seppoman
Frequent Writer-
1,065 -
Everything posted by seppoman
just to be sure, you know that you first need to recompile/upload your application with AOUT mode set for aout_lc? just today there was another midiboxer on the chat who tried to get the LC running and didn't know this. E.g. the Seq app is set for a regular (MAX525) AOUT by default, which gives strange results when using this setting with a LC. S
I think the main reason to have NS10's is/was that they were simply the studio standard in the 80s/90s, so if you knew how they sound and you went to another (commercial/semi-pro) studio, you could be almost certain they have them, too, and feel at home soundwise. They're like the MS Word of mixing. Other reasons why they were so popular are: They were comparatively cheap back then. They represent the lower end stereos of the 80s quite well, i.e. if you mix a pop track so that it sounds ok on them, it will usually sound ok on a common 80s cheap Kenwood/Sony/... stereo or kitchen radio. They do give you quite a lot of mids, so you can hear quite some details and can notice crackles/hiss/other technical problems easily. So while I don't like their sound very much (they can be quite fatiguing imho) and I don't know many people who find the sound pleasing, I can see the point in wanting to have them as a reference. With the electronic music that came up in the 90s, their weak bass became quite a problem. 15 years ago, you would just switch to the large wall monitors every now and then to judge the low end, but when mixing dance/techno/.. tracks, you'll want to hear what's going on in the bass more constantly. S
12V will destroy the chip. Whether the "signal" is changing or constant is irrelevant. The CD4053 can stand higher signal levels, but only if you feed it with at least 12V, and that also means that the control port wants a 12V signal, so not much use for your application. So your "signal" is always either 12V or 0V, right? Maybe you could establish a way to output these two states e.g. by using a simple transistor/pullup circuit (still you'd need a source of regulated 12V DC), and do all the decisions if the output should be high or low in software? S
yes. it is engraved into the Core module schematic PDF and on SmashTV's documentation :P - MD is a pin on J10 yes sure why not? S
you can connect both GND and VEE pins of the hc4053 to GND at the same time, that's no problem. But another problem I ran into is that the 4053 doesn't like being fed signal that is outside of the supply voltages. So as a normal audio signal is bipolar, you will need to feed -5V Vee to not damage the IC. Otherwise you could also use reed relays for signal switching, there are types with SPDT action, although not very common and a bit on the expensive side. S
Gehen tut es natürlich ohne Flußmittel mit etwas Übung auch, sieht dann aber meistens nicht besonders aus, und schneller - naja nen SOIC schaffe ich auch mit Flußmittel und anschließend Saubermachen in einer Minute, das ist mir schnell genug dafür daß es hinterher nicht nach hobbymäßigem Rumgepatze aussieht. Von Lötkolben auf 450 Grad würde ich eher abraten (außer Du hast ne einfache Station die die aufgedruckten Werte sowieso nie erreicht). Ich löte normalerweise bei gut 300 Grad, das reicht locker und gefährdet die Bauteile nicht. S
kein Problem :) Ich habe dafür einen kleinen Noname-Tischgrill, so ein Ding mit oben und unten jeweils einem Heizstab und einem kleinen Rost dazwischen, reicht gerade für zwei Scheiben Hawaii-Toast ;) Der Grill sollte natürlich ordentlich heiß werden, wenn also der Schmelzpunkt des Zinns nur mit Ach und Krach nach 20 Minuten erreicht wird, ist das eher ungünstig (und das mögen auch die Bauteile nicht). Bleifreies Zinn sollte man eher vermeiden, da dieses einen etwas höheren Schmelzpunkt hat - in meinem Ofen muß ich dafür schon ziemlich lang draufbraten... Auf die Pads der Platine gebe ich mit der Spritze (in der die Lötpaste geliefert wird) möglichst kleine Kügelchen der Lötpaste. Das ist ein etwas mühsames Geschäft, und wenn man mal von einer Platine 10 Stück machen wollte, würde sich die Investition in eine Pastenschablone lohnen. Die gibt es z.B. relativ günstig bei PCB-POOL, so viel ich weiß sogar bei Prototypenbestellung auf Wunsch umsonst dazu. Das ist eine dünne Aluplatte mit genau den Pads ausgeschnitten, so daß man nur mit einem Spatel die Lötpaste drüberziehen muß. Damit habe ich leider noch keine Erfahrung, kommt aber bald :) Jedenfalls, sobald die Paste fertig verteilt