73 -
6
Everything posted by srmaietta
--Pushbutton of datawheel might be useful as a single bookmark shortcut. For example, the track config page could be accessed with one push. I may try that.. --Or perhaps as a tap tempo entry if you find yourself playing in a situation where tap tempo is used frequently (live band perhaps) --Or howabout setting the footswitch / gate input as a tap tempo source, that only "listens" when the datawheel encoder is held down. So you could have a tempo stream coming in from other instrument or player, and whenever things change up, you hold the encoder down for a few ticks and the tap tempo would be re set... Would be AMAZING if somehow these things could be set on the machine itself. ~Steve
I'm sure with all his involvement he could have built it in his sleep! And probably can use it fluently in his sleep too!! #44.... Have there been many more than 44 kits sold?? Maybe half sit dormant? Took me about a year to get around to building mine. . .
Can the layer length be different from the track length?
srmaietta replied to andran's topic in MIDIbox SEQ
Andran, the layers follow the length of the track. That being said you can modify things layer by layer so they dont necessarily have to be in lock step. Another way to work within this structure is to set up two tracks both to the same midi channel/output of different lengths. put note/gate info on one track, and velocity, etc info on the other. loads of fun. This is how I work often, it leads to great sequences, uexpected results. The nth functions allow you to set up certain behaviors every # of bars, essentially a shortcut to longer evolving pattens... (Kinda sorta mini-song mode) -
Question about live recording / quantize and unquantized
srmaietta replied to flyweight's topic in MIDIbox SEQ
@Hawkeye Thank you for the thoughtful replies. It is easy to think of future wishes and add ons but at the same time forget about how it would effect everything else. I love the Seq4+, very little I would change! And the fact that I can get into the code and try things myself is pretty amazing. That alone is a "feature" that very few seq's can boast. @flyweightIf I was looking for more humanized recordings I'd use the longer tracks with higher divisions OR the humanizer feature! Also, you can specify your own shuffle parameters, you may find something that gives you YOUR feel.. if you could analyze how your beats groove, you may just be able to create that groove as a template and there ya go. May be worth digging into. At the same time, your experience and learning from building the Seq is not lost if you sell it. You lost time, yes. I'm sure if you put it on the market it will sell pretty quickly. ~Steve -
Hey Michael, here's my notes on the ALL button functionality. I have three uses on my "cheat sheet" that I grabbed from the seq 4 beginners guide. . CHNG ALL JUMP: ALL&hold -Turn the cursor step knob. All steps will JUMP to the value of the cursor step. CHNG ALL RELATIVE: ALL press & release -Turn the cursor step knob. All steps will change but relative to their original value. RAMP BTWN: ALL press & release -Turn a non-cursor step knob. Steps btwn. the turned knob and the cursor position will align values in a smooth(er) RAMP. Not sure about your cursor wheel. I know the scales can be definied somewhere on the SD card in a file and they can be used after that.. Enjoy this BEAST of a machine.. Step by step, you'll wrap your head around it. ~Steve
@Elektruck, looks like there is somewhere a v4.097 OS that gives deeper divisions for clock out (CV page)!! https://github.com/midibox/mios32/blob/master/apps/sequencers/midibox_seq_v4/CHANGELOG.txt ~Steve
It seems that the quantize percentage is used to decide wether to put the note-on into the step it was received or the next step. I’m guessing based on how far it is from either. The question (solution?) is, (for the coders) why can’t the note-on be put where it falls based on step number plus added “delay parameter” ticks. not that I would use unquantized recording much! But seems possible, and may be desirable for users.. -Steve -
@flyweight I just tried some non quantized recording now. (Nope..) I set the track divider relatively slow so it would be easier to notice if the notes were falling on or off the beat perfectly. (Longer steps, more room for the notes to be off the grid) It definitely seems like unquantized recording is not possible. I tried again after setting a parameter layer to delay which allows one to manually shift notes forward in 96th step increments. But recording, even with quantize set to zero does not actually put the notes on the exact spot they come in. They either land in the beginning of the step that you were in when you hit the note, or the beginning of the next note. The quantize percentage just controls whether or not the note will be put into the step after you actually play the note (100% quant) or before the note was received.(0% quant. The fact that quantize mode is doing some calculations in real time based on where the note actually fell, in my mind makes it seem that it might be possible to set a number of ticks in the delay layer at the same time. This way the note would fall on the step you recorded it and have the ticks of delay set at the same time. May be possible to add in the future, Hawkeye would know more about the mechanics of the code and whether or not this is feasible without a major rewrite. Sure would be nice. The workaround is to set a longer pattern with a quicker timebase. Although it’s definitely not the same thing. -Steve -
Really nice work. I love the custom buttons and angled enclosure. You’re gonna love the combination along with your modular.... Can’t help you with the particular midi pass-through issue you were having.
