machinate
    68
Everything posted by machinate
  1. I may be a super-noob in these areas, but why does the connection between c3 and c4 run between the legs of the chip? That seems like some auto-routing gone bad! And if you take the "trace" from pin 6 of the chip underneath the chip instead you can do without the wire bridge by bringing pin 5 around the audio output?
  2. Do you have a link for this? Searching Conrad is a pain and doesn't come up with anything for Anreihtaster.cheers. Andreas
  3. attila, you might want to read the text in the link - as far as I can tell you set the pitches with 10 pots, nothing else - it's a lot simpler, and probably a better solution than all those switches...
  4. Word. You're our golden goose, Thorsten, we want you to liiiiive! :D
  5. http://www.geocities.com/thetonegod/vanpoint2/van_point2.html
  6. very cool project - I worked with similar stuff a long time ago when I was into circuit-bending - the "light-theremin" style circuitbends are all about the 555 - they often pop up on ebay. Get Lofi have a write-up on the 555 as well: http://www.uoguelph.ca/%7Eantoon/gadgets/555/555.html btw, for anyone even slightly interested in lofi gadgetry the GetLofi site is very nice:) http://www.getlofi.com/
  7. check out the changelog: http://ucapps.de/midibox64e_changelog.html -since 2.1: "experimental" support for ain and mf modules
  8. yeah man, good luck - we should get together and share parts ;) hehe. Any idea on how to case it yet?
  9. Artesia, looking at that picture... thinking about the price, and looking at the sheer number of components involved in that beast... The price of a shaeffer board like it would be around 200 pounds on its own ::) it would be kinda cool to rig everything to transmit midi... hmmmm....
  10. did you make the transparent buttons yourself? Could you give a quick run-down of the process? Thanks.
  11. perhaps midi clock sync? I'd love that.
  12. yes, these should be wired to the dinx4 just like an ordinary button, if memory serves. a.
  13. hey Artesia, that design looks awesome. One question though: Won't the handles get in the way when operating the sequencer?
  14. yes. However, by using two different din registers (as in an 8x16 matrix) you would get this effect - and also very neat connections to and from the keypad - at least that's what I'm hoping for: Each keypad takes one of the douts on the common pin and distributes to all 16 dins
  15. these buttons really are cool as f**k! Tiny tiny assembly. The feel of the button is weird, kind of like firm Gameboy buttons. I like it, although they may be a bit too firm for a high-end performance controller. Dunno, they'll definitely be wired up asap for testing. I do have a question about these buttons though. They're arranged in a 16pin+1pin configuration, as opposed to keypads with 2 dedicated pins per button. Could that be a problem when used with the scan matrix? I've got other, bigger buttons lined up if it doesn't work.
  16. I'll be there all day. Seems like a cool thing to do.
  17. cool. Thanks for the link! Are you getting decent results from these? I was looking for a cool way of doing non-traditional crossfaders, and I think a ribbon controller will be fun.
  18. oh wow - looks neat! Another Ableton controller?
  19. hehe, well, I'll need the buttons either way, so I kinda have to try it ;)
  20. A few questions remain: Will it ever make the streets, and will it be something we can afford? And will it be so cheap that we can do case modding ;) Very close, in concept, to the monome controller, http://monome.org/index.php?m=0111 - which will be around 500usd for an 8x8 midicontroller with usb interface :o What we really need is for people to start working on the scan matrix project again - imagine fitting two cores and 8 dinx4s in a small box like that - eek...
  21. Hey man, that's strangely encouraging :-) I'm getting code-fiends to help me - my common sense tells me that duplicating the code and making a few alterations should do the trick - again, I'm glad I've got people helping me;) So for testing purposes how big should we do this matrix? Would 160 do it? I really want to help out all I can, if anything by soldering up a ton of buttons :) Who knows, I may get excited and do 320 buttons in one go, hehe ;) Andreas
  22. ...but remember the bank buttons if you want to access more than 8 channels.
  23. No. It should work with NO modifications, and WITHOUT a computer.
  24. Hi, I'm looking into the whole ribbon controller thing as well - might I ask where you found these?
