281 -
Everything posted by xarolium
it's remember me the Vaco loco Sequencer
How much do you sell your MB6582 ?
He said 20 voice polyphony but i think we could customiz it for something like 50 voice or more :tongue:
Send PM for the TR9090
You could build a your pedalboard with a Midi THRU too and you chain your pedal to the Midibox IN.
Where are the Application files????
xarolium replied to jmayes's topic in MIDIbox Tools & MIOS Studio
Hi Jmayes, You can find the application here http://ucapps.de/mios/midio128_v2_2c.zip Good luck for your project Xarolium -
thank you TK all it's ok now
Dear Midiboxer, I uploaded the SID V2.0 RC36 firmware on my MB6582 and now the value between two detent on my encoder (because i didn't move the detent) is bigger than with the old version (rc25 for me) For example: When i move the attack knob between two detent of my encoder, the attack goes by 4, 8, 12 and 15 I would like to know where can i change it on the program thank you PS:Sorry for my bad english i hope it does meen something for you
Peux tu mettre sur ton prochain post une photo de l'arrière de ton LCD je pense que je pourrai te trouver le datasheet et te donner le câblage adequat
Thank you for your help TK i like the story of scret paramater on the SEQV4 it seem like i have a lot of possibility with the awsome machine
Yes i confirm that the BLM_scalar was in IN1 i select OFF to disable it and it was ok now What is this fonction ?
I create a new track with the same note and i record the MIDI out in Nuendo and i found that there is Note + Velocity + CC32 + CC33 + CC34 and CC35 who was recording How can i solve this problem ?
Thank you TK for your interest of my problem I record the MIDI out of the SEQV4 and it give me that When i delete the parameter CC32 all it's ok, the problem disapear I would like to know how it's possible to not send other parameter than note and velocity on the SEQV4
ok i know that there is a little gap with MIDI control but here the gap is more than 650us i can hear the gap between the both BD and i check my MBSID sound and it did the same thing with the A001 sound Is it possible that the problem come from the SD card because when i put it on 5v the card became very hot and didn't work correctly anymore i checked it and my MicroSD adaptator "burned" ( only the cover) After that i put it on 3,3V and it work correctly but maybe my MicroSD was damage I'll try with an other I hope it will solve my problem because i couldn't use the sequencer like it
I made a new pattern with only the both sound on the track 1 Firdt BD in C1 and the second in F#2 I didn't change the name of the second BD and it was play on the SD layer here is the content of the track 1 [2914.359] track 1 [2914.313] Track Parameters of G1T1 [2914.313] ======================== [2914.313] ParInstruments 16 [2914.313] ParLayers 1 [2914.313] ParSteps 64 [2914.313] TrgInstruments 16 [2914.313] TrgLayers 1 [2914.313] TrgSteps 64 [2914.313] EventMode 3 (Drum ) [2914.313] # | | | | | | | | | | | | | | | | | [2914.315] Name ' BD SD CH PH OH MA CP CY LT MT HT RS CB Smp1 Smp2 Smp3 ' [2914.315] TrackMode 1 (Normal) [2914.315] TrackModeFlags 3 (Unsorted: on, Hold: on, Restart: off, Force Scale: off, Sustain: off) [2914.315] MIDI_Port 0x00 (Def. ) [2914.315] MIDI_Channel 9 (#10) [2914.315] DirectionMode 0 (Forward) [2914.317] StepsForward 0 (1 Steps) [2914.317] StepsJumpBack 0 (0 Steps) [2914.317] StepsReplay 0 [2914.317] StepsRepeat 0 (0 times) [2914.317] StepsSkip 0 (0 Steps) [2914.317] StepsRepeatSkipInterval 3 (4 Steps) [2914.317] Clockdivider 15 (16/384 ppqn) [2914.317] Triplets 0 (no) [2914.318] SynchToMeasure 0 (no) [2914.318] Length 15 (16 Steps) [2914.318] Loop 0 (Step 1) [2914.318] TransposeSemitones 0 (+0) [2914.318] TransposeOctaves 0 (+0) [2914.318] MorphMode 0 (off) [2914.318] MorphDestinationRange 0 (1..16) [2914.320] HumanizeMode 0 (Note: off, Velocity: off, Length: off) [2914.320] HumanizeIntensity 0 [2914.320] GrooveStyle 0 [2914.320] GrooveIntensity 0 [2914.320] TriggerAsngGate 1 (A) [2914.320] TriggerAsngAccent 0 (-) [2914.320] TriggerAsngRoll 0 (-) [2914.320] TriggerAsngGlide 0 (-) [2914.320] TriggerAsgnSkip 0 (-) [2914.320] TriggerAsgnRandomGate 0 (-) [2914.320] TriggerAsgnRandomValue 0 (-) [2914.320] TriggerAsgnNoFx 0 (-) [2914.322] DrumParAsgnA 3 (Vel. ) [2914.322] DrumParAsgnB 0 (None ) [2914.322] EchoRepeats 0 [2914.322] EchoDelay 7 ( 8 ) [2914.322] EchoVelocity 15 [2914.322] EchoFeedbackVelocity 15 (75 [2914.322] EchoFeedbackNote 24 (+0) [2914.322] EchoFeedbackGatelength 20 (100 [2914.322] EchoFeedbackTicks 20 (100 [2914.324] LFO_Waveform 0 ( off ) [2914.324] LFO_Amplitude 192 (64) [2914.324] LFO_Phase 0 (0 [2914.324] LFO_Interval 15 (16 Steps) [2914.324] LFO_Reset_Interval 15 (16 Steps) [2914.324] LFO_Flags 0 (Oneshot: off, Note: off, Velocity: off, Length: off, CC: off) [2914.324] LFO_ExtraCC 0 [2914.324] LFO_ExtraCC_Offset 64 [2914.326] LFO_ExtraCC_PPQN 6 (96 ppqn) [2914.326] NoteLimitLower 0 [2914.326] NoteLimitUpper 0 [2914.326] # MIDI Notes for Drum Instruments: [2914.326] ConstArrayA 0x24 0x36 0x2a 