I’m thinking that if LoopA can do it then seq4 can too.. Aren’t they based on the same core code? mot sure of the unquantized (less quantized I guess) recording options but I’ll give t a try tonight. Steve -
Options for slower, always better, opens up options for all sorts of things, especially when using analog triggers...
403 views!! Anyone have any reasoning for this or possibly a bug fix? Might be as easy to disable Ctrl in layB...? ~Steve
Has anyone thought to implement a drum trigger grid indication on the TPD? It is a natural fit with its 8 x 16 LED display . I know you can hold the instrument mode button down and see all the different tracks triggering but to have a visual grid might be really nice. My first drum machine was TR707 and the grid view lcd was nice!!! ~steve
4+ UI question when I enter mute mode, it is not easy to get back to track edit mode. it requires me to press either param or trigger or step to get back out of mute mode.. then I can press track to get back to basic track edit mode. I would expect to just be able to press track again, and go back to track editing. am I missing something? thanks! ~steve
Well, mental note -if you need Ctrl track, use LayerA. I’m sure this’ll get explained and or fixed. Maybe have something to do with the process of reading ahead in a track to set parameters of things which sounds like something “Ctrl” May need to do.. Steve
Roy, I get the same thing, whenever a drum track with two layers (layA and layB) has layB set to Ctrl, and I jump back to Edit mode, the question marks appear. Im not even sure what Ctrl is supposed to do..? But yes, it keeps anything from being set into the pattern. If layA is set to Ctrl, the question marks do not appear. Another interesting thing is that if you see all the questionmarks in edit mode and then go back to Menu,Evnt, the track is shown as a basic Note 16/64/8 type, even though it was initialized as a drum track earlier. -Steve
Done!!!! Cant wait to get this set into my rig! Amazing job by Hawkeye, Latigid, and of course TK! Thank so much for making this beast available, it is truly an AWESOME piece of sequencing hardware!! ~Steve
aaah, right.. I forgot about Db25 connectors and their screw locking. Its been a while since I've used one!.. Cheers!
Thank you Latigid! I think I found an issue with the BOM, (or the case hardware packege, either way) For the line TR/RX we have DB25 connectors with a 4-40 thread and it should be an unthreaded hole (so we can use the Metric screws and locknuts) The part in the BOM, Mouser 636-182-025-213R561 should probably be 636-182-025-213R551 which is the same part but would come with a bare .120" hole suitable for longer screws and nuts!! (Of course not in stock!) https://www.mouser.com/datasheet/2/296/182-yyy-213Ryy1-54286.pdf Off to buy two screws!!! ~Steve
Guys, a quick question about cable lengths for the RH hardware build. 'Im testing everything here (fluxtest - success!) and its all been great but I realize that I'm following the video which has me building an LH seq. I don't want to keep going forward and have to remake the cables, Is there a place where RH cables are listed? thanks ~Steve
Part swapped and it is now working as it should!! On to the control panel PCB's! Thanks again! ~Steve
Peter, It seems that I did indeed put the non-bussed resistor array in that spot...... damn. time for desoldering!! thank you for the quick response ~Steve
Allright MIDI masters, Im at the point where Im testing my JA board with NG running on the core and all I get is lots of data coming into MIOS studio and lots of flickering LEDs. At least I know all my LEDs work. Loading NG was no problem. "load seq_l" is when all the data streams in and flickering begins. Any ideas on how to troubleshoot this? thanks ~Steve
Thanks Andy, that solves it. And the build continues! -Steve
Hello gents, Im building my Midiphy Seq and want to check something before I move on.. First video, 35 minutes in -"gold headers" - I didn't get any gold headers in my mouser order, but did get two different versions of the single stick pin headers. One is a 3M part, there are two in the order. Mouser part# 517-929700-01-36-RK The second single row straight header is "FCI Headers & Wire housings" One stick came in the order.. part# 649-93992-436HLF The 3M parts are taller. Why are there two different types? Which header stick should I cut up for this step? Is there a list anywhere of which parts go on each PCB? Or is the video it? thanks a lot! ~Steve -
