1,774 -
Everything posted by cimo
Perfect.'>74F786 Perfect. broken link http://www.digchip.com/datasheets/parts/datasheet/364/74F786.php here it is ! nice find S1.
Beat it with a stick? Beat it with a beat
hi i ve heard that SmashTV is stocking the magic crimping tool (as seen here) that will keep artritis away from my fingers in next years, but it s not listed in the shop. Now i think he s too busy with his own matters to provide me with the proper instruction to purchase this unvaluable item but if anybody has purchased it before i d like to know how much it costed so that i can throw a fistful of xtra dollars in my next order and see if i can put my hands on this wortheverycent piece of engineering Simone i ve found this one at conrad http://www1.conrad.de/fas6/fh.php?fh_params=fh_eds%3D%25c3%259f%26fh_sort_by%3D_sortprice%26fh_search%3Dcrimp%2Bzange%26fh_secondid%3Db2c804134%26fh_lister_pos%3D3%26fh_location%3D%252f%252fb2cconrad_de_b2c%252fde_DE%252f%2524s%253dcrimp%255cu0020zange%26fh_refview%3Dsearch&fh_host=http://www1.conrad.de&fh_session=/scripts/wgate/zcop_b2c/~flN0YXRlPTMyMzY5NjYyMjM=?&fh_pic_url=&layout=b2c&fsm_host=&fsm_insertkz= gee what a link, will that be ok ?
hallo i ve found this, it s quite funny and there is a friend of us..
JATTE BRA KOMPIS !
yeah sure! (also an oxygen8 is cheaper than an average midibox ;) )
Bueno, solo para deciros que pusimos videos de las ediciones pasadas y de uno de los grupos que vienen a tocar mas algo de musica y varias link Simone
you need to login first! then edit, it s straight forward you can t miss it Simone
..if i am understanding both of you right: MTE wants to drive line 1 and 2 of the LCD with MBFM and line 3 and 4 with MBSID S1 wants to drive the LCD either with MBSID or MBFM (or whatever he s going to use) wow, i think that both ideas are quite attractive and if we get one going the other will be a piece of cake, i ll take care of dusting properly the cake with dirt Simone
hi yes it looks good, have fun! Simone
hi i just wanted to point out that i was horribly wrong on my post those are nano seconds while the PIC runs at 25 microseconds so no probs from that side.So that chip is ok for our purpose. again and again, beware of timing though Simone
mm turn on time 145 ns turn off time 175 ns now i am not so sure if the following is right but i think that the data is sent at 40Khz, that s the PIC s cpu clock at least; if this is the case then it won t work, you need logic ICs, but i am just guessing, anybody? Simone EDIT: i see it says still i would be a bit concerned about timing
estoy honrado de que me des tanta confianza pero te puedo asegurar que hay mas gente que puede contestarte y tiene mas conocimiento que yo Ademas no entiendo porque sigues en el forum espanol, si sabes ingles es muy aconsejable que vaya a escribir en el forum general, la verda es que somos 4 o 5 personas a escribir aqui actualmente.Escuchame es un buen consejo ;) si sabes programar (casi) todo es posible, hay 2 posibilidades C o ASM, C es mas aconsejado desde que las plantillas de trabajo han sido optimizada, y se puede sempre anadir codigo ASM en C. mas o menos, leete el manual oficial de MackieControl o sea Logic Control. otra vez: cuando tendras en frente un core con din y dout te saldra mas sencillo aprender y entender hasta donde una midibox puede llegar, esto es espeicalmente verdad por la MBLC si nunca utilizaste una Mackie de verdad. espero te ayude Simone
As far as i can understand the problem is that the core is sending data to the data lines all the time therefore whenever an lcd is going to read some data it ll get it from both the core = garbage hardware wise we ll need a 8 line logical switch triggered by the core.... ahahah too crazy software wise we ll need 1 as tilted mentioned, having the cores properly linked 2 tell the core to stop sending data to lcd every second cycle and offset the second core of 1 cycle none of this seems to me any easy thing to do
hola amigos (espero) por fin tenemos un myspace dedicado el evento que estoy organizando con www.colectivodrone.org alli va : http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=373257472 puede qua habra algo de MB por alli... un saludo Simone
Sick! much respect for this work, it should go right on top of the MB6582 kits thread! Simone
hi i had the same idea some time ago so i am also interested in knowing if this is possible or not. Aren t the diodes placed backward? Simone
hola resulta un poco dificil ayudar con tan poca informaion. Lo unico que puedo aconsejarte: -comproba 2 3 4 veces que no hayan lineas cortadas o cortocircuitadas (se dice asi?) -sabes que el led tiene polaridad ? -tienes MIOS cargado corectamente? -tienes una aplicacion cargada? -cuando arrancas el core puedes monitorear algo en la salida midi? -la prueba la haces en el midi out del core o de ltc? Simone
have you seen the stribe project ?
"Cimo training angry raccoons in S1 yard"
.. that s a piece of history !! the numeric pad and buttons board in the second picture, you ve sent it to me cause you had no use for it anymore (with the drill bits remember?) well after some hacking to use the single buttons not on a matrix that s become the DIN test board for my future MBLC !
hi so there is this guy from the spanish forum http://www.midibox.org/forum/index.php/topic,11341.msg89663.html#msg89663 who would like the following to be translated and forwarded to you 2 briefly he says that he s really thankful to TK for his effort and work and dedication for the community he also points out that "that great american SmashTV" is among the most serious business he s found on the net and his boards are top quality stuff dig that! cheers Simone
si eres una chica puedes dejar foto, preferencias musicales y numero de telefono en un PM he cambiado de idea, puedes escribirme tambien si eres un chico, quiero que me invites a tu laboratorio nunca acaba de sorprenderme (positivamente) que haya gente que sin ni 1 post esten alli fabricando MBs yeaaahhh me ha pasado mil veces, por suerte que a lo mejor en el core V3 los malditos estan por arriba consideralo ya hecho no tengo nada que anadir no claro por hoy no, pero despues de la medianoche estaremos esperando por las primeras fotos .... me alegro mucho de que el forum espanol tenga un poco de vidilla por fin! Simone