0x2c 0x2e 0x46 0x27 0x37 0x29 0x2b 0x2f 0x4b 0x38 0x2c 0x3c 0x3d [2914.326] # MIDI Velocity: [2914.328] ConstArrayB 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.328] # MIDI Accent Velocity: [2914.328] ConstArrayC 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f [2914.328] # Parameter Layers: [2914.330] Par 0x000 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.330] Par 0x010 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.332] Par 0x020 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.332] Par 0x030 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.334] Par 0x040 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.334] Par 0x050 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.336] Par 0x060 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.336] Par 0x070 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.338] Par 0x080 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.338] Par 0x090 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.339] Par 0x0a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.339] Par 0x0b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.341] Par 0x0c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.341] Par 0x0d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.343] Par 0x0e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.343] Par 0x0f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.345] Par 0x100 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.345] Par 0x110 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.347] Par 0x120 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.347] Par 0x130 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.349] Par 0x140 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.349] Par 0x150 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.351] Par 0x160 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.351] Par 0x170 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.352] Par 0x180 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.352] Par 0x190 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.354] Par 0x1a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.354] Par 0x1b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.356] Par 0x1c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.356] Par 0x1d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.358] Par 0x1e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.358] Par 0x1f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.360] Par 0x200 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.360] Par 0x210 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.362] Par 0x220 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.362] Par 0x230 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.364] Par 0x240 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.364] Par 0x250 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.365] Par 0x260 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.365] Par 0x270 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.367] Par 0x280 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.367] Par 0x290 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.369] Par 0x2a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.369] Par 0x2b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.371] Par 0x2c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.371] Par 0x2d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.372] Par 0x2e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.372] Par 0x2f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.375] Par 0x300 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.375] Par 0x310 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.377] Par 0x320 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.377] Par 0x330 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.378] Par 0x340 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.378] Par 0x350 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.380] Par 0x360 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.380] Par 0x370 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.382] Par 0x380 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.382] Par 0x390 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.384] Par 0x3a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.384] Par 0x3b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.386] Par 0x3c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.386] Par 0x3d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.388] Par 0x3e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.388] Par 0x3f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2914.388] # Trigger Layers: [2914.390] Trg 0x000 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x00 0x00 0x00 0x00 0x00 0x00 [2914.390] Trg 0x010 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.391] Trg 0x020 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.391] Trg 0x030 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.393] Trg 0x040 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.393] Trg 