891 -
Everything posted by NorthernLightX
Hi Scifo, AFAIK SmashTV is the only one offering the MB6582 PCBs. You can buy a part kit from him as well or just the PCBs, and then order the parts in europe, for example from Reichelt (they should have everything you need). If you are afraid of import taxes Smash offers a special low value order procedure for PCBs only, but I don't know if the MB6582 PCBs are part of this deal, look at his shop for more details. Good luck building! P.S. Keep an eye on the fleamarket over here for additional stuff you might need, such as LCD, PacTec PT-10 case, and a set of panels for the PT-10 case.
PM sent :wink:
This is still up for grabs
Funny enough there seems to have been a revision of that module and it now has a switch for the CV input that lets you select linear or bipolar CV. I'm working on a few other projects right now and expect some front panels for those to arrive soon. When I have the MB6582 finished (or earlier if I get a pressing request, for example from TK who needs the module for testing with the MBCV2.0 project) I'll have a prototype made.
Control surface PCB for 16 encoders/LEDrings Bulk Order
NorthernLightX replied to Fairlightiii's topic in Bulk Orders
If participants pull out at the last moment or for example don't respond to payment requests, I'll be happy to adopt one of their boards. Only in that case though. :thumbsup: -
MB SID with patchbay -> semi-modular Korg MS-Style Synth?
NorthernLightX replied to SIB's topic in MIDIbox SID
I'm not sure to which videos you're referring, because as far as I know now video's of me or my home exist on the net. :angel: For my application I won't use CV in on the MBSID. I'll use analog CV modulation for example on the SSM2044 filters; MBSID will send audio out to the filters and CV can be modulated from a different source than the MBSID. I plan to implement a companion board for the SSM2044 filters that will add a second CV input for the frequency, and bring both the frequency and resonance CV input to respond to +/-5V (now frequency responds to +/- 2,8V and resonanve to 0V-10V). I can't say that there's nothing to be gained; I just haven't imagined a need. If you have a crazy envelope or LFO you want to use, or have other CV equipment that does tricks that the MBSID cannot do, it could be interesting. See point above. If for you it's easier to grab a patchcable than to press a few buttons and turn a few knobs then go for it. It's your box. Buttons and knobs do introduce recall though, and that's hard to achieve with patchcables. This might be one other downside of the Core8 CV in option; it only responds to 0V-5V, which is only half of proper CV resolution. I have little experience with CV in, this is territory you need to navigate yourself I'm afraid. If you have modules that output very hot and/or negative signal it's wise to implement some form of protection on the CV inputs; how you do that you'll need to figure out yourself, I can only give some theoretical pointers: Imagine you have 2 CV inputs for one CV function; one for bipolar and one for linear. You need to use switching jacks for this idea. The bipolar jack switch is connected to GND, so when no jack is inserted this input is at 0V. The linear jack switch is connected to +5V so the input is at 5V when no jack is inserted. Both inputs are summed with an opamp. The sum is then halved with a voltage devider and fed to the CV input. When a -5V signal is received on the bipolar input and nothing is in the linear input the +5V from the switch will cause the sum of the signals to be 0V. When this is halved it will stay 0V. When a +5V signal is received on the biplor input and nothing is in the linear input the sum will be 10V, 5V after halving. a +/-5V signal will thus be converted to a 0V-5V signal which is the perfect range for the AIN. When a 0V-10V signal is received on the linear input it will disconnect the +5V switch and since nothing is on the switch of the bipolar jack the only thing that will happen is the voltage get's devided, so again the signal will be converted to a 0V-5V signal which is the perfect range for the AIN. You can't use both inputs at the same time though, since the bipolar signal needs to be summed with +5V to end up between 0V and 5V. If your input is more than +/-5V this will be dangerous, as -6V will give a sum of -1V which could damage the AIN (not sure if this is the case but IC's not designed for negative voltages usually have a very low tolerance for it). Also, with an input of +/-10V you will end up with a voltage of 7,5V which could be too hot. My best advise would be to make sure the output of all your modules falls in the same, safe range (maybe you need to add companion boards on the ouputs of certain modules to get the voltage to specification), and then use companion boards on the inputs of modules that need adapted CV as well. This way you can safely hook anything to anything withous letting out the magic smoke. -
Sure, it's fun! That alone is enough reason to build it. All that can be done using MIDI, no CV needed. Adding external MIDI control is a very logical expansion (for example adding another midibox based module to the equation). You do realise that the CV in will actually be translated into the digital domain, and thus be no more precise than the internal control messages? Of course. I'm just trying to give you feedback so you don't end up spending a lot of time reasearching and building something that will not behave according to your wishes. :flowers: -
What would they do that the 6 internal LFO's and 2 internal EG's(DADSR with separate curve parameter for the A D and R steps) can't do? I can understand that you want to go the modular route, but after much research I've not found a reason to add CV in to the MBSID. -
[FEELER] Mean Well RPT-60B Switching PSU
NorthernLightX replied to NorthernLightX's topic in Bulk Orders
Nope, I have not ordered any spares, nor am I planning a future bulk order of these, sorry. -
Sir is not bad :flowers: It's just so formal and... mature... not like me :tongue: -
So I'm a sir now? roflol -
Ah now I understand what you mean. :thumbsup: It doesn't really matter what shape the acrylic is as long as it matches the metal and show all the LEDs. You could even make a U shaped insert if you want. I thought round inserts are probably easier to make (and maybe cheaper). -
