812 -
Everything posted by bugfight
				Introducing start of my Midibox SEQ project CHAINREACTOR
bugfight replied to Gridracer's topic in MIDIbox SEQ
having the blm above the displays is no real problem, you don't really need feedback from the displays while tapping those buttons. i think that's kinda the point of having them, aside from the bling... -
	excellent. send to me for testing.
	reconsider strapping a homebrew 220v system on a person, unless you want them to fry. even if you get lucky there, the heat may kill... why not leds? the battery will need to supply the necessary power regardless of final voltage, so your current out of the battery will be high anywayz. unless you are driving very long lines, the transformer efficiency will actually increase your power requirements. car batteries are not designed to handle repeated charge/discharge cycles. you'll want a marine battery instead. lead acid batteries give off hydrogen when they charge, and can explode if an internal short happens. this is especially nasty because of the sulfuric acid. dc thru a transformer will not work, you need an ac inverter or likesuchas for that.
	excellent demo, thanks!
	isn't there already likesuchas? also svn is a better place to store them...
	mmmmm happy knob cranked.... xavyV5smvdI
	lol, i wanna win a granny award!
	i have a few 5101's but haven't used one in a midibox yet. it works very well in my echoplex digital pro, though - no noise and far less heat than the 2 7805's it replaced. the device went from egg-frying temperature to cucumber cool. there's no reason to think it won't work fine in this application too... but if your midibox is all digital, there are cheaper ways to go
	ok, sorry, i thought the table was different. still, i wouldn't call it a stereo pair if it was never used for stereo... anywayz, i'll stick to matching pairs
	in addition to the issues sep mentioned, since the application needs different compile switches for 6581 and 8580/6582, and both sids are connected to a single core, mixing them on a stereo pair is not a good idea... mixing them in an 8 sid configuration, however is very nice...
	just use two opamps, with the x biased so that 580r=0v and gain set for 900r=5v same with y but 120r and 300r ... you'll probably want one that can use single supply and can go nearly rail to rail, so you can use 5v supply. iirc the lm324 would work...
	get your tinfoil hat back on, or the men in black will get you... http://zapatopi.net/afdb/
				Multi-Tap Transformers Versus Voltage Regulators?
bugfight replied to m00dawg's topic in Design Concepts
i meant if you think the load is not balanced, you should map out the paths the current takes for the 2 halfwaves (when x1-1 potential is higher than x1-3 and when x1-3 is higher than x1-1) and see for yourself. i thought it was a rather clever design when i realized this, if only because i would not have thought of it... going with 2 bridges would almost require a dual secondary, but these are more common (in equal v) nowdayz than a real center tap, maybe because centertaps prefer a balanced load and most designs use more on the + side. btw, for those that don't already know, the commodore c64 tx is a dual 9v ... -
you guys may want to reconsider what happens to the current paths on the 2 halfwaves -
these two lines don't go so well together... -
	calipers say altitude panel is within 0.1 mm of fpd, so using -0.5mm should be fine. meanwhile i volunteer dw to include these with his wood cases he's going to make in about 3 years... edit* i see using mk's outer dims actually drops the price and would be more stable since it is taller, but i think using 4mm thickness is a good idea... fpe says this costs $19.95 MB-6582_window_2.zip MB-6582_window_2.zip
i took a look, and first impulse was to think you needed another bridge rectifier, but second look it seems this is better since it should balance the load on the two halves of the secondary. i'd love to see a scope shot of the outputs, maybe i'll build one... will be a while though... my .0047 ucents -
				Midi to CV converter with 32 CV Outputs - 4x AOUT_NG´s ?
bugfight replied to mangor's topic in MIDIfication
yeah sep, it could be i was just remembering this factoid from the context of mb-sid or mb-seq. it could also be that the diminished update rate of s&h can't really be improved on by using multiple aouts. and neb, the sample and hold module already does this multiplexing, it just needs to be redesigned for obtainable s&h chips.... (which will also probably go obsolete) -
	this is even worse than smileys...
chips unobtainium. but i did wonder why this could be supported but not 4 aout modules... -
	i did make it .5mm smaller, but does the altitude panel match your fpd, and does the anodyzing reduce the opening? i'll get the calipers out when i get home...
	actually i haven't had it made yet, seems it would be useful for a lot of folks though, maybe a group buy, or mr wellington could add it to his long long list of things to do... i made it using dims from wilbas fpd, so i'm not sure it's all good for the altitude panels, but should be ok. according to fpd estimater it's $23.45. i'll attach it here but verify dims before sending it off! MB-6582_window.zip MB-6582_window.zip
you forgot "Don't misquote technical information" that's 64 analog inputs. pic core is probably not up to the task of 32 cv outs, but core32 should be... -
	or just use the one i sent you...
