :rofl: Best Regards, Thorsten.
Update: i ordered two Launchpad Minis... Best Regards, Thorsten.
Thanks a lot for the cash! :phone: Of course, once I have it on my hands, I will get a strong wish for a perfect integration into my setup ;) But please note, that it can take some time - one step after another! /edit: removed private stuff.. Best Regards, Thorsten.
No beer w/o success ;) Yes, it makes sense to swap the SIDs, the audio connections, etc. You should also try the Ctrlr based editor, because it gives you the better oversight over all parameters: Best Regards, Thorsten. -
Ok, then the MIDI channel and oscillator assignments are working. Since SID-R is working with other engines, I guess that it's related to the filter or waveform settings. Best Regards, Thorsten. -
Thanks for the feedback! I find it better as well, on the other hand I don't like the flaw in combination with the SELECT button. However, if nobody really minds about this issue, then it's ok for me ;) Remote Control: the code is located in seq_sysex.c: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fsequencers%2Fmidibox_seq_v4%2Fcore%2Fseq_midi_sysex.c keyword "remote" Since the hooks are there, it wouldn't be so difficult to provide a similar solution for Note/CC based communication. Update: I just noticed that Button and Encoder events are already sent as Notes and CCs - just only the LED state is SysEx (for best performance). A one-to-one LED control is too slow over a common MIDI line. It could work over a USB MIDI based line assumed that a novation launchpad can handle USB as fast as MIOS32. Best Regards, Thorsten.
