15,248 -
Mios studio and Linux Puppy Frugal
TK. replied to John_W._Couvillon's topic in MIDIbox Tools & MIOS Studio
I second that! Best Regards, Thorsten. -
Hi, yes, not required for J16 J16 (SD Card) has to be supplied with 3.3V, therefore J24 should select 3.3V J25 and J26 should select 5V No, please install 220 Ohm arrays for J8/9 and J19 yes Best Regards, Thorsten.
Let's take this into the Wishlist for the STM32F4 based "MIDIbox SEQ V4 Plus" Best Regards, Thorsten.
MBSEQ isn't a USB host device as well. This could become a feature of the STM32F4 based "MIDIbox SEQ V4 Plus", but it has low priority at my side (because I know that this will result into some remote troubleshooting for devices which I don't own by myself) Best Regards, Thorsten.
Problem was related to a bug in Lemur - see also Best Regards, Thorsten.
It's a bug in Lemur! "<variable> |= <value>" isn't working anymore. I added a workaround ("<variable> = <variable> | <value>") which solves the issue - patterns are displayed correctly again! :smile: -> MIDIbox_BLM16x16+X_v1_003.zip for Lemur Best Regards, Thorsten.
Ok, LEDs now lit according to the gatelength. :smile: I spent some more thoughts on this: actually it's better if the entire sequence is cleared with CLEAR+SEQ1 resp. CLEAR+SEQ2. And the GP buttons just clear the related track without hidden conventions (e.g. it wasn't obvious that GP#4 only clears PitchBend). In combination with a changed CC line assignment algorithm the CC Clear function finally becomes more useful: o CLEAR button now allows to clear individual tracks with the GP buttons: - CLEAR+SEQ1: clear entire Seq1 + configuration (*) - CLEAR+SEQ2: clear entire Seq2 + configuration (*) - CLEAR+GP1: clear note triggers (values are kept but not played) - CLEAR+GP2: reset velocity values to 64 - CLEAR+GP3: reset note length values to half step - CLEAR+GP4: clear Track 4 (Pitchbend + last CC lines) - CLEAR+GP5: clear CCs of Track 5 - CLEAR+GP6: clear CCs of Track 6 - CLEAR+GP7: clear CCs of Track 7 - CLEAR+GP8: clear CCs of Track 8 Same for GP9..16 for Seq2 (*) track configuration won't be changed if 'PasteClrAll' set to 0 in MBSEQ_GC.V4 file o changed the track and layer assignment algorithm for CCs in recording mode: Previously new CC lines were recorded into Track 4, Layer B upwards. Now they are assigned the following way: - 1st CC line is recorded into Track 5, Layer A - 2nd CC line is recorded into Track 6, Layer A - 3rd CC line is recorded into Track 7, Layer A - 4th CC line is recorded into Track 8, Layer A - 5th CC line is recorded into Track 8, Layer B - 6th CC line is recorded into Track 8, Layer C - 7th CC line is recorded into Track 8, Layer D - 8th CC line is recorded into Track 7, Layer B - 9th CC line is recorded into Track 7, Layer C - 10th CC line is recorded into Track 7, Layer D - 11th CC line is recorded into Track 6, Layer B - 12th CC line is recorded into Track 6, Layer C - 13th CC line is recorded into Track 6, Layer D - 14th CC line is recorded into Track 5, Layer B - 15th CC line is recorded into Track 5, Layer C - 16th CC line is recorded into Track 5, Layer D - 17th CC line is recorded into Track 4, Layer B - 18th CC line is recorded into Track 4, Layer C - 19th CC line is recorded into Track 4, Layer D Same for Track 12..16 for Seq2 Advantage: if only a few CC lines are recorded, we've dedicated tracks for PitchBend and CCs (Track 4-8, Layer A) which can be individually muted and cleared. Additional CCs populate the remaining layers from Track 8 backwards, so that PitchBend remains an individual track if not more than 17 CC lines are recorded. The new pre-release is available at: http://www.ucapps.de/mios32/midibox_seq_v4l_082_pre3.zip /Update: v4l_082_pre3 provides a better Seq1/2 selection handling whenever a track is cleared Best Regards, Thorsten.
no, but I take this as a reminder... Best Regards, Thorsten.