Sure it will be a hole, and bigger than the shaft too, but small enough so the knob skirt will cover it (see the MB6582 frontpanel; shafts poke through but holes are invisible with knobs on shafts). The acrylic will be glued to the alu from the bottom, and will have a recess for it to be flush with the frontpanel, like an LCD window. Yes you are right; the cheapest option is probably to just have a second job and buy all your toys with the extra money. Building them yourself is a big part of the fun though, and fun is allowed to cost money IMHO :laugh: -
For my future panel I'm thinking black anodized alu, with big holes around the encoders and matching "smoke" acrylic inserts to view the LEDs through (a bit similar to an LCD window but now with a hole in the center to poke the encoder shaft through). -
(WTB) Datawheel for MBSEQ - (Albs DK38-144)
NorthernLightX replied to Lamouette's topic in Fleamarket
Me too, me too! :frantics: I've been looking through mouser's catalog last night and they have nothing (or I just can't find it). Reichelt doesn't have any decent knobs anyway. I'd buy 1 to 3 of these; something for a future group buy perhaps? :whistle: -
Small bump: I'm getting into modular stuff, partly because this allows me to finish stuff and expand on it later (opposed to the earlier mantra of "let's spend hours upon hours searchin for extra stuff I can add and never get this thing finished"). I've come to the conclusion that I want to make all my Midibox (SID) CV output's bipolar, but this would make them incompatible with this VCA, which expects a CV range of 0-10V. I have recently aquired one of these VCA boards and want to make a companion board for this to make it compatible with a CV voltage of +/-5V. A simple solution would be to introduce a simple CV level shifter, that would add 5V to the +/-5V, making it 0-10V. I want to add a CV attenuator as well. The necessary components would involve 4 dual opamps (probably TL072) with 2 100n decoupling capacitors each, 2 small electrolytics for power integrity, a couple of resistors, 4 trimmers, and 4 potentiometers. Is there any public interest for such a companion board? If so, I'll make a design topic for it and offer a small bulk order for the final PCB in the end. If not I'll just dump the components on some veroboard and be done with it :tongue:
Took some time off work to go to the post office this morning; all PSU's have been sent out :frantics: One comment on the female Molex connectors: these are not the exact type I had in mind, and need a small modification. These have a ridge that on certain male headers is used to secure the connector to the header. In the case of the Mean Well PSU the ridge interferes with the plastic of the header, and the ridge needs to be cut off. Just use a sharp cutter or a file and you'll be fine; the pins have enough friction to stay in place by themselves. -
w00t! I was so hoping for this! :w00t: -
When googling the subject of unipolar or bipolar control voltages there seem to be equally many modules (not VCO's per sé) that use unipolar 0-10V as there are modules that use bipolar +/-5V. Both standards give a range of 10V, so with my limited knowledge I guess there isn't much difference in operation other than a +5V offset. The level shifting I was talking about earlier I would either build as a separate utility module powered by +/-12V, or as an input expansion on the module that expects to see 0/10V on the CV input. Such a module is most probably powered by +/-12V or even +/-15V so power for a small level shifting circuit can be taken from there if you don't want to power the AOUT with +/-12V.
If you ask me a regular +/- 12V PSU and the original method of powering the module, opamps and everything still sounds the easiest, and you gain a PSU for all your other bipolar PSU modules at the same time :)
One for me please! No idea what I'm going to do with it yet but it just looks too good to let pass :w00t: -
It has already been discussed in this thread, but I'll give some quick answers based on my current knowledge; - The original AOUT standard gives a 0-10V response. - The original AOUT can be expanded (for example with a daughterboard) to give a +/-5V response. - The redesigned AOUT can give both 0/10V response and +/-5V response without the need of a daughterboard, the response is configured by replacing some resistors with bridges. Attention needs to be paid to certain resistor values (R_x and R_y) with each configuration. The configuration options will be documented as soon as a final design is accepted. - Both on the original AOUT and the redesigned AOUT the CV response can be configured per channel. - 1v/oct response depends on the used (target) module, and if it expects 0-10V or +/-5V. In both voltage flavors you have a 10V range. - It is still possible to use a level shifter to convert +/-5V to 0/10V and vice versa. A level shifter is a simple opamp design. I plan to build a set of shifters as a separate module, and will also build some as a preconfigured expansion on several modules that I have that currently expect 0/10V on the CV input.
A PSU with +/-6V is not really more simple than one with +/-12V IMHO :whistle: But if +/-6V has other advantages or preferrence, I'll take over this recommendation.
Regarding the resistors: I'm not in a hurry, so no problem :) If you on the other hand remember what part of the formula (to calculate the values) needs to be adjusted maybe I can work it out myself. Regarding the PSU: don't the opamps need the +/-12V for proper operation? Also, good chance that additional modules will be in the same housing as the AOUT that use +/-12V as this is one of the standard supply methods of synth modules. Well performing switching PSU's are nowadays available for as little as €25 (from Mouser and Reichelt for example) so I don't see the need to divert from the current form of power supply.
Custom MIDIBox CV Project -- is it legal to sell PCBs?
NorthernLightX replied to hexinverter's topic in Design Concepts
Hey Hex, I've seen some of your stuff on MuffWiggler and it looks top notch; wouldn't you rather wait a few months and have the new and improved version?
