stryd_one
Frequent Writer
    8,840
  1. There's a file attached to that post... If you're logged in you should see it ???
  2. But thanks for telling us dude :)
  3. Awesome! Pics!! :D[me=stryd_one]does the "it's working" dance[/me]
  4. Dontcha hate when that happens?! ;D
  5. It shouldn't even be called unless the encoder has moved... I think you made a boo-boo ;D
  6. There was no chat - that was an hallucination. You must have really been feeding out for a fix, dude. Edit: what did I do while it was down? I cut code of course!
  7. We're baaack. Thanks Twinny! Edit: and I don't think we lost any posts at all!
  8. Heh, you said "pull it off" ;D
  9. Seconded..... If he finishes it.... or even ever returns :-\
  10. AWESOME!!!!!!!!! :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D You have no idea! At least a half dozen people have tried with no joy at all... I was about to start canvassing newsgroups he frequents, in attempt to find him :D Thanks Lyle (and Jeff if you read this)
  11. Exactly. Try a java based midi app. That's not recommended.
  12. Or you could have just searched the wiki ;) Counting from 0 is the norm though... You always need to use this function when using DOUTs, and that is explained in the programming examples which are found on the ucapps.de download page and the C page too. Moral of the story: search ;)
  13. I give up ::) Tell me about it, I have 500 of them.......
  14. Does it transmit midi?
  15. There's your first mistake. How does your machine work with other java based midi apps?
  16. I'd be using mine as part of a filterbank and not restricted to the SID, so I like the separate boards thing.
  17. 2 ains and 4 douts = 2 knobs and 4 leds. You have two AIN MODULES and 4 DOUTx4 MODULES. Especially when incorrect terminology has already been used and confusion already abounds ;D
  18. I think the point here is; if things go smoothly as they should, then everything is fine...but if they screw up, futurlec are known for handling it poorly. It should be noted that this is a two-year-old thread that was resurrected. Things change...
  19. Why not go all-SMD then? It seems a shame to make it difficult for people to solder, just for these two chips... There are many holes on the board, a few more is a small consideration...
  20. Hehehehe :D Nah, we're just trying to make sure that when things go offline, the addicts bother us, and not you :)
  21. [me=stryd_one]does the "it's working" dance[/me]
  22. If you want it to look pretty, cut a slit along the back side of the cable with a scalpel, slide the wire out of the insulation, cut it short, and crimp the IDC onto the empty insulation. Noone will know.... or better yet, wrap and heatshrink it ;)
  23. I'll give you a guarantee: Depending on your LCD, doing that is almost as likely to short the pins and destroy your PIC and LCD, as it is to work ;)
