jeroddumas
    144
Everything posted by jeroddumas
  1. So they should work fine???? I am going to order them Monday.
  2. I'm thinking these motorfaders will work. It looks like they run off 5v. I think it will just be a matter of finding the pinout. Any other thoughts??
  3. I have recieved the service manual for the d8b from Mackie. I have nowhere to host it. If someone wants to help out let me know.
  4. I am able to get some motorfaders from a mackie d8b console at a good price. I would like to know if anyone knows if these will work with MBLC??
  5. Just connected up a Dout module. When I turn on my MB i get all LED's lit. I know this is not correct. What could be causing this problem??
  6. thanks tk, what file would that be a part of?
  7. I have all parts ready for my motormix emulation except for motorfaders. I was wondering what do I need to do to get my encoders working for fader control. Could someone help, I am not a programmer.
  8. Allelectronics is sold out. Can anyone help me here? I need 8 to finish my mblc.......
  9. The way Mackie control is running with pro tools is via the HUI protocol which we cannot get. I will work on checking the sysex string Thorston.
  10. Warning, Warning. I have built the motormix emulator. I still have not gotten my motorfaders. All works well except with pro tools. The LCD display does not work with pro tools, it seems as though there is i slightly different protocol for pro tools. So far everything else works!!!!
  11. Great what do you control with it, and how did you make that case???????
  12. Anyone tried these alps encoders from mouser?  http://www3.alps.co.jp/pdf/2004pdf/pdf_e/Switch/Encoder/ec12e.pdf  .  They are $1.47 .  I think I want to use them, any objections???
  13. Oh yeah welcome to UCapps fallout !!!!!!
  14. I would think that you are correct. It can be connected to j2, but you must be sure polarity is right. I would go with j1.
  15. Has anyone completed a motormix clone, I am curredcntly working on one???? Just asking..
  16. Hey  where has TK disappeared to.  Haven't heard from him in a while?????????????????????
  17. no the voltage regulator runs fine when using smaller voltage. Say 9vdc. But when I use my 16vac to power the core and the SID is when I run into problems with the regulator getting hot.
  18. no the voltage regulator runs fine when using smaller voltage. Say 9vdc. But when I use my 16vac to power the core and the SID is when I run into problems with the regulator getting hot.
  19. I jave some pots laying around that I would like to put to use. How can I use these pots with the current SID CS. I don't see a table in which I may use them in the code. Some help would be appreciated.
  20. I jave some pots laying around that I would like to put to use. How can I use these pots with the current SID CS. I don't see a table in which I may use them in the code. Some help would be appreciated.
  21. I am using a 16vac power adaptor with my MBSID. The sid voltage regulator is fine, but the core is getting hot. Should I use a circuit with a 7809 to step down the power before going into the 7805, or should I just heatsink the 05 and let it be????
  22. I am using a 16vac power adaptor with my MBSID. The sid voltage regulator is fine, but the core is getting hot. Should I use a circuit with a 7809 to step down the power before going into the 7805, or should I just heatsink the 05 and let it be????
  23. Problem fixed. SID now working!!!!!!!!
  24. Problem fixed. SID now working!!!!!!!!
  25. sure, even though i can't get my SID to work. Must have a connection problem somewhere.