ist, platziert man vorsichtig mit der Pinzette sämtliche Bauteile an ihre Stelle und drückt sie noch ein wenig in die Paste hinein. Das Schöne an der Paste ist, daß sie die Teile ziemlich gut an ihrem Platz fixiert. Bei TQFP ICs (und kleiner) schafft man es natürlich nicht mehr, die Pads einzeln zu bestreichen, das macht aber gar nichts. Auch hier hilft die klebrige Paste ungemein, die ICs durch vorsichtiges Anstupsen an die richtige Position zu bringen. Sobald alles bereit ist, lege ich die Platine auf das kleine Ofenblech, heize den Ofen noch ne Minute vor und gebe dann die Platine hinein. Dann passiert erstmal ein paar Minuten nichts. Irgendwann kann man dann beobachten, wie an einer Lötstelle nach der anderen die graue Paste in flüssiges Zinn umschlägt und sich die Bauteile durch Oberflächenspannung noch ein wenig auf ihren Pads zentrieren. Sobald sich nichts mehr bewegt, zähle ich noch bis zehn, schalte den Ofen aus, zähle nochmal bis zehn und mache die Klappe halb auf. Nach einer Minute nimmt man die Platine dann zum Abkühlen heraus - möglichst vorsichtig bewegen und nicht hart absetzen, sonst können die Teile auch noch verrutschen. Manchmal tritt der sogenannte Grabsteineffekt auf, d.h. Widerstände oder Kondensatoren stellen sich plötzlich auf und stehen nur noch auf einem Pad. Das passiert bei 0805 noch relativ selten, 0603 ist da schon anfälliger. Wenn das passiert, sollte man möglichst schnell sein und die Klappe gleich ganz aufmachen, für vielleicht 20 Sekunden hat man noch die Chance, die Biester mit der Pinzette wieder richtig hinzulegen. Bei ICs ist normalerweise zu viel Paste drauf und diese auch noch durchs Ausrichten des ICs verschmiert. Das führt dazu, daß man meistens noch nacharbeiten muß. Dafür nehme ich einfach Flußmittel und die erwähnte Hohlkehlenlötspitze, damit kann man prima das überschüssige Zinn wegnehmen und die Lötstellen hübsch machen. Wie das dann aussieht wenns fertig ist, hast Du (hoffentlich) bei Dir zu Hause liegen :) Insgesamt gelingt die Bestückung einer SMD-Platine mit dieser Methode schneller und optisch besser als mit normalem Löten (mit etwas Übung sogar viel schneller als bei einer Through Hole-Platine, inzwischen stöhne ich schon immer, wenn ich mal wieder eine MidiBox-Platine löten muß ;)) Viel Spaß beim Grillen (bzw. bei Euch heißt das ja glaube ich Grillieren :D) S
Vakuumpipette hab ich bisher nicht benutzt, ist aber wahrscheinlich praktisch zum Platzieren von größeren ICs. Für alles andere ist eine feine, kurz gebogene Pinzette sinnvoll (Reichelt EP 150). Flußmittel ist zumindest für ICs unabdingbar. Ich benutze von Reichelt "EDSYN FL 22". Das Zeug ist von der Konsistenz cremig/fettig/harzig und macht insofern eine ziemliche Sauerei. Es läßt sich aber gut verarbeiten und anschließend mit Isopropyl entfernen (KONTAKT 413). Am besten versucht man direkt nach dem Löten mit Küchenrolle möglichst viel Flußmittell mechanisch zu entfernen, dann Isopropyl auf ne kleine Ecke Küchenrolle geben und gründlich abreiben. Wenn dann zwischen den Beinchen noch Reste sind, kann man z.B. mit ner alten Zahnbürste und wieder Isopropyl die letzten Reste vorsichtig entfernen. Es gibt zwar auch "No-Clean Flußmittel, daß man nicht entfernen muß (dieses wässrige Zeug in so ner Art Edding). Das hinterläßt allerdings leichte Ränder, die man, wenn man dann doch Cleanen will, zumindest mit Isopropyl nicht wirklich wegbekommt. Lötzinn: Bleib auf jeden Fall bei verbleitem Lot, das ist besser zu verarbeiten. Zum normalen Löten 0.5mm Durchmesser. Ansonsten Benutze ich meistens Lötpaste (CR 44) zusammen mit nem kleinen Tischgrill. Das funktioniert prima, geht schneller und wird sauberer als Löten von Hand. Bei Bedarf kann ich Dir dazu noch mehr Tips geben. Falls Du ne ordentliche Lötstation haben solltest, kauf Dir auf jeden Fall eine sogenannte Hohlkehlenspitze. Die gibts z.B. für meine Weller WS81, aber auch die WS51 oder die Ersa Analog 60/80. Diese Spitze hat vorne in der Schräge eine leichte Mulde, in der man etwas Zinn zum Drüberziehen aufnehmen kann. Wenn man die Mulde möglichst leerstreift, kann man damit aber auch super überflüssiges Zinn von einer Lötstelle wegnehmen. S
Einfache Schaltnetzteile mögen manchmal große kapazitive Lasten nicht so besonders gerne - Kondensatoren verhalten sich im allerersten Einschaltmoment quasi wie ein Kurzschluß (sie werden geladen). Je größere und je mehr Elkos dranhängen, desto größer wird der Anschaltstrom. Das kann dann dazu führen, daß im Netzteil ein Kurzschlußschutz einsetzt. Du könntest mal probieren, ob das Netzteil stabil anläuft, wenn Du ein paar Elkos provisorisch wieder auslötest. Wenn das was hilft, kannst Du mit Hilfe von Spulen in den Versorgungsleitungen den Anschaltstrom begrenzen. S
