1,468 -
Everything posted by pay_c
Errr, no. With the 16F I even got up to about 400 bytes/s. Pretty fast. Why? @Synergic: Another thing: How do you connect that stuff? Meaning: How long are the cables? If the cable from your USBmodule to your MB64 gets pretty long, you should shield it (I would say if it´s more than 0,5 meters) /modify: Also try following: Completely disconnect the MB64 from your USBmodule and try the optocoupler way. Meaning: Put the optocoupler into your MB64 and into your USB module and try it over normal MIDI cables. That should work really properly. If that works, you know both (MB64 and your MBUSB) are working fine. Greetz & wishing luck... ;)
There´s a parameter in vmidibox: Send rate or so. Put it down (to about 150 or even less). Every Midi Interface needs another rate. E.g. with my Midisport I can hardly achieve 250. That should be it, I think.
!! O M G !! Höhö... weißt du, was cool ist, TK? Nich mal mein Formant Pro hat so viele CV-Eingänge (weiß scho, eher für Keyboard-Scanning, aber trotzdem). Nich mal zwei davon... Ein voll midifizierter Formant Pro... ich kann mich nur wieder holen: !! O M G !!
The first time someone cried out for me! :D Cewl... ;D If you directly connect your MB with your USB over MI/MO pins you *must* get that optocoupler out of there (the one on the core and the one on the USB module), otherwise you´ll have a short one there. Just pray that you didn´t cook anything with that short there... :P Also see here: mbhp_usb_connections_case1.pdf on the UCApps page/USB module http://www.ucapps.de/mbhp/mbhp_usb_connections_case1.pdf But: Yes, I *think* you´re right: MI to MO and viceversa. Greetz! :D
Take a look @ the MIDIO128 on the UCApps page. You don´t have to use all 128 buttons, and there´s no matrix used (all buttons are assigned to a single DIN). So you also can switch five simultanous. For that "What I need to buy" and so on: Just read the page there. Everythings kinda self-explaining and well documented. It´s a hard entry to the DIY world, but others managed that also! :)
So, 8 weeks are over. ;D Just kidding... something new? Didn´t forget that project ! (even already got some old 486er and pulled it into it´s pieces...) Still looking forward! :D
Hoi Jan und willkommen! :D Also du hast es ja selbst schon angedeutet: Alles, was du da hingeschrieben hast, wird kaum möglich sein, ohne selbst Einiges an (Programmier-) arbeit reinzustecken. Mit Bauen und fertig ist bei *dem* Schwanz an Anforderungen leider nicht zu denken. Aber(!): Du solltest unbedingt mal noch ein wenig warten. TK ist im Moment an der (SEHR) aufgemotzten Version der alten MBSeq dran (siehe News - MBSeq - another attempt). Es werden seeeehr viele von deinen Features integriert sein. Lass dich nicht von dem Namen (MBSeq) abschrecken: Es handelt sich um einen 4-Track (3 Layer) 16-Step Sequencer der Luxus-Version, der sich auch (und *DAS* ist es!) in einer Appregiator-Funktion umschalten läßt. TK hatt auch mal einige mp3s als Beispiel zu der Appr.funktion in den News hinterlegt, hör sie dir mal an. Ich weiß jetzt wirklich nicht, ob alle Features von dir auch erledigt werden, aber es ist ein Anfang. Und es wird sicher auch noch Einiges kommen. Einiges bleibt aber fragwürdig (z.B. Tap-Taster oder One-Finger Akkord usw.). Achja: Die Kosten sind bei DIY allgemein extrem variabel. So ganz grob abgeschätzt kannst du bei nem MBSeq so bei 100-150 Eu anfangen (alles selbst gemacht & billige Bauteile (z.B. Ebay usw)), wenn du dich anstrengst und bis zu ca. 300 Eu (Frontplatte bestellt, alle Bauteile neu, PCBs bestellt, Case gekauft, blauer LCD, hochwertigere Buttons & Encoder uswuswusw) und (sehr viel) mehr ausgeben - für die verchromte Luxusversion. Nebenbei nochmal: GROBE Abschätzung (hat noch keiner hier bauen können...) Einfach mal angucken & anhören! ;) Ich persönlich bin von dem Teil aaaabsolut begeistert (vor allem wenn man es mit kommerziellen Lösungen & Preisen vergleicht)!! Gruß pay.c ;D
Mist... mistmistmist... Hab gerade gemerkt, das ich dich volle Bulle missverstanden hab. 1 Core an zwei verschiedene SIDs, richtig? Dann ist die ganze Hardware-Sache vergessen... Mist.... Einfach den Absatz darüber in Gedanken wegstreichen, thnx! Aber trotzdem: 4 SIDs klingen viel geiler als 2! Glaub mir !! ;) Da lohnen sich die 2 PICs/Cores!
