pilo
Frequent Writer-
1,093 -
4
Everything posted by pilo
it works too I think :) do you have the AUD_EXT?
humm... I think people from KX driver would be happy to help us under linux... I think every thing this driver is able to make with this card is also possible under linux...
nothing! I think the easiest way is to buy an EL inverter...
the best card is the SBLive FULL, or any SBlive card with the AUD_EXT connector. First : by now it only works under windows ;) With the KX driver. We want it to work under linux ;D Then, all you need is the SBLive card with no "official" extension... The extension card can be put on the sblive card or in an external box. you see what I mean?
Great!!!! But I don"t think this should bevery hard to do! Imagine what we can do with all this input and ouput. and jackIT + ardoud!! YEAH!!!!!! ;D
hummm forgot to say that I WANT TO USE THIS UNDER LINUX! so I'm going to make all I can for this!!!!
:'( ... yes alsa doesn't work with all this.. but I read that it will be easy to add multichannel support to SBlive... so I write to alsa-devel mailing list and no answer GGRRRR I'm going to try again, as I have some skill in C language, and I have ever worked with old SB16 card under DOS without driver, maybe if someone help me I could do this... but the file for emu10k1 are not well commented !!
;) The next step is a 4 ADC daughter board, whith 8 balanced inputs, and I2S output. This card can be used with SBlive, via the AUD_EXT connector on value or by soldering on the card. If we can get some of the AL1401 and al1402, we can make a ADAT input for the sblive, and a ADC ADAT unit. Smash suggest that we can use RJ45 cable for the adat, insted of optic fiber, which are cheaper. For the output, I think we are going to make another daugther board :)
yes I think it's possiblen it depends on how the sound are store in the ROM. send me the .bin file, and I'll take a look at that
plus de nouvelles la dessus?...
I am maybe wrong but, it camera's flash, those you use only once, there's this kind of circuit
huummm I can't wee why you didn't wire all the connector? VCC -> Vd and VEE->V0 fir the backlight : Where did you get it pleasE?????? I'm very interested in that!!!! and is it a led backlight? of ot's EL backlight you'll need a converter...
on the original LC it's 6 per channel I think (6*8 = 48 + 7 char between each channel makes 55 character)... I think we can put 5, wo it will feet on a 40x2, but no space between channel, and it makes small LC... I'm going to put 2 lCD, but no space between them : one up and one down... I'll have to post a picture!
i want custom button too!!!! but square one is maybe hard to make... I have the idea of making a mold!!! I'm going to look how the Mackie HUI buttons look! ;)
great!! ;D Where do you leave?
oohhh thanks!!! ;D but smash just sent it me!!! thanks !!
*-*-*-*-*-*-*-*-*-*-* PROPAGANDE *-*-*-*-*-*-*-*-*-*-*-*-* If you are sick win M$, try linux :) yes for music it's not the best, but you can keep both OS, as me, and you'll see that thing will be "easier" (mean that when you're not making music under windows, there's no problem! lol) *-*-*-*-*-*-*--*-*-*-*-*- END -*-*-*-*-*-*-*-*-*-*-*-*-*-*
do you have the datasheet??? alesis site is down.... By the way I found a compiler :) http://bkasm.sourceforge.net/
please! STOP GIVING ME IDEA!!!!!!!!!!! ;D one more thing to do ;D
chat is working ??? I'm on right now!
great Thorsten ;) I want to finish my LC soon!!! (to work on the java client for example!!!). still need those MF.. grrrrr Hum if you can send me foto by mail Dan, I will be very happy!!!! :D the C4 is the plugin control?
hehe I'm too fast! but I'm not going to build this berfore 2 or 3 month ;) But I think I should see in LC manual how this work! ;) And yes I saw those beautiful led bar under the screen on your LC Dan!!! looks VERY good! And as I asked, can we have more photo??? héhé For the display panel, you use a "mask" no?
I would like to know to set up meter bridge : it's work the same as led ring, so I take a new core, with a DOUT module, but how this is handle by the LC? thanks!
why parallel port mid interface? and not serial port? I'm going to look on google...