Da muessen aber noch viel mehr Probleme geloest werden, nicht nur ein lokales Stop/Play... ;-) Hast Du Dir schonmal dieses Projekt angesehen? -> http://midisizer.com/midirex/ Gruss, Thorsten.
Hi Jazza, It's sad to read that a MIDIbox builder died! Do you know his forum name? It seems that there is a problem with your MIDI interface, because SysEx messages are corrupted. Is it already listed here? -> http://www.midibox.org/dokuwiki/doku.php?id=midi_interface_blacklist Do you own an alternative MIDI interface? Best Regards, Thorsten.
Well, if you see the AINSER menu item, you can already use the AINSER8 module. Disadvantage: one pot movement will generate 8 MIDI events instead of only 1 (because the analog input is not multiplexed). The 7 redundant MIDI events can be disabled by clearing all MIDI port flags (USB1..4, OUT1..4, OSC1..4) However, if you are saying, that no MIDI events are generated at all, there is either a connection or a software configuration problem. It's very difficult to support you on such an issue remotely if you are not able to use MIOS Studio; and I can't help you on Linux issues! If you would be able to use MIOS Studio, you could just follow the testing procedure under: http://www.ucapps.de/mbhp_ainser8.html Your observations with the ainser_jitter_mon application would make it much easier to give additional debugging hints... Best Regards, Thorsten.
Hi Florian, somehow I already feared that this can lead to confusion: the GP button assignments are similar to the MUTE page: button #1..#8 control Seq1, and button #9..16 control Seq2 independent from the selected sequence. Advantage: direct control over both sequences without switching Disadvantage: unusual/inconsistent UI handling It's probably better if I decouple the UI from the actual track & layer assignments (which are inherited from the "big brother" V4): - button assignments in CLEAR and MUTE page shall reflect the sequence selection, starting from button #1 - button assignments shall differ between Pitchbend and CC layers in track #4..7, which means that: o Button #1 clears/mutes note triggers o Button #2 resets velocity (mutes have same function like Button #1: no notes are played) o Button #3 resets note length (mutes have same function like Button #1: no notes are played) o Button #4 clears/mutes the Pitchbend line o Button #5 clears/mutes the first recorded CC line o Button #6 clears/mutes the second recorded CC line o ... o Button #15 clears/mutes the 11th recorded CC line o Button #16 mutes the remaining CC lines in MUTE page, resp. it initializes the whole sequence & configuration in CLEAR page Do you agree, and/or do you have additional ideas? Best Regards, Thorsten.
This is the default configuration: http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Ftools%2Fmk_syx%2Fmidibox64.ini And with the default LED_MAP the LEDs should reflect the state of the buttons. Best Regards, Thorsten.
It seems that I've to re-adjust the prefetch time which ensures a proper synchronization. It's the most timing critical operation, because a lot of data has to be loaded from SD card while MIDI notes from previous patterns are played by the scheduler. Since the problem happens at the 7th song, it indicates that some additional FAT32 table read operations take place which cause a delay which I haven't considered yet. Could you please create a minimal session which allows me to reproduce this issue at my side for further analysis? Best Regards, Thorsten.
and even more steps are required to implement alternative solutions, especially for somebody who has no access to the hardware extension you have in mind. The assembly based implementation makes it even more difficult to add extensions w/o extensive testing! So: please don't expect support from my side, there are more interesting projects in the queue :) Best Regards, Thorsten.
Thanks for the compliment! :) Hopefully I will get some time to doublecheck the most recent Lemur version at my side this weekend. Best Regards, Thorsten.
Based on your screenshot: https://www.flickr.com/photos/68202862@N03/13710200005/ Change: 0110 = HS-PLL enabled freq=4xFosc1 Disable LVP Disable PORTB = analog input All ID bytes have to be programmed with 00 Best Regards, Thorsten.
Ok, it won't work with a 1:1 connection Best Regards, Thorsten.
In meinem Setup (_tk.asm) habe ich noch zusaetzlich ein AOUT_NG Interface aktiviert, deshalb wird mehr Speicher verbraucht und es kommt abermals zu einem Overrun. Doch eigentlich war das File nur fuer meine eigene MIDIbox FM relevant - "war", weil ich ja mittlerweile den PIC18F452 durch einen PIC18F4685 ersetzt habe, und das setup_pic18f4685_mbfm_tk.hex file verwende, so dass es keine Speicherprobleme mehr gibt, und noch weitere (sehr schoene) Features freigeschaltet werden konnten. Gruss, Thorsten.
