TD
    36
Everything posted by TD
  1. i dig it! that box looks nice mate.. i esp dig the finish on the faceplate and the big buttons. ;D
  2. TD
    my sid
    Lego SID is DOPE!!!! i love it! ;D
  3. that definitely looks more complete than my way... im going to have a go at that. does r19 have the super cool new drum engine as described by TK?
  4. by changing to another patch.. i only have the play button mod on bass & drum engine.. probably a lazy way to do it, but it seems to work out for me. ;)
  5. NICE ONE MATE!!!! the box looks beautiful and the track is dope!!! ;D
  6. are those decals lasertran?
  7. my first go at a mod in MB SID.. i wanted to be able to start a seq in the bass or drum engine without having to trigger a note on.. after following this topic. http://www.midibox.org/forum/index.php/topic,11188.0.html i had a go at this. cs_menu_tables.inc ; -------------------------------------------------------------------------- CS_MENU_TABLES_B ;; pointer to table par. button pressed exec button pressed page name var max print function CS_MENU_T_ENTRY CS_MENU_TABLE_B_ROOT, CS_MENU_Page_Root, CS_MENU_BUTTON_Play, "---", SID_PATCH, 0x7f, PRINT_PAT ; (special handling in CS_MENU_PageUpDown selected with SID_PATCH) and: ; -------------------------------------------------------------------------- CS_MENU_TABLES_D ;; pointer to table par. button pressed exec button pressed page name var max print function CS_MENU_T_ENTRY CS_MENU_TABLE_D_ROOT, CS_MENU_Page_Root, CS_MENU_BUTTON_Play, "---", SID_PATCH, 0x7f, PRINT_PAT ; (special handling in CS_MENU_PageUpDown selected with SID_PATCH) it works out quite nice.. in a bassline or drum patch, once in the menu root, menu button will toggle start /stop sequence 8) cool to be able to just hold the little box and trigger / tweak patterns.. [[sUPER FUN!!!]] ;D switching to a lead patch gets your main menu back.. now i just need to replace my wobbbbly encoder switch! ..just thought id share that.
  8. Yaaaaaaay!!!!! ;D
  9. ive been watching this thread.. im gonna try this same thing but with 'play' on the menu button as opposed to 'shift' ..ill let you know how it goes.
  10. the .inc files are inside the 'src' folder located inside the app folder.. on mac you can just edit them with textedit.. and regarding xcode2 on OSX as suggested by buhler, you a will also need to go get gputils from sourceforge and load gpasm.. ( i hope this doen't seem overwhelming..) then i had to copy the gputils myself to /usr/bin/ before make would see the gpasm lib. cd to the folder containing source files in terminal.. type: sudo ./configure , make , make install run each command in turn.. ..hope that helps.
  11. yeah.. it does sound noisy.. also very low vol since you had to boost it.. but it does seem to trigger a sound from your keyboard, so it must be getting MIDI.. you got me why it sounds messed up though.. did it sound nice and clear yesterday? these things seem fairly sturdy as far as being able to kill one, so its prob just something silly.. id check my connections and maybe try to send the app again.. other than that, its over my rookie head.. ??? maybe step back for a bit and brew on it mate.. 8)
  12. nice one Nils!.. im diggin that break in "nILS_-_%2313.mp3" ok, so im late to this party.. i just noticed this thread.
  13. INFAMOUS.. BUTCHER!!! ANGEL OF DEAAAAAATH!!!!!! :o haa i loove it!!!
  14. when you turn her on, do you hear that little beep tone it makes as it boots up? that may tell you if its something with the hardware or not.. rather i should say, if the problem is with the audio or with recieving midi.. or maybe try the MBSID test tone app.. ? :-\
  15. i have the same type of PLED 'OLED' and wired it in 4bit mode per this diagram.. also omit the backlight connections for that type of display. it is very happy. ;D http://ucapps.de/mbhp/mbhp_lcd_4bit.pdf
  16. I love brit slang!!! and i agree.. saving old hardware IS a bit naff.. i mean.. is anyone going to actually RUN a SX64.. 'cmon.. ( im in IT, so i dont usually get sentimental about old computers ) but maybe you get the SX64 from craigslist for free.. SELL it on ebay ( or the fleamaket ) to someone who wants it.. and buy more SIDS from wilba!!! :D but they dont really go for more than about $80 on ebay from what i can see..
  17. that case has to be one of the nicest ive seen yet.. ace!!!
  18. hey wilba.. if there are any unclaimed SID's after april 3, is it possible to buy up any of those? thanks.
  19. nice one mate! ;D
  20. im lovin' that 'chopper' C64 case!!!
  21. that is immensely cool.. where do those nice buttons come from mate?
  22. yes, that case was an A/B switch in it's past life.. :) ..and i have a second case just like it, so eventually there will be a pair. i tried to recycle as many components as i was i was able, several old hd cases died for the cause, and the nice stainless hex bolts come from dead iBooks, other hardware from dead Dell laptops.
  23. i finished the build last night after redoing the down/up/shift buttons so i could cram all these parts including the DIN4x module. ;) spent all day playing around with Greenie!!! this thing sounds so phat and mean! of note: i had one of those LaCie type power supplies around. yeah, they're a wee bit noisy, also makes noise when its turned OFF (actually way more than when it is powered on)!!! wtf!? maybe i go for the optimised PSU.. oh yeah and my encoder is a bit wonkey.. skips sometimes. those two items withstanding im quite pleased with my first effort and im STOKED to rock out on my new friend!!!! Yeeeeah!!!!! ..working out the rest of the gremlinz.. ;) big up everyone in this community.. MBHP rules!!! esp.. smash for the wicked kits and of course TK. all you guys have this project dialed in!
  24. well, i was able to cram it all in there so i didnt cut it.. :o
  25. Im in the home stretch.. this weekend it felt like orange county choppers as i fabricated my case! also wired up the LCD, soldered din4x module, and soldered buttons to vero, all i need to do now is wire up the buttons and encoder to DIN and im there! ..and a few cosmectic details. ::) question: on a Smash TV DIN4x module, is it kosher to cut it in half, if one is only stuffing half the registers? ( it seems like it wouldnt be a prob, but other side of course, would be no good. ) id like to save the space as it is getting rather cramped inside my case.. if not, ill just have to cram it all in there!! haha. ;) oh yeah, and im calling it.. "Greenie"