0x050 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.395] Trg 0x060 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.395] Trg 0x070 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.397] Trg 0x080 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.397] Trg 0x090 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.399] Trg 0x0a0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.399] Trg 0x0b0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.400] Trg 0x0c0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.400] Trg 0x0d0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.402] Trg 0x0e0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.402] Trg 0x0f0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2914.402] done. here is the gap i recorded with Nuendo
Yes the btoh sound are played from the same track [1931.593] track 1 [1975.546] track 1 [1975.538] Track Parameters of G1T1 [1975.538] ======================== [1975.538] ParInstruments 16 [1975.538] ParLayers 1 [1975.538] ParSteps 64 [1975.538] TrgInstruments 16 [1975.538] TrgLayers 1 [1975.538] TrgSteps 64 [1975.538] EventMode 3 (Drum ) [1975.540] # | | | | | | | | | | | | | | | | | [1975.540] Name ' BD SD CH PH OH MA CP CY LT MT HT RS CB Smp1 Smp2 Smp3 ' [1975.540] TrackMode 1 (Normal) [1975.540] TrackModeFlags 3 (Unsorted: on, Hold: on, Restart: off, Force Scale: off, Sustain: off) [1975.540] MIDI_Port 0x00 (Def. ) [1975.540] MIDI_Channel 9 (#10) [1975.540] DirectionMode 0 (Forward) [1975.542] StepsForward 0 (1 Steps) [1975.542] StepsJumpBack 0 (0 Steps) [1975.542] StepsReplay 0 [1975.542] StepsRepeat 0 (0 times) [1975.542] StepsSkip 0 (0 Steps) [1975.542] StepsRepeatSkipInterval 3 (4 Steps) [1975.542] Clockdivider 15 (16/384 ppqn) [1975.542] Triplets 0 (no) [1975.542] SynchToMeasure 0 (no) [1975.542] Length 15 (16 Steps) [1975.542] Loop 0 (Step 1) [1975.543] TransposeSemitones 0 (+0) [1975.543] TransposeOctaves 0 (+0) [1975.543] MorphMode 0 (off) [1975.543] MorphDestinationRange 0 (1..16) [1975.545] HumanizeMode 0 (Note: off, Velocity: off, Length: off) [1975.545] HumanizeIntensity 0 [1975.545] GrooveStyle 0 [1975.545] GrooveIntensity 0 [1975.545] TriggerAsngGate 1 (A) [1975.545] TriggerAsngAccent 0 (-) [1975.545] TriggerAsngRoll 0 (-) [1975.545] TriggerAsngGlide 0 (-) [1975.545] TriggerAsgnSkip 0 (-) [1975.545] TriggerAsgnRandomGate 0 (-) [1975.545] TriggerAsgnRandomValue 0 (-) [1975.547] TriggerAsgnNoFx 0 (-) [1975.547] DrumParAsgnA 3 (Vel. ) [1975.547] DrumParAsgnB 0 (None ) [1975.547] EchoRepeats 0 [1975.547] EchoDelay 7 ( 8 ) [1975.547] EchoVelocity 15 [1975.547] EchoFeedbackVelocity 15 (75 [1975.547] EchoFeedbackNote 24 (+0) [1975.547] EchoFeedbackGatelength 20 (100 [1975.547] EchoFeedbackTicks 20 (100 [1975.547] LFO_Waveform 0 ( off ) [1975.547] LFO_Amplitude 192 (64) [1975.549] LFO_Phase 0 (0 [1975.549] LFO_Interval 15 (16 Steps) [1975.549] LFO_Reset_Interval 15 (16 Steps) [1975.549] LFO_Flags 0 (Oneshot: off, Note: off, Velocity: off, Length: off, CC: off) [1975.549] LFO_ExtraCC 0 [1975.549] LFO_ExtraCC_Offset 64 [1975.549] LFO_ExtraCC_PPQN 6 (96 ppqn) [1975.549] NoteLimitLower 0 [1975.549] NoteLimitUpper 0 [1975.552] # MIDI Notes for Drum Instruments: [1975.552] ConstArrayA 0x24 0x26 0x2a 0x2c 0x2e 0x46 0x27 0x37 0x29 0x2b 0x2f 0x4b 0x38 0x2c 0x3c 0x3d [1975.552] # MIDI Velocity: [1975.553] ConstArrayB 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.553] # MIDI Accent Velocity: [1975.553] ConstArrayC 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f [1975.553] # Parameter Layers: [1975.555] Par 0x000 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.555] Par 0x010 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.557] Par 0x020 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.559] Par 0x030 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.559] Par 0x040 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.559] Par 0x050 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.560] Par 0x060 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.560] Par 0x070 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.562] Par 0x080 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.562] Par 0x090 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.564] Par 0x0a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.564] Par 0x0b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.566] Par 0x0c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.566] Par 0x0d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.568] Par 0x0e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.568] Par 0x0f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.570] Par 0x100 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.570] Par 0x110 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.572] Par 0x120 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.572] Par 0x130 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.573] Par 0x140 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.573] Par 0x150 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.575] Par 0x160 