SID-Zeug: Ich hab bei den Filtercaps Styroflex verwendet. Der Preis ist absolut vertretbar und die Genauigkeit großartig. Alle Filter sind bei mir jetzt gut in einer Linie (habs vorher mit 10%igen ausprobiert, das ging total in die Hose). Das mit dem 6581/8580 Umschalter ist nicht so leicht: Zum einen unterschiedliche Betriebsspannungen (12V und 9V). Da müsste man 2x die 78xx Schaltung aufbauen. Und zum anderen die Filtercaps. Auch unterschiedlich. Ist nicht so leicht, das alles zu bewerkstelligen. Und: Den SID-IC jedesmal auszutauschen und dann einen Switch umzulegen ist glaub ich ein wenig zu aufwendig. Warum nicht 4 SIDs. 2x 8580 und 2x 6581. Dann kann man auch alle gleichzeitig anspielen (was verdammt fett klingt!!!). Auch ein Problem: Der SID ist im Moment ein reines Empfangsgerät. Mit dem Dipswitch müsste man glaub ich Einiges an der allgemeinen Hardware ändern. MIDIO: Jepp. Die Ausgänge sind nicht multiplexed sondern einzeln angesteuert. Auf deutsch: Du kannst alle 128 Kanäle per MIDI einzeln ansteuern (an/aus). Frage: ML303 ?? Link her!! ;D Greetz! :) /modify: Aaach Gott, vergess ich immer: WILLKOMMEN in der UCApps Family! :D
Zur 3: Jo, mit Sicherheit. Schalt mal nen mehrpoligen Filter dahinter (also sowatt wie 24 oder evtl sogar 48 dB/Okt). Iss besser. 7 kHz? Hart... Der sollte frühestens bei 12-14 anfangen (auch bei 8 Bit). Egal... weiß nich, ob ich dir den Link schon gegeben hab, aber hier mal nochmal zur Sicherheit: www.tonepad.com Da is ein ganz netter Delay schon aufgebaut: Unter fx projects und dann den "Rebote Delay". Der Rebote2 ist auch nett. Kannst dir ja mal angucke, vielleicht ganz interessant. Na dann noch viel Glück&Spass bei dem Projekt! :D
For the cost point: W i d e l y depends on your method: E.g. MB64: - 64 Pots + Knobs: .50-5 Euro per piece makes app. 30-300 Euro - LCD, PCBs and parts mainly the same: app 50 Euro (little more perhaps) - 64 buttons: .15 up to about 2.00 Euros makes app. 10 - 120 Euros (thats some range, is it !?) - 64 LEDs: standard: about 8 Euros, blue: about 60 Euros - Frontplate: selfmade 0.-, ordered app. 50-100 Euro - Casing: About 1 Euro up to 50 Euro - Stuff always needed (cables, conns, etc): about 10 Euros Hope I didn´t forget some stuff... but anyhow: See what I mean? You can start @ 100 Euros for a *full futured* MB and go up to 600 Euros and even more ( "But Mom, those Diamond knobs for the ALPS Potis are looking so dammit cewl" ). Some people even managed it to go down to about 50 Euros (making the PCBs by yourself, getting much stuff on ebay, getting parts out of old stuff and so on). *WIDE* range ;D and I like it! Greetz
??? Will jetzt echt nich rummosern, aber: Ist die 44k Aufnahme echt soooo gut? Ich mein, von 44 kHz ist man ja schon ein wenich besseres gewohnt. Die oberen Frequenzen sind schon fies abgeschnitten und das Rauschen ist auch nicht schlecht... Ist im Moment wahrscheinlich auf Lochraster aufgebaut, oder? Dürfte dann ja auf PCB (mit der Ground - Füllung) um Einiges besser werden (datt rauschen). Aber die obere Grenzfrequenz? Schick mal nen Sinus durch und guck evtl mal, wo die bei dir ist (also wo sind -3dB). Wäre interessant. :-X Wer hat hier blöd rumgelabert? :-X *aufUhrguck* Muss weg... (PS: Hoffentlich hab ichs mir etz ned bei dir versemmelt, Benni ;D )
Doppelt so teuer... PS Benni: Hab heut die Mikroanschlüsse bekommen (für den BS). Schaut lustig aus. Könnte ein wenig eng werden wegen reinbekommen, denk aber, das es grade so langen wird. Probieren kann ichs aber erst in zwei Wochen (Prüfungen an der FH...). Weiß scho, daß das nicht zum Thema passt, aber: Wie schauts bei dir aus?
Links: Three from my side ;D (two standard ones I think) Suggestions: Is the security number really neccesary? I know you don´t log in to often, but anyhow. And: After login the browser shouldn´t go to the "Your Account" page. It should just stay at the actual page and reload it. Great! Greetz!