I've got the M1 Actives, too, and for the price tag they're really good. Room imaging and overall sound are quite good - what they'd really need is a bit more highs and a bit less bass to be balanced... The main thing they're lacking in my opinion is some DIP switches or trimmers for highs and lows. It's not like the high frequencies aren't there or aren't precise, they're just a tad not loud enough so it can be fixed with slight equalization. But you can get used to that, I don't really notice their frequency response anymore. Other monitors: I really hate the Adam ones. I once spent a day at an AES fair and the guys I was with all hung around at the Adam booth and were fascinated. But in my opinion, this special tweater they've developed is extremely aggressive in the very high frequencies, but then there's a huge gap until the big speaker sets in. So they hurt my ears but don't provide precision in all upper frequencies. Genelec is another brand everyone is using, but their systems really don't sound good enough for the price tag in my opinion. They're not bad but also exaggerating a bit on the high end and just too expensive. Fostex - I know a few people using the Fostex monitors and they all like them very much. Supposedly they're good value, I didn't have the chance yet to listen to them for long enough to judge. S
I remember there was a 2.0 version written in C in TK's pipeline - strangely there's no reference to it anywhere on uCApps, the Wiki or the SVN. The link TK mentioned a few times on the forum is dead. So I searched on the forum and found this thread: http://www.midibox.org/forum/index.php/topic,9439.0.html - if you scroll down a few posts, you'll find the v2.0_alpha1 as an attachment. Don't know how alpha this version is, but it should be much easier for you to port to MIOS32 :) S
two hints: 1. DON'T SHOUT!!! ;) 2. rephrase your question - honestly I don't see what you're asking? S
the only crucial distance is between core and din module (more than 1 m is bad, generally as short as possible). The distance from DIN to the buttons shouldn't be a problem with cat5 cable, as long as the distance is not like 500 meters with the cable wound around a refridgerator every 2 meters ;) S
pimping bcr and bcf with lcds to get lc and c4
seppoman replied to rozzilla's topic in Design Concepts
Please read the sticky post: http://www.midibox.org/forum/index.php/topic,8954.0.html then use the search, you'll find e.g. http://www.midibox.org/forum/index.php/topic,12849.0.html S -
what about using some of these funny colored paper things people are referring to as "money"? :P if you can't afford a few PICs, how do you intend to finance the rest of your Midibox? Microchip has obviously stopped offering free samples to many countries because this service was abused by hobbyists. Sample programs are intended as a service to (commercial or educational) customers who will on the long run decide to use some of their products commercially (i.e. in volume) because MCP was nice and helpful to them. As soon as 95% of the sample "customers" are hobbyists who want to save a few bucks while at the same time making MCP pay international postage fees and logistics, I can definitely understand why they changed their policy... S
my PIC18F452 always aborts MIOS Code Upload
seppoman replied to Tomek's topic in Testing/Troubleshooting
you've got me wrong, T - MY post was a shameless ad, not yours :) Of course you can use that module if you think it's easier. I just wanted to give you a tip about the alternative :) My module doesn't have any special parts you can't buy from Reichelt, except for the SSMs (which you can buy for a good price on eBay, too) and the PCB itself. So no problem to buy the parts yourself. Altogether it'll still be cheaper than the Dark Side, has two instead of only one filters on it, is designed for being used with CV outs from a Midibox synth rather than just a clone of the SSM datasheet app note etc. - The Dark Side might be a nice module for use in a modular synth, but for your case, the Dual PCB is better suited. Anyway, I'll stop being off-topic now :P S -
uhm (shameless ad 8)) why would you want to do that if you could use that one instead? http://www.midibox.org/dokuwiki/doku.php?id=ssm2044_pcb S -