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.575] Par 0x170 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.577] Par 0x180 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.577] Par 0x190 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.579] Par 0x1a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.579] Par 0x1b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.581] Par 0x1c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.581] Par 0x1d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.583] Par 0x1e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.583] Par 0x1f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.585] Par 0x200 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.585] Par 0x210 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.586] Par 0x220 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.586] Par 0x230 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.588] Par 0x240 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.588] Par 0x250 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.590] Par 0x260 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.590] Par 0x270 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.592] Par 0x280 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.592] Par 0x290 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.594] Par 0x2a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.595] Par 0x2b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.596] Par 0x2c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.596] Par 0x2d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.597] Par 0x2e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.597] Par 0x2f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.599] Par 0x300 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.599] Par 0x310 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.601] Par 0x320 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.601] Par 0x330 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.603] Par 0x340 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.603] Par 0x350 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.605] Par 0x360 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.605] Par 0x370 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.607] Par 0x380 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.607] Par 0x390 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.609] Par 0x3a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.609] Par 0x3b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.610] Par 0x3c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.611] Par 0x3d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.612] Par 0x3e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.612] Par 0x3f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [1975.612] # Trigger Layers: [1975.614] Trg 0x000 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x00 0x00 0x00 0x00 0x00 0x00 [1975.614] Trg 0x010 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.616] Trg 0x020 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.616] Trg 0x030 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.618] Trg 0x040 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.618] Trg 0x050 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.620] Trg 0x060 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.620] Trg 0x070 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.621] Trg 0x080 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.621] Trg 0x090 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.623] Trg 0x0a0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.623] Trg 0x0b0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.625] Trg 0x0c0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.625] Trg 0x0d0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.627] Trg 0x0e0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.627] Trg 0x0f0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [1975.627] done. the notes are send over the same midi channel here is the content of this track [[2427.031] track 9 [2427.013] Track Parameters of G3T1 [2427.013] ======================== [2427.013] ParInstruments 1 [2427.013] ParLayers 4 [2427.013] ParSteps 256 [2427.013] TrgInstruments 1 [2427.013] TrgLayers 8 [2427.013] TrgSteps 256 [2427.013] EventMode 0 (Note ) [2427.013] # | | | | | | | | | | | | | | | | | [2427.013] Name ' ' [2427.013] TrackMode 1 (Normal) [2427.015] TrackModeFlags 3 (Unsorted: on, Hold: on, Restart: off, Force Scale: off, Sustain: off) [2427.015] MIDI_Port 0x00 (Def. ) [2427.015] MIDI_Channel 0 (#1) [2427.015] DirectionMode 0 (Forward) [2427.015] StepsForward 0 (1 Steps) [2427.015] StepsJumpBack 0 (0 Steps) [2427.015] StepsReplay 0 [2427.015] StepsRepeat 0 (0 times) [2427.015] StepsSkip 0 (0 Steps) [2427.016] StepsRepeatSkipInterval 3 (4 Steps) [2427.016] Clockdivider 15 (16/384 ppqn) [2427.016] Triplets 0 (no) [2427.016] SynchToMeasure 0 (no) [2427.016] Length 15 (16 Steps) [2427.016] Loop 0 (Step 1) [2427.017] TransposeSemitones 0 (+0) [2427.017] TransposeOctaves 0 (+0) [2427.017] MorphMode 0 (off) [2427.017] MorphDestinationRange 0 (1..16) [2427.019] HumanizeMode 0 (Note: off, Velocity: off, Length: off) [2427.019] HumanizeIntensity 0 [2427.019] GrooveStyle 0 [2427.019] GrooveIntensity 0 [2427.019] TriggerAsngGate 1 (A) [2427.019] TriggerAsngAccent 2 (B) [2427.020] TriggerAsngRoll 3 © [2427.020] TriggerAsngGlide 4 (D) [2427.020] TriggerAsgnSkip 5 (E) [2427.020] TriggerAsgnRandomGate 6 (F) [2427.020] TriggerAsgnRandomValue 7 (G) [2427.020] TriggerAsgnNoFx 8 (H) [2427.020] DrumParAsgnA 0 (None ) [2427.020] DrumParAsgnB 0 (None ) [2427.020] EchoRepeats 0 [2427.020] EchoDelay 7 ( 8 ) [2427.021] EchoVelocity 15 [2427.021] EchoFeedbackVelocity 15 (75 [2427.021] EchoFeedbackNote 24 (+0) [2427.021] EchoFeedbackGatelength 20 (100 [2427.021] EchoFeedbackTicks 20 (100 [2427.021] LFO_Waveform 0 ( off ) [2427.022] LFO_Amplitude 192 (64) [2427.022] LFO_Phase 0 (0 [2427.022] LFO_Interval 15 (16 Steps) [2427.022] LFO_Reset_Interval 15 (16 Steps) [2427.023] LFO_Flags 0 (Oneshot: off, Note: off, Velocity: off, Length: off, CC: off) [2427.023] LFO_ExtraCC 0 [2427.023] LFO_ExtraCC_Offset 64 [2427.023] LFO_ExtraCC_PPQN 6 (96 ppqn) [2427.023] NoteLimitLower 0 [2427.025] NoteLimitUpper 0 [2427.026] # Parameter Layer Assignments: [2427.026] ConstArrayA 0x01 0x03 0x04 0x09 0x01 0x01 0x01 0x01 0x01 0x01 0x01 0x01 0x01 0x01 0x01 0x01 [2427.026] # CC Assignments: [2427.027] ConstArrayB 0x01 0x10 0x11 0x12 0x13 0x14 0x15 0x16 0x17 0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x1e [2427.027] # Constant Array C: [2427.027] ConstArrayC 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.027] # Parameter Layers: [2427.028] Par 0x000 0x24 0x24 0x30 0x24 0x24 0x24 0x30 0x24 0x24 0x24 0x30 0x24 0x24 0x24 0x30 0x24 [2427.029] Par 0x010 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.030] Par 0x020 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.033] Par 0x030 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.033] Par 0x040 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.033] Par 0x050 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.034] Par 0x060 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.034] Par 0x070 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.036] Par 0x080 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.036] Par 0x090 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.038] Par 0x0a0 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.038] Par 0x0b0 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.039] Par 0x0c0 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.040] Par 0x0d0 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.041] Par 0x0e0 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.042] Par 0x0f0 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 [2427.043] Par 0x100 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.044] Par 0x110 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.045] Par 0x120 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.045] Par 0x130 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.047] Par 0x140 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.047] Par 0x150 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.050] Par 0x160 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.050] Par 0x170 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.052] Par 0x180 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.052] Par 0x190 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.052] Par 0x1a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.053] Par 0x1b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.054] Par 0x1c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.055] Par 0x1d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.057] Par 0x1e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.057] Par 0x1f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 [2427.059] Par 0x200 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.059] Par 0x210 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.061] Par 0x220 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.061] Par 0x230 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.062] Par 0x240 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.062] Par 0x250 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.064] Par 0x260 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.064] Par 0x270 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.065] Par 0x280 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.066] Par 0x290 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.067] Par 0x2a0 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.068] Par 0x2b0 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.070] Par 0x2c0 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.070] Par 0x2d0 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.072] Par 0x2e0 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.072] Par 0x2f0 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 [2427.074] Par 0x300 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.074] Par 