Oooooopsiii ;D Just refresh the midibox.org site, TK... :P Everything fine (the temp content of IE/NN naturally has saved the old link...)! ;)
On the Reichelt page there´s a link: "Direktbestellung" There you can type in your orders directly. For the encs: Don´t know if there are *any* samples available for that... I really recommend the Encoders TK used, too. (The ALPS ones) - They´re great! (e.g. available @ www.schuricht.de)
Wow! :D Looks great! btw: the link over midibox.org doesn´t function (it goes to the older portal page).
Had the same prob: With the EEPROM WinXP had no probs to recognize the MBUSB. Without exactly the same prob like you had (really weird ...). I went to a friend and tried it there (Win98). Guess! Right: Without EEPROM everything ran perfect. I burned it and tried to install it there. Boom! Nope, won´t install it on Win98... So: Try to burn the EEPROM on some older machine (Win98 worked out for me). Greets
:-/ Isn´t that a little hard? I mean getting two samples is no prob, but if you can´t get anymore (those "samplefree times" or so) paying 30 Euros per chip (60 for the AOUT, right?) *is* really hard... Aren´t there some pin-compatible ICs? A little more like ... ... cheaper? ;D
Here you go: Buttons: "Taster 3301D" (or 3301 or 3301B - those are the ones in TK´s SID - the D is the longest one, 15 cent only! "DT 6 sw" these are used in TK´s MBNG (the big round ones) - the "sw" is the color: sw black, bl blue, ge yellow, gr grey, gn green, rt red, ws white (very nice pushpoint) 45 cent They don´t have any encoders (*but* I mailed them recently if they don´t wanna introduce some - beside other suggestions - still waiting for the answer). Vector boards: "H25PR160" the "160" is the length of the board (it´s always 100mm broad). Following options for the "160": 050,075,100,150, the 160 naturally, 200 500. The costs starts at .61 and ends at 5.00. LEDs: "LED 3mm ST rt" Standard ones for 8 cents. The cheap ones: "LED 3mm rt" for 5 cents. Also available in 5mm diameter (just instead of 3mm 5mm). The colors: rt red, gn green, ge yellow, bl blue (expensive! . 92 cent, only Standard LEDs, no Low cost version). All used in TKs things. Different options with the Audio jacks: PCB-mounted (needs some drilling anyhow): "EBS 63P" for .59 cent - stereo version only, 6,3mm only. I think theyre great!! Plate-mounted (screwed): "EBS 63" - 27 cents, stereo, 6,3mm but sometimes a little ... disfunctioning I would say (know that turning of your audio jacks to make them function?) also available in mono: "EBM 63" and in 3,5mm version: "EB 35" for mono and "EBB 35" for stereo. Cable connectors: VERY many options there - I wont state all of them, because you should get the catalogue for that (they have pictures for every connector and so it´s really self-explaining). For the LCD: "PFL 20" the 20 is the pin-number (double-row!). They fit together with following: "Stiftl. 2x40G" (doesn´t matter whether 40G and 40 pins or 20G and twenty pins cause you can cut them easily) and with the cable: "AWG 28-20G 3m" 20G again the number of cables and 3m for the length (only 3m, 10m, 30m available). For the one-rows: "Stiftl. 40G" (same as above, only one row) and e.g. "PSK 254/10W" - Crimpcontacts!! That means you need the contacts and the tool extra! Can be kinda expensive! Like I said: Veeeery many options there! Also possible: "PS 25/10G WS" - all in one package (lower row, connector and cables) - the 10G is the number of pins. You certainly should get the catalogue!!! They have many pictures there, and so it´s kinda self-explaining (just some things like colors or so are a problem then). Greets! @TK: Perhaps FAQ-Marker?
Caps which are polarized are either clearly marked with a + (or -) and/or have a longer and a shorter leg (longer one always +).
Good workaround I use: Just dont use the mixer of Reason, use Rewire instead. Put every instrument (or whatever) to a Reason output and controll that over the Mixer in Cubase. Works good this way.
Errr... just btw: (am a little ??? cause of your answer) The ground, no matter if the GND of the core or of the AIN or whatever is everywhere the same! So it doesn´t matter wether you take the ground for the chassis from the AIN or the Core or whatever. The only thing you shouldn´t do: Making ground "circles" - this means e.g.: CoreGND---DIN1GND---DIN2GND---whateverGND---chassisGND---andbacktoCoreGND This *can* bring in ground humming into all your signals if the circle is getting very long. Greetz
Bau halt einfach die ersten 8 Encs über und die anderen 8 unter den Display! ;D Wär mal was Neues. Dann brauchst du den Display auch kaum anpassen...
Just for the records: Exactly the same seller sold them to me for 10 Bucks (4 SIDs (!!!) ) some time ago. As he started to value those SIDs after a while (or better said how other people value these babes) he went up to 9 Euro per piece... :-/ Also a point: I got four at him. Three of those are working... (lucky me - I had bought a spare C64 before...) So: If you get more at least try to get him down again...
