TK.
Administrators
    15,251
  1. The vertical row is driven by two lines which go to J15A via two transistors - a broken transistor is unlikely, check the 16 pin cable again. Best Regards, Thorsten.
  2. Yes, the #defines are listed here: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fdoc%2Fmios32%2FMIOS32_CONFIG.txt Best Regards, Thorsten.
  3. It's better to add #define MIOS32_DONT_USE_AIN 1 to the mios32_config.h file, this should disable the MIOS32_AIN code and calls to MIOS32_AIN driver (e.g. in main.c) completely. Best Regards, Thorsten.
  4. TK.
    AOUT problem
    The gate LEDs are a good indicator, if the Core->MAX525 communication is working or not, because an unconnected bipolar PSU or shunt won't affect this. Apparently the communication is not working, otherwise the gates would be enabled whenever a note event is played. Just to doublecheck: I guess that you are trying this example: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2Fcfg%2Ftests%2Fcvnotes.ngc Did you change: AOUT type=AOUT_NG cs=0 num_channels=8 to: AOUT type=AOUT cs=0 num_channels=8 to select the right protocol? If yes: doublecheck the connections between AOUT module and MBHP_CORE_LPC17::J19. Best Regards, Thorsten.
  5. Jo, dann solltest Du mal eine aktuellere MIDIbox NG Version installieren... :rolleyes: Gruss, Thorsten.
  6. TK.
    No sound 18f4685
    Did you consider, that for the PIC18F4685 D2 and D3 of the OPL3 board are available at Pin RE1 and RE2 of the PIC? Because RB2 and RB3 are reserved for the CAN interface. This doesn't explain why you don't see an effect at D0 and D1. But it could explain, why you noticed a difference with the PIC18F4620 Best Regards, Thorsten.
  7. Du musst noch die MIDIbox NG Applikation aufladen. Gruss, Thorsten.
  8. TK.
    No sound 18f4685
    Are you able to control J15:D0..D3 on the MBHP_CORE module with the mbfm_interconnection_test when the MBHP_OPL3 module is *not* connected? Could you please do this check with PIC18F4685 and PIC18F4620? Best Regards, Thorsten.
  9. Klar, wenn Du die MIDIbox NG Applikation verwendest, definierst Du die Pin-Belegung ja nicht in der Firmware, sondern in Deinem .NGC File. Hier muessen lediglich die beiden Pin-Zuweisungen vertauscht werden. Beispiel: aus ENC n= 1 sr= 1 pins=0:1 type=non_detented wird: ENC n= 1 sr= 1 pins=1:0 type=non_detented Gruss, Thorsten.
  10. Hallo Mark, hast Du schon ueberprueft, ob evtl. an der Bruchstelle Leiterbahnen "zusammengequetscht" wurden, so dass ein Kurzschluss entsteht? Gruss, Thorsten.
  11. Ok, I see! In the hysteresis function I haven't considered that somebody could use the new switch mode with a reduced range. This should be fixed now: http://www.ucapps.de/mios32/midibox_ng_v1_030_pre3.zip But you have to change your hardware as well. (don't worry, no risk for damage!) One side of the button should be connected to ground, the other to the analog input. And the Pull-Up resistor is mandatory, otherwise the input will float when the button is not closed, and this will result into random MIDI events. The other unused inputs can be connected to ground directly, no need for 220 Ohm resistors. Best Regards, Thorsten.
  12. Awesome! :hyper: Your tune greatly demonstrates the spirit of SID tunes in combination with MBSID specific features. Therefore I couldn't resist to publish it in the MIDIbox Blog and the MIDIbox SID entry page! :smile: Best Regards, Thorsten.
  13. Hopefully you will find somebody who helps you to doublecheck all connections... yes, unused inputs of this chip should be connected to ground. Best Regards, Thorsten.
  14. Ja, einfach die Pin-Zuweisungen um eins erhoehen, das invertiert automatisch den Incrementer. Bspw. in diesem Tutorial: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Ftutorials%2F014_enc_relative%2Fapp.c enc_config.cfg.pos = pin_pos + 1; // swap pins Gruss, Thorsten.
  15. 5k is perfect (actually I would even prefer such faders instead of 10k due to the better signal/noise ratio!) No changes are required. Best Regards, Thorsten.