0x310 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.075] Par 0x320 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.075] Par 0x330 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.076] Par 0x340 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.077] Par 0x350 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.079] Par 0x360 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.079] Par 0x370 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.081] Par 0x380 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.081] Par 0x390 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.083] Par 0x3a0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.083] Par 0x3b0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.084] Par 0x3c0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.085] Par 0x3d0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.085] Par 0x3e0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.086] Par 0x3f0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.086] # Trigger Layers: [2427.087] Trg 0x000 0x55 0x55 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 [2427.088] Trg 0x010 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 [2427.089] Trg 0x020 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.089] Trg 0x030 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.092] Trg 0x040 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.092] Trg 0x050 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.093] Trg 0x060 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.093] Trg 0x070 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.096] Trg 0x080 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.096] Trg 0x090 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.096] Trg 0x0a0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.097] Trg 0x0b0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.099] Trg 0x0c0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.099] Trg 0x0d0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.101] Trg 0x0e0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.101] Trg 0x0f0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [2427.101] done. i hope it does meen something for you
dear Midiboxer, i finished my SEQ V4 and it 's a amazing sequencer but i have a little problem when i try to sequence my Boss DR660 it seem that when i trig two sound together for example two BD in 1,5,9,13 there is a little bit of gap I believed that came of my dr660 but i tested with Nuendo and no gap Then i tried to sequencer my MB6582 and some strange think happend I build this somple sequence C1-C2-C1-C2-C1-C2-C1-C2- and the second C2 note doesn't play correctly, just like i had a portamento i think that the Midi out signal is too small and there is a bad intepretation about the both machine I bought the Core32 on the SmashTV web'shop and there is only carbon resistor on the kit Do you think if i change the both 220ohm resistor of the Midi out with 1% metal film resistor it will resolve this problem? or any other idea to solve the problem will be fun thank you for your help
As tu verifé la connection de ton lcd ? Si tu as le datasheet de ton LCD je veux bien regardé le cablage de ce dernier ( ou donne moi la ref je trouverai me datasheet) Je pense que ton problème vient de la
Thank you very much TK i try it immediatly
Yeahh!!! This is what i miss it work perfectly now thank you very much
Sorry to ask the question but i think there is a mistake on the Beta 18 release I think the record parameter is faulty I couldn't record any Note or CC but i saw on the MIDI monitor that event is present on the MIDI IN. Maybe it's a mistake or i miss something to do but i don't know what. I go to the record Page and i send MIDI event on the Midi IN1 and nothing happend Anybody could help me please thank you
It will be very simple I was trying to copy the Midifile how's playing to paste in the desired track. Or when i import the midifile it's put directly in a new pattern For example if my midifile contain: -CH1 bass -CH2 Lead -CH3 melody or chord... it will be copy in the track group 1 , track 1,2 and 3 or one by one i import CH1 and copy it on the desired Track I have a other problem with the SEQ V4 when i try to put the length in Glide (more than 100%) i still hear the both note for example First step C1 and second step C1 too, i put the length of the first step over 100% to ahve glide effect but i still hear two note Is there a parameter that i missed ? i found this problem this is the Filter ENV of the sid now is ok with glide
Dear TK I finished my SEQ V4 so awsome machine but one thing is missing for me i would like to know when do you think to implent the MID Import option ? Because i need import all my Live set and there are more than 54 midifile Or maybe i could import them with MIOS studio but how? thank you
how much do you sell it? because i really like to buy it thank you
Very nice design !! i love it do you think it's possible do make other printed vinyl face because i really need one Good job
