MrMusicman
55 -
Everything posted by MrMusicman
Hey Steven_C If you look at the MIDI information send by a mackic controler or XT, you will see that the fader are send as Pitchbend on ch. 1 to 9, so each controler need a midi port at your pc and in the sequencer software. A MIDI merge will not work, sorry. Kent
Hey Doc. Nice Design. But as I know Cubase does not support more than 1. mackie controler (8ch), so if you will control 16 ch. you have to use the "Generic Remote", but you will lose some function and some thing will be harder to control. good luck Kent
Hey Da5id Mouser.com gives the size as Kbit, MIOS as Kbyte. 256Kbit=32Kbyte ( 258 / 8 ) so no problem. ;) Kent
Hej Justin Thanks for getting to order in house (If I can say that in English) :D I will pay with paypal, just tell me when you need the money. To Dr Bunsen, Dr Nick and Sascha, as Justin write I am willing to get them all over to me, and repost then to you. Please send me a email with your address, so I can find out what it will cost to mail to you. If some of you can't pay with paypal it may be more easy to put it on my bankaccount and I can paypal it to Justin. Let me hear what you thing. See you all out here ;) Kent
Hey Xcen The mic. your are trying to use need some power to work. I think its about 3V, so you can't use the phantom power from the mixer (its 48V). Kent
Hey Pulse Yes you can use 1N4001 instead of B40C800, but your picture is not right. The white band on them have to point from - to +. Like this: (as I can't put a picture I use text to draw a diode, like this -|--|------|-, the | in middle is the white band) AC -|--|------|- VSS (-) | | -- -- | | | | | | -- -- | | -- -- | | -|--|------|- VDD(+) AC Hope this helps Kent
Hey Thorsten Nice looking panel. 8) Kent
Hey Thorsten About the idea with (master)fader in 2. layer. I think it will be nice if the MIDI message for fader in 2. layer, are freely assign, ak. all fader send normal "mc" commands in 1. layer, in 2. layer there may be 1 fader for "mc" masterfader and 7 fader using MIDI control message. This way I (and other :)) can control the master fader and 7 master send fader with 2. layer. See you out here Kent
Hey there First entry from Copenhagen, Denmark. Kent
Hey Thorsten Thanks for using the ideas ;D Hope you have time to do other than making new code constant. See you. Kent
Hey Xcen Short, yes Long, Old (AT) keyboards use the same 5pol. DIN 180c plug as MIDI so you can use them. However do not use cabel or extention cabel from old keyboard, as the wireing are not the same. (MIDI use pin 2 as ground, keyboard pin 4.) See you Kent
Hey Thorsten Nice work, speedy ;) ;D I am mounting my pcbboard for my LC clone and at the same time taking some picture, that I hope can be used for a "How to make a LC clone" BTW can a bankstik be used in the LC clone for selecting button, fader and led setup? And does 2. layer support settings for fader. (use 1 fader in 2. layer as master fader) See you out there. Kent
Hey Henrik/Wise There is no need for a AIN module if its only 8 pot/faders. You just use the MIOS function "MIOS_AIN_UnMuxed". Kent
Hey Domas You need: 1 x Core module 3 x DINx4 module (48 input for encoder(2 pr. encoder) +36 for buttons) (or 2 x DINx4 + 1 DINx3) 1 x DOUTx4 module (32 LED) That all If you want to use motorfader you need a MF module. Kent
Hey Xcen The best (for the price) RME card you can get is Hammerfall LE (Digi 9636) list price EUR 368,- but remember that its an "only digital card" and need a Analog/Digital converter (stereo A/D/A or ADAT). Alternative RME makes some A/D and D/A card to use with Hammerfall: AEB 4/I four 24 Bit analog Inputs for all RME cards EUR 139,- AEB 4/O eight 24 Bit analog Outputs for all RME cards EUR 159,- AEB 8/I eight 24 Bit analog Inputs for all RME cards EUR 189,- AEB 8/O eight 24 Bit analog Outputs for all RME cards EUR 199,- Check out the RME homepage www.rme-audio.de BTW about using soundblaster card for audio: It is no good unles you use 48KHz samplerate. The card is intern lock to 48KHz, and if you try to use 44.1KHz your recording will get out off sync. The card will convert to and from 48KHz and use some time on it that the DAW software does not know. See you Kent
Hey there I am using a RME Hammerfall (The best audio card you can get) on my main music computer (running Cubase SX under WinXP) and a Pulsar I on my secondary computer (running V-Stack on Win98SE). Kent
Hey Xcen Good job on my test. I did not get you on the reverse one, Nice :D Kent
Hey Mark90 Using a 5.7Kohm resistor on he optocoupler should not make any different, its only a pulldown resistor to control the intern current. (and only the MIDI input will not work). Kent
Hey Normal resistor (5-10%) have 4 color rings. Ring 1, Ring 2, Ring 3 and Ring 4. One of then will be gold or silver. Place the resistor with that one to the right, Its ring 4. Take the number of ring 1 (from the color code below), write it on a paper. Take the number of ring 2, and write it to the right of first number. Place the number of zero's from ring 3 coler code and place it to the right of the 2 number. Thats you resistor value in ohm. Remove 3 zero's and its in Kohm or remove 6 zero's and its in Mohm. Color code: Color____Number__Number of zero's Black______0________non Brown_____1________0 ( 1 ) Red_______2________00 ( 2 ) Orange____3________000 ( 3 ) Yellow_____4________0000 ( 4 ) Green _____5________00000 ( 5 ) Blue_______6________000000 ( 6 ) Violet______7________0000000 ( 7 ) Grey_______8________00000000 ( 8 ) White______9________000000000 ( 9 ) Like this Resistor Brown, Green, Red, Gold Value 1, 5, 00 =1500Ohm or 1.5Kohm Try for your self: Green,Blue,Yellow,Silver=? Yellow,Violet,Brown,Gold=? Gold,Green,Red,Red=? Orange,White,Black,Gold=? Hope this helps Kent
Hey dendy I sounds to me like you are have a MIDI feedback loop problem. Try only to connect the MIDI out from your controller to the MIDI in on the computer, if its work without any problem then you have with MIDI feedback. If it still does not work then !!!!!!! I do not know what software you are using but you have to disable "midi thru" on computer. Another solution is to disable "MIDI echo" on the controller (if there are a function like that, Thorsten???) Hope it helps Kent
Mackie Control Logic Control???Big Question
MrMusicman replied to jeroddumas's topic in Design Concepts
BTW. about the use of Mackie Controller with ProTools. I thing that the MIDI commands are changed on the controller, so to use the Mackie clone someone has to find the new MIDI commands that the Mackie use. When that it don I do not thing is a problem to program Thorsten's clone to work with ProTools. Kent PS. As I read it on Mackie's site the Mackie Controller has to be updated, I thing that the update makes it use the HUI MIDI commands. -
Hey Jeroddumas The Mackie Controller and the Logic Controller are the same, only the label on the buttom are changed. To get you Controller to work as a Mackie clone you have to change the "LC_EMULATION_ID" in the main.asm file from 0x10 to 0x14. That it. See you Kent -
Hey There ;) The "FLIP" switch on the controler works in Cubase SX. See you Kent