  16. Could you please try following version: http://www.ucapps.de/mios32/midibox_ng_v1_030_pre2.zip It supports the new "ain_mode=Switch", which should work much better: o added ain_mode=Switch for AIN and AINSER events. Can be used if buttons are connected to analog inputs. The event will send the min value if a 30% threshold is reached, and the max value if a 70% threshold is reached. Schematic: Ground |----o Button o-----> analog input + 10k Pull-Up resistor to 3.3V (AIN) resp. 5V (AINSER) No .NGR hack required anymore :) I tested this with: EVENT_AINSER id= 1 type=CC ain_mode=Switch chn= 1 cc= 16 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" Best Regards, Thorsten.
  17. Please try following version: http://www.ucapps.de/mios32/midibox_ng_v1_030_pre2.zip o added new meta events to control the internal MIDI clock generator: MClkPlay, MClkStop, MClkPlayStop, MClkPause, MClkDecTempo, MClkIncTempo, MClkSetTempo. Example can be found under cfg/test/midiclk.ngc o added new string formatting items: %t to display MIDI clock state (Play/Stop) %T to display tempo (BPM) o added new MClk menu page to SCS to control the tempo w/o dedicated controllers Best Regards, Thorsten.
  18. Please try this version: http://www.ucapps.de/mios32/midibox_ng_v1_030_pre2.zip The "silent set" can now be done with: change Button:123 ^value and the reason for 2) was, that the button will always send the "max" value of the specified range (0:127 by default). The new: set_max Button:123 ^value command will allow you to change the range Best Regards, Thorsten.
  19. TK.
    AINSER MIDI Noise
    Evtl. falsch verdrahtet. Mach' mal ein Foto! Gruss, Thorsten.
  20. You could try if it works better for you if you invert the "fast" function selected with the SHIFT button. For this, open src/cs_menu.inc, search for btfss CS_MENU_MODE, CS_MENU_MODE_SHIFT_PRESSED replace "btfss" by "btfsc" Thereafter build a new .hex file (see also the Wiki for more infos on the toolchain) Alternatively it should also be possible to set a specific speed for the cutoff encoder in the CS_MENU_EncSpeedSet function if you prefer this (but I would have to test the code before providing it) Best Regards, Thorsten.
  21. TK.
    AINSER MIDI Noise
    Servus, welchen Widerstandswert haben denn die Schieberegler? Und haben sie (hoffentlich) eine lineare, oder eine logarthmische Kennlinie? (das koenntest Du mit einem Ohmmeter ueberpruefen) Falls das nicht weiterhilft, wuerde ich empfehlen, die Fader abzustoepseln, und temporaer die Eingaenge auf Masse zu haengen. Jittert es dann immer noch? Wenn ja: Loetfehler! ja, kein problem. Gruss, Thorsten.
  22. Works at my side: svn co svn://svnmios.midibox.org/mios32 A mios32/trunk A mios32/trunk/tools ... Best Regards, Thorsten.
  23. Yes, it's possible to run multiple instances. There are two solutions: 1) just duplicate the MIOS_Studio.app, and call it "MIOS_Studio Second.app" 2) call the application from the command line (I prefer this way). E.g. added following aliases to my ~/.batch_profile alias ms='/Applications/MIOS_Studio.app/Contents/MacOS/MIOS_Studio' alias ms_batch='/Applications/MIOS_Studio.app/Contents/MacOS/MIOS_Studio --batch' Whenever I need an additional session, I enter: Or whenever I want to upload a .hex file from the terminal, I use ms_batch Enter ms_batch --help for additional informations. Best Regards, Thorsten.
  24. The implementation shouldn't be a big task, I added this to the Wishlist Best Regards, Thorsten.
  25. By default following stack size is used (see programming_models/traditional/FreeRTOSConfig.h): #ifndef MIOS32_MINIMAL_STACK_SIZE #define MIOS32_MINIMAL_STACK_SIZE 1024 #endif ... #define configMINIMAL_STACK_SIZE ( ( unsigned portSHORT ) (MIOS32_MINIMAL_STACK_SIZE/4) ) as you can see, the byte size has to be divided by 4, because FreeRTOS counts the memory word-wise Which means, that you tried to allocate 24580 bytes - which fails (for obvious reasons). Note that programming_models/traditional/main.c creates two additional tasks for MIDI and other purposes, which need memory from the heap as well (1024 bytes per task as defined with MIOS32_MINIMAL_STACK_SIZE) Best Regards, Thorsten.