yes upload should work regardless of what modules are connected. I'd check the FM connection again - maybe you have accidentally soldered one of the wires to the RX pin of the PIC? S -
That does only mean that the display is powered and not initialized. We should really find a way to clear up that "blocks = bootoader" myth in the Midibox docu ;) ok THAT means the boot loader is active, congrats :) Plus, it means the Midi out is ok. that usually means your Midi in of the core isn't working correctly. That's fine, this is just a warning that you'll overwrite MIOS. That's what you're trying to do, so all good. S -
sure, the filter works with the NG and the NG works with the FM :) Last year I tested this with my still very much unfinished MBFM. I tried to create a few new patches that made use of the filter and didn't come up with something really exciting. But then, I'm not an expert on the FM and also didn't ever create a really cool patch on the FM without the SSM, so that probably doesn't mean very much ;) If you've checked out TK's demos of FM with CEM and Moog filter and you like these, just go on with the SSM and find out for yourself :) S
Gate is a digital output per definition (0 or 5 V) so you will need to use a regular CV output for anything variable. Most often it works like this: A CV is used to determine velocity, then a Gate signal is used to trigger the envelope (depending on the CV). If your target expects CV and gate all in one signal, i.e. it wants to see 0V....some V....0V, either maybe there's a way to configure MBCV to do that on CV out (? or is it already like that? I never used MBCV so far) or you could use the gate out signal to make e.g. a small reed relais switch on and off some CV output. S
Ok today I've drawn a readable version of the module's schematic: http://www.midibox.org/dokuwiki/lib/exe/fetch.php?id=ssm2044_pcb&cache=cache&media=seppoman:ssm2044_schematic.pdf
Finland is also part of the EU so you can send anything (legal) you like without customs declaration :) S
right. Hahaha good one. we've laughed a lot. S
Ok guys, before too much speculation is taking place, I need to clarify a few things: 1. the reason that so far the module schematic is not available is simply that I didn't make a nice and readable version to publish yet. No secrecy involved. On the other hand, everything you need to know to use that module in its intended function is online. That brings us to 2.: I know I told a few people that some time I would publish a mod schematic for using this module in a regular modular synth environment. I won't publish anything as "official solution" that I didn't try out myself before. Maybe releasing that schem is taking a bit long now and I'm not exactly proud of that fact. But on the other hand, when I published infos about this module and while taking orders during the initial bulk order, I never ever advertized it as being suitable for a modular synth without modifications. In addition to that, I pointed out that this is not a beginners project, i.e. being able to make use of the data sheet schematic wouldn't hurt if you wanna use it in a custom situation... If you can read that one, the level of "reverse engineering" involved is really quite low. In the design of this module, I made a few optimizations that lead to reduced parts count and calibration efforts in its originally intended use case (i.e. when being used together with an AOUT_NG or AOUT with bipolar option, e.g. in a MBSID). These omissions are quite the same cirquits that are missing for your situation now. If you were dedicatedly searching for a modular synth module, there are other ready to go modules and schematics out on the web that involve no use of brain ;). I know it's taking long now and I repeat: I'm not proud of that. But I've had/am still having a lot of other things to do both MidiBox and non-MidiBox-related in the last months. And as I don't feel I promised you that kind of useability without engagement of your own brain while the bulk order was running, In my opinion this use case shouldn't have been part of your purchase considerations. I'm slightly pissed off of the demanding nagging of some of you (also via PM) who sound like they've got a right of me publishing that schem ASAP. I know I said that this schematic would come and it's still on my agenda, but if you wanna use the module for something I didn't promise you in the first place and can't figure out for yourself how to, you'll simply have to have some patience. I can only put it with Wilba's words, please "shut up and wait"! S
