Stigmata
    178
Everything posted by Stigmata
  1. Thanks! I will take a look at that tomorrow! Christoffer
  2. Hi there! Just rebuild my SID V1 to V2.. 8) Just wondering: where are the CC function? I can be wrong, but couldn´t you record the midi data on V1 when you turn the CUT knob when CC button is pressed down?? Or is it another way to do that on V2? Thanks Christoffer
  3. Done!! Works great! Thanks! Next thing is to remake the matrix, the old one working bad.. The button i used for that is taken from and old code/cardreader lock... Christoffer
  4. Hi there! Been away for long time now... And I decide to rebuild my Sid v1.7303 to the new v2. And keep my old core V2, just for now... (I got the Pcb from Wilba but i haven´t got the time to rebuild my sid) And I have some questions, (it´s like start all over again). When I look at the new core V3 the PWM on J10 is connected to Pin #17 of PIC, do I need that? And when I look att my other core V2 (slave) I didn´t connect SC on J4 to Pin #28, why??? :o I think I left that for a reason....Hmmm On the slave cores do i need the R12 1k on J4? And another thing...on my master core i didn´t wire the J7:SO/PIC to the SID CLK pin. The SID running on the 1 MHz oscillator instead..Can I keep it like that? I just want do do this the easy way.... ;) Haven´t got so much time with 2 small children..... Like I said, been away for a loooong time.. Thanks Christoffer
  5. hi there. Do you guys think this display will work without any problems??: http://www.fractronics.com/4x20-oled.shtml go down to download the short spec or the full spec.. That one is cheap for being sold here in sweden. christoffer
  6. Hi there. Long time since I wrote here.... I´m now planing the upgrade to SID V2. I´m little confused about the CAN-Bus. What kind of cabel from the J2(Vd) shall I use??? I think I`m confused becuse TK draw the cabel larger than the other.. ??? ::) (in the pdf). What I can see the CAN RX and the CAN TX going to the same cabel?? or I´m missing something?? Best/ Christoffer
  7. Den kommer ändå bara att fungera som en teckenbaserad display? Det vet jag inte.. Har själv en 2x20 vanlig display.....
  8. Hej! Tror att du kan få problem med displayen... Kolla faq.för siden... http://www.avishowtech.com/midibox/wiki/index.php?pagename=MIDIboxSIDFAQ#QA25 MVH Christoffer
  9. ??? :-[ Do I put the fuse on the primary 12V before the rectifier?? Christoffer
  10. Verkar vara kortis någonstans på knappen eller så kolla kortslutningar på lödningarna på DIN ingången. Du ska trycka på knappen filter så tänds lysdioderna upp i ordning... Christoffer
  11. 808
  12. Anyone?? :-[ Christoffer
  13. Hi there! Now planning the FM building... ;D Looking at the pictures of TK´s great MBFM and saw the PSU... Question 1:Where do I put the fuses didn´t see those on the "mbhp opl3 psu.pdf" are those necessery?? Question 2: I also want the 5V psu on the same board(like TK) and I found one 220VAC-6V 633mA are that enough? Found 2x12V 159mA In not planning the AOUT. Thanks Christoffer
  14. Stigmata
    Server Test
    200-250 kb/sec in Sweden... ;D Christoffer
  15. Planning the FM..... ;D Can I use the C64 PSU for the FM too??? Christoffer
  16. Just a thought... Are you shure that the J4 SC (on the core) goes to the pin #28 and not Pin #22 (for the old 16f) Christoffer
  17. AM
  18. NICE PATCHES!!! ;D Christoffer
  19. Thank you! Yes I did...Hmmm I got help from my girlfriend´s brother. Christoffer
  20. Just delsolder 2 YAC´s and 2 YMF´s... I just put my old soundblaser upsidedown in the microwen for 5 min..full effect...JUST KIDDING.... ;D I found a method that worked for me.. I put an really really thin cable (I just use one of many small cables in one cable, Hmmm did anyone understand that???) ;) I didn´t....(sometimes the english don´t work for me ;) ) Anyway, I put that cable around each leg..warm up the leg for like 1 sec and pull. I can tell you that it took a while, but it´s worth it!! I didn´t use an solder sucker. And the soldering iron just 220°C Best Christoffer
  21. Hi there! I´m just started training to desolder smd chip..... :( A question:How hot shall the soldering iron be?? I got an weller ws50, 150 to 450 celsius... how hot is to hot for the small inocent smd´s?? ;D Best Christoffer
  22. Hi! Just a question... How do we pay you? in $ or € or... I´m thinking of buying those becuse i´m not so good at desoldering those f***ing smd ;) The dollar is so low nowdays (in swedish crowns) so it may be worth it.. ;D Where do you live? Thinking of the shiping cost, i`m from sweden.. Best Christoffer
  23. So...you can remove the dented?? I like to have those babies non dented, how hard is it to remove?? Can someone please explain before I order some.... And those with pushbutton function are they easy to push or is easier with an ordernary push button....... Thanks Christoffer
  24. Thanks for the help! ;D ;D Found the pdf for it!! Christoffer
  25. Today I found an graphical lcd  ;D and I can´t find the datasheet for it. :( I got an NAN YA Model:LMBHAT014GC with the T6963c Chip on it..... Someone got the data or an link... Thanks Christoffer