Yes, tie them together and connect a single ground wire to a central ground terminal, e.g. at J2:Vs Best Regards, Thorsten.
MIDIO128 only supports the AINSER64 and not the AINSER8 module. So, currently it won't be possible to use the AINSER8 module properly. I added this to the wishlist. Once a new firmware version is available, you have to update it with MIOS Studio. So, use the time to find a solution for this (e.g. by booting a different Linux version, or by using a different PC) Best Regards, Thorsten.
Yes, (unfortunately) the OSC ADSRs are hardware implemented in the SID chip and can't be emulated via SW - this would solve many things, especially the infamous ADSR bug... Best Regards, Thorsten.
Hast Du es auch mit dem .hex File aus dem neuen .zip Package versucht, das ich heute generiert habe? Die Versionsnummer ist gleich geblieben, da sich an der Firmware selbst nichts geaendert hat. Nein, daran liegt es nicht, denn der Upload funktioniert ja. Dass er bei 98% abbricht hat eine andere Ursache, die mit dem neuen .hex File eigentlich behoben sein sollte. Welches .hex File aus dem Package laedst Du auf? Bzw. generierst Du Dir ein eigenes .hex file? (bspw. nach einer Konfigurationsaenderung?) Gruss, Thorsten.
This is a great idea! :smile: Please try this pre-release: http://www.ucapps.de/mios32/midibox_seq_v4l_082_pre1.zip Button assignments: o CLEAR button now allows to clear individual tracks with the GP buttons: - CLEAR+GP1: clear note triggers (values are kept but not played) - CLEAR+GP2: reset velocity values to 64 - CLEAR+GP3: reset note length values to half step - CLEAR+GP4: clear Pitchbend - CLEAR+GP5: clear all CCs - CLEAR+GP6: clear Seq1 + track configuration (*) (like before) - CLEAR+GP7: like GP6, could be used for other purposes in future - CLEAR+GP8: like GP6, could be used for other purposes in future Same for GP9..16 for Seq2 (*) track configuration won't be changed if 'PasteClrAll' set to 0 in MBSEQ_GC.V4 file As long as the CLEAR button is pressed, the LEDs act as some kind of "track activity indicators" to notify the special function, and to give an oversight about the track utilization. Unfortunately the clear functions of GP#4...8 resp. GP#12..16 conflict with the activity monitor. E.g. track 4/12 not only store the pitchbender, but also the first 3 CC lines. Track 5..8/13..16 store the additional CC lines (4 per track). But GP button 4/12 will only clear the pitchbender (by intention), and GP button 6..8/14..16 will clear the complete sequence instead the assigned CC lines. This could be confusing, on the other hand the additional button assignments are more important than a consistent display. With some dirty patches in the seq core I could improve the activity monitor depending on how important the display capabilities are. Alternatively, I could change the recording function, so that CCs are not stored in the same track like PitchBend anymore. This would also solve an inconsistency in the mute function (which mutes PB and the first 3 CCs) - a difficult decision. Best Regards, Thorsten.
The current draw isn't that high, because LEDs are time-multiplexed. A 1A PSU should be enough, this can be delivered from a USB hub based PSU. The firmware doesn't support LED matrices with 32 LED rows, 16 LEDs per row is the limit (and I can't change this anymore due to conceptional reasons). It isn't a good idea to construct a matrix this way (and similar to the 16 LEDs per row max limit, also the column selection lines are limited to 16 for good reasons). E.g. if a matrix has 8 selection lines (as proposed above), each LED row will display a pattern for 12.5% of the reload period. With 16 selection lines (possible, but not so bright anymore), each LED row will display a pattern for only 6.25% of the reload period anymore. The pattern is still visible, but it's very dimmed. With 32 selection lines (your idea...), each LED row will display a pattern for only 3.125% of the reload period. I guess that with such a short duty cycle nothing will be visible anymore! Instead it's better to use multiple matrices (meanwhile up to 16 matrices are supported) with 8 selection lines each. Each matrix will require 3 DOUT SRs (one for 8 selection lines, two for the 16 LED pattern) Best Regards, Thorsten.
