693 -
Everything posted by /tilted/
Love it! I got a cheapish mono LCD with touchscreen years (freaking YEARS) ago to build into my LC. Nice to know it might actually work...
It's alive! (Obligatory Mad Scientist Riff)
/tilted/ commented on TheAncientOne's blog entry in TheAncientOne's Blog
I've also recently put my MB stuff back on the bench, after a major interstate move and a bit of modular analog tomfoolery. Great to hear you're up and running! -
[Q] how to apply negative voltage to lcd
/tilted/ replied to John E. Finster's topic in Parts Questions
Heya. I had an issue with contrast on a pair of 40x2 LCDs. It was the old issue of negative contrast voltage rearing its head again. I solved it using this schem: http://www.stephenhobley.com/blog/2011/03/28/creating-a-negative-voltage-from-a-positive-one/ I tried it using 3.3v from the J5 port, no dice. Likely because I'm using an NE555 timer, would probably work with the CMOS version. Anyway, it solved the issue I was having. Good luck! /t/ -
Sorry to get all deep-and-meaningful here, and don't get me wrong, I have no immediate plans to expire, but: What should happen to my MIDIboxes when I die? Is it OK for my wife/family to sell them? Or should they only be sold on the forum, or given away? Again, not that I plan to... just something that is on my morbid mind occasionally. /t/
An expandable OSC based networkable MIDI Router
/tilted/ replied to /tilted/'s topic in Design Concepts
Basically my goal is to be able to just drop in there and noodle around, without necessarily needing to plug in the computer to get routing going. It's always sort of felt like a bit of a distraction having to do all that, but then I suppose once it is done, it's easy enough to hit record if I'm happy with the noodling... I also thought it might be an interesting way of viewing a MIDI setup, and could have potential for interesting live collaborations. -
I've been thinking in the back of my mind somewhere about a networkable MIDI router, probably using OSC. I have several racks of commercial synths, am (very slowly) putting together other racks of DIY MIDI and analogue synths. I am imagining a networkable MIDI router system where each rack could have its own router, and the racks themselves connected via ethernet. Such a system would probably need a hub/switch somewhere too, and ideally it should be able to work with or without a computer (especially since there will be a MBSEQ anyway... Perhaps a computer could be used early on, to expedite the setup process, and of course would still be able to individually address synths within their respective racks. I think I might be way over my head... Does any part of this make sense, and in fact is there already such a device on the market, that I could save many hours and dollars by simply purchasing...?
LOG taper faders turned into pseudo-LIN taper?????
/tilted/ replied to mikee's topic in Tips & Tricks
I don't think I need any more neutrons. At last count, I had the correct number. ...whatever that is. -
badges ref: (at 0:50)
I'm not really they guy to talk to about the programming, but for updating ledrings individually you'll need to do a fair portion of bit masking. Pretty sure this is doable in C. I hate to be a bore, but the easiest way to do this is definitely to use 5 SRs. Any big reason why you can't do it this way?
OK, I think I see where you're heading now. you want to make a 16x16 matrix, thus making 4 sub-matrices of 8 8-LED ledrings. This should be workable. The coding will be interesting.
You should be able to do 8 LED ledrings, and this would mean you could do more ledrings. But: You'd need 5 SRs to do this, (1 for anodes, 4 for cathodes, or vice versa), so this means you couldn't really do it all on one DOUTx4, if that was the question. I'm not sure about whether you'd need to change source, you would probably be OK to change SR settings in main.asm . You'd probably need to increase the refresh rate, as 32 of any size ledrings on the same SR line would likely have a noticable flicker. In terms of current, you should be OK... depending on whether you're using a dot indicator (lowest current), or a line, negative line, width, etc. Have fun.
I'm enlisted! What a hilarious site! The SMT chip looks to be a J-lead with a fairly generous lead spacing. It should be a doddle to put together.
Nice going, TK! :) Is there a function to quickly un-mute all partial mutes? Perhaps a combination shift-mute-track# or similar?
Layer mutes / mute groups would be very nice. Some DAW platforms allow tracks to be grouped in folders. This could be a way to ease display congestion. ie, in one display mode, you might see the folders (drums, bass, leads, samples) etc. if you select a group or folder, you can access the contents, so by selecting (drums), you essentially 'zoom in' to see Kick, Snare, Hats, This dosen't mean adding tracks, but instead adds a mute layer which would allow sections of the key range (or even individual keys) to be muted, hence you could mute the kick part, or mute a sub-octave bass part, or lead harmony part. Perhaps the mute could also allow a quick and dirty transpose, so for that layer you could mute, or play the kick part temporarily as a tom, or combined kick/cymbal. Or the bass suboctave could become a diatonic harmony part...
Still working on it. Getting very close though. Want to wait til it's finished before I unveil...
Dang! Been and gone. I've got to pay more attention. Hi Foona!! Welcome back!
