rosch
Programmer
    705
Everything posted by rosch
  1. thanks for sharing the code, julien! i think it will take me some time till i understand how those things work...
  2. hi. sorry i have just several C64 psu connectors desoldered from old computers. i thought they're the same but i just looked & they turned out to have 7 pins. i don't know about the C128 supply but maybe they would work too (??). if someone need some of those, i have 5... but not for sale (edit: means, for free)
  3. yay!! today they showed up! thank you very much, very good packing! :D
  4. rosch
    4-Fach Merger?
    hallo! hast du dir den midi router mal angeschaut? der hat ja zumindest mal mehrere eingänge. http://www.ucapps.de/midi_router.html edit: link
  5. that was because i could not log in on ultra's bulk order Wiki for ultracore with my old name (schmöker), but you changed it for me, so everything's fine now. but good to know about the avatar picture, i always thought i'm just too stupid to do it... edit: attached new avatar
  6. same here. there's no choice like in your picture. i also was not able to change my name in january.
  7. that's how i do it too. uploading from pc didn't work.
  8. thanks! i see it now too, actually easy to find out myself. i can also compare the pdfs.
  9. hi! does anybody know where i could find an old CORE_V2 orderlist? the documentation page on uCapps doesn't contain it.
  10. thanks for the info on R12! i'm soldering my FM core atm :D
  11. no reason for hurry, at least in my case. turuloid: perhaps there'll be the need to split PayPal transfer into two payments then, too. at least here in germany they always want to see the transfer printout (or similar).
  12. hi! ok, i'm back at home again now, so i could inspect the keyboard more closely. result: it has the bars (sammelschienen), they're just on the inside... the older guy had them at the front. but the good thing is they're easily accessible by opening just 3 screws. so i took a few photos. well they're quite nasty, i haven't cleaned it yet :-[ i hope now to be able to build me at least a kbd without velocity. maybe i could make use of the multitude of bars in some way... organ1.JPG organ2.JPG
  13. great, they arrived today! thank you!!! :)
  14. ok i didn't expect that we would try to knock some extra bucks out of Smash. but generally trying to share shipping cost is not that bad idea. but who needs only A CORE from Smash?? means, i'll add the STM32 core to a future order, when i actually need it.
  15. atari teenage riot
  16. cool, dass du dir die arbeit machst, die panasonic encoder einzubinden!
  17. congratulations, cool idea to use a transparent panel! makes me drool (& hope that mine will look even half as good, some day...) nice display btw
  18. oh no problem, i'm very interested in such a lcd myself!
  19. 1x PCB 1x KIT thanks!
  20. dark matter
  21. fussylizard 2 strophlex 3 nsunier ~10 rosch 4 ssp 2 (maybe 4) gtxdude 2 matoz 4 lucem 6 enth 3 flemming 1 kyo 2 wilba 6 (possible per discussion w/ fussylizard) dstamand 1 olga42 5 latigid on 2 ---------------------- ~53
  22. hi! did i get that right? can you mix the colors in your order?
  23. hi! the 6582 parts kit (incl pcb) is basically 4 core modules, 8 sid modules, dins & douts and bank sticks all on one big PCB. more info about the MB6582 you can find here and forum search on MB6582 brings a lot of info too!
  24. slumgud: which philicorda do you have? can you post a pic? because if it has just one manual and the keys all of wood you could have the old legendary one whose sound is not made with transistors but with light bulbs (gas tubes), eventually complete with tube amp & hall?? in that case it could be worth repairing + midifying the old organ! i have the old one too and it sounds great and i intend to midify that guy too, one day! lucem: interesting, but sounds quite expensive to me?? yes please show a pic!
  25. are there any special switches for scan matrices (close/close double contacts) which e.g. provide exactly the same distance between the contacts or is it recommended to use pairs of the well known tactile switches, mounted on breadboard?
